- To: "" <>
- Subject: [cgal-discuss] Order of including CGAL header files
- Date: Fri, 18 Jan 2008 09:59:18 +0800
- Disposition-notification-to: "Max" <>
- Organization: LoadCom
hello,
I just found a copy of CGAL_Tutorial.pdf and finished reading it.
It's a good starting point for CGAL beginners.
I found as this paper stated, the order of inclusion of CGAL header
files, if using catesian.h or homogeneous.h, is striclty required:
If you need any of these 2 files with other headers, they should be
placed before any other CGAL headers.
Is this rule still valid?
Thanks.
B/Rgds
Max
- [cgal-discuss] Coordinate Transformation, Max, 01/17/2008
- Re: [cgal-discuss] Coordinate Transformation, Max, 01/17/2008
- [cgal-discuss][Nef_polehedron]convert_to_Polyhedron ( Polyhedron& P), Max, 01/17/2008
- Re: [cgal-discuss][Nef_polehedron]convert_to_Polyhedron ( Polyhedron& P), Peter Hachenberger, 01/17/2008
- Re: Re: [cgal-discuss][Nef_polyhedron]convert_to_Polyhedron (Polyhedron& P), Max, 01/18/2008
- Re: Re: Re: [cgal-discuss][Nef_polyhedron]convert_to_Polyhedron (Polyhedron& P), Max, 01/18/2008
- Re: Re: Re: [cgal-discuss][Nef_polyhedron]convert_to_Polyhedron (Polyhedron& P), Peter Hachenberger, 01/18/2008
- [cgal-discuss] Order of including CGAL header files, Max, 01/18/2008
