- To:
- Subject: Re: [cgal-discuss] Boundary of alphashapes
- Date: Fri, 08 Aug 2008 15:41:45 +0200
Depending on the value you are going to choose for alpha, you can get a whole family of different alphashapes with different boundaries. I am not sure that one of them corresponds to what you are expecting wrote: Hello Mariette, you are right, there is no relation between alphashapes and shapefiles. The only thing I want to do, is to write the boundaries which are defined by the set of points into a file. Or am I totally wrong and alphashapes are not the right method to solve my problem. Thanks andi -------- Original-Nachricht --------Datum: Fri, 08 Aug 2008 14:59:14 +0200 Von: Mariette Yvinec An: Betreff: Re: [cgal-discuss] Boundary of alphashapesFrom what I see in wikipedia there is no relationship between alphashapes and shape file... and I still don't get what shape you want to get Andi Jochem wrote:Hello Mariette, a shapefile is a popular geospatial vector data format for geographicinformation systems(http://en.wikipedia.org/wiki/Shapefile) As you already know, I am not very familiar with alphashapes, but maybeyou can help me.I am just looking for a method to get the shape, defined by a set ofpoints (the "concave hull" , not the convex hull). After an intensiv google search, I found the CGAL library, installed it and tried to write a function using alpha_shapes_3.My question is: How can I get, the shape which is defined by a set ofpoints in file?Thanks Andi -------- Original-Nachricht --------Datum: Fri, 08 Aug 2008 14:37:54 +0200 Von: Mariette Yvinec An: Betreff: Re: [cgal-discuss] Boundary of alphashapesI am rather familiar with Alpha_shape_3 but I can't answer your questions because I do not understand them... In particular I don't know - what is a shapefile - nor which polygon you want to get out of alpha_shapes_3 - nor what is a roof plane wrote:Hello, I wrote a function to get the alphashapes of a set of points, but howcan Itransform this alphashapes in a polygon...??? Is it posssible to transform the created alphashape in a shapefile??? Is anybody familiar with alphashapes?? Thanks a lot. andi-- Mariette Yvinec Geometrica project team INRIA Sophia-Antipolis -- You are currently subscribed to cgal-discuss. To unsubscribe or access the archives, go to https://lists-sop.inria.fr/wws/info/cgal-discuss-- Mariette Yvinec Geometrica project team INRIA Sophia-Antipolis -- You are currently subscribed to cgal-discuss. To unsubscribe or access the archives, go to https://lists-sop.inria.fr/wws/info/cgal-discuss -- Mariette Yvinec Geometrica project team INRIA Sophia-Antipolis |
- [cgal-discuss] Boundary of alphashapes, andruit, 08/08/2008
- Re: [cgal-discuss] Boundary of alphashapes, Mariette Yvinec, 08/08/2008
- Re: [cgal-discuss] Boundary of alphashapes, Andi Jochem, 08/08/2008
- Re: [cgal-discuss] Boundary of alphashapes, Björn Zehner, 08/08/2008
- Re: [cgal-discuss] Boundary of alphashapes, Andruit, 08/08/2008
