cgal-discuss - Re: [cgal-discuss] 3D surface Mesh Generation
  • To: <>
  • Subject: Re: [cgal-discuss] 3D surface Mesh Generation
  • Date: Wed, 11 Jun 2008 12:07:11 +0200
Hi, Santosh Tiwari
Could you explain a little about the "alpha complex of the shape and output all the surface facets"? Do you mean that those works you mentioned are for the implicit function, like Laurent Rineau said in the other message?
If you want mesh re-construction from point cloud. You have following
options.
1. If you want to use CGAL, you may create an alpha complex of the shape
and output all the surface facets. This method works but is not very
reliable and may not always give you the mesh you want.
2. If you know the approximate direction of normals at every vertex, use
something like poisson surface reconstruction. It is a powerful and
reliable method.
3. If you do not have the normals, you can use the program provided at the
following link.
http://www.den.rcast.u-tokyo.ac.jp/~yu-ohtake/software/index.html
This method also is not very reliable. It works on most standard models
but for complex data sets, it does not do a good job.
On Monday 09 June 2008 18:07:18 Hui Ding wrote:
Hi all,
I have this file of 3D points whose data are from an image depth, which
means those 3D points define an object 3D non-closed. I want to mesh
this
object, is it possible that i can use the make_surface_mesh to do that?
and
how? for example, how to define the sphere_3, the centre, etc? Can
anybody
give an idea? Thanx!!
Here is an answer I made in another thread of this list, last year ("3D
surface meshing", 2007/06/08):
« You seem to have a set of points, as input. Surface_mesher in CGAL-3.3
is a
package to mesh a implicit function. What you need is a surface
reconstruction algorithm (from a set of points). You cannot use
Surface_mesher.
However, there exists some algorithm to compute an implicit function, from
a
set of points, whose zero level represents a smooth surface interpoling
the
points. If you have such a function, then you can use the Surface_mesher
package. »
As far as I know, there are not any code in current CGAL-3.3.1 for such a
task.
Laurent Rineau
INRIA - Sophia Antipolis
BP 93, 2004 Route des Lucioles
06902 Sophia Antipolis Cedex FRANCE
Tel: +33 4 92 38 78 62 (Fax: +33.4.97.15.53.95)
Santosh Tiwari
Fluor Daniel EIB 326
Clemson University, Clemson, SC 29634
http://www.clemson.edu/~stiwari/
