- To:
- Subject: Re: [cgal-discuss]Aff_transformation_3 Plane_3::transform_to_2d() const;
- Date: Wed, 16 Jan 2008 11:33:22 +0800
Max wrote:
> Hello all,
> I've found a method of Plane_3
> Aff_transformation_3 transform_to_2d() const;
> but I cannot find any explanation of it in the doc.
> Could anybody please tell me the meaning of it?
It seems to be an internal function used by Plane_3::to_2d() and
Plane_3::to_3d(). Deriving from the documentation for to_2d(), I would say
this function "returns the affine transformation which maps the plane_3
onto the xy-plane, with the z-coordinate removed."
HTH,
~ash
- [cgal-discuss][Nef_polyhedron] How to convert a Nef_polyhedron_3 into a Nef_polyhedron_2 if meaningful, LoadCom, 01/07/2008
- Re: [cgal-discuss][Nef_polyhedron] How to convert a Nef_polyhedron_3 into a Nef_polyhedron_2 if meaningful, Peter Hachenberger, 01/08/2008
- Re: Re: [cgal-discuss][Nef_polyhedron] How to convert aNef_polyhedron_3 into a Nef_polyhedron_2 if meaningful, LoadCom, 01/09/2008
- Re: Re: [cgal-discuss][Nef_polyhedron] How to convert aNef_polyhedron_3 into a Nef_polyhedron_2 if meaningful, Peter Hachenberger, 01/10/2008
- Re: [cgal-discuss][Nef_polyhedron] How to convertaNef_polyhedron_3 into a Nef_polyhedron_2 if meaningful, Max, 01/11/2008
- [cgal-discuss]Aff_transformation_3 Plane_3::transform_to_2d() const;, Max, 01/12/2008
- Re: [cgal-discuss]Aff_transformation_3 Plane_3::transform_to_2d() const;, Ashwin Nanjappa, 01/16/2008
- Crash on converting Polyhedron_3 to Nef_polyhedron_3 on an OFF input., Stephen Wong, 01/13/2008
- Re: [cgal-discuss] Crash on converting Polyhedron_3 to Nef_polyhedron_3 on an OFFinput., Max, 01/13/2008
- Re: [cgal-discuss] Crash on converting Polyhedron_3 to Nef_polyhedron_3 on an OFF input., Gilbert Bernstein, 01/13/2008
- RE: [cgal-discuss] Crash on converting Polyhedron_3 to Nef_polyhedron_3 on an OFF input., Stephen Wong, 01/13/2008
- Re: [cgal-discuss] Crash on converting Polyhedron_3 to Nef_polyhedron_3 on an OFF input., Gilbert Bernstein, 01/14/2008
- RE: [cgal-discuss] Crash on converting Polyhedron_3 to Nef_polyhedron_3 on an OFF input., Stephen Wong, 01/14/2008
- Re: [cgal-discuss] Crash on converting Polyhedron_3 to Nef_polyhedron_3 on an OFF input., Peter Hachenberger, 01/14/2008
