cgal-discuss - Re: [cgal-discuss] Convex_hull_d performance
  • To:
  • Subject: Re: [cgal-discuss] Convex_hull_d performance
  • Date: Mon, 24 Nov 2008 18:22:32 +0100
I believe that the bottleneck inside CGAL is memory allocation.--
In fact, the bottleneck is due to Convex_hull_d storing constructed hyperplanes (also inside the convex hull, for locating points easily), which means
1) that an exact number type is needed for robustness
2) that the size of the datastructure explodes because of storing all these coefficients (one hyperplane, hence d+1 coefficients, per simplex, and an exploding number of simplices in the dimension) in an exact number type, whose size explodes too.
So it is not really memory allocation, but memory size, which is the problem.
There is currently work being done on algorithms in higher dimensions. So you may see improvements in this area in the not too distant future...
Camille
