cgal-discuss - Re: Re: Re: [cgal-discuss][Nef_polyhedron]convert_to_Polyhedron (Polyhedron& P)
  • To:
  • Subject: Re: Re: Re: [cgal-discuss][Nef_polyhedron]convert_to_Polyhedron (Polyhedron& P)
  • Date: Fri, 18 Jan 2008 12:15:26 +0100
Hi Max,
the problems have nothing to do with the new functionality but with
the kernel. If you modify for off-file with floating-point coordinates
as input, you must use the Exact_predicates_exact_constructions_kernel.
About your other question. To find out how to get all the shells, you
should study the incidence structure. Look at:
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Nef_3/Chapter_main.html#Subsection_18.7.2
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Nef_3_ref/Class_Nef_polyhedron_3-Traits---Volume.html
Peter
On Fri, 2008-01-18 at 10:44 +0800, Max wrote:
> Hello Peter,
> I've tested with three OFF models as attached.
> The output are as follows:
> 1. robocat_deci.off
> I got only a bunch of "Error !!!!!!!!!!!!!!!!!!!!!!!" then
> the program terminated abnormally.
> 2. torus_tri.off
> The program terminated abnormally without saying anything.
> 3. Simple.off
> The program said:
> old impl 0.07
> new impl 0.06
> and then ends normally.
> My platform:
> CGAL 3.3.1
> Windows XP/SP2
> VS2005 without SP1
> Build under release mode.
> One more question: If the code runs correctly, how can I get
> the group of single closed polyhedrona I needed?
> p.s., I've slightly modified the program to get a model in OFF format.
> it's also attached. perhaps some problem comes from the conversion
> from a polyhedron to a nef_3.
> B/Rgds
> Max
> >Hello Peter,
> >Thank you very much for you prompt and detailed reply!
> >I'll test your code addition and post the result asap.
> >B/Rgds
> >Max
> >>Hi Max,
> >>I got this question frequently off late. For this reason I implemented a
> >>new function. Add the attached file shell_to_nef_3.h to your
> >>include/CGAL/Nef_3 directory and add the following code to
> >>Nef_polyhedron_3.h:
> >>Nef_polyhedron_3(const Nef_polyhedron& N,
> >> SFace_const_iterator sf)
> >> SNC_structure rsnc;
> >> *this = Nef_polyhedron_3(rsnc, new SNC_point_locator_default, false);
> >> initialize_infibox_vertices(EMPTY);
> >> shell_to_nef_3(N, sf, snc());
> >> build_external_structure();
> >> simplify();
> >> CGAL::Mark_bounded_volumes<Nef_polyhedron_3> mbv(true);
> >> delegate(mbv);
> >> set_snc(snc());
> >>There is another file attached, which demonstrates the usage. This
> >>program compares two methods of conversion, an old and simple one with
> >>the new one. If you don't use CGAL 3.3.1, you won't have the code for
> >>the old implementation and need to comment/ignore the first part of the
> >>program. I originally wrote the code to work for closed inner shells,
> >>but maybe it also works non-closed shells and outer shells. Please tell
> >>me how it works.
> >>Peter
> >>On Thu, 2008-01-17 at 19:18 +0800, Max wrote:
> >>> Hi all,
> >>> I know if a Nef_polyhedron is simple (or, in other words,
> >>> a manifold), it could be converted to a single polyhedron
> >>> with the method:
> >>> Nef_polyhedron::convert_to_Polyhedron ( Polyhedron& P)
> >>> My question is, if N is not a single manifold, but still finite,
> >>> is there a way in CGAL to convert it into a group of polyhedra?
> >>> Thanks for any help.
> >>> B/Rgds
> >>> Max
> >>You are currently subscribed to cgal-discuss.
> >>To unsubscribe or access the archives, go to
> >>https://lists-sop.inria.fr/wws/info/cgal-discuss
