cgal-discuss - Re: [cgal-discuss] skin surfaces : subdivision is *very* slow, is this normal ?
  • To:
  • Subject: Re: [cgal-discuss] skin surfaces : subdivision is *very* slow, is this normal ?
  • Date: Sun, 23 Nov 2008 12:10:47 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version :content-type:content-transfer-encoding:content-disposition :references; b=nErb6GFjCJ9PrJR/DH8yQrvV9NaR/41rTvznDDiS4+FP8qJFnDLwhoKpafmu5GOpXm eRxfZZdtxZV4p5MkZm6VRL5xNzQvMC7omLV9iTNhQde+VRnrK4JQjj9O/63lcKkFx6ua MgnXbAAHRp9G8WkbGAbEkG8pk3R9uHbLQUHm8=
You should have the version with the reduced memory usage. Note that
the subdivision takes exponentially more memory. With every additional
subdivision step you have 4 times as many triangles in your mesh.
-- Nico
On Sun, Nov 23, 2008 at 11:39 AM, Benjamin schwarz
wrote:
> Hello Nico,
> and thanks for the answer.
>> point, the algorithm was extremely fast, but also used a lot of
>> memory. How much memory do you have? In the latest public release
>> there is a better tradeoff between cpu times and memory consumption.
> for a 28 atoms molecule, with the "good" insertion order I have times
> in accordance with those you give in the cgal manual : 0.7s for the
> third subdivision.
> For a 1600 atoms protein, two subdivisions are OK, but the third one
> induces my computer to swap and lagg, and ultimately I have to kill
> the process. I only have 1Go mem and run greedy softs in the meantime
> (Eclipse, firefox). Anyway, two subdivisions are enough for me at the
> moment, and since you said the memory management is best in the newer
> versions...
>> In the meantime I switched to industry and have a deadline on tuesday.
>> After that I'll have a look. At one
> Good luck with that.
> Let me know if you can't reproduce the problem with the includes order.
> cheers
> --Ben
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
