- To:
- Subject: Re: Re: Re: RE: Re: [cgal-discuss] Nef Polyhedron no simple to OFF
- Date: Thu, 18 Dec 2008 11:30:05 -0500 (EST)
- Importance: Normal
> When I make the difference of two meshes, it takes a long time. Is
> possible to
> optimize the time?
> The difference of two balls with 3000 triangles is about five minutes...
Are you using an Extended kernel, because this is not necessary in your
case, and something like Exact_predicates_exact_constructions_kernel would
be much faster.
Also are you including the time required to construct the input Nefs? If
you're building them with something like OFF_to_nef_3 expect it to be very
slow. You're better off reading the OFF into a Polyhedron_3 and converting
that to a Nef.
Fred
- Re: [cgal-discuss] A problem with iso oriented box intersection package, (continued)
- Re: [cgal-discuss] A problem with iso oriented box intersection package, Pierre Alliez, 12/10/2008
- Re : [cgal-discuss] A problem with iso oriented box intersection package, BBB HHH, 12/11/2008
- Re: [cgal-discuss] A problem with iso oriented box intersection package, Andreas Fabri, 12/10/2008
- Re : [cgal-discuss] A problem with iso oriented box intersection package, BBB HHH, 12/10/2008
- Re: Re: [cgal-discuss] Nef Polyhedron no simple to OFF, jona_100, 12/10/2008
- RE: Re: [cgal-discuss] Nef Polyhedron no simple to OFF, Fred Dorosh, 12/10/2008
- Re: RE: Re: [cgal-discuss] Nef Polyhedron no simple to OFF, jona_100, 12/11/2008
- Re: RE: Re: [cgal-discuss] Nef Polyhedron no simple to OFF, dekosser, 12/11/2008
- Re: Re: RE: Re: [cgal-discuss] Nef Polyhedron no simple to OFF, jona_100, 12/17/2008
- Re: Re: Re: RE: Re: [cgal-discuss] Nef Polyhedron no simple to OFF, jona_100, 12/18/2008
- Re: Re: Re: RE: Re: [cgal-discuss] Nef Polyhedron no simple to OFF, dekosser, 12/18/2008
- Re: [cgal-discuss] Nef Polyhedron no simple to OFF, Laurent Rineau (GeometryFactory), 12/18/2008
- Re: [cgal-discuss] Nef Polyhedron no simple to OFF, Pierre Alliez, 12/18/2008
- Re: Re: [cgal-discuss] Nef Polyhedron no simple to OFF, jona_100, 12/19/2008
- Re: [cgal-discuss] Nef Polyhedron no simple to OFF, Pierre Alliez, 12/19/2008
- Re: Re: Re: [cgal-discuss] Nef Polyhedron no simple to OFF, jona_100, 12/19/2008
- Re: [cgal-discuss] Nef Polyhedron no simple to OFF, Laurent Rineau (GeometryFactory), 12/19/2008
- Re: Re: [cgal-discuss] Nef Polyhedron no simple to OFF, jona_100, 12/22/2008
- Re: Re: Re: [cgal-discuss] Nef Polyhedron no simple to OFF, jona_100, 12/24/2008
- Re: [cgal-discuss] Nef Polyhedron no simple to OFF, Pierre Alliez, 12/24/2008
- Re: Re: [cgal-discuss] Nef Polyhedron no simple to OFF, jona_100, 12/24/2008
