- To:
- Subject: Re: [cgal-discuss] Boundary of alphashapes
- Date: Fri, 08 Aug 2008 14:52:59 +0200
Hello Mariette,
a shapefile is a popular geospatial vector data format for geographic
information systems
(http://en.wikipedia.org/wiki/Shapefile)
As you already know, I am not very familiar with alphashapes, but maybe you
can help me.
I am just looking for a method to get the shape, defined by a set of points
(the "concave hull" , not the convex hull). After an intensiv google search,
I found the CGAL library, installed it and tried to write a function using
alpha_shapes_3.
My question is: How can I get, the shape which is defined by a set of points
in file?
Thanks
Andi
-------- Original-Nachricht --------
> Datum: Fri, 08 Aug 2008 14:37:54 +0200
> Von: Mariette Yvinec
> An:
> Betreff: Re: [cgal-discuss] Boundary of alphashapes
> I am rather familiar with Alpha_shape_3
> but I can't answer your questions
> because I do not understand them...
> In particular I don't know
> - what is a shapefile
> - nor which polygon you want to get out of alpha_shapes_3
> - nor what is a roof plane
> wrote:
> > Hello,
> > I wrote a function to get the alphashapes of a set of points, but how
> can I
> > transform this alphashapes in a polygon...???
> > Is it posssible to transform the created alphashape in a shapefile???
> > Is anybody familiar with alphashapes??
> > Thanks a lot.
> > andi
> Mariette Yvinec
> Geometrica project team
> INRIA Sophia-Antipolis
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
Psssst! Schon das coole Video vom GMX MultiMessenger gesehen?
Der Eine für Alle: http://www.gmx.net/de/go/messenger03
- [cgal-discuss] Boundary of alphashapes, andruit, 08/08/2008
- Re: [cgal-discuss] Boundary of alphashapes, Mariette Yvinec, 08/08/2008
- Re: [cgal-discuss] Boundary of alphashapes, Andi Jochem, 08/08/2008
- Re: [cgal-discuss] Boundary of alphashapes, Björn Zehner, 08/08/2008
- Re: [cgal-discuss] Boundary of alphashapes, Andruit, 08/08/2008
