cgal-discuss - Re: Re: [cgal-discuss] What's the most efficient configuration for
  • To: "" <>
  • Subject: Re: Re: [cgal-discuss] What's the most efficient configuration for
  • Date: Wed, 11 Jun 2008 17:30:42 +0800
  • Organization: Max
>Hi Max,
>> I attach the test program for reproducing the problem.
>> To make the code as small in size as possible, I've commented out
>> the irrelevant code. The sample data file is also attached.
>> I hope I'm not making stupid mistake. :-)
>the problem is not the indexed items themselves, but the combination of
>experimental code that you use and the indexed items. The constructor
>Nef_polyhedron_3(Nef_polyhedron_3 N, SFace_handle sf)
>does not work together with those items, yet. I can easily fix that, but
>give me some time.
Hello Peter,
Thank you for your help.
B/Rgds
Max
