Re: Re: RE: Re: Re: [cgal-discuss][Nef_polyhedron]A morecomplexbutstillsimplequestion
- To: "" <>
- Subject: Re: Re: RE: Re: Re: [cgal-discuss][Nef_polyhedron]A morecomplexbutstillsimplequestion
- Date: Thu, 7 Feb 2008 15:00:57 +0800
- Disposition-notification-to: "Max" <>
- Organization: LoadCom
>>Hello Stephen,
>>Thanks for your information.
>>I'll test with this kernel and checkout the related archive.
>I've digged into the archive and found the answer Peter Gave you:
>Just use the undocumented function:
>N = N.intersection(Plane_3(a,b,c,d));
>If I understand correctly, it's senmatically equivalent to
>N = N * Nef_3(Plane_3(a,b,c,d), Nef_3::INCLUDED);
>except the fact that with it it's not mandatory to use an extended kernel.
I've tested with the following typedef's:
typedef CGAL::Gmpq NT;
typedef CGAL::Cartesian<NT> Kernel;
typedef CGAL::Nef_polyhedron_3<Kernel, CGAL::SNC_indexed_items>
Nef_polyhedron_3;
But I was still given an "Constructor not available for this Kernel" warning
when the N.intersection(Plane_3(a,b,c,d)) function was called.
For the case that I use the default items type, instead of the indexed items
type,
in typedef'ing Nef_3, i.e.:
typedef CGAL::Nef_polyhedron_3<Kernel> Nef_polyhedron_3;
the result was identical.
B/Rgds
Max
>>>Hi guys,
>>>Please find the conversation Peter and I have on the archives, the
>>>half-spaces question has been answered previously there! Peter, you have
>>>sent these to me!
>>>Max, I also use double coordinates with half-plane operations. I have
>>>used Cartesian<Gmpq> (exact constructions, exact predicates).
>One more question:
>Do you use the indexed items type, i.e. SNC_indexed_items, or just the
>default one?
>Thanks
>Max
>>>Stephen
>You are currently subscribed to cgal-discuss.
>To unsubscribe or access the archives, go to
>https://lists-sop.inria.fr/wws/info/cgal-discuss
- Re: Re: Re: [cgal-discuss][Nef_polyhedron]A more complex butstillsimplequestion, (continued)
- Re: Re: Re: [cgal-discuss][Nef_polyhedron]A more complex butstillsimplequestion, Max, 02/06/2008
- Re: Re: Re: [cgal-discuss][Nef_polyhedron]A more complex butstillsimplequestion, Peter Hachenberger, 02/06/2008
- Re: Re: Re: [cgal-discuss][Nef_polyhedron]A more complexbutstillsimplequestion, Max, 02/06/2008
- Re: Re: Re: [cgal-discuss][Nef_polyhedron]A more complexbutstillsimplequestion, Peter Hachenberger, 02/06/2008
- RE: Re: Re: [cgal-discuss][Nef_polyhedron]A more complexbutstillsimplequestion, Stephen Wong, 02/06/2008
- Re: RE: Re: Re: [cgal-discuss][Nef_polyhedron]A morecomplexbutstillsimplequestion, Max, 02/07/2008
- Re: Re: RE: Re: Re: [cgal-discuss][Nef_polyhedron]A morecomplexbutstillsimplequestion, Max, 02/07/2008
- Re: Re: Re: RE: Re: Re: [cgal-discuss][Nef_polyhedron]A morecomplexbutstillsimplequestion, Max, 02/07/2008
- Re: Re: Re: RE: Re: Re: [cgal-discuss][Nef_polyhedron]A morecomplexbutstillsimplequestion, Peter Hachenberger, 02/07/2008
- Re: [cgal-discuss][Nef_polyhedron]Amorecomplexbutstillsimplequestion, Max, 02/07/2008
- Re: [cgal-discuss][Nef_polyhedron]Amorecomplexbutstillsimplequestion, Peter Hachenberger, 02/07/2008
- Re: Re:[cgal-discuss][Nef_polyhedron]Amorecomplexbutstillsimplequestion, Max, 02/07/2008
- Re: [cgal-discuss][Nef_polyhedron] How to mannualy construct a (non-manifold) Nef_polyhedron?, Peter Hachenberger, 02/04/2008
- Re: [cgal-discuss][Nef_polyhedron] How to mannualy construct a(non-manifold) Nef_polyhedron?, Max, 02/11/2008
- Re: [cgal-discuss][Nef_polyhedron] How to mannualy construct a(non-manifold) Nef_polyhedron?, Peter Hachenberger, 02/11/2008
