- To: <>
- Subject: [cgal-discuss] format and viewer for the 3D surface Mesh Generation
- Date: Thu, 12 Jun 2008 15:49:58 +0000
- Importance: Normal
Hi, all
Still the question for the chapitre 35:
1) in the first example, I write an output file for the C2t3, but I don't understand the file. for example: what do those lignes mean:
4353
124 389 396 400 440 42 441 442 0 599 54 600 ... 0 0 0 0
0 0 0 1 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 1 ... 2) And can the "CGAL demo"(a software viewer of CGAL) read this file? Or is there some viewer can read this format for windows?
Get news, entertainment and everything you care about at Live.com. Check it out! |
- Re: [cgal-discuss] Setting up Triangulation_3 datastructure with no neighboring information, (continued)
- Re: [cgal-discuss] Setting up Triangulation_3 datastructure with no neighboring information, Nico Kruithof, 06/03/2008
- Re: [cgal-discuss] Setting up Triangulation_3 datastructure with no neighboring information, Daniel Weber, 06/03/2008
- [cgal-discuss] What't the most efficient configuration for Bool Op of Nef_3, Max, 06/07/2008
- Re: [cgal-discuss] What't the most efficient configuration for, Peter Hachenberger, 06/09/2008
- [cgal-discuss] 3D surface Mesh Generation, Hui Ding, 06/09/2008
- Re: [cgal-discuss] 3D surface Mesh Generation, Laurent Rineau, 06/09/2008
- Re: [cgal-discuss] 3D surface Mesh Generation, Santosh Tiwari, 06/09/2008
- Re: [cgal-discuss] 3D surface Mesh Generation, Hui DING, 06/11/2008
- Re: [cgal-discuss] 3D surface Mesh Generation, Santosh Tiwari, 06/11/2008
- [cgal-discuss] format and viewer for the 3D surface Mesh Generation, Hui Ding, 06/12/2008
- [cgal-discuss] Is there a data structure for non-manifold 3D, Calvin Lim, 06/10/2008
- Re: [cgal-discuss] Is there a data structure for non-manifold 3D, Laurent Rineau, 06/10/2008
- Re: [cgal-discuss] Is there a data structure for non-manifold 3D, Marco Attene, 06/10/2008
- Re: [cgal-discuss] Is there a data structure for non-manifold 3D, Max, 06/11/2008
- Re: [cgal-discuss] Is there a data structure for non-manifold 3D, Robert Bilant, 06/11/2008
- Re: Re: [cgal-discuss] What't the most efficient configuration for, Max, 06/10/2008
- Re: Re: [cgal-discuss] What't the most efficient configuration for, Peter Hachenberger, 06/10/2008
- Re: [cgal-discuss] What's the most efficient configuration for nef_3, Max, 06/11/2008
- Re: [cgal-discuss] What's the most efficient configuration for, Peter Hachenberger, 06/11/2008
