- To:
- Subject: Re: [cgal-discuss] Boundary of alphashapes
- Date: Fri, 08 Aug 2008 15:04:57 +0200
- Priority: normal
Hello,
I hope I do not miss completely the point, but I think he wants the polygon that describes the outer (possibly concave) boundary of the alpha shape. Am I right Andi?
Kind regards,
Bjoern Zehner
----- Ursprüngliche Nachricht -----
Von: Mariette Yvinec <>
Datum: Freitag, 8. August 2008, 14:59
Betreff: Re: [cgal-discuss] Boundary of alphashapes
An:
> From what I see in wikipedia > Hello Mariette, > > a shapefile is a popular geospatial vector data format for geographic information systems > (http://en.wikipedia.org/wiki/Shapefile) > > As you already know, I am not very familiar with alphashapes, but maybe you can help me. > > > > I am just looking for a method to get the shape, defined by a set of points (the "concave hull" , not the convex hull). After an intensiv google search, I found the CGAL library, installed it and tried to write a function using alpha_shapes_3. > > My question is: How can I get, the shape which is defined by a set of points in file? > > > Thanks > > Andi > > > > > -------- Original-Nachricht -------- >> Datum: Fri, 08 Aug 2008 14:37:54 +0200 > Von: Mariette Yvinec <> > An: > Betreff: Re: [cgal-discuss] Boundary of alphashapes >> >> I am rather familiar with Alpha_shape_3 > but I can't answer your questions > because I do not understand them... > In particular I don't know > - what is a shapefile > - nor which polygon you want to get out of alpha_shapes_3 > - nor what is a roof plane > > wrote: >> Hello, > I wrote a function to get the alphashapes of a set of points, but how >> can I >> transform this alphashapes in a polygon...??? > Is it posssible to transform the created alphashape in a shapefile??? > > Is anybody familiar with alphashapes?? > > Thanks a lot. > > andi > >> -- > Mariette Yvinec > Geometrica project team > INRIA Sophia-Antipolis > > > > -- > You are currently subscribed to cgal-discuss. > To unsubscribe or access the archives, go to > https://lists-sop.inria.fr/wws/info/cgal-discuss >> > > -- > Mariette Yvinec > Geometrica project team > INRIA Sophia-Antipolis > > > |
Dr. Bjoern Zehner
UFZ Centre for Environmental Research Leipzig-Halle
Permoserstrasse 15
04318 Leipzig
Germany
http://www.ufz.de/index.php?en=5673
Tel: ++49 (341) 235 3979
Fax: ++49 (341) 235 3939
- [cgal-discuss] Boundary of alphashapes, andruit, 08/08/2008
- Re: [cgal-discuss] Boundary of alphashapes, Mariette Yvinec, 08/08/2008
- Re: [cgal-discuss] Boundary of alphashapes, Andi Jochem, 08/08/2008
- Re: [cgal-discuss] Boundary of alphashapes, Björn Zehner, 08/08/2008
- Re: [cgal-discuss] Boundary of alphashapes, Andruit, 08/08/2008
