cgal-discuss - Re: Re: Re: [cgal-discuss][Nef_polyhedron]convert_to_Polyhedron (Polyhedron& P)
  • To: "" <>
  • Subject: Re: Re: Re: [cgal-discuss][Nef_polyhedron]convert_to_Polyhedron (Polyhedron& P)
  • Date: Fri, 18 Jan 2008 10:44:12 +0800
  • Disposition-notification-to: "Max" <>
  • Organization: LoadCom
Hello Peter,
I've tested with three OFF models as attached.
The output are as follows:
1. robocat_deci.off
I got only a bunch of "Error !!!!!!!!!!!!!!!!!!!!!!!" then
the program terminated abnormally.
2. torus_tri.off
The program terminated abnormally without saying anything.
3. Simple.off
The program said:
old impl 0.07
new impl 0.06
and then ends normally.
My platform:
CGAL 3.3.1
Windows XP/SP2
VS2005 without SP1
Build under release mode.
One more question: If the code runs correctly, how can I get
the group of single closed polyhedrona I needed?
p.s., I've slightly modified the program to get a model in OFF format.
it's also attached. perhaps some problem comes from the conversion
from a polyhedron to a nef_3.
B/Rgds
Max
>Hello Peter,
>Thank you very much for you prompt and detailed reply!
>I'll test your code addition and post the result asap.
>B/Rgds
>Max
>>Hi Max,
>>I got this question frequently off late. For this reason I implemented a
>>new function. Add the attached file shell_to_nef_3.h to your
>>include/CGAL/Nef_3 directory and add the following code to
>>Nef_polyhedron_3.h:
>>Nef_polyhedron_3(const Nef_polyhedron& N,
>> SFace_const_iterator sf)
>> SNC_structure rsnc;
>> *this = Nef_polyhedron_3(rsnc, new SNC_point_locator_default, false);
>> initialize_infibox_vertices(EMPTY);
>> shell_to_nef_3(N, sf, snc());
>> build_external_structure();
>> simplify();
>> CGAL::Mark_bounded_volumes<Nef_polyhedron_3> mbv(true);
>> delegate(mbv);
>> set_snc(snc());
>>There is another file attached, which demonstrates the usage. This
>>program compares two methods of conversion, an old and simple one with
>>the new one. If you don't use CGAL 3.3.1, you won't have the code for
>>the old implementation and need to comment/ignore the first part of the
>>program. I originally wrote the code to work for closed inner shells,
>>but maybe it also works non-closed shells and outer shells. Please tell
>>me how it works.
>>Peter
>>On Thu, 2008-01-17 at 19:18 +0800, Max wrote:
>>> Hi all,
>>> I know if a Nef_polyhedron is simple (or, in other words,
>>> a manifold), it could be converted to a single polyhedron
>>> with the method:
>>> Nef_polyhedron::convert_to_Polyhedron ( Polyhedron& P)
>>> My question is, if N is not a single manifold, but still finite,
>>> is there a way in CGAL to convert it into a group of polyhedra?
>>> Thanks for any help.
>>> B/Rgds
>>> Max
>>You are currently subscribed to cgal-discuss.
>>To unsubscribe or access the archives, go to
>>https://lists-sop.inria.fr/wws/info/cgal-discuss
Attachment: torus_tri.off
Description: Binary data
Attachment: simple.off
Attachment: robocat_deci.off
Attachment: convert_shell_to_nef3.cpp
