- To: "" <>
- Subject: [cgal-discuss] A couple of questions on Nef_x
- Date: Wed, 11 Jun 2008 08:33:00 +0800
- Organization: Max
Hi,
I'm curious on these questions:
- is there a nef_1 representation of a nef in 1 dimension?
(yes, it's just a combinition of any open or close ranges. What I mean is
a universal representation as nef_3)
- is there a function to elevate the number of dimensions to higher dimension,
e.g., convert a nef_2 into a nef_3?
- is there a convenient way to perform some well-know geometric operation,
such as
glide, extrude, etc., with an existing nef_X?
- is there a function to glide a nef_3 to get the swept nef_3?
- is there a machanism to shift the kernel types of one nef_3 (and any other
CGAL data structure) at runtime?
- is there a function to incrementally build a (not necessarily 2-manifold)
nef_3?
Thanks for you time.
B/Rgds
Max
- Re: [cgal-discuss] Is there a data structure for non-manifold 3D, (continued)
- Re: [cgal-discuss] Is there a data structure for non-manifold 3D, Robert Bilant, 06/11/2008
- Re: Re: [cgal-discuss] What't the most efficient configuration for, Max, 06/10/2008
- Re: Re: [cgal-discuss] What't the most efficient configuration for, Peter Hachenberger, 06/10/2008
- Re: [cgal-discuss] What's the most efficient configuration for nef_3, Max, 06/11/2008
- Re: [cgal-discuss] What's the most efficient configuration for, Peter Hachenberger, 06/11/2008
- Re: Re: [cgal-discuss] What's the most efficient configuration for, Max, 06/11/2008
- [cgal-discuss] A couple of questions on Nef_x, Max, 06/11/2008
- Re: [cgal-discuss] A couple of questions on Nef_x, Peter Hachenberger, 06/11/2008
- Re: [cgal-discuss] A couple of questions on Nef_x, Max, 06/11/2008
- Re: [cgal-discuss] A couple of questions on Nef_x, Max, 06/13/2008
- [cgal-discuss] A problem found by accident, Max, 06/11/2008
