- To:
- Subject: Re: [cgal-discuss] skin surfaces : subdivision is *very* slow, is
- Date: Sun, 23 Nov 2008 11:04:26 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version :content-type:content-transfer-encoding:content-disposition :references; b=oC0ufXp0+da2enB9bVwJCLguzdvhaqSIdn59WswHg4g57HdVIZkyua/gkwA1fbeJcE +V77F3BgClwmJpYPBMNkcszSlfHpdVC2+oRMsO4i6ngQncOHH8tZxcMV0eC3CcMC/tLC 8OV5Xl0jSYTI9Lb7jx4IUInBjGUMqDYXSn3XU=
Hi Sylvain,
I didn't know about the assertion categorization. I'll check the
assertions and move some of them to the expensive set.
Nico
On Fri, Nov 21, 2008 at 11:25 AM, Sylvain Pion
wrote:
> Benjamin schwarz wrote:
>> Well... I can't explain why, but I just changed the order of my
>> includes... "et voilà " (What is the english for "c'est tombé en
>> marche" ?), now it runs a lot faster and in accordance with the
>> expected times.
>> Still, is it possible to choose the subdivision scheme ?
>> I don't know if the dependance on includes order is a normal behavior,
>> if not, here is a hint to solve the problem :
>> My actual includes
>> #include <CGAL/Exact_predicates_inexact_constructions_kernel.h>
>> #include <CGAL/Skin_surface_3.h>
>> #include <CGAL/Polyhedron_incremental_builder_3.h>
>> #include <CGAL/Polyhedron_3.h>
>> #include <CGAL/mesh_skin_surface_3.h>
>> #include <CGAL/subdivide_skin_surface_mesh_3.h>
>> #include <CGAL/IO/Geomview_stream.h>
>> #include <CGAL/IO/Polyhedron_geomview_ostream.h>
>> #include <CGAL/Timer.h>
>> #include <list>
>> #include <iostream>
>> #include <fstream>
>> my former includes :
>> #include "skin_surface_writer.h"
>> #include <list>
>> #include <iostream>
>> #include <fstream>
> This one is probably for Nico.
>>> -DNDEBUG is important for performances.
>> I already had a bad experience with that a long time ago ;)
> Note that NDEBUG is not supposed to dramatically improve performance.
> The difference is supposed to be around 20% maximum, and at the maximum
> one order of magnitude. If you notice more than that, please report it.
> CGAL has several categories of assertions, and the costly ones should
> not be activated by default (CGAL_CHECK_EXPENSIVE enables those).
> So there might be some errors in the categorization.
> Sylvain Pion
> INRIA Sophia-Antipolis
> Geometrica Project-Team
> CGAL, http://cgal.org/
- [cgal-discuss] skin surfaces : subdivision is *very* slow, is this normal ?, Benjamin schwarz, 11/21/2008
- Re: [cgal-discuss] skin surfaces : subdivision is *very* slow, is, Sylvain Pion, 11/21/2008
- Re: [cgal-discuss] skin surfaces : subdivision is *very* slow, is, Benjamin schwarz, 11/21/2008
- Re: [cgal-discuss] skin surfaces : subdivision is *very* slow, is, Nico Kruithof, 11/23/2008
- Re: [cgal-discuss] skin surfaces : subdivision is *very* slow, is this normal ?, Laurent Rineau, 11/21/2008
- Re: [cgal-discuss] skin surfaces : subdivision is *very* slow, is this normal ?, Benjamin schwarz, 11/21/2008
- Re: [cgal-discuss] skin surfaces : subdivision is *very* slow, is this normal ?, Nico Kruithof, 11/23/2008
- Re: [cgal-discuss] skin surfaces : subdivision is *very* slow, is this normal ?, Benjamin schwarz, 11/23/2008
- Re: [cgal-discuss] skin surfaces : subdivision is *very* slow, is this normal ?, Nico Kruithof, 11/30/2008
