Re: Re: Re: RE: Re: Re: [cgal-discuss][Nef_polyhedron]A morecomplexbutstillsimplequestion
- To: "" <>
- Subject: Re: Re: Re: RE: Re: Re: [cgal-discuss][Nef_polyhedron]A morecomplexbutstillsimplequestion
- Date: Thu, 7 Feb 2008 15:56:16 +0800
- Disposition-notification-to: "Max" <>
- Organization: LoadCom
I've found the cause by debugging,
1) I found there's an implicit conversion from a Plane_3 to
a Nef_3 because there's no 'explicit' before:
Nef_polyhedron_3(const Plane_3& p, Boundary b = INCLUDED);
in Nef_polyhedron_3.h.
That means the undocumented function mentioned by Peter has actually
not been called.
No matter wheather it's the intention of the authors, I recommend an
'explicit' be added for this ctor to disable such implicit conversion.
2) after this modification,
a) I uncommented the contents related to intersection(const Plane_3&
plane);
b) I copied the file Combine_with_halfspace.h that Peter gave Stephen
to
Nef_3 folder.
and re-compile.
but I was told by the compiler that I still need file
CGAL/Nef_3/Binary_operation.h
(or even more).
I would appreciate if the authors of Nef_3 could give me the latest runnable
files
related to this issue, including the new version of Nef_polyhedron_3.h.
Thanks in advance.
Max
>>>Hello Stephen,
>>>Thanks for your information.
>>>I'll test with this kernel and checkout the related archive.
>>I've digged into the archive and found the answer Peter Gave you:
>>Just use the undocumented function:
>>N = N.intersection(Plane_3(a,b,c,d));
>>If I understand correctly, it's senmatically equivalent to
>>N = N * Nef_3(Plane_3(a,b,c,d), Nef_3::INCLUDED);
>>except the fact that with it it's not mandatory to use an extended kernel.
>I've tested with the following typedef's:
>typedef CGAL::Gmpq NT;
>typedef CGAL::Cartesian<NT> Kernel;
>typedef CGAL::Nef_polyhedron_3<Kernel, CGAL::SNC_indexed_items>
>Nef_polyhedron_3;
>But I was still given an "Constructor not available for this Kernel" warning
>when the N.intersection(Plane_3(a,b,c,d)) function was called.
>For the case that I use the default items type, instead of the indexed items
>type,
>in typedef'ing Nef_3, i.e.:
>typedef CGAL::Nef_polyhedron_3<Kernel> Nef_polyhedron_3;
>the result was identical.
>B/Rgds
>Max
>>>>Hi guys,
>>>>Please find the conversation Peter and I have on the archives, the
>>>>half-spaces question has been answered previously there! Peter, you have
>>>>sent these to me!
>>>>Max, I also use double coordinates with half-plane operations. I have
>>>>used Cartesian<Gmpq> (exact constructions, exact predicates).
>>One more question:
>>Do you use the indexed items type, i.e. SNC_indexed_items, or just the
>>default one?
>>Thanks
>>Max
>>>>Stephen
>>You are currently subscribed to cgal-discuss.
>>To unsubscribe or access the archives, go to
>>https://lists-sop.inria.fr/wws/info/cgal-discuss
- Re: Re: Re: [cgal-discuss][Nef_polyhedron]A more complex butstillsimplequestion, (continued)
- Re: Re: Re: [cgal-discuss][Nef_polyhedron]A more complex butstillsimplequestion, Max, 02/06/2008
- Re: Re: Re: [cgal-discuss][Nef_polyhedron]A more complex butstillsimplequestion, Peter Hachenberger, 02/06/2008
- Re: Re: Re: [cgal-discuss][Nef_polyhedron]A more complexbutstillsimplequestion, Max, 02/06/2008
- Re: Re: Re: [cgal-discuss][Nef_polyhedron]A more complexbutstillsimplequestion, Peter Hachenberger, 02/06/2008
- RE: Re: Re: [cgal-discuss][Nef_polyhedron]A more complexbutstillsimplequestion, Stephen Wong, 02/06/2008
- Re: RE: Re: Re: [cgal-discuss][Nef_polyhedron]A morecomplexbutstillsimplequestion, Max, 02/07/2008
- Re: Re: RE: Re: Re: [cgal-discuss][Nef_polyhedron]A morecomplexbutstillsimplequestion, Max, 02/07/2008
- Re: Re: Re: RE: Re: Re: [cgal-discuss][Nef_polyhedron]A morecomplexbutstillsimplequestion, Max, 02/07/2008
- Re: Re: Re: RE: Re: Re: [cgal-discuss][Nef_polyhedron]A morecomplexbutstillsimplequestion, Peter Hachenberger, 02/07/2008
- Re: [cgal-discuss][Nef_polyhedron]Amorecomplexbutstillsimplequestion, Max, 02/07/2008
- Re: [cgal-discuss][Nef_polyhedron]Amorecomplexbutstillsimplequestion, Peter Hachenberger, 02/07/2008
- Re: Re:[cgal-discuss][Nef_polyhedron]Amorecomplexbutstillsimplequestion, Max, 02/07/2008
- Re: [cgal-discuss][Nef_polyhedron] How to mannualy construct a (non-manifold) Nef_polyhedron?, Peter Hachenberger, 02/04/2008
- Re: [cgal-discuss][Nef_polyhedron] How to mannualy construct a(non-manifold) Nef_polyhedron?, Max, 02/11/2008
- Re: [cgal-discuss][Nef_polyhedron] How to mannualy construct a(non-manifold) Nef_polyhedron?, Peter Hachenberger, 02/11/2008
