Re: RE: Re: Re: [cgal-discuss][Nef_polyhedron]A morecomplexbutstillsimplequestion
- To: "" <>
- Subject: Re: RE: Re: Re: [cgal-discuss][Nef_polyhedron]A morecomplexbutstillsimplequestion
- Date: Thu, 7 Feb 2008 10:28:45 +0800
- Disposition-notification-to: "Max" <>
- Organization: LoadCom
Hello Stephen,
Thanks for your information.
I'll test with this kernel and checkout the related archive.
B/Rgds
Max
>Hi guys,
>Please find the conversation Peter and I have on the archives, the
>half-spaces question has been answered previously there! Peter, you have
>sent these to me!
>Max, I also use double coordinates with half-plane operations. I have used
>Cartesian<Gmpq> (exact constructions, exact predicates).
>Stephen
>-----Original Message-----
>From: Max
>[mailto:]
>Sent: February-06-08 5:10 AM
>To:
>Subject: Re: Re: Re: [cgal-discuss][Nef_polyhedron]A more
>>I might have asked you this before, but why do you need halfspaces? If
>>you only need halfspaces to perform intersections, then you don't need
>>the extended kernels. I wrote an intersection routine that intersects a
>>halfspace with a Nef polyhedron without constructing the halfspace
>>explicitly.
>where can I found the routine?
>Thanks
>B/Rgds
>Max
>>Peter
- Re: Re: Re: [cgal-discuss][Nef_polyhedron]A more complex but stillsimplequestion, (continued)
- Re: Re: Re: [cgal-discuss][Nef_polyhedron]A more complex but stillsimplequestion, Peter Hachenberger, 02/05/2008
- Re: Re: Re: [cgal-discuss][Nef_polyhedron]A more complex butstillsimplequestion, Max, 02/05/2008
- Re: Re: Re: [cgal-discuss][Nef_polyhedron]A more complex butstillsimplequestion, Max, 02/06/2008
- Re: Re: Re: [cgal-discuss][Nef_polyhedron]A more complex butstillsimplequestion, Peter Hachenberger, 02/06/2008
- Re: Re: Re: [cgal-discuss][Nef_polyhedron]A more complexbutstillsimplequestion, Max, 02/06/2008
- Re: Re: Re: [cgal-discuss][Nef_polyhedron]A more complexbutstillsimplequestion, Peter Hachenberger, 02/06/2008
- RE: Re: Re: [cgal-discuss][Nef_polyhedron]A more complexbutstillsimplequestion, Stephen Wong, 02/06/2008
- Re: RE: Re: Re: [cgal-discuss][Nef_polyhedron]A morecomplexbutstillsimplequestion, Max, 02/07/2008
- Re: Re: RE: Re: Re: [cgal-discuss][Nef_polyhedron]A morecomplexbutstillsimplequestion, Max, 02/07/2008
- Re: Re: Re: RE: Re: Re: [cgal-discuss][Nef_polyhedron]A morecomplexbutstillsimplequestion, Max, 02/07/2008
- Re: Re: Re: RE: Re: Re: [cgal-discuss][Nef_polyhedron]A morecomplexbutstillsimplequestion, Peter Hachenberger, 02/07/2008
- Re: [cgal-discuss][Nef_polyhedron]Amorecomplexbutstillsimplequestion, Max, 02/07/2008
- Re: [cgal-discuss][Nef_polyhedron]Amorecomplexbutstillsimplequestion, Peter Hachenberger, 02/07/2008
- Re: Re:[cgal-discuss][Nef_polyhedron]Amorecomplexbutstillsimplequestion, Max, 02/07/2008
- Re: [cgal-discuss][Nef_polyhedron] How to mannualy construct a (non-manifold) Nef_polyhedron?, Peter Hachenberger, 02/04/2008
