- To: "" <>
- Subject: Re: Re: [cgal-discuss][Nef_polyhedron]convert_to_Polyhedron (Polyhedron& P)
- Date: Fri, 18 Jan 2008 09:41:05 +0800
- Disposition-notification-to: "Max" <>
- Organization: LoadCom
Hello Peter,
Thank you very much for you prompt and detailed reply!
I'll test your code addition and post the result asap.
B/Rgds
Max
>Hi Max,
>I got this question frequently off late. For this reason I implemented a
>new function. Add the attached file shell_to_nef_3.h to your
>include/CGAL/Nef_3 directory and add the following code to
>Nef_polyhedron_3.h:
>Nef_polyhedron_3(const Nef_polyhedron& N,
> SFace_const_iterator sf)
> SNC_structure rsnc;
> *this = Nef_polyhedron_3(rsnc, new SNC_point_locator_default, false);
> initialize_infibox_vertices(EMPTY);
> shell_to_nef_3(N, sf, snc());
> build_external_structure();
> simplify();
> CGAL::Mark_bounded_volumes<Nef_polyhedron_3> mbv(true);
> delegate(mbv);
> set_snc(snc());
>There is another file attached, which demonstrates the usage. This
>program compares two methods of conversion, an old and simple one with
>the new one. If you don't use CGAL 3.3.1, you won't have the code for
>the old implementation and need to comment/ignore the first part of the
>program. I originally wrote the code to work for closed inner shells,
>but maybe it also works non-closed shells and outer shells. Please tell
>me how it works.
>Peter
>On Thu, 2008-01-17 at 19:18 +0800, Max wrote:
>> Hi all,
>> I know if a Nef_polyhedron is simple (or, in other words,
>> a manifold), it could be converted to a single polyhedron
>> with the method:
>> Nef_polyhedron::convert_to_Polyhedron ( Polyhedron& P)
>> My question is, if N is not a single manifold, but still finite,
>> is there a way in CGAL to convert it into a group of polyhedra?
>> Thanks for any help.
>> B/Rgds
>> Max
>You are currently subscribed to cgal-discuss.
>To unsubscribe or access the archives, go to
>https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] Coordinate Transformation, Max, 01/17/2008
- Re: [cgal-discuss] Coordinate Transformation, Max, 01/17/2008
- [cgal-discuss][Nef_polehedron]convert_to_Polyhedron ( Polyhedron& P), Max, 01/17/2008
- Re: [cgal-discuss][Nef_polehedron]convert_to_Polyhedron ( Polyhedron& P), Peter Hachenberger, 01/17/2008
- Re: Re: [cgal-discuss][Nef_polyhedron]convert_to_Polyhedron (Polyhedron& P), Max, 01/18/2008
- Re: Re: Re: [cgal-discuss][Nef_polyhedron]convert_to_Polyhedron (Polyhedron& P), Max, 01/18/2008
- Re: Re: Re: [cgal-discuss][Nef_polyhedron]convert_to_Polyhedron (Polyhedron& P), Peter Hachenberger, 01/18/2008
- [cgal-discuss] Order of including CGAL header files, Max, 01/18/2008
