- To: <>
- Subject: [cgal-discuss] 3D surface Mesh Generation
- Date: Mon, 9 Jun 2008 16:07:18 +0000
- Importance: Normal
Hi all, I have this file of 3D points whose data are from an image depth, which means those 3D points define an object 3D non-closed. I want to mesh this object, is it possible that i can use the make_surface_mesh to do that? and how? for example, how to define the sphere_3, the centre, etc? Can anybody give an idea? Thanx!! Hui Invite your mail contacts to join your friends list with Windows Live Spaces. It's easy! Try it! |
- Setting up Triangulation_3 datastructure with no neighboring information, megaweber, 06/03/2008
- Re: [cgal-discuss] Setting up Triangulation_3 datastructure with no neighboring information, Nico Kruithof, 06/03/2008
- Re: [cgal-discuss] Setting up Triangulation_3 datastructure with no neighboring information, Daniel Weber, 06/03/2008
- [cgal-discuss] What't the most efficient configuration for Bool Op of Nef_3, Max, 06/07/2008
- Re: [cgal-discuss] What't the most efficient configuration for, Peter Hachenberger, 06/09/2008
- [cgal-discuss] 3D surface Mesh Generation, Hui Ding, 06/09/2008
- Re: [cgal-discuss] 3D surface Mesh Generation, Laurent Rineau, 06/09/2008
- Re: [cgal-discuss] 3D surface Mesh Generation, Santosh Tiwari, 06/09/2008
- Re: [cgal-discuss] 3D surface Mesh Generation, Hui DING, 06/11/2008
- Re: [cgal-discuss] 3D surface Mesh Generation, Santosh Tiwari, 06/11/2008
- [cgal-discuss] format and viewer for the 3D surface Mesh Generation, Hui Ding, 06/12/2008
- [cgal-discuss] Is there a data structure for non-manifold 3D, Calvin Lim, 06/10/2008
- Re: [cgal-discuss] Is there a data structure for non-manifold 3D, Laurent Rineau, 06/10/2008
- Re: [cgal-discuss] Is there a data structure for non-manifold 3D, Marco Attene, 06/10/2008
- Re: [cgal-discuss] Is there a data structure for non-manifold 3D, Max, 06/11/2008
