- To:
- Subject: CGALimageIO supports more formats to load origin information
- Date: Wed, 7 May 2008 01:51:49 -0700
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:mime-version:content-type; b=T6cY197xNhq+ZTbabDKrjuHgBA+apyTu9I73M5RlZyDWaIY8hjOS4NxXVNGQ8On0t0iOvQsrGI2QrcPiBpd6/k7TCkzpHn4oSKxiTBWTwG1D99UZ21M/x9V7/BRFAt7SBqvaeSem/CZAOodtj+Gs5CeDJtctrwzWpP69vhRbtGU=
Hi all,
I have been using Analyze format of CGALimageIO to generate surface mesh from. But I found the Analyze format
does not support origin information. So CGALimageIO seems to assume the origin is located [0,0,0], which is incorrect
for most cases because the coordinates for all vertices are shifted.
I am wondering if CGAL can support more image formats, such as MetaImage format (http://www.itk.org/Wiki/MetaIO) which
has origin information. BTW, ITK (http://www.itk.org) has readers for nearly all ordinary formats.
Thanks,
Mengda
- CGALimageIO supports more formats to load origin information, Mengda Wu, 05/07/2008
- Re: [cgal-discuss] CGALimageIO supports more formats to load origin information, Laurent Rineau, 05/07/2008
- [cgal-discuss]To understand half edge data structure (VERY IMPORTANT), samuel kim, 05/07/2008
- Re: [cgal-discuss]To understand half edge data structure (VERY IMPORTANT), Bart Janssens, 05/07/2008
- Re: [cgal-discuss]To understand half edge data structure (VERY IMPORTANT), Mathieu Brédif, 05/07/2008
- RE: [cgal-discuss]To understand half edge data structure, samuel kim, 05/07/2008
- Message not available
- Re: [cgal-discuss]To understand half edge data structure, Mathieu Brédif, 05/07/2008
- Re: [cgal-discuss]To understand half edge data structure, Monique . Teillaud, 05/07/2008
