cgal-discuss - Re: [cgal-discuss] A couple of questions on Nef_x
  • To: "" <>
  • Subject: Re: [cgal-discuss] A couple of questions on Nef_x
  • Date: Wed, 11 Jun 2008 16:41:38 +0800
  • Organization: Max
Hello Peter,
>> I'm curious on these questions:
>> - is there a nef_1 representation of a nef in 1 dimension?
>> (yes, it's just a combinition of any open or close ranges. What I mean
>> is
>> a universal representation as nef_3)
>We don't have that in CGAL and it does not seem interesting to have.
I also agree that this may be of no use in practice. I'm just interested
in the completeness of the module. Sorry for the naive question.
>> - is there a function to elevate the number of dimensions to higher
>> dimension,
>> e.g., convert a nef_2 into a nef_3?
>Not yet.
Is this on your todo list or would it be?
>> - is there a convenient way to perform some well-know geometric operation,
>> such as
>> glide, extrude, etc., with an existing nef_X?
>Sorry to say, but I don't know glide and extrude.
What I mean by glide is as you understood as below. That by extrude is
similar,
except these 2 aspects:
1. the 'gliding' path of extrude op is a line segment rather than a polyline;
2. the extrude op make d+1 dimensional obj from dD obj.
>> - is there a function to glide a nef_3 to get the swept nef_3?
>if glide means to compute the area swept by a nef_3 moved along a
>polygonal line, then you can do that with the Minkowski_sum_3 package
>that hopefully will be in the next CGAL release.
That's a good news, thank you.
Is there a scheduled time for the next release?
>> - is there a machanism to shift the kernel types of one nef_3 (and any
>> other
>> CGAL data structure) at runtime?
>No.
That's a bad news. Is there a plan to let us have this? :-)
I think it will be useful in promoting the efficiency of our code.
>> - is there a function to incrementally build a (not necessarily
>> 2-manifold) nef_3?
>No, I neither have an idea how it might work, nor the manpower to do
>realize that at the moment.
>Peter
Thank you so much for you reply.
B/Rgds
Max
