cgal-discuss - Re: [cgal-discuss] Convex_hull_d performance
  • To:
  • Subject: Re: [cgal-discuss] Convex_hull_d performance
  • Date: Mon, 24 Nov 2008 16:54:44 -0300
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version :content-type:content-transfer-encoding:content-disposition :references; b=xs0lA4a0QeMxuKcJkKNBPsX1ZNVpiKJoCHr2W+HPwVO6wQfoftmOIIuAmdB2b+SUPz TWqtuKt9XQS6opQcrKQkV//WvKOPlXMwcERMyRcKYn6NWTvHNE2qLrsCctmHqS5UViQz FPxA0tuiqCh82aalHnWSd+7vUZ20yaoZ5ISzE=
Thank you!
I will try qhull. :-)
On Mon, Nov 24, 2008 at 3:44 PM,
wrote:
> I had the same issue. I needed to compute the convex hull of a set of points
> on a sphere.
> This may not work for you, but I ended up using the triangulation routine
> after which I only consider infinite cells.
> I can't quote exact numbers, but the convex hull algorithm performed very
> poorly on my machine (in the order of hundreds of ms for perhaps 100
> points?). I tried qhull, which did the same number of points in mere
> milliseconds.
> The triangulation takes about 20ms for 50-100 points and what's more, it
> supports insertion as well as deletion of points.
>> To:
>> From:
>> Date: Mon, 24 Nov 2008 17:31:19 +0100
>> Subject: [cgal-discuss] Convex_hull_d performance
>> Dear all,
>> I am using CGAL::Convex_hull_d to compute the convex hull of a small set
>> of
>> points in some n-dimensional space. Here, small means 2*n points, where n
>> is
>> the number of dimensions of the space (3 <= n <= 6). Unfortunately,
>> compute the
>> convex hull is the bottleneck of my implementation. Actually, the program
>> spends 87% of the time calling CGAL::Convex_hull_d.insert().
>> Today, my implementation takes several minutes to process simple data sets
>> and
>> I want to make it run faster. My question is: There is some trick that I
>> can
>> use to improve CGAL's performance assuming a small number of input points?
>> I
>> believe that the bottleneck inside CGAL is memory allocation.--
>> You are currently subscribed to cgal-discuss.
>> To unsubscribe or access the archives, go to
>> https://lists-sop.inria.fr/wws/info/cgal-discuss
> ________________________________
> Vanaf nu heb je je vrienden overal bij! Messenger voor Mobile
Leandro Augusto Frata Fernandes
http://www.inf.ufrgs.br/~laffernandes
Porto Alegre - RS
"A computer lets you make more mistakes faster than any invention in
human history - with the possible exceptions of handguns and tequila"
