- To:
- Subject: Re: [cgal-discuss]To understand half edge data structure
- Date: Wed, 7 May 2008 15:13:07 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:sender:to:subject:in-reply-to:mime-version:content-type:content-transfer-encoding:content-disposition:references:x-google-sender-auth; b=gdu0iRXA2ckBY+sied8CdEstniXUDHAoosobkV7ZIiJaTePcGXvY3c5FLBJJLhsFgYGQc+VbiR0DLY4VEsZJoB3CrvLxc6fVlbteDdbH2UDLW7LeTDCnl37JWJCbiDtZcujBdf+w4UDiHuw9XttVEWll8zFNWHWRL20yrflFesU=
you cannot assign an handle to a circulator, either construct a new
circulator or affect the handle to an handle :
Halfedge_around_facet_circulator pHalfedge_new(pHalfedge->prev()->opposite());
or
Halfedge_handle pHalfedge_new = pHalfedge->prev()->opposite();
Mathieu
> On Wed, May 7, 2008 at 2:57 PM, samuel kim
> wrote:
> > Hi Mathieu and Janssens,
> > Thank you very much for your reply, I think you are right. So I tried
> it but
> > an error coming out.
> > When I run as the below,
> > Halfedge_around_facet_circulator pHalfedge = pFacet->facet_begin();
> > pHalfedge = pHalfedge->prev()->opposite();
> > error C2679: binary '=' : no operator found which takes a right-hand
> operand
> > of type 'CGAL::CGALi::In_place_list_iterator<T,Alloc>' (or there is no
> > acceptable conversion)
> > Would you mind if I ask you one more time How can I solve this?
> > Samuel
> > -----Original Message-----
> > From:
> [mailto:]
> On Behalf Of Mathieu
> > Bredif
> > Sent: Wednesday, May 07, 2008 2:34 PM
> > To:
> > Subject: Re: [cgal-discuss]To understand half edge data structure (VERY
> > IMPORTANT)
> > Hi,
> > the facet_begin() halfedge is arbitrary, your mistake is to assume
> > that facet2->facet_begin() is a particular halfedge handle.
> > My advice is to stay with halfedges without using the intermediate face
> > handles:
> > A C = AB->prev()->opposite()
> > A'C = AC->next_on_vertex() // or more verbosely AB->next()->opposite()
> > Mathieu
> > On Wed, May 7, 2008 at 1:58 PM, samuel kim
> wrote:
> > > Hi all,
> > > I am struggling in an implementation with the half edge data
> structure.
> > What I want to do is to travel the triangles from triangle# 1 to
> triangle# 3
> > as shown at attached picture. For this, I read CGAL document and
> implemented
> > based on what I understood. But result is not going to triangle# 3 but
> going
> > back to triangle# 1 from triangle#2. The below is the source code I
> tried.
> > > Facet_handle hf_new;
> > > Facet_iterator pFacet = facets_begin();
> > expecting to get the handle of half_edge1 on triangle#1
> > > hf_new = pHalfedge->prev()->opposite()->facet(); // expecting to get
> the
> > handle of facet of triangle#2
> > > pHalfedge = hf_new->facet_begin(); // expecting to get the handle of
> > half_edge2 in the triangle#2
> > > hf_new = pHalfedge->next()->opposite()->facet(); // expecting to get
> the
> > handle of facet of triangle#3
> > half_edge2 on the triangle#3
> > > If I did as the above, the handle of facet was that of triangle#1.
> So I
> > want to ask you a question, when I do this,
> to
> > get the handle of facet of triangle#2
> handle
> > of half_edge2 in the triangle#2
> > > Which edge handle should be returned in triangle#2?
> > > And what is the base rule to get to know the exact pointer of the
> handle
> > of half_edge data structure whenever travel triangles? Because I have
> tried
> > many times, and found that the pointer of handle of half_edge data
> structure
> > was varying at each triangle which was not expectable.
> > > Thank you for your help.
> > > Samuel
> > > You are currently subscribed to cgal-discuss.
> > > To unsubscribe or access the archives, go to
> > > https://lists-sop.inria.fr/wws/info/cgal-discuss
- CGALimageIO supports more formats to load origin information, Mengda Wu, 05/07/2008
- Re: [cgal-discuss] CGALimageIO supports more formats to load origin information, Laurent Rineau, 05/07/2008
- [cgal-discuss]To understand half edge data structure (VERY IMPORTANT), samuel kim, 05/07/2008
- Re: [cgal-discuss]To understand half edge data structure (VERY IMPORTANT), Bart Janssens, 05/07/2008
- Re: [cgal-discuss]To understand half edge data structure (VERY IMPORTANT), Mathieu Brédif, 05/07/2008
- RE: [cgal-discuss]To understand half edge data structure, samuel kim, 05/07/2008
- Message not available
- Re: [cgal-discuss]To understand half edge data structure, Mathieu Brédif, 05/07/2008
- Re: [cgal-discuss]To understand half edge data structure, Monique . Teillaud, 05/07/2008
- Re: [cgal-discuss]To understand half edge data structure, Laurent Rineau, 05/07/2008
