cgal-discuss - RE: [cgal-discuss] Convex_hull_d performance
  • To: cgal <>
  • Subject: RE: [cgal-discuss] Convex_hull_d performance
  • Date: Mon, 24 Nov 2008 20:40:52 +0000
  • Importance: Normal
I should warn you though that qhull isn't exactly user friendly. It's not designed to be used as an API as far as I know, just as an executable.
If you do find a proper way to use it, directly in code or any other convex hull program that's quick and has decent output, please drop me a line, thanks.
> Date: Mon, 24 Nov 2008 16:54:44 -0300
> From:
> To:
> Subject: Re: [cgal-discuss] Convex_hull_d performance
> Thank you!
> I will try qhull. :-)
> On Mon, Nov 24, 2008 at 3:44 PM, <> wrote:
> > I had the same issue. I needed to compute the convex hull of a set of points
> > on a sphere.
> > This may not work for you, but I ended up using the triangulation routine
> > after which I only consider infinite cells.
> > I can't quote exact numbers, but the convex hull algorithm performed very
> > poorly on my machine (in the order of hundreds of ms for perhaps 100
> > points?). I tried qhull, which did the same number of points in mere
> > milliseconds.
> > The triangulation takes about 20ms for 50-100 points and what's more, it
> > supports insertion as well as deletion of points.
> >> To:
> >> From:
> >> Date: Mon, 24 Nov 2008 17:31:19 +0100
> >> Subject: [cgal-discuss] Convex_hull_d performance
> >> Dear all,
> >> I am using CGAL::Convex_hull_d to compute the convex hull of a small set
> >> of
> >> points in some n-dimensional space. Here, small means 2*n points, where n
> >> is
> >> the number of dimensions of the space (3 <= n <= 6). Unfortunately,
> >> compute the
> >> convex hull is the bottleneck of my implementation. Actually, the program
> >> spends 87% of the time calling CGAL::Convex_hull_d.insert().
> >> Today, my implementation takes several minutes to process simple data sets
> >> and
> >> I want to make it run faster. My question is: There is some trick that I
> >> can
> >> use to improve CGAL's performance assuming a small number of input points?
> >> I
> >> believe that the bottleneck inside CGAL is memory allocation.--
> >> You are currently subscribed to cgal-discuss.
> >> To unsubscribe or access the archives, go to
> >> https://lists-sop.inria.fr/wws/info/cgal-discuss
> > ________________________________
> > Vanaf nu heb je je vrienden overal bij! Messenger voor Mobile
> Leandro Augusto Frata Fernandes
> http://www.inf.ufrgs.br/~laffernandes
> Porto Alegre - RS
> "A computer lets you make more mistakes faster than any invention in
> human history - with the possible exceptions of handguns and tequila"
De nieuwe Hotmail maakt je leven nog makkelijker Wees er als eerste bij.
