cgal-discuss - Re: [cgal-discuss] Boundary of alphashapes
  • To:
  • Subject: Re: [cgal-discuss] Boundary of alphashapes
  • Date: Fri, 08 Aug 2008 15:06:58 +0200
Hello Mariette,
you are right, there is no relation between alphashapes and shapefiles.
The only thing I want to do, is to write the boundaries which are defined by
the set of points into a file.
Or am I totally wrong and alphashapes are not the right method to solve my
problem.
Thanks
andi
-------- Original-Nachricht --------
> Datum: Fri, 08 Aug 2008 14:59:14 +0200
> Von: Mariette Yvinec
> An:
> Betreff: Re: [cgal-discuss] Boundary of alphashapes
> From what I see in wikipedia
> there is no relationship between alphashapes and shape file...
> and I still don't get what shape you want to get
> Andi Jochem wrote:
> > Hello Mariette,
> > a shapefile is a popular geospatial vector data format for geographic
> information systems
> > (http://en.wikipedia.org/wiki/Shapefile)
> > As you already know, I am not very familiar with alphashapes, but maybe
> you can help me.
> > I am just looking for a method to get the shape, defined by a set of
> points (the "concave hull" , not the convex hull). After an intensiv google
> search, I found the CGAL library, installed it and tried to write a function
> using alpha_shapes_3.
> > My question is: How can I get, the shape which is defined by a set of
> points in file?
> > Thanks
> > Andi
> >> Datum: Fri, 08 Aug 2008 14:37:54 +0200
> >> An:
> >> I am rather familiar with Alpha_shape_3
> >> but I can't answer your questions
> >> because I do not understand them...
> >> In particular I don't know
> >> - what is a shapefile
> >> - nor which polygon you want to get out of alpha_shapes_3
> >> - nor what is a roof plane
> >> wrote:
> >>> Hello,
> >>> I wrote a function to get the alphashapes of a set of points, but how
> >> can I
> >>> transform this alphashapes in a polygon...???
> >>> Is it posssible to transform the created alphashape in a shapefile???
> >>> Is anybody familiar with alphashapes??
> >>> Thanks a lot.
> >>> andi
> >> Mariette Yvinec
> >> Geometrica project team
> >> INRIA Sophia-Antipolis
> >> You are currently subscribed to cgal-discuss.
> >> To unsubscribe or access the archives, go to
> >> https://lists-sop.inria.fr/wws/info/cgal-discuss
> Mariette Yvinec
GMX startet ShortView.de. Hier findest Du Leute mit Deinen Interessen!
Jetzt dabei sein:
http://www.shortview.de/wasistshortview.php?mc=sv_ext_mf@gmx
