cgal-discuss - RE: [cgal-discuss]To understand half edge data structure
  • To: <>
  • Subject: RE: [cgal-discuss]To understand half edge data structure
  • Date: Wed, 7 May 2008 15:20:34 +0200
  • Organization: Purdue
Hi Mathieu,
I tried both as you said, but the same error comes out.
Sam
-----Original Message-----
[mailto:]
On Behalf Of Mathieu
Bredif
Sent: Wednesday, May 07, 2008 3:13 PM
To:
Subject: Re: [cgal-discuss]To understand half edge data structure
you cannot assign an handle to a circulator, either construct a new
circulator or affect the handle to an handle :
Halfedge_around_facet_circulator
pHalfedge_new(pHalfedge->prev()->opposite());
or
Halfedge_handle pHalfedge_new = pHalfedge->prev()->opposite();
Mathieu
> On Wed, May 7, 2008 at 2:57 PM, samuel kim
> wrote:
> > Hi Mathieu and Janssens,
> > Thank you very much for your reply, I think you are right. So I tried
it but
> > an error coming out.
> > When I run as the below,
> > Halfedge_around_facet_circulator pHalfedge = pFacet->facet_begin();
> > pHalfedge = pHalfedge->prev()->opposite();
> > error C2679: binary '=' : no operator found which takes a right-hand
operand
> > of type 'CGAL::CGALi::In_place_list_iterator<T,Alloc>' (or there is no
> > acceptable conversion)
> > Would you mind if I ask you one more time How can I solve this?
> > Samuel
> > From:
> [mailto:]
> On Behalf Of
Mathieu
> > Bredif
> > Sent: Wednesday, May 07, 2008 2:34 PM
> > To:
(VERY
> > IMPORTANT)
> > Hi,
> > the facet_begin() halfedge is arbitrary, your mistake is to assume
> > that facet2->facet_begin() is a particular halfedge handle.
> > My advice is to stay with halfedges without using the intermediate
face
> > handles:
> > A C = AB->prev()->opposite()
> > A'C = AC->next_on_vertex() // or more verbosely AB->next()->opposite()
> > Mathieu
> > On Wed, May 7, 2008 at 1:58 PM, samuel kim
wrote:
> > > Hi all,
> > > I am struggling in an implementation with the half edge data
structure.
> > What I want to do is to travel the triangles from triangle# 1 to
triangle# 3
> > as shown at attached picture. For this, I read CGAL document and
implemented
> > based on what I understood. But result is not going to triangle# 3 but
going
> > back to triangle# 1 from triangle#2. The below is the source code I
tried.
> > > Facet_handle hf_new;
> > > Facet_iterator pFacet = facets_begin();
> > expecting to get the handle of half_edge1 on triangle#1
> > > hf_new = pHalfedge->prev()->opposite()->facet(); // expecting to
get the
> > handle of facet of triangle#2
> > > pHalfedge = hf_new->facet_begin(); // expecting to get the handle
of
> > half_edge2 in the triangle#2
> > > hf_new = pHalfedge->next()->opposite()->facet(); // expecting to
get the
> > handle of facet of triangle#3
of
> > half_edge2 on the triangle#3
> > > If I did as the above, the handle of facet was that of triangle#1.
So I
> > want to ask you a question, when I do this,
expecting to
> > get the handle of facet of triangle#2
handle
> > of half_edge2 in the triangle#2
> > > Which edge handle should be returned in triangle#2?
> > > And what is the base rule to get to know the exact pointer of the
handle
> > of half_edge data structure whenever travel triangles? Because I have
tried
> > many times, and found that the pointer of handle of half_edge data
structure
> > was varying at each triangle which was not expectable.
> > > Thank you for your help.
> > > Samuel
> > > You are currently subscribed to cgal-discuss.
> > > To unsubscribe or access the archives, go to
> > > https://lists-sop.inria.fr/wws/info/cgal-discuss
