- To:
- Subject: Re: [cgal-discuss] A couple of questions on Nef_x
- Date: Wed, 11 Jun 2008 09:54:37 +0200
> I'm curious on these questions:
> - is there a nef_1 representation of a nef in 1 dimension?
> (yes, it's just a combinition of any open or close ranges. What I mean is
> a universal representation as nef_3)
We don't have that in CGAL and it does not seem interesting to have.
> - is there a function to elevate the number of dimensions to higher
> dimension,
> e.g., convert a nef_2 into a nef_3?
Not yet.
> - is there a convenient way to perform some well-know geometric operation,
> such as
> glide, extrude, etc., with an existing nef_X?
Sorry to say, but I don't know glide and extrude.
> - is there a function to glide a nef_3 to get the swept nef_3?
if glide means to compute the area swept by a nef_3 moved along a
polygonal line, then you can do that with the Minkowski_sum_3 package
that hopefully will be in the next CGAL release.
> - is there a machanism to shift the kernel types of one nef_3 (and any
> other
> CGAL data structure) at runtime?
No.
> - is there a function to incrementally build a (not necessarily 2-manifold)
> nef_3?
No, I neither have an idea how it might work, nor the manpower to do
realize that at the moment.
Peter
- Re: Re: [cgal-discuss] What't the most efficient configuration for, (continued)
- Re: Re: [cgal-discuss] What't the most efficient configuration for, Max, 06/10/2008
- Re: Re: [cgal-discuss] What't the most efficient configuration for, Peter Hachenberger, 06/10/2008
- Re: [cgal-discuss] What's the most efficient configuration for nef_3, Max, 06/11/2008
- Re: [cgal-discuss] What's the most efficient configuration for, Peter Hachenberger, 06/11/2008
- Re: Re: [cgal-discuss] What's the most efficient configuration for, Max, 06/11/2008
- [cgal-discuss] A couple of questions on Nef_x, Max, 06/11/2008
- Re: [cgal-discuss] A couple of questions on Nef_x, Peter Hachenberger, 06/11/2008
- Re: [cgal-discuss] A couple of questions on Nef_x, Max, 06/11/2008
- Re: [cgal-discuss] A couple of questions on Nef_x, Max, 06/13/2008
- [cgal-discuss] A problem found by accident, Max, 06/11/2008
