cgal-discuss - Re: [cgal-discuss] Setting up Triangulation_3 datastructure with no neighboring information
  • To:
  • Subject: Re: [cgal-discuss] Setting up Triangulation_3 datastructure with no neighboring information
  • Date: Tue, 03 Jun 2008 17:07:47 +0200
Hi Nico,
thats exactly what i needed! It works fine, thanks a lot!
If i encounter any problems, i will let you know!
Daniel
-------- Original-Nachricht --------
> Datum: Tue, 03 Jun 2008 16:27:08 +0200
> Von: Nico Kruithof
> An:
> Betreff: Re: [cgal-discuss] Setting up Triangulation_3 datastructure with
> Hi Daniel,
> I did the same for the skin surface package, where I have the vertices
> and tetrahedra of the triangulation and want to reconstruct the neighbor
> information. The class is not documented and there is no guarantee that
> it works for your cases as well.
> You could have a look at that. It's in the file
> CGAL/Triangulation_incremental_builder_3.h
> You give the triangulation in the constructor, then you start building
> the triangulation with "begin_triangulation(int dim)". I don't remember
> whether dim<3 works as I don't use it.
> You build the triangulation with the functions:
> Vertex_handle add_vertex();
> Cell_handle add_cell(Vertex_handle vh0, Vertex_handle vh1,
> Vertex_handle vh2, Vertex_handle vh3);
> Finally, you build the triangulation with
> void end_triangulation()
> which also creates the infinite cells and might do some validity
> checking.
> Let me know whether you find it usefull and whether it could be
> improved.
> Bests,
> Nico
> On Tue, 2008-06-03 at 16:13 +0200,
> wrote:
> > Hi at all!
> > I'm using the Triangulation_3 data structure for simulating deformable
> models. The advantage of that data structure is the simple access for
> information about neighbors.
> > I constructed different models, in my case simple bars, by inserting
> equidistant points in a Delaunaytriangulation. Using the I/O functionality
> of
> the data structures i can load and save these Triangulations.
> > Now i want to simulate other models. I've got the tetrahedral mesh as
> list of points and tetrahedra referring to the points. I've already spent a
> long time for an incremental construction of the tetrahedral mesh. But i
> failed, because of the very complex neighbor information especially of
> infinite tetrahedrons.
> > Is there any existing algorithm for that kind of problem? Or can anybody
> give me a hint how to construct the tetrahedral mesh properly?
> > Best regards,
> > Daniel Weber
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
Ist Ihr Browser Vista-kompatibel? Jetzt die neuesten
Browser-Versionen downloaden: http://www.gmx.net/de/go/browser
