cgal-discuss - Re: [cgal-discuss] skin surfaces : subdivision is *very* slow, is this normal ?
  • To:
  • Subject: Re: [cgal-discuss] skin surfaces : subdivision is *very* slow, is this normal ?
  • Date: Sun, 23 Nov 2008 11:02:35 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version :content-type:content-transfer-encoding:content-disposition :references; b=L+SzNruL6cESCa3IdiFHGeB8q/nmKDGQAqnO9P3hs8cXQiKg8gfz58+hn6UUzChgWK QY1iMwtiMIxEFHK4hG4Wz7rnSP4osn49H+5VI8ORTtmXNDNcoz9IOAsLQK5oeS7j1eGx D96BLrBpQ247kwxWZpEEcLFXqUch32N7ypou4=
Hi Benjamin,
The order of the include files shoudn't matter and if it does, I
consider it a bug in my code. In the meantime I switched to industry
and have a deadline on tuesday. After that I'll have a look. At one
point, the algorithm was extremely fast, but also used a lot of
memory. How much memory do you have? In the latest public release
there is a better tradeoff between cpu times and memory consumption.
Bests,
Nico
On Fri, Nov 21, 2008 at 11:16 AM, Benjamin schwarz
wrote:
> Well... I can't explain why, but I just changed the order of my
> includes... "et voilà" (What is the english for "c'est tombé en
> marche" ?), now it runs a lot faster and in accordance with the
> expected times.
> Still, is it possible to choose the subdivision scheme ?
> I don't know if the dependance on includes order is a normal behavior,
> if not, here is a hint to solve the problem :
> My actual includes
> #include <CGAL/Exact_predicates_inexact_constructions_kernel.h>
> #include <CGAL/Skin_surface_3.h>
> #include <CGAL/Polyhedron_incremental_builder_3.h>
> #include <CGAL/Polyhedron_3.h>
> #include <CGAL/mesh_skin_surface_3.h>
> #include <CGAL/subdivide_skin_surface_mesh_3.h>
> #include <CGAL/IO/Geomview_stream.h>
> #include <CGAL/IO/Polyhedron_geomview_ostream.h>
> #include <CGAL/Timer.h>
> #include <list>
> #include <iostream>
> #include <fstream>
> my former includes :
> #include "skin_surface_writer.h"
> #include <list>
> #include <iostream>
> #include <fstream>
>> -DNDEBUG is important for performances.
> I already had a bad experience with that a long time ago ;)
>> Try -O3 instead of -O2.
> Ok, I'll try that
>> That one is correct too. -O2 is useless here.
> right.
> Thanks Laurent
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
