- To: "" <>
- Subject: Crash on converting Polyhedron_3 to Nef_polyhedron_3 on an OFF input.
- Date: Sat, 12 Jan 2008 17:47:08 -0800
- Accept-language: en-US, en-CA
- Acceptlanguage: en-US, en-CA
Hi there,
On this seemingly innocent input solid in the form of a OFF file, CGAL's
Nef_polyhedron_3 constructor using Polyhedron_3 crashes. I believe that the
solid represented by the OFF file is valid based on the specification (you
can see the model in geomview or any other OFF viewer). I caused this crash
by modifying the Nef_3.sln's interface_polyhedron:
Polyhedron P ;
std::ifstream fin( "Triangle - Copy.off" ) ;
fin >> P ;
if ( P.is_closed() && P.is_valid() )
Nef_polyhedron_3 N1( poly ) ;
Thanks,
Stephen
Triangle - Copy.off
Description: Triangle - Copy.off
- [cgal-discuss][Nef_polyhedron] How to convert a Nef_polyhedron_3 into a Nef_polyhedron_2 if meaningful, LoadCom, 01/07/2008
- Re: [cgal-discuss][Nef_polyhedron] How to convert a Nef_polyhedron_3 into a Nef_polyhedron_2 if meaningful, Peter Hachenberger, 01/08/2008
- Re: Re: [cgal-discuss][Nef_polyhedron] How to convert aNef_polyhedron_3 into a Nef_polyhedron_2 if meaningful, LoadCom, 01/09/2008
- Re: Re: [cgal-discuss][Nef_polyhedron] How to convert aNef_polyhedron_3 into a Nef_polyhedron_2 if meaningful, Peter Hachenberger, 01/10/2008
- Re: [cgal-discuss][Nef_polyhedron] How to convertaNef_polyhedron_3 into a Nef_polyhedron_2 if meaningful, Max, 01/11/2008
- [cgal-discuss]Aff_transformation_3 Plane_3::transform_to_2d() const;, Max, 01/12/2008
- Re: [cgal-discuss]Aff_transformation_3 Plane_3::transform_to_2d() const;, Ashwin Nanjappa, 01/16/2008
- Crash on converting Polyhedron_3 to Nef_polyhedron_3 on an OFF input., Stephen Wong, 01/13/2008
- Re: [cgal-discuss] Crash on converting Polyhedron_3 to Nef_polyhedron_3 on an OFFinput., Max, 01/13/2008
- Re: [cgal-discuss] Crash on converting Polyhedron_3 to Nef_polyhedron_3 on an OFF input., Gilbert Bernstein, 01/13/2008
- RE: [cgal-discuss] Crash on converting Polyhedron_3 to Nef_polyhedron_3 on an OFF input., Stephen Wong, 01/13/2008
- Re: [cgal-discuss] Crash on converting Polyhedron_3 to Nef_polyhedron_3 on an OFF input., Gilbert Bernstein, 01/14/2008
- RE: [cgal-discuss] Crash on converting Polyhedron_3 to Nef_polyhedron_3 on an OFF input., Stephen Wong, 01/14/2008
- Re: [cgal-discuss] Crash on converting Polyhedron_3 to Nef_polyhedron_3 on an OFF input., Peter Hachenberger, 01/14/2008
