- To:
- Subject: Re: [cgal-discuss] Convex_hull_d performance
- Date: Mon, 24 Nov 2008 17:43:16 +0100
It also depends on what you want to do with the convex hull. Do you really need the hull explicitly, or do you for example just need to test whether some other point is inside the hull? The latter task can be done much faster, by using CGAL's QP_solver; get back to me for details if this is what you need.
Best,
Bernd.
wrote:
Dear all,
I am using CGAL::Convex_hull_d to compute the convex hull of a small set of
points in some n-dimensional space. Here, small means 2*n points, where n is
the number of dimensions of the space (3 <= n <= 6). Unfortunately, compute
the
convex hull is the bottleneck of my implementation. Actually, the program
spends 87% of the time calling CGAL::Convex_hull_d.insert().
Today, my implementation takes several minutes to process simple data sets and
I want to make it run faster. My question is: There is some trick that I can
use to improve CGAL’s performance assuming a small number of input points? I
believe that the bottleneck inside CGAL is memory allocation.-- You are currently subscribed to cgal-discuss.
- [cgal-discuss] Convex_hull_d performance, laffernandes, 11/24/2008
- Re: [cgal-discuss] Convex_hull_d performance, Bernd Gaertner, 11/24/2008
- Re: Re: [cgal-discuss] Convex_hull_d performance, laffernandes, 11/24/2008
- Re: [cgal-discuss] Convex_hull_d performance, Camille Wormser, 11/24/2008
- RE: [cgal-discuss] Convex_hull_d performance, pgoeleven, 11/24/2008
- Re: [cgal-discuss] Convex_hull_d performance, Leandro Augusto Frata Fernandes, 11/24/2008
