cgal-discuss - Re: [cgal-discuss] Crash on converting Polyhedron_3 to Nef_polyhedron_3 on an OFFinput.
  • To: "" <>
  • Subject: Re: [cgal-discuss] Crash on converting Polyhedron_3 to Nef_polyhedron_3 on an OFFinput.
  • Date: Sun, 13 Jan 2008 10:30:13 +0800
  • Disposition-notification-to: "Max" <>
  • Organization: LoadCom
Hello,
I once had similar experience. I was attempting to read an OFF file
containing a valid polyhedron from std::ifstream, but failed.
The strange aspect of this problem is that it worked when I
input the data with std::cin and command prompt redirection
as 'interface_polyhedron.exe < my_polyhedron.off'.
B/Rgds
Max
----- Original Message ----
To:
Sent: 2008-01-13 09:47:55
Subject: [cgal-discuss] Crash on converting Polyhedron_3 to Nef_polyhedron_3
on an OFFinput.
Hi there,
On this seemingly innocent input solid in the form of a OFF file, CGAL's
Nef_polyhedron_3 constructor using Polyhedron_3 crashes. I believe that the
solid represented by the OFF file is valid based on the specification (you
can see the model in geomview or any other OFF viewer). I caused this crash
by modifying the Nef_3.sln's interface_polyhedron:
Polyhedron P ;
std::ifstream fin( "Triangle - Copy.off" ) ;
fin >> P ;
if ( P.is_closed() && P.is_valid() )
Nef_polyhedron_3 N1( poly ) ;
Thanks,
Stephen
