- To:
- Subject: Re: [cgal-discuss]To understand half edge data structure (VERY IMPORTANT)
- Date: Wed, 7 May 2008 14:28:12 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:sender:to:subject:in-reply-to:mime-version:content-type:content-transfer-encoding:content-disposition:references:x-google-sender-auth; b=UrbDhpVqchu0hyNdT1jT5zNZtO0Im5Fn/FphUYCBBrmMVerG5Ah54mL4SA2uo5ziEC2D3Cc6acYnaxBJJYfsKWlG8josNoqxg5V3rbdGIuta17dO8lx/0gWY4fYL2LTtshsX0bL6lIw/RdmvDvXkV9hO7qRePX+FsfsC4Yl6OJ0=
On 5/7/08, samuel kim
wrote:
> If I did as the above, the handle of facet was that of triangle#1. So I want
> to ask you a question, when I do this,
> hf_new = pHalfedge->prev()->opposite()->facet(); // expecting to get
> the
> handle of facet of triangle#2
> pHalfedge = hf_new->facet_begin(); // expecting to get the handle of
> half_edge2 in the triangle#2
> Which edge handle should be returned in triangle#2?
Hi Samuel,
I don't think you need to get the facets when changing between triangles.
Instead, you can just do
facet_2_edge_2 = pHalfedge->prev()->opposite()
facet_3_edge_2 = facet_2_edge_2 ->next()->opposite()
If you are sure you get the right edge in facet 1, that should work.
> And what is the base rule to get to know the exact pointer of the handle of
> half_edge data structure whenever travel triangles? Because I have tried
> many times, and found that the pointer of handle of half_edge data structure
> was varying at each triangle which was not expectable.
Not sure what you want to do here. I think the CGAL way is to stick with the
handles, and avoid pointers.
Cheers,
Bart Janssens
- CGALimageIO supports more formats to load origin information, Mengda Wu, 05/07/2008
- Re: [cgal-discuss] CGALimageIO supports more formats to load origin information, Laurent Rineau, 05/07/2008
- [cgal-discuss]To understand half edge data structure (VERY IMPORTANT), samuel kim, 05/07/2008
- Re: [cgal-discuss]To understand half edge data structure (VERY IMPORTANT), Bart Janssens, 05/07/2008
- Re: [cgal-discuss]To understand half edge data structure (VERY IMPORTANT), Mathieu Brédif, 05/07/2008
- RE: [cgal-discuss]To understand half edge data structure, samuel kim, 05/07/2008
- Message not available
- Re: [cgal-discuss]To understand half edge data structure, Mathieu Brédif, 05/07/2008
- Re: [cgal-discuss]To understand half edge data structure, Monique . Teillaud, 05/07/2008
- Re: [cgal-discuss]To understand half edge data structure, Laurent Rineau, 05/07/2008
