- To: <>
- Subject: RE: [cgal-discuss]To understand half edge data structure
- Date: Wed, 7 May 2008 15:57:08 +0200
- Organization: Purdue
Hi Mathieu,
I am sorry that there was a mistake. It works now fine. Thanks. But is there
any way to give the handle back to pHalfedge? , because I need to use
pHalfedge continuously in my program.
pHalfedge_new = pHalfedge->prev()->opposite() then how can I give the new
pHalfedge = ?
Thank you in advance.
Samuel
-----Original Message-----
[mailto:]
Sent: Wednesday, May 07, 2008 3:35 PM
To:
Hi Mathieu,
It is not working with the same error.
I tried again as follows,
Halfedge_handle pHalfedge_new(pHalfedge->prev()->opposite());
For more understanding, I amd using CGAL::Polyhedron_3 with Polyhedron_3.h.
Is there anything else should be included?
Samuel
[mailto:]
Sent: Wednesday, May 07, 2008 3:26 PM
To:
Subject: Re: [cgal-discuss]To understand half edge data structure
samuel kim wrote:
> Hi Mathieu,
> I tried both as you said, but the same error comes out.
> Sam
> From:
> [mailto:]
> On Behalf Of Mathieu
> Bredif
> Sent: Wednesday, May 07, 2008 3:13 PM
> To:
> you cannot assign an handle to a circulator, either construct a new
> circulator or affect the handle to an handle :
the same explanation is still valid, but:
> Halfedge_around_facet_circulator
there is a copy-paste mistake here, the explanation above allows to
easily fix it... :
Halfedge_handle
> or
> Halfedge_handle pHalfedge_new = pHalfedge->prev()->opposite();
this should work
Monique Teillaud
> Mathieu
>> On Wed, May 7, 2008 at 2:57 PM, samuel kim
>> wrote:
>> > Hi Mathieu and Janssens,
>> > Thank you very much for your reply, I think you are right. So I tried
> it but
>> > an error coming out.
>> > When I run as the below,
>> > Halfedge_around_facet_circulator pHalfedge = pFacet->facet_begin();
>> > pHalfedge = pHalfedge->prev()->opposite();
>> > error C2679: binary '=' : no operator found which takes a right-hand
> operand
>> > of type 'CGAL::CGALi::In_place_list_iterator<T,Alloc>' (or there is no
>> > acceptable conversion)
>> > Would you mind if I ask you one more time How can I solve this?
>> > Samuel
>> > From:
>> > [mailto:]
>> > On Behalf Of
> Mathieu
>> > Bredif
>> > Sent: Wednesday, May 07, 2008 2:34 PM
>> > To:
> (VERY
>> > IMPORTANT)
>> > Hi,
>> > the facet_begin() halfedge is arbitrary, your mistake is to assume
>> > that facet2->facet_begin() is a particular halfedge handle.
>> > My advice is to stay with halfedges without using the intermediate
> face
>> > handles:
>> > A C = AB->prev()->opposite()
>> > A'C = AC->next_on_vertex() // or more verbosely AB->next()->opposite()
>> > Mathieu
>> > On Wed, May 7, 2008 at 1:58 PM, samuel kim
> wrote:
>> > > Hi all,
>> > > I am struggling in an implementation with the half edge data
> structure.
>> > What I want to do is to travel the triangles from triangle# 1 to
> triangle# 3
>> > as shown at attached picture. For this, I read CGAL document and
> implemented
>> > based on what I understood. But result is not going to triangle# 3 but
> going
>> > back to triangle# 1 from triangle#2. The below is the source code I
> tried.
>> > > Facet_handle hf_new;
>> > > Facet_iterator pFacet = facets_begin();
>> > expecting to get the handle of half_edge1 on triangle#1
>> > > hf_new = pHalfedge->prev()->opposite()->facet(); // expecting to
> get the
>> > handle of facet of triangle#2
>> > > pHalfedge = hf_new->facet_begin(); // expecting to get the handle
> of
>> > half_edge2 in the triangle#2
>> > > hf_new = pHalfedge->next()->opposite()->facet(); // expecting to
> get the
>> > handle of facet of triangle#3
> of
>> > half_edge2 on the triangle#3
>> > > If I did as the above, the handle of facet was that of triangle#1.
> So I
>> > want to ask you a question, when I do this,
> expecting to
>> > get the handle of facet of triangle#2
> handle
>> > of half_edge2 in the triangle#2
>> > > Which edge handle should be returned in triangle#2?
>> > > And what is the base rule to get to know the exact pointer of the
> handle
>> > of half_edge data structure whenever travel triangles? Because I have
> tried
>> > many times, and found that the pointer of handle of half_edge data
> structure
>> > was varying at each triangle which was not expectable.
>> > > Thank you for your help.
>> > > Samuel
>> > > You are currently subscribed to cgal-discuss.
>> > > To unsubscribe or access the archives, go to
>> > > https://lists-sop.inria.fr/wws/info/cgal-discuss
- CGALimageIO supports more formats to load origin information, Mengda Wu, 05/07/2008
- Re: [cgal-discuss] CGALimageIO supports more formats to load origin information, Laurent Rineau, 05/07/2008
- [cgal-discuss]To understand half edge data structure (VERY IMPORTANT), samuel kim, 05/07/2008
- Re: [cgal-discuss]To understand half edge data structure (VERY IMPORTANT), Bart Janssens, 05/07/2008
- Re: [cgal-discuss]To understand half edge data structure (VERY IMPORTANT), Mathieu Brédif, 05/07/2008
- RE: [cgal-discuss]To understand half edge data structure, samuel kim, 05/07/2008
- Message not available
- Re: [cgal-discuss]To understand half edge data structure, Mathieu Brédif, 05/07/2008
- Re: [cgal-discuss]To understand half edge data structure, Monique . Teillaud, 05/07/2008
- Re: [cgal-discuss]To understand half edge data structure, Laurent Rineau, 05/07/2008
