cgal-discuss - Re: Re: [cgal-discuss] Nef Polyhedron no simple to OFF
  • To:
  • Subject: Re: Re: [cgal-discuss] Nef Polyhedron no simple to OFF
  • Date: Fri, 19 Dec 2008 09:56:38 +0100 (CET)
I'm using a Cartesian Kernel. I have been trying to test with
Exact_predicates_exact_constructions_kernel in this code, but it gives me some
errors that I haven't could solucionate yet.
That's my code:
//The head:
typedef CGAL::Cartesian<CGAL::Gmpq> Kernel;
typedef CGAL::Polyhedron_3<Kernel> Polyhedron;
typedef CGAL::Nef_polyhedron_3<Kernel> Nef_polyhedron;
//The functions:
bool SaveOFF( char* filename, Polyhedron &aux )
const char* name = "cout";
ostream* p_out = &cout;
ofstream out;
out.open( filename );
p_out = &out;
name = filename;
if ( !*p_out ) return false;
CGAL::set_ascii_mode( *p_out );
(*p_out ) << aux;
return true;
bool ReadOFF( char* filename, Polyhedron &P )
const char* name = "cin";
istream* p_in = &cin;
ifstream in;
in.open( filename);
p_in = &in;
name = filename;
if ( !*p_in ) return false;
(*p_in ) >> P;
return true;
//typedef Nef2Mesh<Kernel,Nef_polyhedron> MyNef2Mesh;
void TEST3()
FILE *fich1,*fich2;
Polyhedron P1,P2,SOL1;
ReadOFF( "c:\\temp\\diff1.off", P1 );
Nef_polyhedron N1( P1 );
ReadOFF( "c:\\temp\\diff2.off", P2 );
Nef_polyhedron N2( P2 );
Nef_polyhedron N_sol;
clock_t times[ 10 ];
times[ 0 ] = clock( );
N_sol = N1 - N2;
times[ 1 ] = clock( );
cout << "La diferencia ha durado: " << ( float )( times[ 1 ] - times[ 0
] ) / CLOCKS_PER_SEC << endl;
fich1 = fopen( "c:\\temp\\caja1.off" ,"w" );
if(N_sol.is_simple()) {
N_sol.convert_to_Polyhedron( SOL1 );
else {
fstream fs("c:\\temp\\caja1.off", ios::in | ios::out |
ios::trunc);
fs << N_sol;
fs.close();
SaveOFF( "c:\\temp\\solution2.off", SOL1 );
//The main:
int main( int argc, char **argv)
TEST3( );
getchar( );
return 0;
And here we are the two balls:
OFF
1627 3250 0
-386.887 150.288 -13.2468
-383.348 147.95 -15.9947
-385.68 144.401 -14.2008
-388.514 146.81 -11.908
-400.378 143.309 5.11721
-400.691 148.499 5.60586
-399.15 148.38 2.06703
-401.87 145.944 8.9095
-400.948 149.166 39.6836
-400.762 144.832 40.1094
-399.197 148.66 43.7863
-399.129 145.134 43.8635
-388.643 147.423 57.8135
-385.758 144.298 60.1324
-386.234 148.36 59.8172
-383.063 147.646 62.1938
-379.109 145.047 64.4889
-378.449 148.838 64.8509
-370.527 145.999 -22.0489
-369.58 149.792 -22.2462
-366.82 146.701 -22.9855
-387.808 142.32 -12.2988
-391.006 146.883 -9.56544
-393.97 143.428 -5.92109
-393.998 147.888 -6.06821
-396.799 147.138 -2.11039
-398.37 143.121 0.865172
-402.603 143.194 12.1474
-402.748 146.836 12.0449
-403.327 142.719 15.885
-403.573 146.983 16.2609
-403.809 144.069 19.7682
-403.984 147.054 20.66
-403.887 143.255 23.0736
-404.025 146.941 23.7702
-403.736 143.637 27.2688
-403.844 147.164 27.4315
-403.047 144.453 32.4303
-403.161 146.736 32.1873
-401.918 145.198 36.8746
-396.831 145.274 48.016
-394.342 144.671 51.5013
-393.984 147.641 52.1123
-391.236 143.738 55.1189
-390.895 147.502 55.605
-375.07 146.207 66.4434
-363.251 144.621 69.5673
-358.428 147.043 70.0588
-362.291 148.787 69.6935
-381 144.184 -17.403
-396.086 141.537 -2.59681
-401.473 142.295 8.4286
-397.3 141.255 46.6302
-388.23 143.231 57.9656
-403.435 140.208 19.7177
-402.674 139.431 31.5472
-403.213 139.048 27.2386
-401.672 139.638 35.9058
-400.535 140.699 39.7121
-399.221 141.051 42.877
-394.059 140.251 51.2714
-382 142.26 62.5993
-366.648 143.23 -22.9018
-363.573 146.829 -23.5789
-390.597 141.271 -9.42091
-402.213 139.899 12.1648
-400.499 137.683 7.52484
-403.388 139.113 23.1785
-366.958 148.908 68.9849
-367.9 144.552 68.7254
-371.546 142.942 -21.5541
-374.811 146.043 -20.534
-393.169 139.411 -6.15304
-397.451 139.306 0.263241
-398.768 137.674 3.39784
-402.77 138.627 16.1059
-390.416 139.99 55.3671
-372.534 143.556 67.2635
-371.699 147.383 67.6751
-374.395 141.503 -20.3606
-377.441 145.51 -19.3651
-380.546 140.641 -17.2272
-383.418 141.017 -15.4436
-387.768 140.111 57.9008
-385.447 140.834 59.9313
-376.988 140.853 65.1897
-395.914 136.531 -1.35784
-401.607 136.656 12.2318
-402.259 136.134 16.1025
-402.608 136.006 19.7723
-398.535 137.357 42.8377
-399.626 136.713 40.0001
-396.486 137.417 46.7662
-377.229 139.96 -18.9021
-385.376 138.633 -13.5814
-389.012 136.708 -9.96591
-402.645 135.675 23.1257
-402.122 134.26 27.2074
-401.55 134.397 31.409
-400.764 135.113 35.5854
-391.968 135.889 52.4688
-389.654 136.704 55.2717
-384.178 138.01 60.3363
-381.26 138.863 62.4566
-381.742 135.837 -15.465
-391.351 133.959 -6.4374
-393.918 134.024 -3.16681
-399.098 132.536 7.62034
-396.743 132.411 2.39965
-400.297 132.277 11.8513
-401.172 132.262 16.1561
-401.459 132.009 19.5202
-401.605 132.015 22.6595
-399.164 133.047 38.4871
-397.865 132.779 41.5029
-396.637 133.37 44.3837
-394.313 134.172 48.6383
-386.784 136.707 57.9144
-369.704 140.809 67.8743
-400.72 130.106 27.206
-400.065 130.005 31.3966
-399.664 131.17 34.8886
-372.555 139.102 66.7056
-385.231 134.712 -12.568
-389.093 132.973 54.4018
-360.639 146.244 -23.8941
-362.432 142.364 -23.4911
-379.303 136.225 -16.9972
-399.414 128.048 15.4625
-399.805 127.83 19.4299
-399.541 126.81 22.5865
-398 129.407 37.9053
-393.843 130.027 46.8749
-391.704 131.919 50.9409
-386.531 133.273 56.9408
-383.447 134.188 59.7668
-379.671 135.838 62.6859
-376.837 137.076 64.4933
-369.729 139.629 -21.7087
-387.597 132.111 -9.47978
-393.294 129.546 -1.32287
-395.237 129.227 2.17949
-395.853 127.652 4.77084
-397.271 127.419 8.53947
-398.084 127.148 11.4598
-398.699 125.741 28.1374
-398.247 126.883 33.4156
-395.974 128.867 42.1306
-365.224 140.77 68.9013
-391.18 129.946 -4.42546
-372.864 137.078 -20.1716
-384.119 131.758 -12.3179
-389.039 128.794 -6.28239
-396.602 126.313 37.7805
-389.854 127.836 50.7146
-387.917 129.575 53.9186
-364.173 139.574 -22.9114
-375.748 136.15 -18.7393
-392.529 125.859 0.534116
-397.955 124.623 16.9442
-394.249 125.778 42.3637
-392.901 127.856 46.653
-390.792 126.782 -2.71228
-396.447 122.961 14.1606
-384.77 129.931 56.9055
-381.613 129.113 58.9153
-379.209 132.333 61.8118
-359.914 142.838 69.761
-394.732 123.808 7.14525
-395.657 123.103 10.8807
-397.047 122.424 21.0826
-395.725 120.425 19.5383
-397.029 122.36 24.9803
-396.283 123.26 33.3591
-396.276 121.847 29.0773
-393.682 123.152 40.3333
-358.818 142.941 -23.8251
-376.818 132.213 -17.0363
-379.511 131.025 -15.1163
-381.873 129.496 -12.8742
-385.991 128.429 -9.04334
-393.099 124.103 3.41689
-394.304 122.094 37.1748
-391.674 123.528 44.4572
-390.46 124.911 47.5914
-371.807 135.531 66.1788
-375.796 134.244 64.1764
-372.598 133.28 -19.2311
-383.383 127.568 -10.7369
-385.477 125.188 -7.45407
-388.402 124.36 -3.74789
-389.16 121.793 -0.394115
-391.506 121.68 3.48486
-392.916 121.056 7.14732
-394.062 120.429 11.4113
-394.705 119.898 15.5526
-395.478 119.991 24.81
-394.225 120.023 33.0395
-394.35 119.07 29.1216
-387.512 123.619 50.1256
-386.48 125.408 52.5924
-383.896 126.381 55.6524
-367.749 137.378 67.7728
-392.076 118.183 35.4491
-391.051 119.596 40.4301
-389.836 120.634 43.9658
-388.242 121.42 47.1293
-378.687 128.97 60.6355
-372.483 131.874 64.786
-368.647 135.456 -21.0892
-391.794 117.457 11.5444
-392.873 117.486 15.5997
-393.182 117.05 20.1022
-393.209 116.993 24.8724
-375.17 129.866 62.8764
-365.818 137.205 -22.1466
-379.116 127.258 -13.5148
-381.637 125.209 -10.6446
-384.579 120.57 -4.51963
-389.504 119.407 3.17121
-390.942 118.625 7.01299
-391.778 116.075 29.9769
-383.458 123.304 53.8722
-385.353 120.627 49.7349
-382.627 121.722 -7.30856
-379.072 124.288 57.8382
-372.242 130.202 -18.2194
-375.655 128.338 -15.9333
-385.323 118.782 -1.79115
-385.921 117.042 1.05653
-388.336 116.794 5.15913
-388.808 114.75 10.1378
-390.257 114.626 15.3275
-390.74 114.364 19.5073
-390.24 113.733 25.2573
-389.276 114.965 35.2405
-388.14 115.927 39.7399
-386.859 117.586 44.4485
-375.012 126.182 61.1735
-361.223 139.678 69.2883
-357.024 146.017 -24.0172
-376.598 124.863 -13.5996
-378.965 122.68 -10.7863
-386.18 114.547 5.4126
-389.299 113.502 29.9191
-382.784 119.206 50.8599
-379.877 120.147 54.1618
-387.511 111.169 22.0969
-383.519 116.424 47.0129
-387.297 112.076 14.4101
-387.106 111.256 17.543
-367.464 133.281 66.7812
-368.286 131.199 -19.8516
-372.492 126.246 -16.3077
-378.179 119.169 -8.46791
-379.689 117.192 -5.51234
-381.981 115.341 -1.30938
-385.509 111.756 10.3617
-386.321 110.373 26.451
-386.014 110.531 29.6907
-386.5 112.346 35.0422
-385.223 113.26 39.6355
-384.323 114.305 42.9037
-370.63 129.82 64.6218
-363.046 135.775 68.3238
-382.754 112.869 3.36467
-383.298 111.952 5.84439
-380.327 117.083 50.8138
-376.79 121.29 57.0462
-374.452 122.805 59.3877
-372.131 126.65 62.6039
-384.141 109.437 14.8741
-364.578 132.144 -21.0205
-374.392 122.94 -13.4801
-375.943 120.642 -11.0254
-384.296 108.886 19.1758
-384.263 108.67 22.8603
-384.155 110.186 33.8786
-383.038 110.87 38.1551
-382.13 112.261 42.3604
-380.912 114.173 46.7729
-362.664 135.134 -22.1791
-383.126 110.075 10.0771
-377.379 115.856 51.8338
-374.598 118.376 55.9608
-359.463 138.658 -23.2467
-367.334 128.002 -18.8067
-376.445 116.165 -6.71434
-378.784 113.289 -1.54505
-378.669 110.482 2.65535
-382.394 107.619 27.2664
-381.202 107.516 31.4151
-380.407 108.256 35.919
-370.723 123.245 -15.2017
-371.531 119.672 -12.4765
-373.957 117.54 -9.51559
-379.537 108.762 7.2962
-380.358 107.705 11.8565
-380.846 107.027 16.0647
-381.031 106.704 19.6406
-381.092 106.584 22.8475
-379.452 109.406 40.2195
-378.537 111.18 44.6153
-376.627 112.708 48.5457
-370.567 123.358 61.326
-367.7 125.288 63.3796
-366.644 128.76 65.2782
-375.968 112.917 -3.30875
-371.181 119.999 58.8367
-373.427 114.444 -6.72528
-376.647 110.85 0.213493
-378.483 105.313 26.7858
-364.361 130.929 66.597
-367.562 125.092 -17.2609
-372.942 113.631 52.1365
-372.875 111.092 -2.95829
-376.408 107.05 7.43892
-377.167 106.021 11.7758
-377.586 105.277 15.9709
-377.797 104.951 19.7577
-377.874 104.845 23.0473
-377.467 105.376 30.9614
-377.185 106.475 35.8114
-376.388 108.053 40.9602
-373.702 109.42 45.9084
-366.348 120.983 -15.0979
-369.68 115.321 -9.41194
-373.187 109.262 0.0313025
-373.779 107.826 3.03652
-372.533 110.816 48.733
-370.372 115.759 55.5824
-367.539 121.951 61.3896
-367.71 117.995 -12.4725
-373.735 105.836 7.50631
-374.021 104.426 12.4127
-373.048 102.979 18.1015
-373.66 102.968 23.2387
-373.832 103.21 26.9448
-373.611 103.641 30.7712
-374.207 105.1 35.7705
-373.743 106.424 39.9054
-372.26 107.133 42.7754
-367.922 118.862 59.0707
-362.073 128.268 -19.8571
-364.615 124.386 -17.5609
-369.125 112.206 -6.30054
-362.443 125.799 64.6785
-369.036 109.487 -2.68204
-369.585 107.825 0.209909
-370.046 106.381 3.20746
-370.292 104.9 6.72545
-370.892 103.76 10.7604
-370.823 102.867 14.4474
-371.016 103.899 35.6652
-369.714 104.887 39.7164
-368.74 107.658 45.9891
-368.533 109.325 48.7131
-367.545 111.6 52.2015
-367.419 114.841 55.6976
-364.731 116.501 58.0058
-356.306 140.471 69.5967
-359.543 131.656 -21.3966
-363.802 119.53 60.6058
-362.759 122.231 62.5842
-361.408 129.609 66.4793
-359.706 132.441 67.6652
-357.685 136.437 68.8394
-357.875 134.175 -22.2614
-363.668 117.473 -13.0096
-368.968 101.581 20.4763
-368.806 101.489 24.8267
-368.759 102.03 30.5034
-368.053 105.85 42.9154
-360.481 124.596 -18.2282
-361.474 121.353 -16.1855
-364.696 114.094 -9.75838
-364.733 110.313 -5.49325
-365.238 107.065 -0.533789
-367.06 105.496 3.29452
-367.436 104.142 6.65942
-367.716 102.88 10.7247
-366.585 101.722 14.3884
-366.826 101.108 19.1951
-366.141 102.63 35.8152
-363.735 113.806 55.6466
-355.608 144.289 69.9434
-359.171 127.931 -19.9458
-360.075 119.326 -14.9565
-363.468 103.058 7.38855
-365.584 100.765 24.7776
-365.552 101.258 30.1357
-365.146 103.532 38.9783
-365.183 104.882 42.2886
-365.227 106.665 45.7247
-364.802 108.641 49.0747
-363.397 111.032 52.6356
-359.938 114.381 -10.8113
-363.267 104.693 3.38273
-362.804 101.845 11.0192
-357.792 128.596 66.3162
-361.327 108.352 -3.4864
-361.44 106.303 46.2328
-361.35 104.59 42.8875
-360.175 108.526 49.9276
-359.228 116.535 -12.7611
-360.565 111.474 -7.64305
-359.734 105.932 0.210853
-362.293 100.785 16.01
-361.446 100.152 21.1377
-360.605 100.144 25.5021
-361.643 100.633 29.5924
-361.263 101.483 34.1203
-361.204 102.169 36.6379
-361.355 103.217 39.6813
-359.926 111.303 53.5509
-359.856 115.26 57.6041
-359.973 118.408 60.2404
-359.474 121.473 62.4118
-357.827 124.198 64.1514
-356.447 139.163 -23.3888
-355.618 122.238 -17.0219
-357.938 108.262 -3.70333
-357.933 103.545 4.85814
-359.261 100.55 15.8491
-357.495 100.469 30.0694
-354.781 133.528 68.0419
-354.338 143.158 -23.8213
-355.613 130.142 -20.904
-357.039 111.014 -7.31199
-357.792 102.216 8.62304
-358.779 101.311 12.0226
-355.291 126.459 -19.3179
-356.98 100.073 19.8944
-355.285 100.565 15.4708
-357.744 101.265 33.919
-357.019 102.069 36.8851
-357.36 103.327 40.5075
-357.759 105.127 44.372
-355.65 107.272 48.2369
-355.361 114.103 56.6724
-356.72 118.464 60.4205
-355.747 122.016 62.8297
-354.952 117.994 -14.0079
-354.726 114.285 -10.7856
-355.048 106.422 -0.7623
-355.232 104.801 2.29562
-354.41 101.558 11.0635
-355.941 99.9737 24.5939
-354.541 110.573 52.7415
-352.972 101.41 34.0067
-353.73 105.214 44.4069
-354.397 109.095 -4.71203
-352.18 102.607 8.12418
-353.017 103.585 5.37803
-352.535 100.296 19.4461
-352.583 100.129 24.1675
-352.833 100.609 29.7804
-352.685 102.635 38.1153
-353.048 103.98 41.6333
-354.014 134.881 -22.3789
-352.46 111.369 -7.38326
-352.75 118.574 60.2799
-354.199 126.268 65.1641
-350.768 108.743 -3.69946
-350.588 106.399 0.0880191
-350.275 105.194 2.4707
-350.895 101.055 14.8774
-351.18 107.969 48.6461
-351.882 120.056 -15.209
-349.379 104.09 5.30127
-350.34 101.943 11.351
-351.475 122.477 62.7652
-352.472 131.051 67.0425
-353.961 137.341 68.9256
-350.694 124.793 -18.0454
-350.275 116.991 -12.6136
-350.329 114.023 -9.85265
-348.678 100.848 19.4142
-348.783 100.663 24.0363
-349.061 101.187 30.3664
-347.226 102.786 35.9178
-348.4 104.184 40.5506
-349.046 105.832 44.3233
-349.107 111.404 52.7576
-350.348 113.187 55.0033
-350.217 115.835 57.5957
-348.935 112.179 -7.59858
-346.63 103.136 9.40178
-346.727 101.743 15.0468
-351.416 130.226 -20.6126
-344.708 101.704 26.4824
-344.597 102.224 30.6076
-346.932 107.809 46.9858
-347.318 109.621 49.9176
-350.491 126.889 65.0608
-352.379 139.342 -23.1913
-347.143 110.137 -4.48549
-346.618 108.063 -1.26919
-346.011 106.343 2.06755
-344.802 105.248 5.03875
-344.991 101.609 20.1849
-344.277 101.718 23.4292
-348.498 119.701 60.3806
-348.246 120.724 -15.0274
-346.978 115.364 -10.3283
-343.624 105.153 39.8422
-343.773 106.664 43.368
-345.962 115.581 56.2968
-345.942 118.247 -12.5733
-344.53 113.107 -7.18788
-343.335 102.588 15.4609
-342.934 104.105 9.67654
-343.682 111.236 -4.49313
-343.428 109.238 -1.57841
-341.947 107.399 2.49271
-340.238 103.094 20.5134
-342.599 104.067 35.771
-341.57 103.454 31.8091
-343.186 108.974 47.0061
-344.598 112.916 52.9425
-346.849 123.991 62.7742
-348.373 126.691 -18.5418
-340.279 103.682 15.2804
-339.912 103.176 24.1091
-339.103 103.79 28.495
-341.572 111.498 49.8057
-349.722 133.844 -21.5894
-339.618 106.539 6.4393
-339.959 105.008 10.3499
-345.566 123.016 -15.8504
-341.819 116.513 -9.48884
-338.88 104.943 33.7113
-338.869 106.211 37.9272
-339.494 107.558 41.7287
-345.318 120.194 59.8694
-350.23 135.431 68.096
-342.466 120.289 -12.917
-339.848 111.652 -2.849
-339.104 110.096 -0.0596179
-338.309 109.878 45.1199
-341.486 115.057 53.8744
-347.193 130.33 -19.8697
-340.567 113.771 -5.94593
-337.26 108.927 3.64728
-336.614 106.48 10.4684
-336.292 105.634 14.3687
-335.918 105.154 18.4909
-336.772 104.539 23.6896
-342.264 117.849 56.8261
-347.214 130.142 65.8365
-348.063 133.306 67.1035
-344.203 127.278 -17.7746
-335.256 106.023 30.9007
-336.176 106.429 34.4496
-345.175 128.192 64.4912
-352.193 141.536 69.4843
-348.676 137.367 -22.3172
-335.279 108.241 7.54353
-334.005 105.984 22.1038
-334.169 106.008 26.4586
-335.416 107.916 37.8257
-336.378 109.141 41.7956
-337.873 112.671 48.8574
-338.32 115.563 52.6055
-341.951 120.947 59.1555
-338.349 119.335 56.2079
-342.417 123.534 61.0808
-337.802 114.809 -5.47855
-335.107 112.281 -0.116591
-349.672 138.094 68.6137
-339.019 119.618 -10.7603
-331.967 109.298 10.0354
-331.862 108.224 14.0715
-332.483 107.316 17.0647
-331.617 108.782 33.6084
-344.975 134.393 -20.7124
-341.081 124.604 -15.1929
-337.27 118.063 -8.3865
-333.352 110.38 5.34794
-331.42 107.568 20.9646
-330.584 108.099 24.9121
-331.543 107.951 29.2667
-332.38 109.945 38.3848
-332.653 111.81 42.5863
-335.182 112.175 45.851
-335.583 114.129 48.9601
-342.699 126.829 63.0146
-338.02 122.901 -12.7024
-333.165 117.878 -5.31759
-333.927 115.453 -3.14478
-329.644 109.013 18.2336
-332.477 113.676 45.3989
-335.607 117.483 52.7559
-338.175 123.325 59.0548
-343.919 131.409 -19.4061
-331.171 113.349 2.66939
-329.604 112.59 6.26541
-328.243 110.131 28.3837
-334.337 121.622 -9.52054
-331.336 115.467 -0.649142
-328.096 111.813 11.0742
-327.732 111.096 14.8733
-327.513 110.385 21.1488
-329.131 113.117 40.0056
-332.319 116.405 48.8791
-342.916 132.517 65.5037
-339.983 129.632 -17.3083
-326.922 110.879 24.3806
-327.465 111.709 32.8384
-328.42 112.267 36.7181
-338.521 127.059 61.402
-325.865 112.337 16.3306
-329.546 115.31 44.3145
-332.778 119.765 52.7489
-334.669 121.763 55.8238
-340.564 129.155 63.2907
-345.173 135.873 67.1586
-336.826 127.457 -14.7786
-327.944 115.968 2.82047
-329.807 121.448 -5.69973
-328.946 118.189 -1.44104
-326.197 115.439 6.64609
-325.871 113.935 10.6664
-324.81 112.814 20.3625
-324.305 113.187 24.9219
-324.637 113.451 29.3697
-324.997 114.145 33.4979
-325.692 114.814 37.0207
-326.782 115.378 40.3606
-327.649 117.17 44.5254
-329.286 118.72 48.462
-332.834 125.962 -11.4937
-335.333 125.599 58.8639
-339.698 133.452 -18.637
-329.688 124.236 -7.84474
-323.558 116.294 10.6578
-323.072 115.573 14.41
-322.801 115.206 17.3256
-322.494 115.134 20.3144
-330.316 121.794 52.4272
-331.9 124.054 55.5094
-337.68 131.913 63.1812
-347.059 140.086 68.4835
-349.072 142.833 -23.2147
-325.775 121.703 -1.51597
-325.082 118.859 2.89714
-344.046 139.937 -21.7169
-323.54 118.418 6.35407
-321.963 115.671 24.8178
-322.354 115.807 29.1672
-322.713 116.305 32.6647
-323.444 117.35 37.4689
-324.5 119.068 42.4236
-325.227 120.868 45.7831
-326.168 123.259 49.5274
-332.394 126.868 57.6683
-334.258 130.17 60.6203
-333.111 129.201 -13.396
-323.769 121.311 1.83572
-320.699 119.555 10.9533
-320.043 119.205 14.2493
-319.886 118.523 17.8457
-320.014 117.952 22.7224
-320.276 117.812 26.4321
-320.356 118.464 30.4429
-320.8 119.059 34.0325
-328.211 124.946 52.949
-340.128 135.458 65.3993
-325.985 124.88 -4.59805
-320.802 120.5 37.1264
-322.328 121.111 41.535
-328.915 127.586 55.3713
-341.057 138.611 -20.5016
-335.13 131.636 -15.7082
-328.134 127.45 -8.61738
-321.618 121.661 5.18129
-320.507 121.155 8.43563
-318.358 120.266 20.5765
-318.059 120.966 27.3411
-322.926 123.637 45.5155
-354.134 148.015 -23.9528
-317.887 120.935 24.937
-329.632 130.324 57.4572
-329.598 130.62 -11.5369
-323.116 126.113 -2.05475
-321.788 124.67 1.15384
-318.499 121.192 31.0037
-318.083 123.146 34.4058
-319.689 124.132 40.3227
-336.054 135.306 -17.4647
-330.608 132.802 -13.2892
-319.402 124.51 5.84576
-317.527 124.472 10.7117
-316.943 123.78 14.5247
-317.254 122.472 17.4631
-318.54 123.882 37.1
-325.482 127.633 52.0563
-332.771 135.126 61.5635
-342.49 140.267 67.27
-352.051 145.735 69.7463
-324.211 128.658 -5.31524
-326.068 131.311 -8.82007
-319.731 127.945 1.46813
-315.881 124.47 19.1686
-316.146 123.707 22.1495
-316.574 124.135 30.4809
-320.361 125.588 43.2421
-323.06 126.928 48.6253
-320.819 127.967 46.2915
-334.859 137.262 63.419
-348.769 143.961 69.2125
-337.317 138.26 -18.827
-333.169 135.916 -16.0512
-315.823 124.495 26.4094
-325.896 130.28 54.085
-330.484 133.236 59.338
-321.639 129.969 -2.92428
-317.699 127.392 6.10281
-315.925 126.594 33.3812
-316.435 127.439 36.6141
-317.577 127.877 40.1469
-318.797 128.406 43.1511
-322.397 130.647 50.3917
-338.953 139.371 65.7574
-350.76 146.474 -23.6156
-326.989 134.506 -11.0021
-323.608 131.485 -6.2479
-315.245 129.155 10.6438
-314.539 128.829 13.9344
-314.005 128.281 18.653
-313.949 127.98 23.1191
-313.926 128.508 27.1103
-314.229 128.724 30.2512
-324.635 133.145 54.2057
-327.039 134.064 56.8739
-318.769 131.073 45.278
-329.084 136.93 -13.5065
-320.507 133.529 -3.50091
-318.367 132.624 0.278054
-316.68 131.574 4.26323
-315.729 130.398 7.74529
-314.618 129.797 33.934
-320.04 132.359 48.1304
-328.921 136.21 59.1589
-345.275 144.116 68.4679
-323.214 135.734 -7.78862
-315.293 131.196 37.981
-316.374 132.736 42.0014
-321.249 134.737 51.0199
-329.562 140.178 60.6295
-335.481 140.813 64.3618
-336.911 142.22 -19.2768
-334.174 140.175 -17.5535
-330.822 140.551 -15.5508
-313.995 133.198 9.77837
-315.224 133.623 6.04141
-312.94 133.051 14.2338
-312.473 132.425 18.5118
-312.266 132.389 24.1704
-312.373 133.568 29.61
-313.439 132.947 33.8412
-316.992 134.551 44.3686
-318.468 135.194 47.2776
-323.11 137.561 54.3105
-326.13 139.324 57.7046
-325.195 139.691 -10.9225
-314.037 134.942 37.9417
-338.359 144.163 66.1494
-345.857 144.771 -22.6661
-340.963 144.909 -21.1997
-328.06 140.85 -13.5943
-319.839 138.104 -4.42331
-318.207 137.332 -1.79724
-315.982 136.295 2.58895
-322.001 139.685 -7.60067
-313.625 137.136 7.62099
-312.434 136.734 12.0213
-311.658 136.59 15.9978
-311.239 136.278 20.7742
-311.366 135.811 25.1286
-312.543 136.075 33.7904
-315.012 137.006 41.6825
-319.765 138.279 50.3719
-331.529 143.4 62.4412
-332.841 143.446 -17.2162
-316.179 138.762 44.8834
-317.519 139.81 47.5757
-317.094 140.529 -1.11213
-314.692 140.423 3.47241
-311.232 138.036 29.3122
-313.196 138.586 37.9743
-342.065 145.179 67.5481
-319.923 142.231 -5.59547
-312.826 140.755 7.9799
-311.743 140.378 11.9966
-310.933 140.478 15.8563
-310.536 139.79 20.722
-310.536 139.931 25.1253
-311.965 139.101 33.9904
-314.595 140.642 42.3398
-319.787 141.581 51.2997
-322.587 143.074 54.8555
-324.792 143.224 57.0886
-334.47 144.06 64.181
-338.172 146.154 -20.1057
-349.073 147.911 69.3807
-353.601 148.814 69.8888
-334.906 146.763 -18.5375
-329.161 145.163 -14.8888
-325.872 143.99 -12.1301
-322.877 144.711 -9.30941
-316.009 143.01 0.27856
-310.511 142.306 28.3918
-311.089 141.485 31.5533
-311.86 142.848 35.6485
-313.142 142.217 39.3137
-315.738 143.093 45.2191
-328.241 144.959 60.2002
-343.979 148.953 -22.1746
-320.63 146.249 -6.83387
-317.994 145.864 -3.31387
-313.839 144.975 4.35304
-312.35 144.214 8.47198
-311.125 144.976 12.6608
-310.577 143.661 16.2009
-310.198 143.856 19.7854
-310.078 143.678 23.5943
-310.774 144.82 31.4369
-314.245 146.186 42.7145
-317.21 144.9 48.0286
-319.694 146.156 51.6722
-325.589 148.04 -12.033
-310.183 145.943 27.541
-312.415 146.634 38.0345
-331.719 147.867 -16.6612
-315.822 146.383 0.299989
-311.872 147.697 9.68235
-310.355 148.281 16.9615
-310.067 146.897 19.9576
-309.962 146.933 22.9683
-311.336 147.202 34.2588
-322.492 147.574 54.9804
-324.989 147.463 57.4779
-334.422 148.642 64.2742
-344.187 149.316 68.2387
-347.467 148.758 -23.0332
-323.03 149.268 -9.46411
-313.757 148.261 4.44242
-316.031 148.811 46.042
-317.611 148.506 48.6694
-328.476 148.529 60.3707
-331.049 149.437 62.169
-339.292 148.854 66.5751
-328.388 148.537 -14.2972
-315.959 150.517 0.231107
-318.278 149.589 -3.61078
-310.784 150.422 14.734
-310.125 149.415 26.48
-310.718 148.65 31.1035
-340.39 149.765 -20.9274
-336.482 149.807 -19.2316
-320.949 149.737 -7.06829
-310.19 151.21 20.5094
-311.754 151.572 35.2006
-313.157 149.935 39.7514
-314.816 152.343 43.1854
-320.326 150.423 52.2857
-326.388 151.228 58.4882
-312.898 151.76 7.29539
-311.806 152.053 10.985
-310.824 151.801 30.5456
-330.634 151.303 -15.7011
-327.84 151.822 -13.6023
-318.56 152.597 -3.57215
-314.568 151.947 3.34511
-310.338 152.915 23.583
-310.841 154.513 28.3333
-313.438 153.298 39.6278
-316.078 152.655 45.4913
-317.82 151.68 48.5807
-323.625 153.135 55.6362
-333.867 151.437 -17.7129
-324.268 152.352 -10.3605
-321.235 153.036 -6.95324
-311.214 155.234 15.7172
-328.517 152.398 60.0303
-316.594 155.189 0.359514
-315.141 155.471 3.26596
-313.656 155.505 6.78408
-312.32 155.182 10.7962
-310.845 155.694 20.5134
-311.005 156.706 25.237
-311.843 155.325 33.2381
-318.87 155.1 49.3943
-321.563 154.359 53.0632
-339.551 152.651 -20.3175
-312.932 155.816 36.8076
-332.562 153.472 62.7032
-336.743 152.459 65.0891
-347.247 151.025 68.8434
-332.277 153.758 -16.4263
-324.677 155.23 -10.2268
-320.772 156.582 -5.4774
-318.04 157.041 -1.386
-312.154 159.241 30.4168
-314.852 157.709 41.0698
-316.935 156.313 45.8002
-350.473 151.103 -23.4306
-337.273 154.26 -19.0937
-328.781 155.296 -13.7418
-313.028 159.315 11.5869
-313.796 159.104 8.85959
-312.177 159.654 16.2232
-311.682 159.589 20.9706
-313.312 159.039 35.6409
-326.442 156.182 57.5786
-329.523 155.532 60.207
-340.417 152.79 66.6394
-317.131 160.378 1.858
-315.569 160.86 5.43291
-317.431 159.812 44.9884
-335.347 156.576 -17.6869
-312.349 161.552 25.9308
-319.111 160.319 47.5301
-321.326 158.752 51.3411
-324.231 159.192 54.5052
-347.194 153.939 -22.5207
-343.065 153.335 -21.4681
-323.368 160.257 -7.12581
-326.346 159.711 -10.3925
-321.607 160.714 -4.83092
-319.29 160.393 -1.72283
-314.141 161.601 35.8111
-313.379 162.204 31.8433
-315.364 161.282 39.5622
-336.409 156.337 64.2617
-332.219 157.488 -15.5716
-314.451 163.071 10.894
-313.464 163.425 16.0221
-313.145 163.603 19.4598
-312.85 163.19 23.0126
-313.893 164.482 30.172
-317.185 162.363 42.7683
-327.892 159.309 57.876
-338.97 155.488 65.6061
-330.164 159.677 -13.5358
-333.199 157.057 62.3028
-313.989 166.057 22.7552
-313.901 165.521 26.2823
-315.152 164.78 35.1009
-316.868 165.041 39.6877
-319.214 163.845 45.3559
-322.783 162.993 51.0935
-344.505 153.732 67.8407
-321.441 164.254 -2.50717
-319.596 164.135 0.218928
-318.415 165.406 3.34584
-316.78 165.85 7.45556
-315.512 166.142 11.8336
-314.693 166.379 16.0162
-314.414 166.655 19.6673
-331.083 158.488 60.5082
-341.657 156.836 -20.3925
-324.773 162.916 -7.33863
-317.426 168.454 36.6771
-319.605 167.11 43.3095
-321.511 165.505 47.7708
-325.054 163.049 53.5468
-323.635 166.421 -3.95462
-315.824 169.4 27.4591
-315.917 169.914 24.0524
-316.297 169.214 30.9582
-316.25 167.819 33.8575
-327.58 163.315 55.8908
-331.392 163.075 59.101
-334.5 160.184 62.1612
-350.665 152.249 69.3149
-334.698 160.503 -16.1544
-321.448 167.677 0.151258
-317.709 169.7 10.5684
-316.533 169.644 14.9054
-316.246 170.402 20.3765
-344.049 156.273 67.2979
-339.177 158.396 -18.9894
-328.446 163.884 -10.3709
-327.446 166.474 -8.03842
-319.826 169.271 4.66227
-318.73 170.043 8.23237
-319.242 169.809 39.4049
-318.416 171.335 34.5577
-323.799 168.248 48.6719
-324.992 167.06 51.0135
-327.87 166.217 54.6143
-337.494 160.015 63.7569
-340.482 158.706 65.4618
-345.249 156.099 -21.6184
-333.497 163.091 -14.4227
-331.796 165.374 -12.2616
-318.209 172.915 16.9975
-322.924 170.003 45.8637
-337.354 162.128 -17.0063
-322.263 171.339 2.65599
-318.514 174.031 25.0223
-318.925 173.766 29.9707
-321.8 171.642 42.166
-325.877 170.043 -3.7372
-323.713 170.845 -0.121959
-322.063 173.137 5.40258
-320.978 173.61 8.56827
-319.498 173.544 12.8293
-318.811 174.341 20.4001
-349.252 155.033 68.7091
-321.104 175.353 34.0332
-321.703 174.268 38.0019
-327.719 170.961 50.9974
-325.79 171.759 48.0032
-332.375 167.913 57.1963
-334.794 165.346 60.213
-337.256 163.438 62.4033
-341.527 162.381 -18.7198
-329.629 171.176 -6.70913
-321.478 177.216 16.4673
-336.243 166.172 -14.6177
-331.246 169.32 -9.41723
-328.012 173.633 -2.78467
-326.342 174.458 0.158675
-325.604 175.466 2.52677
-321.892 176.32 12.0736
-321.554 177.801 20.0644
-321.467 177.855 23.0728
-321.786 178.005 26.7999
-320.969 176.426 30.0596
-324.573 175.318 41.9713
-324.526 173.292 44.5658
-330.014 169.387 54.3533
-340.583 162.589 64.2401
-324.055 176.818 7.45369
-324.206 177.245 37.9721
-325.988 175.292 44.1915
-327.926 174.923 47.304
-343.237 160.933 65.7625
-344.945 160.031 -20.5594
-334.702 168.96 -12.1198
-324.781 179.481 12.0087
-324.564 179.775 32.6105
-331.917 172.065 53.9621
-335.555 170.212 57.8729
-348.416 158.37 67.8284
-337.667 167.015 60.9147
-341.784 167.187 62.7366
-354.111 152.984 -23.5772
-339.629 166.831 -15.9864
-334.061 172.915 -8.90302
-327.055 179.697 7.15663
-324.74 180.574 16.1942
-324.595 180.929 19.8708
-324.442 180.945 22.9583
-324.879 181.15 27.098
-326.639 178.226 40.7659
-328.736 178.311 43.8205
-330.808 175.245 49.988
-346.4 160.937 66.6822
-349.063 158.588 -21.9173
-331.608 175.779 -4.25567
-330.361 178.405 0.19536
-329.546 179.582 2.95968
-326.872 180.471 36.5925
-338.303 171.363 -12.7003
-330.234 181.672 40.2688
-334.091 176.77 51.3561
-327.693 182.117 12.0641
-329.792 183.231 10.294
-326.88 182.48 16.0898
-326.941 183.077 20.3266
-328.427 184.391 24.8217
-331.178 177.997 47.1793
-335.49 174.714 54.3732
-354.19 153.674 69.491
-352.374 155.653 -23.0062
-347.477 163.608 -20.0131
-334.009 176.645 -5.35909
-328.013 183.406 29.869
-329.596 183.346 35.083
-339.022 170.775 59.4043
-343.94 167.19 -17.4699
-331.417 180.325 44.1469
-339.086 174.217 56.9568
-344.57 164.707 64.7649
-342.865 170.132 -15.4447
-337.217 175.429 -8.86605
-334.088 179.037 -2.69716
-331.135 182.916 7.05469
-330.063 184.593 14.4074
-329.984 185.393 19.4524
-334.354 179.561 48.3134
-334.183 181.287 0.277507
-334.175 183.169 3.34226
-331.169 185.729 29.9291
-334.472 181.917 45.11
-337.611 179.289 -5.20907
-357.651 149.814 -23.9582
-341.313 174.683 -11.6581
-340.953 177.833 -8.75143
-337.098 181.01 -2.68726
-334.154 184.785 6.75711
-334.239 186.208 10.3575
-333.463 186.731 13.8535
-332.525 187.029 19.1381
-332.974 187.437 24.8022
-333.805 186.379 34.2176
-334.23 185.368 37.9788
-334.7 183.801 42.024
-337.67 179.09 51.4362
-338.915 177.101 54.3043
-342.947 171.914 60.3486
-352.522 157.307 68.6725
-342.207 173.968 58.585
-351.52 160.45 -21.7767
-348.907 166.719 -18.9505
-343.7 173.399 -13.5859
-338.04 183.658 0.406915
-334.456 187.716 29.9289
-338.025 181.377 48.8981
-346.275 170.655 62.265
-348.001 164.208 65.8256
-348.177 167.766 64.2985
-350.847 161.083 67.4627
-341.156 183.17 -2.59559
-338.326 185.327 3.13871
-337.792 186.831 6.92419
-336.584 189.115 18.2075
-336.432 189.306 22.0025
-336.695 189.312 26.1614
-337.794 185.611 41.7658
-337.619 187.201 37.898
-338.61 184.117 45.3058
-341.945 180.277 52.6945
-343.418 177.977 55.7168
-358.477 150.955 69.8769
-348.266 169.783 -17.2304
-347.143 172.819 -15.1218
-341.434 180.761 -5.81963
-337.815 188.237 11.0041
-337.562 189.013 14.602
-337.551 189.248 30.0914
-337.811 188.532 33.9121
-341.503 183.095 48.9174
-346.442 177.115 -11.6092
-347.075 175.601 59.0761
-341.208 185.009 0.241449
-341.548 187.347 4.32516
-340.681 191.117 24.9849
-340.554 187.801 39.639
-341.008 186.641 42.618
-341.464 185.428 45.2106
-351.669 165.29 66.0171
-346.439 179.52 -9.35383
-344.434 181.744 -6.13719
-342.354 189.346 8.56525
-342.282 190.701 13.4434
-341.433 191.019 17.1436
-340.091 190.817 20.6125
-341.18 190.818 29.7529
-341.459 190.095 33.7118
-342.02 189.472 36.6411
-352.827 164.924 -20.2872
-346.556 184.821 -3.02189
-344.126 186.549 0.972702
-342.529 191.672 20.3024
-343.666 188.497 40.7271
-344.539 186.798 44.728
-344.875 185.25 47.5383
-346.373 183.219 51.1269
-347.532 180.956 54.178
-346.552 178.865 55.9715
-354.961 162.19 67.5252
-352.549 169.776 -17.9557
-350.11 171.903 62.312
-346.596 189.02 4.5499
-345.169 192.522 23.1704
-344.834 192.306 26.3113
-344.59 191.87 29.7497
-345.265 191.199 33.9871
-352.783 168.702 64.531
-355.756 156.78 -22.9825
-355.787 161.056 -21.9053
-351.64 173.666 -15.3859
-351.338 176.089 -13.5408
-348.773 182.566 -6.66661
-347.372 187.013 0.231617
-346.536 190.816 9.40929
-346.826 192.06 14.0831
-345.816 192.469 18.4021
-348.173 192.303 32.0702
-347.106 190.262 38.6791
-348.001 188.274 43.7714
-348.17 186.175 47.495
-350.021 179.036 56.7144
-356.558 157.92 68.7641
-352.045 176.572 59.2544
-352.428 173.036 61.9499
-350.991 178.583 -11.3238
-351.721 181.86 -8.17319
-350.646 189.171 3.1415
-349.175 190.004 5.6607
-349.666 193.432 20.7095
-348.601 193.248 25.1274
-348.122 192.792 29.0425
-348.926 191.526 35.8546
-349.958 184.91 49.9072
-351.428 185.408 -3.62725
-350.908 187.702 0.207658
-350.425 191.875 10.3526
-350.801 193.155 16.1091
-351.293 183.223 52.4557
-353.256 181.893 54.368
-354.045 179.376 -10.9881
-351.41 190.398 40.2969
-351.514 188.505 44.4522
-352.708 186.857 47.6382
-354.351 179.092 57.3079
-356.701 165.953 -20.0923
-353.36 191.234 7.31991
-351.362 193.666 24.9
-351.516 193.239 29.7183
-353.274 192.417 34.8785
-354.408 185.015 50.6031
-356.122 166.546 65.7714
-358.817 154.599 69.4097
-356.659 170.573 -17.7281
-355.317 172.914 -16.1925
-355.335 176.262 -13.816
-354.576 184.836 -4.85143
-358.678 152.953 -23.6469
-356.311 182.473 -7.9314
-355.763 186.882 -1.91775
-355.244 188.007 -0.0102846
-355.748 189.607 3.03683
-354.682 192.741 12.2692
-354.702 193.954 20.5844
-354.719 193.925 25.4623
-354.366 193.497 29.8188
-355.068 190.731 40.2858
-354.919 188.947 44.204
-355.639 176.209 59.8322
-357.419 173.581 61.8573
-355.865 169.836 64.0894
-355.53 193.505 16.0853
-360.114 158.266 -22.6207
-357.052 179.61 -10.8805
-356.958 190.931 6.20414
-357.675 192.481 10.9184
-358.34 191.996 36.7129
-357.725 187.002 47.7933
-357.367 182.93 53.3506
-357.802 180.813 55.6813
-360.076 174.278 -15.2545
-358.798 185.615 -3.82688
-359.087 193.517 16.0784
-358.511 193.98 20.7656
-357.766 193.953 25.5181
-357.875 193.554 29.7287
-358.914 192.723 33.9586
-358.74 189.243 43.6132
-358.786 177.462 -12.7842
-360.489 188.179 0.483188
-358.543 190.803 40.0457
-360.475 184.821 50.8097
-359.884 177.717 58.5631
-359.765 169.225 64.3927
-359.231 165.085 66.372
-362.027 179.888 -10.3065
-360.243 182.515 -7.71739
-360.991 190.022 4.3311
-359.691 191.691 8.63317
-361.432 193.781 25.5585
-361.907 193.764 21.0844
-361.267 193.4 29.6013
-361.134 167.51 -19.1638
-360.042 171.382 -17.0966
-362.973 192.386 12.0211
-362.632 190.43 40.2622
-361.06 187.515 46.5417
-360.999 181.623 54.6251
-359.652 163.591 -20.9252
-362.623 185.652 -3.26505
-363.888 190.863 7.38837
-363.741 193.022 15.9177
-363.666 192.269 33.9544
-363.404 191.559 36.6489
-363.027 188.69 43.9491
-361.706 173.046 61.9268
-359.506 161.029 67.8212
-362.205 176.486 -13.2529
-364.983 185.952 48.2027
-364.75 182.917 -6.39137
-365.359 187.487 0.562364
-365.5 188.789 3.14082
-365.22 193.277 20.6609
-364.827 193.308 25.4135
-365.356 192.831 29.6174
-364.58 171.188 -16.654
-365.338 178.192 -11.2328
-365.596 182.767 52.3677
-364.17 179.712 56.0513
-363.084 165.442 65.8447
-367.08 185.177 -2.59707
-368.193 189.816 6.98087
-368.079 191.054 10.7362
-368.798 191.779 14.5261
-368.893 192.193 17.4511
-369.187 192.419 21.0581
-368.022 192.672 25.3952
-367.565 191.53 33.8449
-367.423 190.431 37.8043
-366.941 188.968 41.7643
-366.677 187.522 44.8124
-364.392 176.373 58.9753
-363.195 161.367 67.4106
-361.794 157.156 68.694
-363.431 163.276 -20.6959
-365.936 174.58 -14.0797
-367.112 180.638 -8.2988
-369.166 191.876 30.2597
-363.904 168.233 64.4113
-368.639 186.489 0.272147
-369.022 187.914 3.16176
-364.99 170.914 62.7256
-366.291 167.605 -18.2884
-368.941 182.627 -5.28443
-371.81 191.589 25.5682
-371.934 191.267 28.4841
-372.472 190.282 33.1504
-371.32 189.479 37.3601
-371.077 188.075 41.1423
-369.946 186.479 45.0989
-370.078 184.079 48.8781
-368.428 180.126 54.3834
-367.059 177.924 56.9749
-366.895 173.923 60.3234
-371.876 189.929 10.8516
-371.963 188.583 6.84395
-370.128 182.076 51.4618
-370.391 180.544 -7.12724
-371.003 184.632 -1.51928
-372.968 186.385 2.80446
-373.481 190.463 15.6126
-373.42 191.046 20.8872
-369.655 176.795 -11.1701
-372.871 182.054 -4.05164
-374.507 187.7 7.19283
-375.501 188.708 11.482
-375.431 190.225 25.5194
-376.208 189.298 30.4104
-374.856 188.274 36.7283
-374.267 185.969 42.8902
-373.994 184.533 45.7178
-371.452 177.686 55.6027
-370.081 174.726 58.7028
-363.768 154.489 -22.979
-365.137 159.504 -21.6281
-369.955 169.509 -16.2533
-370.627 171.936 -14.54
-374.772 183.931 -0.121442
-376.605 189.111 15.6705
-376.808 189.593 20.2442
-376.063 188.637 33.687
-376.356 186.606 39.4834
-372.243 179.811 53.0445
-373.231 178.793 -7.66114
-375.176 181.741 49.0623
-369.491 171.309 61.2724
-368.975 169.124 62.7404
-368.003 166.42 64.4381
-366.727 163.488 -19.9643
-372.731 174.93 -11.4547
-378.012 184.733 4.23016
-378.256 186.748 9.4567
-379.733 188.234 23.1768
-379.088 188.14 28.9885
-378.178 186.699 36.7189
-367.062 163.625 65.8227
-375.659 180.959 -3.70347
-380.099 187.042 14.2056
-379.513 187.938 17.6123
-379.011 187.091 33.9753
-377.646 183.992 43.4872
-375.852 177.929 53.0531
-374.113 174.627 57.0392
-376.509 174.245 -10.0807
-376.827 177.404 -6.91602
-379.023 181.25 -0.610987
-381.252 184.689 8.62707
-382.199 186.425 18.1417
-380.954 183.925 39.6141
-377.52 179.587 49.9948
-373.094 170.747 60.3137
-371.207 164.907 -18.1401
-379.62 177.802 -4.46165
-382.421 185.015 12.0031
-384.014 185.552 22.4471
-382.598 186.274 26.829
-382.224 185.908 30.9091
-381.727 185.34 34.387
-381.681 184.598 36.766
-380.857 182.26 43.0589
-378.892 180.895 47.1755
-378.448 174.494 54.6205
-375.318 170.803 -13.2073
-382.428 181.488 3.48143
-385.224 183.903 15.4295
-373.174 165.677 63.0874
-368.132 158.947 67.1433
-366.098 156.254 68.2263
-363.046 152.756 69.2935
-369.414 161.725 -19.929
-374.224 167.245 -15.8279
-386.33 183.622 19.3789
-385.558 184.19 26.9116
-385.193 183.956 30.212
-384.76 183.317 34.1333
-384.51 182.582 36.7522
-381.36 178.783 47.744
-380.266 177.064 50.7206
-370.114 162.223 65.5424
-381.053 175.426 -5.81498
-382.247 178.584 -1.05551
-384.702 182.033 8.22607
-385.288 182.96 12.0962
-384.11 181.696 39.5198
-376.927 171.429 57.8943
-387.74 181.344 32.3711
-383.605 180.126 43.1701
-368.564 157.147 -21.4799
-385.484 179.072 3.63107
-388.464 181.991 24.0556
-385.184 177.835 44.6842
-381.095 170.281 56.0616
-376.449 168.227 60.2146
-362.247 150.581 -23.6246
-378.348 169.267 -12.5435
-380.439 172.426 -8.87252
-385.488 175.821 -1.00009
-386.966 180.163 8.30816
-387.725 180.897 12.0742
-389.321 180.673 29.0665
-387.484 180.326 36.1488
-386.237 179.673 40.0433
-389.504 180.228 15.5756
-389.475 180.831 19.4936
-384.795 175.413 48.1656
-382.843 173.689 51.902
-376.687 164.464 -16.0396
-380.732 168.13 57.7097
-382.604 169.519 -9.41995
-384.854 172.162 -5.42613
-387.948 176.376 3.22336
-389.051 177.502 7.02289
-390.968 177.247 10.891
-392.222 178.222 22.5343
-392.33 178.014 25.4281
-390.306 178.857 32.3364
-390.933 177.14 35.5975
-388.795 177.053 40.3505
-388.295 174.394 45.0048
-372.469 158.866 65.8154
-372.967 157.945 -19.9041
-373.647 161.565 -18.5075
-381.06 166.19 -12.6454
-392.492 177.602 18.5807
-386.795 172.348 49.1606
-385.188 169.922 52.8882
-378.972 164.525 60.7774
-375.537 161.427 63.7932
-388.498 172.638 -0.779376
-389.893 174.189 3.2349
-391.052 175.223 6.93509
-392.553 176.494 14.1226
-392.509 177.097 29.8385
-390.596 174.276 41.5031
-385.857 169.159 -6.79766
-367.283 152.753 68.5489
-377.422 158.189 -17.9179
-385.449 166.1 55.283
-367.824 153.387 -22.3206
-380.141 160.989 -15.5205
-385.221 166.294 -9.30383
-389.494 168.256 -3.63888
-392.252 170.91 3.00395
-391.269 170.052 0.468508
-393.593 171.727 6.70951
-393.837 173.54 10.7109
-394.569 173.872 14.1023
-395.501 173.792 18.8676
-395.827 173.618 22.615
-395.56 173.709 26.8676
-394.336 174.084 32.3189
-393.258 173.439 37.1208
-391.528 170.445 44.7185
-389.227 169.521 48.9221
-392.822 171.433 41.2336
-383.14 164.443 57.9954
-370.821 154.856 67.2782
-387.748 165.322 -7.55971
-397.242 170.452 29.8471
-387.357 166.839 52.9451
-379.231 159.398 62.578
-384.358 162.585 -12.0032
-395.87 170.577 10.9135
-396.321 171.244 14.1521
-397.433 170.605 18.2001
-396.202 170.441 34.348
-395.012 169.917 38.5901
-383.056 160.612 59.7608
-371.15 153.561 -21.3708
-393.79 165.955 0.578652
-395.129 167.025 4.01404
-396.36 167.694 7.66782
-398.553 169.093 22.6765
-398.079 169.688 26.0558
-395.294 166.885 41.7538
-394.054 166.771 44.2687
-392.176 165.695 48.0697
-389.568 164.443 52.1595
-385.713 161.32 57.4013
-377.6 157.2 64.0287
-374.747 156.11 65.5924
-398.073 168.514 15.045
-375.22 153.306 -19.9397
-387.409 161.404 -9.84515
-391.788 164.289 -3.5679
-389.651 162.239 -7.22747
-397.478 167.674 10.9262
-398.295 166.613 34.1038
-397.051 166.595 38.0092
-388.802 160.824 54.8295
-366.478 149.699 -22.9919
-383.135 158.173 -14.4744
-385.902 159.184 -12.0479
-399.86 164.782 15.0208
-399.611 166.541 19.1556
-400.066 165.676 26.2404
-399.562 165.938 29.7146
-381.049 156.437 -16.2945
-397.112 163.386 4.66264
-398.077 164.005 7.65066
-398.922 164.376 10.5894
-391.933 161.62 50.8862
-381.803 156.257 61.9188
-374.401 151.647 66.4985
-392.919 161.858 -3.53752
-395.382 162.335 0.538937
-400.593 164.67 22.9006
-398.301 163.831 37.9715
-397.086 163.177 41.5318
-395.795 162.903 44.2997
-394.046 162.064 47.776
-379.288 153.945 -17.8462
-389.832 156.685 -9.31918
-390.523 159.782 -7.41472
-401.433 162.158 19.8865
-400.119 163.103 32.8147
-386.52 156.311 58.477
-377.967 153.614 64.5895
-385.158 154.982 -13.8567
-388.055 155.574 -11.2807
-393.109 157.195 -5.41467
-395.635 159.046 -1.00844
-398 160.326 4.13595
-400.063 159.616 8.77005
-400.907 159.917 12.0575
-401.464 160.738 16.0523
-401.859 161.161 22.9837
-401.639 161.245 27.4256
-399.477 160.703 37.8939
-397.937 160.21 42.0704
-396.468 158.541 45.8635
-394.142 158.495 49.5026
-391.736 157.283 53.0272
-389.519 156.531 55.6278
-371.214 150.866 67.6568
-374.449 149.57 -20.6478
-401.474 158.785 33.069
-382.769 152.945 -15.895
-381.101 152.03 63.0812
-396.35 154.734 -1.66668
-398.023 156.828 2.20657
-399.659 155.925 5.26155
-402.222 158.048 16.2149
-402.62 157.958 19.7949
-402.77 157.848 22.8994
-402.466 158.319 27.2727
-400.334 157.552 37.9803
-398.844 156.866 42.1158
-384.578 152.123 60.7879
-395.155 154.285 49.6141
-379.733 149.956 -18.1061
-393.615 152.935 -5.9574
-391 151.789 -9.20496
-401.131 154.527 8.51543
-401.951 155.321 11.9338
-402.538 155.429 14.8452
-403.087 155.389 27.4086
-402.586 155.453 30.8518
-397.598 153.583 45.8687
-391.875 152.385 54.1469
-388.909 151.755 57.2728
-398.661 153.618 2.21601
-403.357 153.977 18.8708
-403.312 155.16 23.0672
-402.19 153.766 34.1854
-401.209 153.861 37.5944
-399.558 153.326 42.0784
-397.432 151.545 -0.580888
-400.241 152.095 5.23315
-402.614 151.29 12.2476
-403.117 151.454 14.86
-403.82 151.7 23.7623
-403.64 151.068 27.7352
-403.145 151.203 31.1911
-394.186 150.918 51.5336
-395.851 149.815 -3.36406
-401.688 150.152 8.68258
-403.55 150.334 17.2922
-403.855 150.055 20.3228
-402.206 149.847 35.6907
-396.706 149.462 48.0986
3 0 1 2
3 2 3 0
3 4 5 6
3 7 5 4
3 8 9 10
3 11 10 9
3 12 13 14
3 15 14 13
3 16 17 15
3 18 19 20
3 21 3 2
3 22 3 21
3 23 24 22
3 24 23 25
3 6 25 26
3 6 26 4
3 27 28 7
3 29 30 28
3 27 29 28
3 31 32 30
3 30 29 31
3 33 32 31
3 33 34 32
3 35 36 34
3 33 35 34
3 37 38 36
3 36 35 37
3 39 38 37
3 39 9 8
3 40 41 42
3 42 41 43
3 43 44 42
3 12 44 43
3 45 17 16
3 46 47 48
3 1 49 2
3 23 50 25
3 50 26 25
3 4 51 7
3 7 51 27
3 40 11 52
3 53 12 43
3 12 53 13
3 29 54 31
3 33 31 54
3 55 37 35
3 35 56 55
3 37 55 57
3 57 39 37
3 58 9 39
3 57 58 39
3 11 9 59
3 58 59 9
3 11 59 52
3 40 52 60
3 60 41 40
3 41 60 43
3 13 61 15
3 61 16 15
3 62 20 63
3 21 64 22
3 23 22 64
3 65 27 51
3 51 66 65
3 29 27 65
3 54 67 33
3 56 35 33
3 33 67 56
3 68 69 46
3 62 18 20
3 18 70 71
3 72 23 64
3 23 72 50
3 26 50 73
3 26 73 74
3 4 26 74
3 74 66 4
3 66 51 4
3 65 75 29
3 54 29 75
3 43 76 53
3 45 77 78
3 78 77 69
3 70 79 71
3 80 71 79
3 49 81 82
3 49 82 2
3 21 2 82
3 76 43 60
3 83 53 76
3 13 53 84
3 53 83 84
3 61 13 84
3 85 16 61
3 45 16 85
3 85 77 45
3 72 86 50
3 86 73 50
3 66 87 65
3 88 75 65
3 87 88 65
3 89 54 75
3 75 88 89
3 67 54 89
3 90 59 58
3 58 91 90
3 92 52 59
3 59 90 92
3 60 52 92
3 79 93 80
3 49 80 93
3 93 81 49
3 94 21 82
3 64 21 95
3 72 64 95
3 74 73 86
3 89 96 67
3 97 56 67
3 67 96 97
3 55 56 98
3 56 97 98
3 99 57 55
3 55 98 99
3 91 58 57
3 57 99 91
3 60 100 76
3 70 18 62
3 21 94 95
3 100 101 76
3 84 102 61
3 102 103 61
3 81 104 82
3 95 105 72
3 105 106 72
3 106 86 72
3 107 66 74
3 74 108 107
3 87 66 109
3 66 107 109
3 110 88 87
3 109 110 87
3 111 89 88
3 88 110 111
3 112 96 89
3 111 112 89
3 112 97 96
3 99 113 91
3 114 91 113
3 114 90 91
3 90 114 115
3 90 115 92
3 92 116 60
3 100 60 116
3 76 101 83
3 117 83 101
3 102 84 83
3 83 117 102
3 77 118 69
3 104 94 82
3 108 74 86
3 85 61 103
3 119 97 112
3 98 97 120
3 97 119 120
3 99 98 121
3 98 120 121
3 113 99 121
3 116 92 115
3 85 122 77
3 122 118 77
3 104 123 94
3 123 95 94
3 86 106 108
3 100 124 101
3 63 125 126
3 62 63 126
3 127 81 93
3 81 127 104
3 128 110 109
3 111 110 129
3 110 128 129
3 112 111 130
3 111 129 130
3 112 130 119
3 131 113 121
3 114 113 131
3 132 116 115
3 100 116 133
3 124 134 101
3 117 101 134
3 135 102 117
3 136 103 102
3 137 85 103
3 136 137 103
3 138 70 62
3 79 70 138
3 95 123 139
3 95 139 105
3 108 106 140
3 140 141 108
3 108 141 142
3 107 108 142
3 142 143 107
3 107 143 144
3 109 107 144
3 144 128 109
3 120 119 145
3 120 146 121
3 131 121 146
3 147 114 131
3 115 114 147
3 147 132 115
3 132 133 116
3 124 100 133
3 135 117 134
3 135 136 102
3 46 69 148
3 106 105 149
3 140 106 149
3 145 119 130
3 85 137 122
3 138 150 79
3 93 79 150
3 151 123 104
3 139 152 105
3 152 149 105
3 146 153 131
3 131 153 147
3 132 154 133
3 154 155 133
3 155 124 133
3 126 156 62
3 157 93 150
3 127 93 157
3 139 123 151
3 158 141 140
3 142 141 158
3 159 128 144
3 129 128 159
3 130 129 159
3 146 120 145
3 160 147 153
3 161 132 147
3 160 161 147
3 132 161 154
3 124 155 134
3 140 149 162
3 144 163 159
3 155 164 134
3 135 134 164
3 135 165 166
3 166 136 135
3 46 167 47
3 149 152 162
3 158 140 162
3 142 168 143
3 168 169 143
3 144 143 169
3 144 169 163
3 170 130 159
3 171 170 159
3 170 172 130
3 130 172 145
3 173 146 145
3 145 174 173
3 146 173 153
3 175 160 153
3 125 176 126
3 177 127 157
3 104 127 178
3 177 178 127
3 104 178 151
3 178 179 151
3 139 151 180
3 180 152 139
3 158 181 142
3 168 142 181
3 163 171 159
3 145 172 174
3 182 153 173
3 153 182 175
3 160 183 161
3 183 184 161
3 161 184 154
3 164 165 135
3 185 122 137
3 137 186 185
3 137 136 186
3 166 186 136
3 62 156 138
3 150 187 157
3 157 187 177
3 151 179 188
3 188 180 151
3 152 180 189
3 190 152 189
3 162 152 190
3 191 158 162
3 162 190 191
3 192 181 158
3 191 192 158
3 193 168 181
3 192 193 181
3 194 169 168
3 168 193 194
3 163 169 194
3 195 163 194
3 171 163 195
3 196 172 170
3 171 196 170
3 172 196 174
3 197 173 174
3 174 198 197
3 173 197 182
3 183 160 175
3 184 199 154
3 154 199 200
3 155 154 200
3 200 201 155
3 201 164 155
3 189 180 188
3 198 174 196
3 165 164 201
3 202 118 122
3 185 202 122
3 69 118 148
3 203 182 197
3 203 204 182
3 175 182 204
3 205 183 175
3 204 205 175
3 206 184 183
3 183 205 206
3 199 184 206
3 165 207 166
3 208 185 186
3 202 148 118
3 138 209 150
3 210 194 193
3 211 195 194
3 194 210 211
3 212 171 195
3 211 212 195
3 213 196 171
3 171 212 213
3 196 213 198
3 166 214 186
3 208 186 214
3 156 215 138
3 138 215 209
3 178 216 179
3 217 188 179
3 179 216 217
3 188 217 189
3 218 190 189
3 191 190 218
3 191 219 192
3 220 193 192
3 192 219 220
3 193 220 210
3 221 198 213
3 197 198 221
3 203 197 221
3 222 200 199
3 199 223 222
3 222 201 200
3 187 150 209
3 224 189 217
3 189 224 218
3 165 225 207
3 166 207 214
3 187 226 177
3 227 178 177
3 216 178 227
3 218 228 191
3 191 228 229
3 219 191 229
3 230 219 229
3 230 220 219
3 220 230 231
3 210 220 231
3 210 232 211
3 233 212 211
3 211 232 233
3 234 213 212
3 212 233 234
3 213 234 221
3 235 203 221
3 236 204 203
3 203 235 236
3 237 205 204
3 236 237 204
3 205 237 206
3 223 199 206
3 201 222 225
3 225 165 201
3 223 206 237
3 207 238 214
3 148 239 46
3 176 125 240
3 227 177 226
3 241 216 227
3 242 217 216
3 216 241 242
3 224 217 242
3 243 230 229
3 210 231 232
3 234 244 221
3 235 221 244
3 223 245 222
3 246 222 245
3 246 225 222
3 239 167 46
3 233 247 234
3 237 248 223
3 248 245 223
3 225 238 207
3 231 230 243
3 231 249 232
3 233 232 250
3 249 250 232
3 233 250 247
3 185 251 202
3 252 187 209
3 226 253 227
3 227 253 241
3 242 254 224
3 255 224 254
3 218 224 255
3 255 256 218
3 256 228 218
3 229 228 256
3 257 231 243
3 231 257 249
3 247 258 234
3 259 244 234
3 234 258 259
3 260 235 244
3 244 259 260
3 236 235 261
3 235 260 261
3 262 237 236
3 236 261 262
3 237 262 248
3 185 208 251
3 208 263 251
3 264 239 148
3 226 187 252
3 229 256 265
3 243 229 265
3 243 265 266
3 243 266 257
3 267 245 248
3 246 245 267
3 268 225 246
3 225 268 269
3 225 269 238
3 238 270 214
3 263 208 214
3 270 263 214
3 202 251 264
3 148 202 264
3 257 271 249
3 271 250 249
3 209 215 272
3 272 252 209
3 273 241 253
3 242 241 274
3 241 273 274
3 254 242 274
3 250 271 275
3 247 250 275
3 276 247 275
3 258 247 276
3 259 277 260
3 260 277 278
3 278 261 260
3 278 279 261
3 279 262 261
3 280 248 262
3 262 279 280
3 248 280 267
3 215 281 272
3 282 257 266
3 257 282 271
3 283 267 280
3 246 267 283
3 283 284 246
3 284 268 246
3 156 126 285
3 156 281 215
3 252 286 226
3 254 287 255
3 288 256 255
3 256 288 289
3 265 256 289
3 290 258 276
3 259 258 290
3 290 291 259
3 259 291 277
3 292 277 291
3 292 278 277
3 269 268 284
3 253 226 286
3 253 293 273
3 294 273 293
3 294 274 273
3 294 295 274
3 254 274 295
3 287 254 295
3 296 266 265
3 289 296 265
3 296 282 266
3 282 296 297
3 282 297 271
3 297 298 271
3 271 298 275
3 299 275 298
3 300 276 275
3 275 299 300
3 276 300 290
3 278 292 301
3 301 279 278
3 302 279 301
3 302 280 279
3 280 302 303
3 303 283 280
3 304 270 238
3 305 270 304
3 305 263 270
3 305 306 263
3 263 306 251
3 255 287 307
3 307 288 255
3 308 269 284
3 238 269 304
3 295 309 287
3 288 307 310
3 289 288 310
3 300 311 290
3 291 290 311
3 304 269 308
3 306 312 251
3 251 312 264
3 286 313 253
3 293 253 313
3 287 309 307
3 314 283 303
3 283 314 284
3 176 285 126
3 286 252 272
3 315 307 309
3 316 296 289
3 297 296 317
3 296 316 317
3 318 298 297
3 297 317 318
3 299 298 319
3 298 318 319
3 300 299 320
3 319 320 299
3 311 300 320
3 311 321 291
3 322 292 291
3 291 321 322
3 323 301 292
3 292 322 323
3 302 301 323
3 302 323 324
3 302 324 303
3 325 293 313
3 294 293 325
3 326 295 294
3 326 309 295
3 327 310 307
3 315 327 307
3 289 310 328
3 310 327 328
3 289 328 316
3 324 329 303
3 314 303 329
3 314 330 284
3 284 330 308
3 308 331 304
3 305 304 331
3 332 294 325
3 333 316 328
3 334 317 316
3 316 333 334
3 318 317 334
3 335 318 334
3 335 319 318
3 336 320 319
3 335 336 319
3 337 311 320
3 336 337 320
3 338 321 311
3 337 338 311
3 339 322 321
3 321 338 339
3 340 323 322
3 322 339 340
3 323 340 341
3 323 341 324
3 330 342 308
3 281 156 285
3 343 286 272
3 344 313 286
3 325 313 344
3 326 294 332
3 326 345 309
3 345 315 309
3 308 342 331
3 346 306 305
3 343 344 286
3 315 345 347
3 327 315 348
3 315 347 348
3 328 327 349
3 327 348 349
3 350 333 328
3 328 349 350
3 333 350 351
3 333 351 334
3 334 352 335
3 338 353 339
3 354 340 339
3 339 353 354
3 341 340 354
3 341 355 324
3 356 329 324
3 355 356 324
3 357 314 329
3 356 357 329
3 314 357 330
3 357 358 330
3 359 342 330
3 330 358 359
3 312 306 346
3 239 360 167
3 272 281 361
3 343 272 361
3 334 351 352
3 359 362 342
3 362 331 342
3 363 305 331
3 362 363 331
3 305 363 346
3 364 312 346
3 365 264 312
3 312 364 365
3 366 239 264
3 367 281 285
3 368 332 325
3 335 369 336
3 370 336 369
3 370 337 336
3 337 370 371
3 371 338 337
3 338 371 353
3 354 372 341
3 355 341 372
3 367 361 281
3 343 373 344
3 344 374 325
3 332 368 375
3 326 332 375
3 326 375 345
3 376 345 375
3 345 376 347
3 376 377 347
3 377 348 347
3 378 349 348
3 348 377 378
3 379 350 349
3 349 378 379
3 351 350 380
3 350 379 380
3 381 352 351
3 351 380 381
3 335 352 382
3 381 382 352
3 382 369 335
3 383 353 371
3 354 353 383
3 384 358 357
3 358 384 359
3 47 167 385
3 366 360 239
3 386 343 361
3 373 374 344
3 325 374 387
3 368 325 387
3 379 388 380
3 389 370 369
3 369 382 389
3 390 371 370
3 370 389 390
3 371 390 383
3 383 391 354
3 354 391 392
3 354 392 372
3 393 355 372
3 372 392 393
3 394 356 355
3 355 393 394
3 356 394 357
3 395 357 394
3 357 395 384
3 264 365 366
3 396 375 368
3 377 397 378
3 388 379 378
3 397 388 378
3 388 398 380
3 398 381 380
3 346 399 364
3 376 400 377
3 401 393 392
3 392 402 401
3 393 401 394
3 401 403 394
3 394 403 395
3 360 385 167
3 343 386 373
3 387 404 368
3 396 368 404
3 396 405 375
3 405 376 375
3 397 377 406
3 407 381 398
3 407 382 381
3 407 408 382
3 382 408 389
3 408 409 389
3 410 390 389
3 409 410 389
3 390 410 411
3 383 390 411
3 411 412 383
3 413 391 383
3 383 412 413
3 392 391 413
3 392 413 402
3 414 395 403
3 414 384 395
3 414 415 384
3 359 384 415
3 416 362 359
3 415 416 359
3 417 363 362
3 362 416 417
3 346 363 418
3 363 417 418
3 399 365 364
3 419 285 176
3 285 419 367
3 376 405 400
3 377 400 406
3 373 420 374
3 387 374 420
3 400 421 406
3 422 397 406
3 422 388 397
3 423 407 398
3 408 407 423
3 410 424 411
3 399 346 418
3 425 366 365
3 426 419 176
3 386 361 427
3 428 405 396
3 421 400 405
3 405 428 421
3 422 429 388
3 398 388 429
3 430 398 429
3 398 430 423
3 427 361 367
3 431 386 427
3 373 386 431
3 373 431 420
3 432 408 423
3 423 433 432
3 424 410 409
3 424 434 411
3 412 411 435
3 411 434 435
3 436 413 412
3 435 436 412
3 402 413 436
3 436 437 402
3 401 402 437
3 401 437 438
3 438 403 401
3 439 415 414
3 440 416 415
3 439 440 415
3 416 440 417
3 440 441 417
3 417 441 418
3 399 425 365
3 404 387 442
3 396 404 443
3 442 443 404
3 406 421 444
3 422 406 445
3 406 444 445
3 429 446 430
3 446 433 430
3 433 423 430
3 408 432 447
3 447 409 408
3 424 409 447
3 448 414 403
3 403 438 448
3 448 439 414
3 420 442 387
3 396 443 428
3 449 434 424
3 434 449 435
3 450 437 436
3 437 450 438
3 451 421 428
3 444 421 451
3 429 422 452
3 422 453 452
3 452 446 429
3 433 454 432
3 455 447 432
3 432 454 455
3 456 424 447
3 447 455 456
3 424 456 449
3 449 457 435
3 457 436 435
3 457 458 436
3 436 458 450
3 419 459 367
3 428 443 460
3 451 428 460
3 422 445 453
3 440 461 441
3 418 462 399
3 426 176 240
3 463 451 460
3 463 444 451
3 444 463 464
3 445 444 465
3 444 464 465
3 453 445 465
3 466 433 446
3 433 466 454
3 438 450 467
3 461 440 439
3 367 459 427
3 468 442 420
3 465 469 453
3 452 453 469
3 470 446 452
3 466 446 470
3 438 467 448
3 461 471 441
3 418 441 462
3 399 462 472
3 399 472 425
3 425 473 366
3 473 360 366
3 474 420 431
3 442 475 443
3 475 476 443
3 443 476 460
3 477 454 466
3 478 455 454
3 454 477 478
3 479 456 455
3 455 478 479
3 449 456 479
3 480 449 479
3 480 457 449
3 481 457 480
3 481 458 457
3 450 458 482
3 458 481 482
3 467 450 482
3 483 448 467
3 484 439 448
3 483 484 448
3 484 485 439
3 439 485 461
3 471 462 441
3 475 442 468
3 486 460 476
3 463 460 486
3 487 452 469
3 487 470 452
3 488 466 470
3 470 487 488
3 466 488 477
3 431 427 489
3 468 420 474
3 478 490 479
3 490 491 479
3 482 492 467
3 492 493 467
3 467 493 483
3 462 494 472
3 419 495 459
3 489 427 459
3 486 496 463
3 463 496 497
3 463 497 464
3 464 497 498
3 465 464 498
3 499 469 465
3 498 499 465
3 487 469 499
3 488 500 477
3 478 477 500
3 501 478 500
3 478 501 490
3 479 491 480
3 461 502 471
3 494 462 471
3 474 503 468
3 503 475 468
3 504 476 475
3 486 476 504
3 480 505 481
3 505 506 481
3 482 481 506
3 506 492 482
3 507 485 484
3 502 461 485
3 474 431 489
3 475 508 504
3 486 509 496
3 510 488 487
3 487 511 510
3 488 510 500
3 507 484 483
3 508 475 503
3 509 512 496
3 513 497 496
3 512 513 496
3 514 498 497
3 497 513 514
3 499 498 514
3 511 487 499
3 515 500 510
3 501 500 515
3 480 491 516
3 491 517 516
3 505 480 516
3 506 518 492
3 519 483 493
3 483 519 507
3 502 485 507
3 502 520 471
3 494 471 520
3 521 474 489
3 509 486 504
3 522 510 511
3 515 523 501
3 490 501 523
3 523 524 490
3 491 490 524
3 524 517 491
3 493 492 518
3 525 493 518
3 493 525 519
3 526 489 459
3 527 499 514
3 499 527 511
3 528 511 527
3 511 528 522
3 515 510 522
3 495 419 426
3 474 521 529
3 529 503 474
3 504 508 530
3 530 509 504
3 531 517 524
3 531 516 517
3 516 531 532
3 516 532 505
3 533 506 505
3 532 533 505
3 534 502 507
3 425 472 535
3 508 503 529
3 508 536 530
3 537 513 512
3 513 537 538
3 514 513 538
3 506 533 539
3 539 518 506
3 525 518 539
3 525 540 519
3 507 519 540
3 502 534 520
3 489 526 541
3 489 541 521
3 542 509 530
3 512 509 542
3 512 542 537
3 543 514 538
3 527 514 543
3 527 544 528
3 522 528 545
3 528 544 545
3 545 546 522
3 522 546 515
3 515 546 547
3 547 523 515
3 524 523 547
3 540 548 507
3 507 548 534
3 494 549 472
3 549 550 472
3 472 550 535
3 473 425 535
3 551 521 541
3 551 529 521
3 536 508 529
3 524 552 531
3 552 553 531
3 531 553 532
3 520 554 494
3 554 549 494
3 555 360 473
3 385 360 555
3 495 556 459
3 556 526 459
3 557 527 543
3 557 544 527
3 546 558 547
3 559 547 558
3 559 524 547
3 524 559 552
3 560 532 553
3 561 533 532
3 532 560 561
3 539 533 561
3 539 562 525
3 563 540 525
3 564 534 548
3 548 565 564
3 564 566 534
3 520 534 566
3 567 542 530
3 542 567 537
3 567 568 537
3 568 538 537
3 568 543 538
3 525 562 563
3 535 569 473
3 555 473 569
3 536 570 530
3 544 557 571
3 545 544 572
3 544 571 572
3 573 546 545
3 545 572 573
3 552 574 553
3 560 553 574
3 565 548 540
3 526 575 541
3 529 551 576
3 529 576 536
3 530 577 567
3 543 568 578
3 543 578 557
3 571 557 578
3 546 573 579
3 579 558 546
3 580 559 558
3 558 579 580
3 552 559 581
3 559 580 581
3 552 581 574
3 582 560 574
3 560 582 561
3 583 561 582
3 583 539 561
3 583 584 539
3 585 562 539
3 539 584 585
3 562 585 563
3 540 563 565
3 566 586 520
3 586 554 520
3 576 587 536
3 587 570 536
3 570 577 530
3 577 588 567
3 588 589 567
3 568 567 589
3 572 590 573
3 590 579 573
3 583 591 584
3 585 584 591
3 592 563 585
3 565 563 592
3 565 593 564
3 564 593 566
3 551 541 594
3 568 595 578
3 595 596 578
3 571 578 596
3 580 597 581
3 574 581 597
3 575 594 541
3 587 598 570
3 577 570 598
3 568 589 599
3 572 571 600
3 600 601 572
3 572 601 590
3 579 590 602
3 580 579 602
3 582 603 583
3 604 585 591
3 585 604 592
3 549 605 550
3 526 556 575
3 551 594 606
3 576 551 606
3 588 577 598
3 568 599 595
3 571 596 600
3 602 607 580
3 597 580 607
3 608 574 597
3 609 582 574
3 574 608 609
3 582 609 603
3 593 610 566
3 586 566 610
3 599 589 588
3 601 611 590
3 590 611 602
3 603 612 583
3 612 591 583
3 613 592 604
3 614 565 592
3 592 613 614
3 565 614 593
3 615 586 610
3 616 550 605
3 606 617 576
3 617 587 576
3 618 595 599
3 618 596 595
3 591 612 604
3 554 586 615
3 605 554 615
3 549 554 605
3 535 550 616
3 569 535 616
3 619 588 598
3 588 620 599
3 599 620 618
3 596 618 621
3 622 600 596
3 596 621 622
3 611 601 600
3 600 622 611
3 611 623 602
3 624 607 602
3 602 623 624
3 597 607 624
3 624 625 597
3 597 625 608
3 626 608 625
3 609 608 627
3 608 626 627
3 628 603 609
3 627 628 609
3 629 612 603
3 603 628 629
3 630 604 612
3 629 630 612
3 604 630 613
3 617 631 587
3 587 631 598
3 632 593 614
3 610 593 632
3 575 633 594
3 634 619 598
3 588 619 620
3 622 635 636
3 636 611 622
3 611 636 637
3 638 623 611
3 611 637 638
3 624 623 638
3 639 613 630
3 640 614 613
3 613 639 640
3 614 640 632
3 610 641 615
3 615 641 605
3 569 642 555
3 495 426 643
3 633 606 594
3 631 634 598
3 644 620 619
3 645 618 620
3 620 644 645
3 618 645 621
3 556 646 575
3 645 647 621
3 635 622 621
3 621 647 635
3 648 624 638
3 649 625 624
3 624 648 649
3 650 626 625
3 625 649 650
3 626 650 651
3 651 627 626
3 651 628 627
3 651 652 628
3 628 652 629
3 642 569 616
3 643 556 495
3 629 652 653
3 653 630 629
3 654 630 653
3 630 654 639
3 640 655 632
3 656 610 632
3 610 656 641
3 617 657 631
3 644 658 645
3 647 659 635
3 660 636 635
3 659 660 635
3 661 637 636
3 636 660 661
3 661 638 637
3 662 638 661
3 662 648 638
3 648 662 663
3 648 663 649
3 664 649 663
3 649 664 650
3 665 650 664
3 665 651 650
3 654 666 639
3 639 666 640
3 656 632 655
3 667 605 641
3 605 667 616
3 619 634 668
3 644 619 668
3 651 665 669
3 651 669 670
3 670 652 651
3 640 671 655
3 643 646 556
3 646 672 575
3 633 575 672
3 606 633 673
3 617 606 673
3 617 673 657
3 674 634 631
3 645 658 675
3 647 645 675
3 676 647 675
3 676 659 647
3 661 677 662
3 664 663 678
3 679 653 652
3 652 670 679
3 654 653 679
3 666 671 640
3 426 240 680
3 663 662 681
3 662 677 681
3 663 681 678
3 671 682 655
3 656 655 682
3 631 657 683
3 674 631 683
3 668 634 674
3 684 644 668
3 644 684 685
3 685 658 644
3 675 658 685
3 678 686 664
3 665 664 686
3 686 687 665
3 669 665 687
3 688 670 669
3 633 689 673
3 690 657 673
3 690 683 657
3 691 675 685
3 676 675 691
3 692 676 691
3 659 676 692
3 693 660 659
3 692 693 659
3 661 660 694
3 693 694 660
3 677 661 694
3 687 695 669
3 688 669 695
3 696 666 654
3 696 671 666
3 656 697 641
3 667 698 616
3 698 642 616
3 699 385 555
3 700 668 674
3 674 701 700
3 684 668 700
3 685 702 691
3 703 677 694
3 677 703 704
3 677 704 681
3 705 686 678
3 687 686 705
3 670 688 706
3 679 670 706
3 707 654 679
3 708 707 679
3 654 707 696
3 709 667 641
3 642 710 555
3 672 711 633
3 711 689 633
3 673 689 712
3 712 690 673
3 701 674 683
3 713 681 704
3 678 681 713
3 705 678 713
3 708 679 706
3 696 714 671
3 682 671 714
3 682 715 656
3 697 709 641
3 684 700 716
3 702 685 684
3 684 716 702
3 702 717 691
3 692 691 717
3 703 694 693
3 705 718 687
3 718 719 687
3 695 687 719
3 720 688 695
3 719 720 695
3 721 706 688
3 688 720 721
3 708 706 721
3 722 707 708
3 722 696 707
3 696 722 714
3 697 656 715
3 667 709 723
3 426 724 643
3 725 683 690
3 701 683 725
3 701 726 700
3 716 700 726
3 727 692 717
3 692 727 728
3 693 692 728
3 729 703 693
3 693 728 729
3 704 703 730
3 729 730 703
3 713 704 730
3 730 731 713
3 732 705 713
3 713 731 732
3 705 732 718
3 733 714 722
3 734 682 714
3 714 733 734
3 715 682 734
3 667 723 698
3 721 735 708
3 712 689 711
3 736 690 712
3 737 716 726
3 738 702 716
3 737 738 716
3 738 739 702
3 739 717 702
3 717 739 740
3 717 740 727
3 732 741 718
3 718 741 719
3 708 735 742
3 742 722 708
3 734 743 715
3 697 715 743
3 642 698 744
3 744 710 642
3 555 710 699
3 725 690 736
3 745 701 725
3 726 701 745
3 745 737 726
3 746 719 741
3 746 720 719
3 720 746 747
3 747 721 720
3 735 721 747
3 722 742 748
3 722 748 733
3 426 680 724
3 709 697 749
3 709 750 723
3 751 711 672
3 752 712 711
3 712 752 753
3 712 753 736
3 754 740 739
3 739 755 754
3 727 740 754
3 728 727 756
3 727 754 756
3 729 728 757
3 728 756 757
3 758 730 729
3 729 757 758
3 758 731 730
3 731 758 759
3 732 731 759
3 760 741 732
3 732 759 760
3 741 760 746
3 747 761 735
3 761 762 735
3 762 742 735
3 748 742 762
3 763 733 748
3 733 763 734
3 763 764 734
3 764 743 734
3 743 749 697
3 751 752 711
3 745 725 765
3 766 746 760
3 746 766 747
3 767 723 750
3 698 723 767
3 643 768 646
3 672 646 769
3 751 672 769
3 753 770 736
3 765 725 736
3 770 765 736
3 771 737 745
3 737 771 772
3 737 772 738
3 738 773 739
3 739 773 755
3 749 743 764
3 769 646 768
3 745 774 771
3 773 738 772
3 775 755 773
3 775 754 755
3 754 775 776
3 756 754 776
3 777 756 776
3 757 756 777
3 778 757 777
3 778 758 757
3 758 778 779
3 758 779 759
3 759 780 760
3 766 760 780
3 766 781 747
3 761 747 781
3 782 748 762
3 763 748 782
3 749 783 709
3 750 709 783
3 752 784 753
3 765 774 745
3 785 761 781
3 761 785 762
3 785 786 762
3 762 786 782
3 784 752 751
3 787 773 772
3 773 787 788
3 773 788 775
3 789 759 779
3 759 789 780
3 790 766 780
3 766 790 781
3 767 791 698
3 744 698 791
3 771 774 792
3 787 772 771
3 771 792 787
3 793 775 788
3 794 776 775
3 775 793 794
3 795 777 776
3 776 794 795
3 796 778 777
3 777 795 796
3 797 779 778
3 778 796 797
3 797 789 779
3 798 780 789
3 790 780 798
3 799 781 790
3 799 785 781
3 800 782 786
3 763 782 800
3 800 801 763
3 764 763 802
3 763 801 802
3 783 803 750
3 767 750 803
3 769 804 751
3 710 805 699
3 385 699 806
3 47 385 806
3 643 724 768
3 751 804 807
3 807 784 751
3 753 784 808
3 770 753 808
3 765 770 809
3 774 765 810
3 792 774 810
3 787 811 788
3 797 812 789
3 789 812 813
3 789 813 798
3 814 798 813
3 814 790 798
3 814 815 790
3 790 815 799
3 799 816 785
3 786 785 816
3 817 749 764
3 764 802 817
3 817 783 749
3 805 710 744
3 765 809 810
3 768 818 769
3 809 770 808
3 810 819 792
3 792 820 787
3 811 787 820
3 821 788 811
3 793 788 821
3 793 821 822
3 823 794 793
3 793 822 823
3 824 795 794
3 823 824 794
3 796 795 825
3 795 824 825
3 796 825 826
3 796 826 797
3 812 797 826
3 812 827 813
3 814 813 827
3 799 815 828
3 828 816 799
3 829 786 816
3 786 829 800
3 830 800 829
3 800 830 801
3 831 809 808
3 809 831 810
3 832 812 826
3 833 815 814
3 828 815 833
3 834 784 807
3 784 834 808
3 792 819 820
3 820 835 811
3 811 835 821
3 836 823 822
3 823 837 824
3 825 824 838
3 824 837 838
3 839 826 825
3 838 839 825
3 826 839 832
3 827 812 832
3 827 840 814
3 833 814 840
3 829 816 828
3 830 841 801
3 842 802 801
3 841 842 801
3 802 842 817
3 843 803 783
3 767 803 843
3 744 791 844
3 744 844 805
3 845 768 724
3 819 810 846
3 847 821 835
3 836 822 821
3 821 847 836
3 828 848 829
3 848 849 829
3 830 829 849
3 850 817 842
3 817 850 851
3 783 817 851
3 767 852 791
3 852 844 791
3 834 853 808
3 808 853 831
3 831 846 810
3 854 835 820
3 820 855 854
3 835 854 847
3 856 823 836
3 856 837 823
3 857 832 839
3 858 827 832
3 832 857 858
3 840 827 858
3 851 843 783
3 852 767 843
3 805 806 699
3 768 845 818
3 859 769 818
3 859 804 769
3 860 807 804
3 846 861 819
3 855 820 819
3 819 861 855
3 862 838 837
3 862 839 838
3 857 839 862
3 863 833 840
3 833 863 864
3 828 833 864
3 865 828 864
3 828 865 848
3 830 866 841
3 842 867 850
3 804 859 860
3 847 868 836
3 836 868 869
3 856 836 869
3 857 870 858
3 863 840 858
3 858 870 863
3 834 871 853
3 872 853 871
3 831 853 872
3 873 855 861
3 854 855 873
3 854 874 847
3 847 874 868
3 862 837 856
3 862 875 857
3 857 875 876
3 876 870 857
3 863 877 864
3 865 864 877
3 865 878 848
3 849 848 879
3 848 878 879
3 866 830 849
3 849 879 866
3 880 841 866
3 880 842 841
3 867 842 880
3 807 860 881
3 834 807 881
3 882 846 831
3 883 861 846
3 846 882 883
3 883 873 861
3 856 884 862
3 867 885 850
3 851 850 885
3 871 834 881
3 872 882 831
3 873 886 854
3 887 874 854
3 854 886 887
3 888 868 874
3 874 887 888
3 889 869 868
3 868 888 889
3 856 869 884
3 869 889 884
3 884 890 862
3 890 875 862
3 891 875 890
3 891 876 875
3 876 892 870
3 863 870 892
3 893 879 878
3 893 866 879
3 866 893 894
3 866 894 880
3 859 895 860
3 892 896 863
3 863 896 877
3 897 851 885
3 843 851 897
3 843 898 852
3 844 899 805
3 881 900 871
3 901 882 872
3 882 901 883
3 902 873 883
3 873 902 903
3 903 886 873
3 904 892 876
3 905 877 896
3 905 865 877
3 906 878 865
3 865 905 906
3 878 906 893
3 907 845 724
3 895 908 860
3 881 860 908
3 871 900 909
3 909 872 871
3 872 909 901
3 902 883 901
3 910 889 888
3 888 911 910
3 884 889 910
3 910 912 884
3 913 890 884
3 884 912 913
3 891 890 913
3 904 876 891
3 914 892 904
3 914 896 892
3 905 896 914
3 867 915 885
3 885 916 897
3 843 897 898
3 898 917 852
3 680 907 724
3 886 903 918
3 887 886 918
3 918 919 887
3 888 887 919
3 919 911 888
3 905 920 906
3 867 880 915
3 844 852 917
3 881 921 900
3 891 913 922
3 904 891 922
3 920 923 906
3 893 906 923
3 924 893 923
3 894 893 924
3 880 894 925
3 894 924 925
3 880 925 915
3 915 916 885
3 818 845 926
3 859 818 927
3 895 859 927
3 928 902 901
3 901 929 928
3 902 928 930
3 903 902 931
3 902 930 931
3 918 903 931
3 932 914 904
3 904 933 932
3 905 914 934
3 914 932 934
3 897 935 898
3 921 936 900
3 909 900 936
3 929 901 909
3 937 911 919
3 910 911 937
3 938 912 910
3 910 937 938
3 913 912 939
3 912 938 939
3 940 913 939
3 913 940 922
3 922 941 904
3 941 933 904
3 905 934 942
3 920 905 942
3 915 943 916
3 944 917 898
3 908 921 881
3 945 909 936
3 945 929 909
3 946 897 916
3 897 946 935
3 927 818 926
3 947 940 939
3 922 940 948
3 940 947 948
3 941 922 948
3 949 933 941
3 949 932 933
3 950 934 932
3 932 949 950
3 934 950 942
3 942 951 920
3 923 920 951
3 923 952 924
3 924 952 925
3 925 943 915
3 935 944 898
3 917 953 844
3 845 907 926
3 930 954 931
3 954 955 931
3 918 931 955
3 918 955 956
3 919 918 956
3 957 919 956
3 957 937 919
3 937 957 958
3 959 938 937
3 937 958 959
3 939 938 960
3 938 959 960
3 947 939 960
3 943 961 916
3 916 961 946
3 895 927 962
3 908 895 962
3 929 963 928
3 949 964 950
3 950 965 942
3 965 951 942
3 966 923 951
3 966 952 923
3 952 967 925
3 844 953 899
3 930 928 968
3 928 963 968
3 968 954 930
3 969 948 947
3 970 969 947
3 969 941 948
3 969 971 941
3 972 949 941
3 941 971 972
3 949 972 964
3 925 967 973
3 973 943 925
3 974 961 943
3 974 975 961
3 975 946 961
3 805 899 976
3 977 936 921
3 945 936 977
3 978 955 954
3 956 955 978
3 957 979 958
3 979 980 958
3 980 959 958
3 981 960 959
3 959 980 981
3 947 960 981
3 981 970 947
3 966 951 965
3 974 943 973
3 935 946 975
3 917 944 982
3 982 953 917
3 962 983 908
3 921 908 983
3 984 929 945
3 929 984 963
3 985 963 984
3 968 963 985
3 986 957 956
3 957 986 987
3 957 987 979
3 964 988 950
3 950 988 965
3 978 954 968
3 986 956 978
3 971 989 972
3 964 972 989
3 966 990 991
3 952 966 991
3 991 992 952
3 992 967 952
3 992 973 967
3 975 993 935
3 944 994 982
3 926 995 927
3 962 927 995
3 977 996 945
3 996 997 945
3 997 984 945
3 980 998 981
3 965 999 966
3 999 990 966
3 994 944 935
3 983 1000 921
3 1000 977 921
3 1001 986 978
3 1002 970 981
3 1002 969 970
3 1002 1003 969
3 969 1003 971
3 989 971 1003
3 988 964 989
3 988 1004 965
3 974 973 992
3 993 994 935
3 806 805 976
3 1005 968 985
3 978 968 1006
3 968 1005 1006
3 978 1006 1001
3 986 1001 1007
3 987 986 1008
3 1007 1008 986
3 979 987 1009
3 1008 1009 987
3 980 979 1009
3 998 980 1009
3 998 1010 981
3 981 1010 1002
3 965 1004 999
3 953 1011 899
3 977 1000 996
3 985 984 997
3 1003 1012 989
3 1012 1013 989
3 1013 988 989
3 1004 988 1013
3 1014 991 990
3 990 1015 1014
3 992 991 1014
3 992 1016 974
3 974 1017 975
3 1017 1018 975
3 975 1018 993
3 953 982 1011
3 1011 976 899
3 962 1019 983
3 1019 1000 983
3 985 1020 1005
3 1021 998 1009
3 1010 998 1021
3 1015 990 999
3 1000 1022 996
3 997 996 1022
3 997 1023 985
3 1023 1020 985
3 1005 1024 1025
3 1025 1006 1005
3 1006 1025 1001
3 1026 1001 1025
3 1007 1001 1026
3 1027 1009 1008
3 1009 1027 1021
3 1021 1028 1010
3 1028 1029 1010
3 1002 1010 1029
3 1002 1029 1030
3 1031 1003 1002
3 1030 1031 1002
3 1012 1003 1031
3 1013 1032 1004
3 1004 1032 1033
3 999 1004 1033
3 999 1033 1015
3 1014 1034 992
3 992 1034 1016
3 1017 974 1016
3 993 1035 994
3 1036 1007 1026
3 1036 1008 1007
3 1008 1036 1027
3 1018 1035 993
3 1024 1005 1020
3 1013 1037 1032
3 1032 1038 1033
3 1033 1038 1039
3 1039 1015 1033
3 982 994 1040
3 962 995 1041
3 962 1041 1019
3 1042 997 1022
3 997 1042 1023
3 1036 1043 1027
3 1021 1027 1043
3 1044 1031 1030
3 1044 1012 1031
3 1037 1013 1012
3 1012 1044 1037
3 1015 1039 1014
3 1045 1034 1014
3 1016 1034 1045
3 1046 1017 1016
3 982 1047 1011
3 1046 1048 1017
3 1035 1018 1049
3 1035 1040 994
3 1050 907 680
3 1000 1019 1051
3 1051 1022 1000
3 1042 1052 1023
3 1020 1023 1052
3 1053 1036 1026
3 1036 1053 1043
3 1043 1054 1021
3 1055 1028 1021
3 1021 1054 1055
3 1056 1029 1028
3 1055 1056 1028
3 1030 1029 1057
3 1029 1056 1057
3 1030 1057 1044
3 1037 1058 1032
3 1038 1032 1059
3 1032 1058 1059
3 1039 1038 1059
3 1039 1060 1014
3 1045 1014 1060
3 1046 1016 1045
3 1017 1048 1018
3 1049 1018 1048
3 1040 1061 982
3 1062 995 926
3 1062 1041 995
3 1063 1024 1020
3 1025 1024 1064
3 1024 1063 1064
3 1026 1025 1065
3 1025 1064 1065
3 1065 1053 1026
3 1037 1044 1066
3 1037 1066 1058
3 1042 1067 1052
3 1020 1052 1063
3 1068 1058 1066
3 1059 1058 1068
3 1060 1069 1045
3 982 1061 1047
3 1067 1042 1022
3 1022 1051 1067
3 1070 1043 1053
3 1071 1070 1053
3 1072 1054 1043
3 1043 1070 1072
3 1073 1055 1054
3 1054 1072 1073
3 1056 1055 1073
3 1074 1056 1073
3 1074 1057 1056
3 1075 1039 1059
3 1039 1075 1060
3 1045 1076 1046
3 1077 806 976
3 907 1050 1078
3 926 907 1078
3 1019 1041 1079
3 1052 1080 1063
3 1074 1081 1057
3 1044 1057 1081
3 1082 1066 1044
3 1044 1081 1082
3 1066 1082 1068
3 1069 1060 1075
3 1069 1076 1045
3 1046 1083 1048
3 1049 1048 1083
3 1062 926 1078
3 1084 1051 1019
3 1068 1085 1059
3 1059 1085 1075
3 1076 1086 1046
3 1086 1083 1046
3 1049 1087 1035
3 1087 1040 1035
3 1061 1040 1087
3 1079 1041 1062
3 1084 1019 1079
3 1051 1084 1088
3 1067 1051 1088
3 1089 1052 1067
3 1052 1089 1080
3 1063 1080 1090
3 1064 1063 1090
3 1091 1053 1065
3 1091 1071 1053
3 1092 1070 1071
3 1072 1070 1092
3 1092 1093 1072
3 1093 1073 1072
3 1074 1073 1093
3 1094 1075 1085
3 1094 1069 1075
3 1090 1095 1064
3 1065 1064 1096
3 1095 1096 1064
3 1065 1096 1091
3 1074 1097 1081
3 1082 1081 1097
3 1098 1085 1068
3 1098 1094 1085
3 1099 1080 1089
3 1080 1099 1090
3 1077 976 1011
3 680 240 1100
3 1067 1101 1089
3 1089 1102 1099
3 1099 1103 1090
3 1095 1090 1103
3 1096 1104 1091
3 1071 1091 1105
3 1091 1104 1105
3 1105 1106 1071
3 1106 1092 1071
3 1107 1093 1092
3 1106 1107 1092
3 1108 1074 1093
3 1093 1107 1108
3 1074 1108 1097
3 1097 1109 1082
3 1109 1110 1082
3 1068 1082 1110
3 1110 1111 1068
3 1111 1098 1068
3 1069 1094 1112
3 1113 1076 1069
3 1112 1113 1069
3 1086 1076 1113
3 1049 1083 1114
3 1011 1115 1077
3 1086 1116 1083
3 1083 1116 1114
3 1011 1047 1115
3 1062 1117 1079
3 1079 1118 1084
3 1088 1119 1067
3 1067 1119 1101
3 1102 1089 1101
3 1103 1120 1095
3 1096 1095 1120
3 1121 1097 1108
3 1109 1097 1121
3 1094 1098 1122
3 1094 1122 1112
3 1114 1123 1049
3 1087 1124 1061
3 1123 1125 1049
3 1087 1049 1125
3 1125 1124 1087
3 1047 1126 1115
3 1120 1103 1127
3 1120 1128 1096
3 1129 1104 1096
3 1096 1128 1129
3 1105 1104 1129
3 1130 1107 1106
3 1107 1130 1131
3 1131 1108 1107
3 1108 1131 1132
3 1108 1132 1121
3 1133 1111 1110
3 1110 1134 1133
3 1111 1133 1135
3 1098 1111 1135
3 1098 1135 1122
3 1136 1112 1122
3 1136 1113 1112
3 1136 1137 1113
3 1086 1113 1137
3 1116 1086 1137
3 806 1077 1138
3 1118 1139 1084
3 1140 1088 1084
3 1084 1139 1140
3 1140 1119 1088
3 1102 1141 1099
3 1127 1103 1099
3 1099 1141 1127
3 1129 1142 1105
3 1106 1105 1143
3 1105 1142 1143
3 1106 1143 1130
3 1144 1121 1132
3 1145 1109 1121
3 1121 1144 1145
3 1134 1110 1109
3 1109 1145 1134
3 1146 1122 1135
3 1122 1146 1136
3 1061 1124 1126
3 1126 1047 1061
3 1138 47 806
3 1102 1101 1147
3 1114 1116 1148
3 1123 1114 1148
3 1117 1062 1078
3 1127 1149 1120
3 1150 1128 1120
3 1120 1149 1150
3 1129 1128 1150
3 1151 1132 1131
3 1134 1152 1133
3 1152 1153 1133
3 1153 1135 1133
3 1153 1154 1135
3 1146 1135 1154
3 1148 1116 1137
3 1125 1155 1124
3 1101 1119 1147
3 1119 1140 1147
3 1147 1156 1102
3 1157 1141 1102
3 1156 1157 1102
3 1127 1141 1157
3 1129 1150 1158
3 1158 1142 1129
3 1159 1142 1158
3 1159 1143 1142
3 1143 1159 1160
3 1130 1143 1160
3 1161 1130 1160
3 1161 1131 1130
3 1151 1131 1161
3 1162 1144 1132
3 1132 1151 1162
3 1163 1145 1144
3 1144 1162 1163
3 1134 1145 1164
3 1145 1163 1164
3 1152 1134 1164
3 1124 1155 1126
3 1079 1117 1165
3 1118 1079 1165
3 1157 1166 1127
3 1167 1149 1127
3 1127 1166 1167
3 1149 1167 1150
3 1160 1168 1161
3 1151 1161 1168
3 1169 1152 1164
3 1153 1152 1169
3 1170 1153 1169
3 1154 1153 1170
3 1171 1146 1154
3 1154 1170 1171
3 1146 1171 1172
3 1146 1172 1136
3 1172 1173 1136
3 1137 1136 1173
3 1137 1174 1148
3 1175 1126 1155
3 1050 680 1100
3 1176 1139 1118
3 1173 1174 1137
3 1177 1123 1148
3 1123 1177 1125
3 1126 1175 1115
3 1150 1167 1178
3 1158 1150 1178
3 1168 1179 1151
3 1179 1180 1151
3 1162 1151 1181
3 1151 1180 1181
3 1163 1162 1182
3 1162 1181 1182
3 1164 1163 1182
3 1125 1183 1155
3 1078 1050 1184
3 1117 1185 1165
3 1140 1139 1186
3 1139 1176 1186
3 1140 1186 1187
3 1140 1187 1147
3 1156 1188 1157
3 1166 1157 1188
3 1166 1189 1167
3 1178 1167 1189
3 1190 1158 1178
3 1159 1158 1190
3 1159 1190 1191
3 1160 1159 1192
3 1159 1191 1192
3 1192 1168 1160
3 1179 1168 1192
3 1181 1193 1182
3 1194 1164 1182
3 1194 1169 1164
3 1195 1169 1194
3 1195 1170 1169
3 1196 1171 1170
3 1195 1196 1170
3 1172 1171 1196
3 1174 1173 1197
3 1148 1174 1197
3 1183 1125 1177
3 1175 1198 1115
3 1115 1198 1077
3 1078 1184 1117
3 1148 1199 1200
3 1200 1177 1148
3 1176 1118 1165
3 1187 1201 1147
3 1156 1147 1201
3 1202 1156 1201
3 1202 1188 1156
3 1178 1203 1204
3 1178 1204 1190
3 1192 1205 1179
3 1206 1179 1205
3 1206 1180 1179
3 1207 1181 1180
3 1180 1206 1207
3 1181 1207 1193
3 1208 1182 1193
3 1208 1194 1182
3 1196 1209 1172
3 1199 1148 1197
3 1185 1117 1184
3 1188 1202 1210
3 1166 1188 1210
3 1211 1189 1166
3 1166 1210 1211
3 1203 1178 1189
3 1189 1211 1203
3 1212 1190 1204
3 1190 1212 1191
3 1191 1213 1192
3 1192 1213 1205
3 1172 1209 1214
3 1173 1172 1214
3 1173 1214 1215
3 1173 1215 1197
3 1177 1200 1183
3 1202 1201 1216
3 1194 1217 1195
3 1217 1218 1195
3 1219 1196 1195
3 1195 1218 1219
3 1196 1219 1209
3 1220 1199 1197
3 1185 1221 1165
3 1165 1221 1176
3 1216 1201 1187
3 1203 1222 1204
3 1222 1212 1204
3 1213 1191 1212
3 1205 1223 1206
3 1224 1207 1206
3 1206 1223 1224
3 1193 1207 1224
3 1193 1224 1225
3 1225 1208 1193
3 1194 1208 1217
3 1208 1225 1217
3 1219 1226 1209
3 1226 1214 1209
3 1215 1220 1197
3 1155 1183 1227
3 1175 1155 1227
3 1198 1228 1077
3 1228 1138 1077
3 1176 1229 1230
3 1186 1176 1230
3 1231 1186 1230
3 1231 1187 1186
3 1187 1231 1216
3 1202 1232 1210
3 1050 1100 1233
3 1050 1233 1184
3 1221 1229 1176
3 1234 1202 1216
3 1234 1232 1202
3 1210 1232 1235
3 1211 1210 1236
3 1210 1235 1236
3 1203 1211 1237
3 1211 1236 1237
3 1222 1203 1237
3 1212 1222 1238
3 1212 1238 1213
3 1239 1205 1213
3 1205 1239 1223
3 1240 1223 1239
3 1241 1224 1223
3 1223 1240 1241
3 1225 1224 1241
3 1225 1242 1217
3 1243 1218 1217
3 1217 1242 1243
3 1219 1218 1243
3 1215 1214 1226
3 1244 1199 1220
3 1200 1199 1244
3 1245 1200 1244
3 1246 1183 1200
3 1200 1245 1246
3 1183 1246 1227
3 1247 1213 1238
3 1213 1247 1239
3 1248 1185 1184
3 1216 1231 1249
3 1234 1216 1249
3 1237 1250 1222
3 1251 1238 1222
3 1225 1252 1242
3 1253 1219 1243
3 1253 1226 1219
3 1226 1254 1215
3 1254 1255 1215
3 1255 1220 1215
3 1256 1230 1229
3 1256 1231 1230
3 1234 1257 1232
3 1257 1235 1232
3 1222 1250 1251
3 1258 1247 1238
3 1238 1251 1258
3 1259 1239 1247
3 1258 1259 1247
3 1240 1239 1260
3 1239 1259 1260
3 1261 1241 1240
3 1240 1260 1261
3 1262 1225 1241
3 1241 1261 1262
3 1225 1262 1252
3 1242 1263 1243
3 1233 1248 1184
3 1256 1264 1231
3 1231 1264 1249
3 1237 1236 1265
3 1252 1266 1242
3 1242 1266 1263
3 1243 1263 1253
3 1253 1267 1226
3 1254 1226 1267
3 1220 1255 1268
3 1220 1268 1244
3 1268 1245 1244
3 1245 1269 1246
3 1227 1246 1269
3 1175 1227 1270
3 1249 1264 1271
3 1272 1234 1249
3 1271 1272 1249
3 1234 1272 1257
3 1236 1235 1265
3 1235 1257 1265
3 1265 1273 1237
3 1250 1237 1273
3 1273 1274 1250
3 1251 1250 1274
3 1275 1260 1259
3 1259 1276 1275
3 1277 1261 1260
3 1275 1277 1260
3 1262 1261 1277
3 1269 1270 1227
3 1221 1278 1229
3 1278 1279 1229
3 1229 1279 1256
3 1251 1274 1280
3 1258 1251 1280
3 1281 1266 1252
3 1266 1281 1263
3 1282 1253 1263
3 1267 1253 1282
3 1267 1283 1254
3 1283 1255 1254
3 1185 1248 1284
3 1284 1221 1185
3 1285 1257 1272
3 1257 1285 1265
3 1273 1286 1274
3 1286 1280 1274
3 1280 1287 1258
3 1276 1259 1258
3 1258 1287 1276
3 1277 1288 1262
3 1252 1262 1289
3 1262 1288 1289
3 1281 1252 1289
3 1281 1290 1263
3 1290 1282 1263
3 1255 1283 1268
3 1245 1291 1269
3 1292 1175 1270
3 1292 1198 1175
3 1278 1221 1284
3 1256 1293 1264
3 1271 1264 1293
3 1282 1294 1267
3 1291 1245 1268
3 1295 1285 1272
3 1285 1296 1265
3 1297 1273 1265
3 1296 1297 1265
3 1286 1273 1297
3 1298 1276 1287
3 1275 1276 1299
3 1276 1298 1299
3 1300 1277 1275
3 1275 1299 1300
3 1277 1300 1288
3 1294 1282 1290
3 1301 1279 1278
3 1256 1279 1301
3 1302 1271 1293
3 1295 1272 1271
3 1267 1294 1303
3 1283 1267 1303
3 1303 1304 1283
3 1283 1304 1268
3 1269 1305 1270
3 1295 1306 1285
3 1285 1306 1296
3 1307 1286 1297
3 1286 1307 1308
3 1286 1308 1280
3 1308 1309 1280
3 1287 1280 1309
3 1298 1287 1310
3 1309 1310 1287
3 1310 1311 1298
3 1312 1299 1298
3 1298 1311 1312
3 1299 1312 1300
3 1313 1288 1300
3 1314 1289 1288
3 1288 1313 1314
3 1281 1289 1314
3 1314 1315 1281
3 1281 1315 1290
3 1316 1290 1315
3 1290 1316 1294
3 1304 1317 1268
3 1318 1292 1270
3 1198 1292 1319
3 1319 1228 1198
3 1248 1320 1284
3 1320 1278 1284
3 1301 1321 1256
3 1321 1293 1256
3 1321 1302 1293
3 1295 1271 1322
3 1302 1322 1271
3 1323 1300 1312
3 1300 1323 1313
3 1268 1317 1291
3 1269 1324 1305
3 1306 1325 1296
3 1326 1297 1296
3 1296 1325 1326
3 1307 1297 1326
3 1269 1291 1324
3 1291 1327 1324
3 1305 1318 1270
3 1328 1301 1278
3 1295 1322 1329
3 1306 1295 1329
3 1311 1330 1312
3 1331 1323 1312
3 1330 1331 1312
3 1323 1332 1313
3 1332 1333 1313
3 1333 1314 1313
3 1334 1315 1314
3 1314 1333 1334
3 1335 1316 1315
3 1334 1335 1315
3 1294 1316 1335
3 1335 1336 1294
3 1294 1336 1303
3 1303 1337 1304
3 1337 1338 1304
3 1304 1338 1317
3 1339 1291 1317
3 1339 1327 1291
3 1292 1318 1319
3 1308 1307 1340
3 1307 1341 1340
3 1309 1308 1340
3 1336 1342 1303
3 1303 1342 1337
3 1339 1317 1338
3 1278 1320 1328
3 1322 1343 1329
3 1344 1306 1329
3 1325 1306 1344
3 1344 1345 1325
3 1325 1345 1326
3 1345 1341 1326
3 1341 1307 1326
3 1346 1309 1340
3 1310 1309 1346
3 1347 1311 1310
3 1310 1346 1347
3 1311 1347 1330
3 1323 1331 1332
3 1348 1302 1321
3 1302 1348 1322
3 1343 1322 1348
3 1329 1343 1349
3 1349 1344 1329
3 1350 1341 1345
3 1351 1340 1341
3 1341 1350 1351
3 1351 1346 1340
3 1352 1330 1347
3 1331 1330 1352
3 1353 1331 1352
3 1353 1332 1331
3 1354 1333 1332
3 1334 1355 1335
3 1355 1356 1335
3 1336 1335 1356
3 1337 1357 1338
3 1357 1358 1338
3 1358 1339 1338
3 1233 1359 1248
3 1248 1360 1320
3 1328 1361 1301
3 1362 1321 1301
3 1361 1362 1301
3 1321 1362 1348
3 1349 1363 1344
3 1344 1363 1345
3 1364 1346 1351
3 1346 1364 1365
3 1365 1347 1346
3 1347 1365 1352
3 1353 1366 1332
3 1332 1366 1354
3 1333 1354 1367
3 1334 1333 1367
3 1368 1337 1342
3 1357 1337 1368
3 125 1100 240
3 1369 1343 1348
3 1343 1369 1349
3 1355 1334 1367
3 1370 1336 1356
3 1336 1370 1342
3 1368 1342 1370
3 1358 1371 1339
3 1327 1339 1372
3 1339 1371 1372
3 1373 1324 1327
3 1372 1373 1327
3 1305 1324 1373
3 1328 1320 1374
3 1348 1375 1369
3 1345 1363 1376
3 1350 1345 1376
3 1376 1377 1350
3 1377 1351 1350
3 1378 1352 1365
3 1352 1378 1379
3 1379 1353 1352
3 1380 1354 1366
3 1367 1354 1380
3 1373 1381 1305
3 1318 1305 1381
3 1362 1375 1348
3 1382 1349 1369
3 1349 1382 1363
3 1377 1383 1351
3 1351 1383 1364
3 1384 1364 1383
3 1365 1364 1384
3 1378 1365 1384
3 1385 1366 1353
3 1353 1379 1385
3 1380 1366 1385
3 1367 1386 1355
3 1386 1356 1355
3 1370 1387 1368
3 1357 1368 1387
3 1357 1388 1358
3 1370 1356 1386
3 1320 1360 1374
3 1375 1389 1369
3 1369 1390 1382
3 1391 1363 1382
3 1376 1363 1391
3 1376 1392 1377
3 1384 1393 1378
3 1367 1394 1386
3 1370 1395 1387
3 1388 1357 1387
3 1358 1388 1396
3 1396 1371 1358
3 1248 1359 1360
3 1374 1397 1328
3 1361 1328 1397
3 1389 1390 1369
3 1390 1398 1382
3 1391 1382 1398
3 1392 1399 1377
3 1383 1377 1399
3 1383 1393 1384
3 1400 1378 1393
3 1378 1400 1401
3 1379 1378 1401
3 1402 1379 1401
3 1379 1402 1385
3 1403 1385 1402
3 1380 1385 1404
3 1385 1403 1404
3 1367 1380 1394
3 1380 1404 1394
3 1405 1386 1394
3 1386 1405 1406
3 1406 1370 1386
3 1370 1406 1395
3 1372 1371 1396
3 1387 1407 1388
3 1362 1408 1375
3 1389 1375 1408
3 1409 1376 1391
3 1392 1376 1409
3 1410 1383 1399
3 1410 1393 1383
3 1396 1411 1372
3 1411 1373 1372
3 1412 1413 1318
3 1319 1318 1413
3 1228 1319 1414
3 1415 1374 1360
3 1374 1415 1397
3 1362 1361 1416
3 1362 1416 1408
3 1410 1417 1393
3 1400 1393 1417
3 1400 1418 1401
3 1419 1402 1401
3 1418 1419 1401
3 1402 1419 1420
3 1402 1420 1403
3 1404 1403 1421
3 1420 1421 1403
3 1422 1406 1405
3 1423 1395 1406
3 1406 1422 1423
3 1387 1395 1423
3 1412 1318 1381
3 1381 1424 1412
3 1138 1228 1414
3 1389 1425 1390
3 1425 1398 1390
3 1398 1426 1391
3 1426 1409 1391
3 1427 1392 1409
3 1428 1399 1392
3 1392 1427 1428
3 1399 1428 1410
3 1394 1404 1429
3 1421 1429 1404
3 1405 1394 1429
3 1407 1387 1423
3 1388 1407 1430
3 1396 1388 1430
3 1411 1424 1373
3 1373 1424 1381
3 1416 1361 1397
3 1419 1431 1420
3 1432 1405 1429
3 1405 1432 1422
3 1360 1433 1415
3 1434 1409 1426
3 1409 1434 1427
3 1400 1417 1435
3 1435 1418 1400
3 1436 1422 1432
3 1407 1437 1430
3 1438 1396 1430
3 1396 1438 1411
3 1359 1233 1439
3 1440 1389 1408
3 1389 1441 1425
3 1442 1426 1398
3 1398 1425 1442
3 1443 1427 1434
3 1444 1428 1427
3 1427 1443 1444
3 1410 1428 1444
3 1418 1435 1445
3 1445 1419 1418
3 1431 1419 1445
3 1446 1420 1431
3 1446 1421 1420
3 1447 1429 1421
3 1446 1447 1421
3 1429 1447 1432
3 1436 1432 1447
3 1319 1413 1414
3 1389 1440 1441
3 1426 1442 1434
3 1448 1410 1444
3 1417 1410 1448
3 1449 1417 1448
3 1417 1449 1435
3 1422 1436 1450
3 1423 1422 1451
3 1450 1451 1422
3 1451 1407 1423
3 1437 1407 1451
3 1359 1433 1360
3 1440 1408 1416
3 1416 1452 1440
3 1437 1453 1430
3 1438 1430 1453
3 1452 1416 1397
3 1454 1441 1440
3 1425 1441 1455
3 1454 1455 1441
3 1425 1455 1442
3 1442 1456 1434
3 1434 1456 1457
3 1457 1443 1434
3 1443 1457 1458
3 1458 1444 1443
3 1448 1444 1458
3 1449 1459 1435
3 1459 1460 1435
3 1435 1460 1445
3 1445 1461 1431
3 1462 1446 1431
3 1461 1462 1431
3 1463 1447 1446
3 1462 1463 1446
3 1447 1463 1436
3 1436 1464 1450
3 1412 1424 1465
3 1233 1100 1439
3 1433 1466 1415
3 1466 1467 1415
3 1397 1415 1467
3 1397 1467 1452
3 1440 1468 1454
3 1448 1469 1449
3 1459 1449 1469
3 1464 1436 1463
3 1468 1440 1452
3 1470 1451 1450
3 1451 1470 1471
3 1437 1451 1471
3 1453 1472 1438
3 1411 1438 1472
3 1473 1411 1472
3 1473 1424 1411
3 1473 1465 1424
3 1474 1442 1455
3 1475 1456 1442
3 1442 1474 1475
3 1476 1457 1456
3 1456 1475 1476
3 1458 1457 1476
3 1458 1477 1448
3 1469 1448 1477
3 1460 1478 1445
3 1461 1445 1478
3 1462 1461 1478
3 1479 1464 1463
3 1470 1450 1464
3 1480 1455 1454
3 1479 1463 1462
3 1413 1481 1414
3 1482 1452 1467
3 1471 1483 1437
3 1453 1437 1483
3 1414 48 1138
3 1484 1433 1359
3 1467 1466 1482
3 1452 1485 1468
3 1468 1486 1454
3 1454 1486 1480
3 1455 1480 1487
3 1487 1474 1455
3 1488 1475 1474
3 1474 1489 1488
3 1490 1476 1475
3 1475 1488 1490
3 1491 1458 1476
3 1476 1490 1491
3 1492 1477 1458
3 1458 1491 1492
3 1493 1469 1477
3 1477 1492 1493
3 1459 1469 1494
3 1469 1493 1494
3 1460 1459 1494
3 1495 1460 1494
3 1495 1478 1460
3 1478 1495 1496
3 1478 1496 1462
3 1496 1497 1462
3 1462 1497 1479
3 1464 1479 1498
3 1499 1470 1464
3 1464 1498 1499
3 1470 1499 1471
3 1487 1489 1474
3 1500 1479 1497
3 1479 1500 1498
3 1483 1501 1453
3 1472 1453 1501
3 1413 1412 1502
3 1481 1413 1502
3 1482 1485 1452
3 1486 1503 1480
3 1487 1480 1503
3 1495 1504 1496
3 1499 1505 1471
3 1471 1505 1483
3 1506 1473 1472
3 1502 1412 1465
3 1468 1485 1507
3 1468 1507 1486
3 1490 1508 1491
3 1509 1492 1491
3 1508 1509 1491
3 1493 1492 1510
3 1492 1509 1510
3 1504 1511 1496
3 1511 1497 1496
3 1511 1512 1497
3 1497 1512 1500
3 1513 1472 1501
3 47 1138 48
3 1433 1484 1514
3 1472 1513 1506
3 1466 1433 1514
3 1503 1486 1507
3 1487 1515 1489
3 1488 1489 1516
3 1515 1516 1489
3 1490 1488 1516
3 1490 1516 1517
3 1490 1517 1508
3 1494 1493 1518
3 1493 1510 1518
3 1495 1494 1519
3 1494 1518 1519
3 1504 1495 1519
3 1512 1520 1500
3 1498 1500 1521
3 1520 1521 1500
3 1499 1498 1522
3 1521 1522 1498
3 1499 1522 1523
3 1523 1505 1499
3 1483 1505 1523
3 1483 1524 1501
3 1524 1513 1501
3 1473 1506 1525
3 1526 1465 1473
3 1525 1526 1473
3 1465 1526 1502
3 1527 1509 1508
3 1510 1509 1527
3 1482 1466 1528
3 1507 1529 1503
3 1487 1503 1530
3 1503 1531 1530
3 1487 1530 1515
3 1517 1532 1508
3 1508 1532 1527
3 1533 1511 1504
3 1511 1533 1534
3 1534 1512 1511
3 1520 1512 1534
3 1523 1535 1483
3 1535 1524 1483
3 1481 68 1414
3 1359 1439 1536
3 1484 1359 1536
3 1528 1466 1514
3 1485 1537 1507
3 1507 1538 1529
3 1539 1527 1532
3 1510 1527 1540
3 1518 1510 1540
3 1518 1541 1519
3 1542 1504 1519
3 1541 1542 1519
3 1504 1542 1533
3 1485 1482 1543
3 1543 1537 1485
3 1538 1507 1537
3 1531 1503 1529
3 1544 1516 1515
3 1517 1516 1545
3 1516 1544 1545
3 1546 1532 1517
3 1517 1545 1546
3 1532 1546 1539
3 1539 1540 1527
3 1547 1523 1522
3 1513 1548 1506
3 1549 1502 1526
3 68 48 1414
3 125 1439 1100
3 1550 1530 1531
3 1515 1530 1551
3 1530 1550 1551
3 1552 1518 1540
3 1541 1518 1552
3 1553 1534 1533
3 1554 1520 1534
3 1534 1553 1554
3 1521 1520 1555
3 1520 1554 1555
3 1522 1521 1556
3 1555 1556 1521
3 1522 1556 1547
3 1506 1548 1525
3 1536 19 1484
3 1514 1484 19
3 1482 1557 1543
3 1538 1558 1529
3 1559 1531 1529
3 1558 1559 1529
3 1531 1559 1550
3 1544 1515 1551
3 1560 1540 1539
3 1540 1560 1552
3 1561 1533 1542
3 1533 1561 1553
3 1535 1523 1547
3 1535 1562 1524
3 1513 1524 1562
3 1563 1526 1525
3 1549 1526 1563
3 1563 1525 1548
3 1564 1537 1543
3 1564 1538 1537
3 1564 1565 1538
3 1538 1565 1558
3 1566 1550 1559
3 1567 1550 1566
3 1567 1551 1550
3 1551 1567 1568
3 1568 1544 1551
3 1545 1544 1569
3 1544 1568 1569
3 1546 1545 1569
3 1569 1570 1546
3 1539 1546 1570
3 1571 1539 1570
3 1539 1571 1560
3 1560 1572 1552
3 1573 1541 1552
3 1572 1573 1552
3 1542 1541 1573
3 1561 1542 1573
3 1574 1553 1561
3 1575 1554 1553
3 1553 1574 1575
3 1555 1554 1575
3 1576 1556 1555
3 1555 1575 1576
3 1577 1556 1576
3 1547 1556 1577
3 1578 1535 1547
3 1577 1578 1547
3 1578 1579 1535
3 1535 1579 1562
3 1548 1513 1562
3 1549 1580 1502
3 1502 1580 1481
3 68 1481 1580
3 1439 63 1536
3 19 1581 1514
3 1581 1528 1514
3 1528 1557 1482
3 1566 1559 1558
3 1582 1561 1573
3 1561 1582 1574
3 1557 1583 1543
3 1583 1564 1543
3 1548 1584 1563
3 1566 1585 1567
3 1567 1585 1586
3 1567 1586 1568
3 1587 1568 1586
3 1568 1587 1569
3 1570 1588 1571
3 1560 1571 1589
3 1571 1588 1589
3 1590 1572 1560
3 1589 1590 1560
3 1591 1573 1572
3 1572 1590 1591
3 1573 1591 1582
3 1582 1592 1574
3 1593 1575 1574
3 1574 1592 1593
3 1575 1593 1576
3 1562 1594 1548
3 1594 1584 1548
3 1595 1577 1576
3 1578 1577 1595
3 1596 1557 1528
3 1557 1596 1583
3 1597 1566 1558
3 1598 1597 1558
3 1585 1566 1597
3 1587 1599 1569
3 1600 1570 1569
3 1569 1599 1600
3 1601 1588 1570
3 1570 1600 1601
3 1602 1591 1590
3 1603 1582 1591
3 1591 1602 1603
3 1604 1576 1593
3 1576 1604 1595
3 1578 1605 1579
3 1606 1579 1605
3 1562 1579 1606
3 1584 17 1563
3 1549 1563 17
3 1528 1581 1596
3 0 1564 1583
3 1564 0 1565
3 0 1598 1565
3 1558 1565 1598
3 1607 1586 1585
3 1587 1586 1607
3 1588 1601 1608
3 1608 1589 1588
3 1609 1590 1589
3 1589 1608 1609
3 1590 1609 1602
3 1582 1603 1610
3 1611 1592 1582
3 1582 1610 1611
3 1612 1593 1592
3 1592 1611 1612
3 1593 1612 1604
3 1605 1578 1595
3 1562 1606 1594
3 68 1580 78
3 1596 1 1583
3 1 0 1583
3 1585 1613 1607
3 1614 1587 1607
3 1599 1587 1614
3 1599 1615 1600
3 1601 1600 1616
3 1615 1616 1600
3 1608 1601 1616
3 1608 1617 1609
3 1617 1602 1609
3 1617 1618 1602
3 1619 1603 1602
3 1602 1618 1619
3 1619 1610 1603
3 1595 1620 1605
3 78 1580 1549
3 45 78 1549
3 1439 125 63
3 1621 1585 1597
3 1621 1613 1585
3 6 1607 1613
3 1607 6 1614
3 1594 15 1584
3 17 1584 15
3 45 1549 17
3 19 1536 20
3 22 1598 0
3 24 1597 1598
3 24 1621 1597
3 6 5 1614
3 1622 1599 1614
3 5 1622 1614
3 1615 1599 1622
3 1616 1623 1608
3 1623 1624 1608
3 1608 1624 1617
3 1619 1625 1610
3 1611 1610 1625
3 1611 1625 8
3 1611 8 1612
3 10 1612 8
3 1604 1612 10
3 1604 10 1626
3 1595 1604 1626
3 1620 1595 1626
3 14 1594 1606
3 1606 12 14
3 1594 14 15
3 19 18 1581
3 80 1596 1581
3 1581 71 80
3 22 24 1598
3 1621 25 1613
3 6 1613 25
3 42 1620 1626
3 1605 1620 42
3 42 44 1605
3 44 1606 1605
3 1606 44 12
3 63 20 1536
3 1 1596 49
3 0 3 22
3 5 7 1622
3 28 1615 1622
3 7 28 1622
3 30 1616 1615
3 28 30 1615
3 1623 1616 30
3 32 1624 1623
3 30 32 1623
3 1617 1624 34
3 32 34 1624
3 36 1618 1617
3 34 36 1617
3 38 1619 1618
3 1618 36 38
3 1625 1619 38
3 1625 38 39
3 8 1625 39
3 1626 40 42
3 68 46 48
3 1581 18 71
3 80 49 1596
3 25 1621 24
3 40 1626 10
3 10 11 40
3 78 69 68
And the other ball:
OFF
1627 3250 0
-333.887 150.288 -13.2468
-330.348 147.95 -15.9947
-332.68 144.401 -14.2008
-335.514 146.81 -11.908
-347.378 143.309 5.11721
-347.691 148.499 5.60586
-346.15 148.38 2.06703
-348.87 145.944 8.9095
-347.948 149.166 39.6836
-347.762 144.832 40.1094
-346.197 148.66 43.7863
-346.129 145.134 43.8635
-335.643 147.423 57.8135
-332.758 144.298 60.1324
-333.234 148.36 59.8172
-330.063 147.646 62.1938
-326.109 145.047 64.4889
-325.449 148.838 64.8509
-317.527 145.999 -22.0489
-316.58 149.792 -22.2462
-313.82 146.701 -22.9855
-334.808 142.32 -12.2988
-338.006 146.883 -9.56544
-340.97 143.428 -5.92109
-340.998 147.888 -6.06821
-343.799 147.138 -2.11039
-345.37 143.121 0.865172
-349.603 143.194 12.1474
-349.748 146.836 12.0449
-350.327 142.719 15.885
-350.573 146.983 16.2609
-350.809 144.069 19.7682
-350.984 147.054 20.66
-350.887 143.255 23.0736
-351.025 146.941 23.7702
-350.736 143.637 27.2688
-350.844 147.164 27.4315
-350.047 144.453 32.4303
-350.161 146.736 32.1873
-348.918 145.198 36.8746
-343.831 145.274 48.016
-341.342 144.671 51.5013
-340.984 147.641 52.1123
-338.236 143.738 55.1189
-337.895 147.502 55.605
-322.07 146.207 66.4434
-310.251 144.621 69.5673
-305.428 147.043 70.0588
-309.291 148.787 69.6935
-328 144.184 -17.403
-343.086 141.537 -2.59681
-348.473 142.295 8.4286
-344.3 141.255 46.6302
-335.23 143.231 57.9656
-350.435 140.208 19.7177
-349.674 139.431 31.5472
-350.213 139.048 27.2386
-348.672 139.638 35.9058
-347.535 140.699 39.7121
-346.221 141.051 42.877
-341.059 140.251 51.2714
-329 142.26 62.5993
-313.648 143.23 -22.9018
-310.573 146.829 -23.5789
-337.597 141.271 -9.42091
-349.213 139.899 12.1648
-347.499 137.683 7.52484
-350.388 139.113 23.1785
-313.958 148.908 68.9849
-314.9 144.552 68.7254
-318.546 142.942 -21.5541
-321.811 146.043 -20.534
-340.169 139.411 -6.15304
-344.451 139.306 0.263241
-345.768 137.674 3.39784
-349.77 138.627 16.1059
-337.416 139.99 55.3671
-319.534 143.556 67.2635
-318.699 147.383 67.6751
-321.395 141.503 -20.3606
-324.441 145.51 -19.3651
-327.546 140.641 -17.2272
-330.418 141.017 -15.4436
-334.768 140.111 57.9008
-332.447 140.834 59.9313
-323.988 140.853 65.1897
-342.914 136.531 -1.35784
-348.607 136.656 12.2318
-349.259 136.134 16.1025
-349.608 136.006 19.7723
-345.535 137.357 42.8377
-346.626 136.713 40.0001
-343.486 137.417 46.7662
-324.229 139.96 -18.9021
-332.376 138.633 -13.5814
-336.012 136.708 -9.96591
-349.645 135.675 23.1257
-349.122 134.26 27.2074
-348.55 134.397 31.409
-347.764 135.113 35.5854
-338.968 135.889 52.4688
-336.654 136.704 55.2717
-331.178 138.01 60.3363
-328.26 138.863 62.4566
-328.742 135.837 -15.465
-338.351 133.959 -6.4374
-340.918 134.024 -3.16681
-346.098 132.536 7.62034
-343.743 132.411 2.39965
-347.297 132.277 11.8513
-348.172 132.262 16.1561
-348.459 132.009 19.5202
-348.605 132.015 22.6595
-346.164 133.047 38.4871
-344.865 132.779 41.5029
-343.637 133.37 44.3837
-341.313 134.172 48.6383
-333.784 136.707 57.9144
-316.704 140.809 67.8743
-347.72 130.106 27.206
-347.065 130.005 31.3966
-346.664 131.17 34.8886
-319.555 139.102 66.7056
-332.231 134.712 -12.568
-336.093 132.973 54.4018
-307.639 146.244 -23.8941
-309.432 142.364 -23.4911
-326.303 136.225 -16.9972
-346.414 128.048 15.4625
-346.805 127.83 19.4299
-346.541 126.81 22.5865
-345 129.407 37.9053
-340.843 130.027 46.8749
-338.704 131.919 50.9409
-333.531 133.273 56.9408
-330.447 134.188 59.7668
-326.671 135.838 62.6859
-323.837 137.076 64.4933
-316.729 139.629 -21.7087
-334.597 132.111 -9.47978
-340.294 129.546 -1.32287
-342.237 129.227 2.17949
-342.853 127.652 4.77084
-344.271 127.419 8.53947
-345.084 127.148 11.4598
-345.699 125.741 28.1374
-345.247 126.883 33.4156
-342.974 128.867 42.1306
-312.224 140.77 68.9013
-338.18 129.946 -4.42546
-319.864 137.078 -20.1716
-331.119 131.758 -12.3179
-336.039 128.794 -6.28239
-343.602 126.313 37.7805
-336.854 127.836 50.7146
-334.917 129.575 53.9186
-311.173 139.574 -22.9114
-322.748 136.15 -18.7393
-339.529 125.859 0.534116
-344.955 124.623 16.9442
-341.249 125.778 42.3637
-339.901 127.856 46.653
-337.792 126.782 -2.71228
-343.447 122.961 14.1606
-331.77 129.931 56.9055
-328.613 129.113 58.9153
-326.209 132.333 61.8118
-306.914 142.838 69.761
-341.732 123.808 7.14525
-342.657 123.103 10.8807
-344.047 122.424 21.0826
-342.725 120.425 19.5383
-344.029 122.36 24.9803
-343.283 123.26 33.3591
-343.276 121.847 29.0773
-340.682 123.152 40.3333
-305.818 142.941 -23.8251
-323.818 132.213 -17.0363
-326.511 131.025 -15.1163
-328.873 129.496 -12.8742
-332.991 128.429 -9.04334
-340.099 124.103 3.41689
-341.304 122.094 37.1748
-338.674 123.528 44.4572
-337.46 124.911 47.5914
-318.807 135.531 66.1788
-322.796 134.244 64.1764
-319.598 133.28 -19.2311
-330.383 127.568 -10.7369
-332.477 125.188 -7.45407
-335.402 124.36 -3.74789
-336.16 121.793 -0.394115
-338.506 121.68 3.48486
-339.916 121.056 7.14732
-341.062 120.429 11.4113
-341.705 119.898 15.5526
-342.478 119.991 24.81
-341.225 120.023 33.0395
-341.35 119.07 29.1216
-334.512 123.619 50.1256
-333.48 125.408 52.5924
-330.896 126.381 55.6524
-314.749 137.378 67.7728
-339.076 118.183 35.4491
-338.051 119.596 40.4301
-336.836 120.634 43.9658
-335.242 121.42 47.1293
-325.687 128.97 60.6355
-319.483 131.874 64.786
-315.647 135.456 -21.0892
-338.794 117.457 11.5444
-339.873 117.486 15.5997
-340.182 117.05 20.1022
-340.209 116.993 24.8724
-322.17 129.866 62.8764
-312.818 137.205 -22.1466
-326.116 127.258 -13.5148
-328.637 125.209 -10.6446
-331.579 120.57 -4.51963
-336.504 119.407 3.17121
-337.942 118.625 7.01299
-338.778 116.075 29.9769
-330.458 123.304 53.8722
-332.353 120.627 49.7349
-329.627 121.722 -7.30856
-326.072 124.288 57.8382
-319.242 130.202 -18.2194
-322.655 128.338 -15.9333
-332.323 118.782 -1.79115
-332.921 117.042 1.05653
-335.336 116.794 5.15913
-335.808 114.75 10.1378
-337.257 114.626 15.3275
-337.74 114.364 19.5073
-337.24 113.733 25.2573
-336.276 114.965 35.2405
-335.14 115.927 39.7399
-333.859 117.586 44.4485
-322.012 126.182 61.1735
-308.223 139.678 69.2883
-304.024 146.017 -24.0172
-323.598 124.863 -13.5996
-325.965 122.68 -10.7863
-333.18 114.547 5.4126
-336.299 113.502 29.9191
-329.784 119.206 50.8599
-326.877 120.147 54.1618
-334.511 111.169 22.0969
-330.519 116.424 47.0129
-334.297 112.076 14.4101
-334.106 111.256 17.543
-314.464 133.281 66.7812
-315.286 131.199 -19.8516
-319.492 126.246 -16.3077
-325.179 119.169 -8.46791
-326.689 117.192 -5.51234
-328.981 115.341 -1.30938
-332.509 111.756 10.3617
-333.321 110.373 26.451
-333.014 110.531 29.6907
-333.5 112.346 35.0422
-332.223 113.26 39.6355
-331.323 114.305 42.9037
-317.63 129.82 64.6218
-310.046 135.775 68.3238
-329.754 112.869 3.36467
-330.298 111.952 5.84439
-327.327 117.083 50.8138
-323.79 121.29 57.0462
-321.452 122.805 59.3877
-319.131 126.65 62.6039
-331.141 109.437 14.8741
-311.578 132.144 -21.0205
-321.392 122.94 -13.4801
-322.943 120.642 -11.0254
-331.296 108.886 19.1758
-331.263 108.67 22.8603
-331.155 110.186 33.8786
-330.038 110.87 38.1551
-329.13 112.261 42.3604
-327.912 114.173 46.7729
-309.664 135.134 -22.1791
-330.126 110.075 10.0771
-324.379 115.856 51.8338
-321.598 118.376 55.9608
-306.463 138.658 -23.2467
-314.334 128.002 -18.8067
-323.445 116.165 -6.71434
-325.784 113.289 -1.54505
-325.669 110.482 2.65535
-329.394 107.619 27.2664
-328.202 107.516 31.4151
-327.407 108.256 35.919
-317.723 123.245 -15.2017
-318.531 119.672 -12.4765
-320.957 117.54 -9.51559
-326.537 108.762 7.2962
-327.358 107.705 11.8565
-327.846 107.027 16.0647
-328.031 106.704 19.6406
-328.092 106.584 22.8475
-326.452 109.406 40.2195
-325.537 111.18 44.6153
-323.627 112.708 48.5457
-317.567 123.358 61.326
-314.7 125.288 63.3796
-313.644 128.76 65.2782
-322.968 112.917 -3.30875
-318.181 119.999 58.8367
-320.427 114.444 -6.72528
-323.647 110.85 0.213493
-325.483 105.313 26.7858
-311.361 130.929 66.597
-314.562 125.092 -17.2609
-319.942 113.631 52.1365
-319.875 111.092 -2.95829
-323.408 107.05 7.43892
-324.167 106.021 11.7758
-324.586 105.277 15.9709
-324.797 104.951 19.7577
-324.874 104.845 23.0473
-324.467 105.376 30.9614
-324.185 106.475 35.8114
-323.388 108.053 40.9602
-320.702 109.42 45.9084
-313.348 120.983 -15.0979
-316.68 115.321 -9.41194
-320.187 109.262 0.0313025
-320.779 107.826 3.03652
-319.533 110.816 48.733
-317.372 115.759 55.5824
-314.539 121.951 61.3896
-314.71 117.995 -12.4725
-320.735 105.836 7.50631
-321.021 104.426 12.4127
-320.048 102.979 18.1015
-320.66 102.968 23.2387
-320.832 103.21 26.9448
-320.611 103.641 30.7712
-321.207 105.1 35.7705
-320.743 106.424 39.9054
-319.26 107.133 42.7754
-314.922 118.862 59.0707
-309.073 128.268 -19.8571
-311.615 124.386 -17.5609
-316.125 112.206 -6.30054
-309.443 125.799 64.6785
-316.036 109.487 -2.68204
-316.585 107.825 0.209909
-317.046 106.381 3.20746
-317.292 104.9 6.72545
-317.892 103.76 10.7604
-317.823 102.867 14.4474
-318.016 103.899 35.6652
-316.714 104.887 39.7164
-315.74 107.658 45.9891
-315.533 109.325 48.7131
-314.545 111.6 52.2015
-314.419 114.841 55.6976
-311.731 116.501 58.0058
-303.306 140.471 69.5967
-306.543 131.656 -21.3966
-310.802 119.53 60.6058
-309.759 122.231 62.5842
-308.408 129.609 66.4793
-306.706 132.441 67.6652
-304.685 136.437 68.8394
-304.875 134.175 -22.2614
-310.668 117.473 -13.0096
-315.968 101.581 20.4763
-315.806 101.489 24.8267
-315.759 102.03 30.5034
-315.053 105.85 42.9154
-307.481 124.596 -18.2282
-308.474 121.353 -16.1855
-311.696 114.094 -9.75838
-311.733 110.313 -5.49325
-312.238 107.065 -0.533789
-314.06 105.496 3.29452
-314.436 104.142 6.65942
-314.716 102.88 10.7247
-313.585 101.722 14.3884
-313.826 101.108 19.1951
-313.141 102.63 35.8152
-310.735 113.806 55.6466
-302.608 144.289 69.9434
-306.171 127.931 -19.9458
-307.075 119.326 -14.9565
-310.468 103.058 7.38855
-312.584 100.765 24.7776
-312.552 101.258 30.1357
-312.146 103.532 38.9783
-312.183 104.882 42.2886
-312.227 106.665 45.7247
-311.802 108.641 49.0747
-310.397 111.032 52.6356
-306.938 114.381 -10.8113
-310.267 104.693 3.38273
-309.804 101.845 11.0192
-304.792 128.596 66.3162
-308.327 108.352 -3.4864
-308.44 106.303 46.2328
-308.35 104.59 42.8875
-307.175 108.526 49.9276
-306.228 116.535 -12.7611
-307.565 111.474 -7.64305
-306.734 105.932 0.210853
-309.293 100.785 16.01
-308.446 100.152 21.1377
-307.605 100.144 25.5021
-308.643 100.633 29.5924
-308.263 101.483 34.1203
-308.204 102.169 36.6379
-308.355 103.217 39.6813
-306.926 111.303 53.5509
-306.856 115.26 57.6041
-306.973 118.408 60.2404
-306.474 121.473 62.4118
-304.827 124.198 64.1514
-303.447 139.163 -23.3888
-302.618 122.238 -17.0219
-304.938 108.262 -3.70333
-304.933 103.545 4.85814
-306.261 100.55 15.8491
-304.495 100.469 30.0694
-301.781 133.528 68.0419
-301.338 143.158 -23.8213
-302.613 130.142 -20.904
-304.039 111.014 -7.31199
-304.792 102.216 8.62304
-305.779 101.311 12.0226
-302.291 126.459 -19.3179
-303.98 100.073 19.8944
-302.285 100.565 15.4708
-304.744 101.265 33.919
-304.019 102.069 36.8851
-304.36 103.327 40.5075
-304.759 105.127 44.372
-302.65 107.272 48.2369
-302.361 114.103 56.6724
-303.72 118.464 60.4205
-302.747 122.016 62.8297
-301.952 117.994 -14.0079
-301.726 114.285 -10.7856
-302.048 106.422 -0.7623
-302.232 104.801 2.29562
-301.41 101.558 11.0635
-302.941 99.9737 24.5939
-301.541 110.573 52.7415
-299.972 101.41 34.0067
-300.73 105.214 44.4069
-301.397 109.095 -4.71203
-299.18 102.607 8.12418
-300.017 103.585 5.37803
-299.535 100.296 19.4461
-299.583 100.129 24.1675
-299.833 100.609 29.7804
-299.685 102.635 38.1153
-300.048 103.98 41.6333
-301.014 134.881 -22.3789
-299.46 111.369 -7.38326
-299.75 118.574 60.2799
-301.199 126.268 65.1641
-297.768 108.743 -3.69946
-297.588 106.399 0.0880191
-297.275 105.194 2.4707
-297.895 101.055 14.8774
-298.18 107.969 48.6461
-298.882 120.056 -15.209
-296.379 104.09 5.30127
-297.34 101.943 11.351
-298.475 122.477 62.7652
-299.472 131.051 67.0425
-300.961 137.341 68.9256
-297.694 124.793 -18.0454
-297.275 116.991 -12.6136
-297.329 114.023 -9.85265
-295.678 100.848 19.4142
-295.783 100.663 24.0363
-296.061 101.187 30.3664
-294.226 102.786 35.9178
-295.4 104.184 40.5506
-296.046 105.832 44.3233
-296.107 111.404 52.7576
-297.348 113.187 55.0033
-297.217 115.835 57.5957
-295.935 112.179 -7.59858
-293.63 103.136 9.40178
-293.727 101.743 15.0468
-298.416 130.226 -20.6126
-291.708 101.704 26.4824
-291.597 102.224 30.6076
-293.932 107.809 46.9858
-294.318 109.621 49.9176
-297.491 126.889 65.0608
-299.379 139.342 -23.1913
-294.143 110.137 -4.48549
-293.618 108.063 -1.26919
-293.011 106.343 2.06755
-291.802 105.248 5.03875
-291.991 101.609 20.1849
-291.277 101.718 23.4292
-295.498 119.701 60.3806
-295.246 120.724 -15.0274
-293.978 115.364 -10.3283
-290.624 105.153 39.8422
-290.773 106.664 43.368
-292.962 115.581 56.2968
-292.942 118.247 -12.5733
-291.53 113.107 -7.18788
-290.335 102.588 15.4609
-289.934 104.105 9.67654
-290.682 111.236 -4.49313
-290.428 109.238 -1.57841
-288.947 107.399 2.49271
-287.238 103.094 20.5134
-289.599 104.067 35.771
-288.57 103.454 31.8091
-290.186 108.974 47.0061
-291.598 112.916 52.9425
-293.849 123.991 62.7742
-295.373 126.691 -18.5418
-287.279 103.682 15.2804
-286.912 103.176 24.1091
-286.103 103.79 28.495
-288.572 111.498 49.8057
-296.722 133.844 -21.5894
-286.618 106.539 6.4393
-286.959 105.008 10.3499
-292.566 123.016 -15.8504
-288.819 116.513 -9.48884
-285.88 104.943 33.7113
-285.869 106.211 37.9272
-286.494 107.558 41.7287
-292.318 120.194 59.8694
-297.23 135.431 68.096
-289.466 120.289 -12.917
-286.848 111.652 -2.849
-286.104 110.096 -0.0596179
-285.309 109.878 45.1199
-288.486 115.057 53.8744
-294.193 130.33 -19.8697
-287.567 113.771 -5.94593
-284.26 108.927 3.64728
-283.614 106.48 10.4684
-283.292 105.634 14.3687
-282.918 105.154 18.4909
-283.772 104.539 23.6896
-289.264 117.849 56.8261
-294.214 130.142 65.8365
-295.063 133.306 67.1035
-291.203 127.278 -17.7746
-282.256 106.023 30.9007
-283.176 106.429 34.4496
-292.175 128.192 64.4912
-299.193 141.536 69.4843
-295.676 137.367 -22.3172
-282.279 108.241 7.54353
-281.005 105.984 22.1038
-281.169 106.008 26.4586
-282.416 107.916 37.8257
-283.378 109.141 41.7956
-284.873 112.671 48.8574
-285.32 115.563 52.6055
-288.951 120.947 59.1555
-285.349 119.335 56.2079
-289.417 123.534 61.0808
-284.802 114.809 -5.47855
-282.107 112.281 -0.116591
-296.672 138.094 68.6137
-286.019 119.618 -10.7603
-278.967 109.298 10.0354
-278.862 108.224 14.0715
-279.483 107.316 17.0647
-278.617 108.782 33.6084
-291.975 134.393 -20.7124
-288.081 124.604 -15.1929
-284.27 118.063 -8.3865
-280.352 110.38 5.34794
-278.42 107.568 20.9646
-277.584 108.099 24.9121
-278.543 107.951 29.2667
-279.38 109.945 38.3848
-279.653 111.81 42.5863
-282.182 112.175 45.851
-282.583 114.129 48.9601
-289.699 126.829 63.0146
-285.02 122.901 -12.7024
-280.165 117.878 -5.31759
-280.927 115.453 -3.14478
-276.644 109.013 18.2336
-279.477 113.676 45.3989
-282.607 117.483 52.7559
-285.175 123.325 59.0548
-290.919 131.409 -19.4061
-278.171 113.349 2.66939
-276.604 112.59 6.26541
-275.243 110.131 28.3837
-281.337 121.622 -9.52054
-278.336 115.467 -0.649142
-275.096 111.813 11.0742
-274.732 111.096 14.8733
-274.513 110.385 21.1488
-276.131 113.117 40.0056
-279.319 116.405 48.8791
-289.916 132.517 65.5037
-286.983 129.632 -17.3083
-273.922 110.879 24.3806
-274.465 111.709 32.8384
-275.42 112.267 36.7181
-285.521 127.059 61.402
-272.865 112.337 16.3306
-276.546 115.31 44.3145
-279.778 119.765 52.7489
-281.669 121.763 55.8238
-287.564 129.155 63.2907
-292.173 135.873 67.1586
-283.826 127.457 -14.7786
-274.944 115.968 2.82047
-276.807 121.448 -5.69973
-275.946 118.189 -1.44104
-273.197 115.439 6.64609
-272.871 113.935 10.6664
-271.81 112.814 20.3625
-271.305 113.187 24.9219
-271.637 113.451 29.3697
-271.997 114.145 33.4979
-272.692 114.814 37.0207
-273.782 115.378 40.3606
-274.649 117.17 44.5254
-276.286 118.72 48.462
-279.834 125.962 -11.4937
-282.333 125.599 58.8639
-286.698 133.452 -18.637
-276.688 124.236 -7.84474
-270.558 116.294 10.6578
-270.072 115.573 14.41
-269.801 115.206 17.3256
-269.494 115.134 20.3144
-277.316 121.794 52.4272
-278.9 124.054 55.5094
-284.68 131.913 63.1812
-294.059 140.086 68.4835
-296.072 142.833 -23.2147
-272.775 121.703 -1.51597
-272.082 118.859 2.89714
-291.046 139.937 -21.7169
-270.54 118.418 6.35407
-268.963 115.671 24.8178
-269.354 115.807 29.1672
-269.713 116.305 32.6647
-270.444 117.35 37.4689
-271.5 119.068 42.4236
-272.227 120.868 45.7831
-273.168 123.259 49.5274
-279.394 126.868 57.6683
-281.258 130.17 60.6203
-280.111 129.201 -13.396
-270.769 121.311 1.83572
-267.699 119.555 10.9533
-267.043 119.205 14.2493
-266.886 118.523 17.8457
-267.014 117.952 22.7224
-267.276 117.812 26.4321
-267.356 118.464 30.4429
-267.8 119.059 34.0325
-275.211 124.946 52.949
-287.128 135.458 65.3993
-272.985 124.88 -4.59805
-267.802 120.5 37.1264
-269.328 121.111 41.535
-275.915 127.586 55.3713
-288.057 138.611 -20.5016
-282.13 131.636 -15.7082
-275.134 127.45 -8.61738
-268.618 121.661 5.18129
-267.507 121.155 8.43563
-265.358 120.266 20.5765
-265.059 120.966 27.3411
-269.926 123.637 45.5155
-301.134 148.015 -23.9528
-264.887 120.935 24.937
-276.632 130.324 57.4572
-276.598 130.62 -11.5369
-270.116 126.113 -2.05475
-268.788 124.67 1.15384
-265.499 121.192 31.0037
-265.083 123.146 34.4058
-266.689 124.132 40.3227
-283.054 135.306 -17.4647
-277.608 132.802 -13.2892
-266.402 124.51 5.84576
-264.527 124.472 10.7117
-263.943 123.78 14.5247
-264.254 122.472 17.4631
-265.54 123.882 37.1
-272.482 127.633 52.0563
-279.771 135.126 61.5635
-289.49 140.267 67.27
-299.051 145.735 69.7463
-271.211 128.658 -5.31524
-273.068 131.311 -8.82007
-266.731 127.945 1.46813
-262.881 124.47 19.1686
-263.146 123.707 22.1495
-263.574 124.135 30.4809
-267.361 125.588 43.2421
-270.06 126.928 48.6253
-267.819 127.967 46.2915
-281.859 137.262 63.419
-295.769 143.961 69.2125
-284.317 138.26 -18.827
-280.169 135.916 -16.0512
-262.823 124.495 26.4094
-272.896 130.28 54.085
-277.484 133.236 59.338
-268.639 129.969 -2.92428
-264.699 127.392 6.10281
-262.925 126.594 33.3812
-263.435 127.439 36.6141
-264.577 127.877 40.1469
-265.797 128.406 43.1511
-269.397 130.647 50.3917
-285.953 139.371 65.7574
-297.76 146.474 -23.6156
-273.989 134.506 -11.0021
-270.608 131.485 -6.2479
-262.245 129.155 10.6438
-261.539 128.829 13.9344
-261.005 128.281 18.653
-260.949 127.98 23.1191
-260.926 128.508 27.1103
-261.229 128.724 30.2512
-271.635 133.145 54.2057
-274.039 134.064 56.8739
-265.769 131.073 45.278
-276.084 136.93 -13.5065
-267.507 133.529 -3.50091
-265.367 132.624 0.278054
-263.68 131.574 4.26323
-262.729 130.398 7.74529
-261.618 129.797 33.934
-267.04 132.359 48.1304
-275.921 136.21 59.1589
-292.275 144.116 68.4679
-270.214 135.734 -7.78862
-262.293 131.196 37.981
-263.374 132.736 42.0014
-268.249 134.737 51.0199
-276.562 140.178 60.6295
-282.481 140.813 64.3618
-283.911 142.22 -19.2768
-281.174 140.175 -17.5535
-277.822 140.551 -15.5508
-260.995 133.198 9.77837
-262.224 133.623 6.04141
-259.94 133.051 14.2338
-259.473 132.425 18.5118
-259.266 132.389 24.1704
-259.373 133.568 29.61
-260.439 132.947 33.8412
-263.992 134.551 44.3686
-265.468 135.194 47.2776
-270.11 137.561 54.3105
-273.13 139.324 57.7046
-272.195 139.691 -10.9225
-261.037 134.942 37.9417
-285.359 144.163 66.1494
-292.857 144.771 -22.6661
-287.963 144.909 -21.1997
-275.06 140.85 -13.5943
-266.839 138.104 -4.42331
-265.207 137.332 -1.79724
-262.982 136.295 2.58895
-269.001 139.685 -7.60067
-260.625 137.136 7.62099
-259.434 136.734 12.0213
-258.658 136.59 15.9978
-258.239 136.278 20.7742
-258.366 135.811 25.1286
-259.543 136.075 33.7904
-262.012 137.006 41.6825
-266.765 138.279 50.3719
-278.529 143.4 62.4412
-279.841 143.446 -17.2162
-263.179 138.762 44.8834
-264.519 139.81 47.5757
-264.094 140.529 -1.11213
-261.692 140.423 3.47241
-258.232 138.036 29.3122
-260.196 138.586 37.9743
-289.065 145.179 67.5481
-266.923 142.231 -5.59547
-259.826 140.755 7.9799
-258.743 140.378 11.9966
-257.933 140.478 15.8563
-257.536 139.79 20.722
-257.536 139.931 25.1253
-258.965 139.101 33.9904
-261.595 140.642 42.3398
-266.787 141.581 51.2997
-269.587 143.074 54.8555
-271.792 143.224 57.0886
-281.47 144.06 64.181
-285.172 146.154 -20.1057
-296.073 147.911 69.3807
-300.601 148.814 69.8888
-281.906 146.763 -18.5375
-276.161 145.163 -14.8888
-272.872 143.99 -12.1301
-269.877 144.711 -9.30941
-263.009 143.01 0.27856
-257.511 142.306 28.3918
-258.089 141.485 31.5533
-258.86 142.848 35.6485
-260.142 142.217 39.3137
-262.738 143.093 45.2191
-275.241 144.959 60.2002
-290.979 148.953 -22.1746
-267.63 146.249 -6.83387
-264.994 145.864 -3.31387
-260.839 144.975 4.35304
-259.35 144.214 8.47198
-258.125 144.976 12.6608
-257.577 143.661 16.2009
-257.198 143.856 19.7854
-257.078 143.678 23.5943
-257.774 144.82 31.4369
-261.245 146.186 42.7145
-264.21 144.9 48.0286
-266.694 146.156 51.6722
-272.589 148.04 -12.033
-257.183 145.943 27.541
-259.415 146.634 38.0345
-278.719 147.867 -16.6612
-262.822 146.383 0.299989
-258.872 147.697 9.68235
-257.355 148.281 16.9615
-257.067 146.897 19.9576
-256.962 146.933 22.9683
-258.336 147.202 34.2588
-269.492 147.574 54.9804
-271.989 147.463 57.4779
-281.422 148.642 64.2742
-291.187 149.316 68.2387
-294.467 148.758 -23.0332
-270.03 149.268 -9.46411
-260.757 148.261 4.44242
-263.031 148.811 46.042
-264.611 148.506 48.6694
-275.476 148.529 60.3707
-278.049 149.437 62.169
-286.292 148.854 66.5751
-275.388 148.537 -14.2972
-262.959 150.517 0.231107
-265.278 149.589 -3.61078
-257.784 150.422 14.734
-257.125 149.415 26.48
-257.718 148.65 31.1035
-287.39 149.765 -20.9274
-283.482 149.807 -19.2316
-267.949 149.737 -7.06829
-257.19 151.21 20.5094
-258.754 151.572 35.2006
-260.157 149.935 39.7514
-261.816 152.343 43.1854
-267.326 150.423 52.2857
-273.388 151.228 58.4882
-259.898 151.76 7.29539
-258.806 152.053 10.985
-257.824 151.801 30.5456
-277.634 151.303 -15.7011
-274.84 151.822 -13.6023
-265.56 152.597 -3.57215
-261.568 151.947 3.34511
-257.338 152.915 23.583
-257.841 154.513 28.3333
-260.438 153.298 39.6278
-263.078 152.655 45.4913
-264.82 151.68 48.5807
-270.625 153.135 55.6362
-280.867 151.437 -17.7129
-271.268 152.352 -10.3605
-268.235 153.036 -6.95324
-258.214 155.234 15.7172
-275.517 152.398 60.0303
-263.594 155.189 0.359514
-262.141 155.471 3.26596
-260.656 155.505 6.78408
-259.32 155.182 10.7962
-257.845 155.694 20.5134
-258.005 156.706 25.237
-258.843 155.325 33.2381
-265.87 155.1 49.3943
-268.563 154.359 53.0632
-286.551 152.651 -20.3175
-259.932 155.816 36.8076
-279.562 153.472 62.7032
-283.743 152.459 65.0891
-294.247 151.025 68.8434
-279.277 153.758 -16.4263
-271.677 155.23 -10.2268
-267.772 156.582 -5.4774
-265.04 157.041 -1.386
-259.154 159.241 30.4168
-261.852 157.709 41.0698
-263.935 156.313 45.8002
-297.473 151.103 -23.4306
-284.273 154.26 -19.0937
-275.781 155.296 -13.7418
-260.028 159.315 11.5869
-260.796 159.104 8.85959
-259.177 159.654 16.2232
-258.682 159.589 20.9706
-260.312 159.039 35.6409
-273.442 156.182 57.5786
-276.523 155.532 60.207
-287.417 152.79 66.6394
-264.131 160.378 1.858
-262.569 160.86 5.43291
-264.431 159.812 44.9884
-282.347 156.576 -17.6869
-259.349 161.552 25.9308
-266.111 160.319 47.5301
-268.326 158.752 51.3411
-271.231 159.192 54.5052
-294.194 153.939 -22.5207
-290.065 153.335 -21.4681
-270.368 160.257 -7.12581
-273.346 159.711 -10.3925
-268.607 160.714 -4.83092
-266.29 160.393 -1.72283
-261.141 161.601 35.8111
-260.379 162.204 31.8433
-262.364 161.282 39.5622
-283.409 156.337 64.2617
-279.219 157.488 -15.5716
-261.451 163.071 10.894
-260.464 163.425 16.0221
-260.145 163.603 19.4598
-259.85 163.19 23.0126
-260.893 164.482 30.172
-264.185 162.363 42.7683
-274.892 159.309 57.876
-285.97 155.488 65.6061
-277.164 159.677 -13.5358
-280.199 157.057 62.3028
-260.989 166.057 22.7552
-260.901 165.521 26.2823
-262.152 164.78 35.1009
-263.868 165.041 39.6877
-266.214 163.845 45.3559
-269.783 162.993 51.0935
-291.505 153.732 67.8407
-268.441 164.254 -2.50717
-266.596 164.135 0.218928
-265.415 165.406 3.34584
-263.78 165.85 7.45556
-262.512 166.142 11.8336
-261.693 166.379 16.0162
-261.414 166.655 19.6673
-278.083 158.488 60.5082
-288.657 156.836 -20.3925
-271.773 162.916 -7.33863
-264.426 168.454 36.6771
-266.605 167.11 43.3095
-268.511 165.505 47.7708
-272.054 163.049 53.5468
-270.635 166.421 -3.95462
-262.824 169.4 27.4591
-262.917 169.914 24.0524
-263.297 169.214 30.9582
-263.25 167.819 33.8575
-274.58 163.315 55.8908
-278.392 163.075 59.101
-281.5 160.184 62.1612
-297.665 152.249 69.3149
-281.698 160.503 -16.1544
-268.448 167.677 0.151258
-264.709 169.7 10.5684
-263.533 169.644 14.9054
-263.246 170.402 20.3765
-291.049 156.273 67.2979
-286.177 158.396 -18.9894
-275.446 163.884 -10.3709
-274.446 166.474 -8.03842
-266.826 169.271 4.66227
-265.73 170.043 8.23237
-266.242 169.809 39.4049
-265.416 171.335 34.5577
-270.799 168.248 48.6719
-271.992 167.06 51.0135
-274.87 166.217 54.6143
-284.494 160.015 63.7569
-287.482 158.706 65.4618
-292.249 156.099 -21.6184
-280.497 163.091 -14.4227
-278.796 165.374 -12.2616
-265.209 172.915 16.9975
-269.924 170.003 45.8637
-284.354 162.128 -17.0063
-269.263 171.339 2.65599
-265.514 174.031 25.0223
-265.925 173.766 29.9707
-268.8 171.642 42.166
-272.877 170.043 -3.7372
-270.713 170.845 -0.121959
-269.063 173.137 5.40258
-267.978 173.61 8.56827
-266.498 173.544 12.8293
-265.811 174.341 20.4001
-296.252 155.033 68.7091
-268.104 175.353 34.0332
-268.703 174.268 38.0019
-274.719 170.961 50.9974
-272.79 171.759 48.0032
-279.375 167.913 57.1963
-281.794 165.346 60.213
-284.256 163.438 62.4033
-288.527 162.381 -18.7198
-276.629 171.176 -6.70913
-268.478 177.216 16.4673
-283.243 166.172 -14.6177
-278.246 169.32 -9.41723
-275.012 173.633 -2.78467
-273.342 174.458 0.158675
-272.604 175.466 2.52677
-268.892 176.32 12.0736
-268.554 177.801 20.0644
-268.467 177.855 23.0728
-268.786 178.005 26.7999
-267.969 176.426 30.0596
-271.573 175.318 41.9713
-271.526 173.292 44.5658
-277.014 169.387 54.3533
-287.583 162.589 64.2401
-271.055 176.818 7.45369
-271.206 177.245 37.9721
-272.988 175.292 44.1915
-274.926 174.923 47.304
-290.237 160.933 65.7625
-291.945 160.031 -20.5594
-281.702 168.96 -12.1198
-271.781 179.481 12.0087
-271.564 179.775 32.6105
-278.917 172.065 53.9621
-282.555 170.212 57.8729
-295.416 158.37 67.8284
-284.667 167.015 60.9147
-288.784 167.187 62.7366
-301.111 152.984 -23.5772
-286.629 166.831 -15.9864
-281.061 172.915 -8.90302
-274.055 179.697 7.15663
-271.74 180.574 16.1942
-271.595 180.929 19.8708
-271.442 180.945 22.9583
-271.879 181.15 27.098
-273.639 178.226 40.7659
-275.736 178.311 43.8205
-277.808 175.245 49.988
-293.4 160.937 66.6822
-296.063 158.588 -21.9173
-278.608 175.779 -4.25567
-277.361 178.405 0.19536
-276.546 179.582 2.95968
-273.872 180.471 36.5925
-285.303 171.363 -12.7003
-277.234 181.672 40.2688
-281.091 176.77 51.3561
-274.693 182.117 12.0641
-276.792 183.231 10.294
-273.88 182.48 16.0898
-273.941 183.077 20.3266
-275.427 184.391 24.8217
-278.178 177.997 47.1793
-282.49 174.714 54.3732
-301.19 153.674 69.491
-299.374 155.653 -23.0062
-294.477 163.608 -20.0131
-281.009 176.645 -5.35909
-275.013 183.406 29.869
-276.596 183.346 35.083
-286.022 170.775 59.4043
-290.94 167.19 -17.4699
-278.417 180.325 44.1469
-286.086 174.217 56.9568
-291.57 164.707 64.7649
-289.865 170.132 -15.4447
-284.217 175.429 -8.86605
-281.088 179.037 -2.69716
-278.135 182.916 7.05469
-277.063 184.593 14.4074
-276.984 185.393 19.4524
-281.354 179.561 48.3134
-281.183 181.287 0.277507
-281.175 183.169 3.34226
-278.169 185.729 29.9291
-281.472 181.917 45.11
-284.611 179.289 -5.20907
-304.651 149.814 -23.9582
-288.313 174.683 -11.6581
-287.953 177.833 -8.75143
-284.098 181.01 -2.68726
-281.154 184.785 6.75711
-281.239 186.208 10.3575
-280.463 186.731 13.8535
-279.525 187.029 19.1381
-279.974 187.437 24.8022
-280.805 186.379 34.2176
-281.23 185.368 37.9788
-281.7 183.801 42.024
-284.67 179.09 51.4362
-285.915 177.101 54.3043
-289.947 171.914 60.3486
-299.522 157.307 68.6725
-289.207 173.968 58.585
-298.52 160.45 -21.7767
-295.907 166.719 -18.9505
-290.7 173.399 -13.5859
-285.04 183.658 0.406915
-281.456 187.716 29.9289
-285.025 181.377 48.8981
-293.275 170.655 62.265
-295.001 164.208 65.8256
-295.177 167.766 64.2985
-297.847 161.083 67.4627
-288.156 183.17 -2.59559
-285.326 185.327 3.13871
-284.792 186.831 6.92419
-283.584 189.115 18.2075
-283.432 189.306 22.0025
-283.695 189.312 26.1614
-284.794 185.611 41.7658
-284.619 187.201 37.898
-285.61 184.117 45.3058
-288.945 180.277 52.6945
-290.418 177.977 55.7168
-305.477 150.955 69.8769
-295.266 169.783 -17.2304
-294.143 172.819 -15.1218
-288.434 180.761 -5.81963
-284.815 188.237 11.0041
-284.562 189.013 14.602
-284.551 189.248 30.0914
-284.811 188.532 33.9121
-288.503 183.095 48.9174
-293.442 177.115 -11.6092
-294.075 175.601 59.0761
-288.208 185.009 0.241449
-288.548 187.347 4.32516
-287.681 191.117 24.9849
-287.554 187.801 39.639
-288.008 186.641 42.618
-288.464 185.428 45.2106
-298.669 165.29 66.0171
-293.439 179.52 -9.35383
-291.434 181.744 -6.13719
-289.354 189.346 8.56525
-289.282 190.701 13.4434
-288.433 191.019 17.1436
-287.091 190.817 20.6125
-288.18 190.818 29.7529
-288.459 190.095 33.7118
-289.02 189.472 36.6411
-299.827 164.924 -20.2872
-293.556 184.821 -3.02189
-291.126 186.549 0.972702
-289.529 191.672 20.3024
-290.666 188.497 40.7271
-291.539 186.798 44.728
-291.875 185.25 47.5383
-293.373 183.219 51.1269
-294.532 180.956 54.178
-293.552 178.865 55.9715
-301.961 162.19 67.5252
-299.549 169.776 -17.9557
-297.11 171.903 62.312
-293.596 189.02 4.5499
-292.169 192.522 23.1704
-291.834 192.306 26.3113
-291.59 191.87 29.7497
-292.265 191.199 33.9871
-299.783 168.702 64.531
-302.756 156.78 -22.9825
-302.787 161.056 -21.9053
-298.64 173.666 -15.3859
-298.338 176.089 -13.5408
-295.773 182.566 -6.66661
-294.372 187.013 0.231617
-293.536 190.816 9.40929
-293.826 192.06 14.0831
-292.816 192.469 18.4021
-295.173 192.303 32.0702
-294.106 190.262 38.6791
-295.001 188.274 43.7714
-295.17 186.175 47.495
-297.021 179.036 56.7144
-303.558 157.92 68.7641
-299.045 176.572 59.2544
-299.428 173.036 61.9499
-297.991 178.583 -11.3238
-298.721 181.86 -8.17319
-297.646 189.171 3.1415
-296.175 190.004 5.6607
-296.666 193.432 20.7095
-295.601 193.248 25.1274
-295.122 192.792 29.0425
-295.926 191.526 35.8546
-296.958 184.91 49.9072
-298.428 185.408 -3.62725
-297.908 187.702 0.207658
-297.425 191.875 10.3526
-297.801 193.155 16.1091
-298.293 183.223 52.4557
-300.256 181.893 54.368
-301.045 179.376 -10.9881
-298.41 190.398 40.2969
-298.514 188.505 44.4522
-299.708 186.857 47.6382
-301.351 179.092 57.3079
-303.701 165.953 -20.0923
-300.36 191.234 7.31991
-298.362 193.666 24.9
-298.516 193.239 29.7183
-300.274 192.417 34.8785
-301.408 185.015 50.6031
-303.122 166.546 65.7714
-305.817 154.599 69.4097
-303.659 170.573 -17.7281
-302.317 172.914 -16.1925
-302.335 176.262 -13.816
-301.576 184.836 -4.85143
-305.678 152.953 -23.6469
-303.311 182.473 -7.9314
-302.763 186.882 -1.91775
-302.244 188.007 -0.0102846
-302.748 189.607 3.03683
-301.682 192.741 12.2692
-301.702 193.954 20.5844
-301.719 193.925 25.4623
-301.366 193.497 29.8188
-302.068 190.731 40.2858
-301.919 188.947 44.204
-302.639 176.209 59.8322
-304.419 173.581 61.8573
-302.865 169.836 64.0894
-302.53 193.505 16.0853
-307.114 158.266 -22.6207
-304.052 179.61 -10.8805
-303.958 190.931 6.20414
-304.675 192.481 10.9184
-305.34 191.996 36.7129
-304.725 187.002 47.7933
-304.367 182.93 53.3506
-304.802 180.813 55.6813
-307.076 174.278 -15.2545
-305.798 185.615 -3.82688
-306.087 193.517 16.0784
-305.511 193.98 20.7656
-304.766 193.953 25.5181
-304.875 193.554 29.7287
-305.914 192.723 33.9586
-305.74 189.243 43.6132
-305.786 177.462 -12.7842
-307.489 188.179 0.483188
-305.543 190.803 40.0457
-307.475 184.821 50.8097
-306.884 177.717 58.5631
-306.765 169.225 64.3927
-306.231 165.085 66.372
-309.027 179.888 -10.3065
-307.243 182.515 -7.71739
-307.991 190.022 4.3311
-306.691 191.691 8.63317
-308.432 193.781 25.5585
-308.907 193.764 21.0844
-308.267 193.4 29.6013
-308.134 167.51 -19.1638
-307.042 171.382 -17.0966
-309.973 192.386 12.0211
-309.632 190.43 40.2622
-308.06 187.515 46.5417
-307.999 181.623 54.6251
-306.652 163.591 -20.9252
-309.623 185.652 -3.26505
-310.888 190.863 7.38837
-310.741 193.022 15.9177
-310.666 192.269 33.9544
-310.404 191.559 36.6489
-310.027 188.69 43.9491
-308.706 173.046 61.9268
-306.506 161.029 67.8212
-309.205 176.486 -13.2529
-311.983 185.952 48.2027
-311.75 182.917 -6.39137
-312.359 187.487 0.562364
-312.5 188.789 3.14082
-312.22 193.277 20.6609
-311.827 193.308 25.4135
-312.356 192.831 29.6174
-311.58 171.188 -16.654
-312.338 178.192 -11.2328
-312.596 182.767 52.3677
-311.17 179.712 56.0513
-310.084 165.442 65.8447
-314.08 185.177 -2.59707
-315.193 189.816 6.98087
-315.079 191.054 10.7362
-315.798 191.779 14.5261
-315.893 192.193 17.4511
-316.187 192.419 21.0581
-315.022 192.672 25.3952
-314.565 191.53 33.8449
-314.423 190.431 37.8043
-313.941 188.968 41.7643
-313.677 187.522 44.8124
-311.392 176.373 58.9753
-310.195 161.367 67.4106
-308.794 157.156 68.694
-310.431 163.276 -20.6959
-312.936 174.58 -14.0797
-314.112 180.638 -8.2988
-316.166 191.876 30.2597
-310.904 168.233 64.4113
-315.639 186.489 0.272147
-316.022 187.914 3.16176
-311.99 170.914 62.7256
-313.291 167.605 -18.2884
-315.941 182.627 -5.28443
-318.81 191.589 25.5682
-318.934 191.267 28.4841
-319.472 190.282 33.1504
-318.32 189.479 37.3601
-318.077 188.075 41.1423
-316.946 186.479 45.0989
-317.078 184.079 48.8781
-315.428 180.126 54.3834
-314.059 177.924 56.9749
-313.895 173.923 60.3234
-318.876 189.929 10.8516
-318.963 188.583 6.84395
-317.128 182.076 51.4618
-317.391 180.544 -7.12724
-318.003 184.632 -1.51928
-319.968 186.385 2.80446
-320.481 190.463 15.6126
-320.42 191.046 20.8872
-316.655 176.795 -11.1701
-319.871 182.054 -4.05164
-321.507 187.7 7.19283
-322.501 188.708 11.482
-322.431 190.225 25.5194
-323.208 189.298 30.4104
-321.856 188.274 36.7283
-321.267 185.969 42.8902
-320.994 184.533 45.7178
-318.452 177.686 55.6027
-317.081 174.726 58.7028
-310.768 154.489 -22.979
-312.137 159.504 -21.6281
-316.955 169.509 -16.2533
-317.627 171.936 -14.54
-321.772 183.931 -0.121442
-323.605 189.111 15.6705
-323.808 189.593 20.2442
-323.063 188.637 33.687
-323.356 186.606 39.4834
-319.243 179.811 53.0445
-320.231 178.793 -7.66114
-322.176 181.741 49.0623
-316.491 171.309 61.2724
-315.975 169.124 62.7404
-315.003 166.42 64.4381
-313.727 163.488 -19.9643
-319.731 174.93 -11.4547
-325.012 184.733 4.23016
-325.256 186.748 9.4567
-326.733 188.234 23.1768
-326.088 188.14 28.9885
-325.178 186.699 36.7189
-314.062 163.625 65.8227
-322.659 180.959 -3.70347
-327.099 187.042 14.2056
-326.513 187.938 17.6123
-326.011 187.091 33.9753
-324.646 183.992 43.4872
-322.852 177.929 53.0531
-321.113 174.627 57.0392
-323.509 174.245 -10.0807
-323.827 177.404 -6.91602
-326.023 181.25 -0.610987
-328.252 184.689 8.62707
-329.199 186.425 18.1417
-327.954 183.925 39.6141
-324.52 179.587 49.9948
-320.094 170.747 60.3137
-318.207 164.907 -18.1401
-326.62 177.802 -4.46165
-329.421 185.015 12.0031
-331.014 185.552 22.4471
-329.598 186.274 26.829
-329.224 185.908 30.9091
-328.727 185.34 34.387
-328.681 184.598 36.766
-327.857 182.26 43.0589
-325.892 180.895 47.1755
-325.448 174.494 54.6205
-322.318 170.803 -13.2073
-329.428 181.488 3.48143
-332.224 183.903 15.4295
-320.174 165.677 63.0874
-315.132 158.947 67.1433
-313.098 156.254 68.2263
-310.046 152.756 69.2935
-316.414 161.725 -19.929
-321.224 167.245 -15.8279
-333.33 183.622 19.3789
-332.558 184.19 26.9116
-332.193 183.956 30.212
-331.76 183.317 34.1333
-331.51 182.582 36.7522
-328.36 178.783 47.744
-327.266 177.064 50.7206
-317.114 162.223 65.5424
-328.053 175.426 -5.81498
-329.247 178.584 -1.05551
-331.702 182.033 8.22607
-332.288 182.96 12.0962
-331.11 181.696 39.5198
-323.927 171.429 57.8943
-334.74 181.344 32.3711
-330.605 180.126 43.1701
-315.564 157.147 -21.4799
-332.484 179.072 3.63107
-335.464 181.991 24.0556
-332.184 177.835 44.6842
-328.095 170.281 56.0616
-323.449 168.227 60.2146
-309.247 150.581 -23.6246
-325.348 169.267 -12.5435
-327.439 172.426 -8.87252
-332.488 175.821 -1.00009
-333.966 180.163 8.30816
-334.725 180.897 12.0742
-336.321 180.673 29.0665
-334.484 180.326 36.1488
-333.237 179.673 40.0433
-336.504 180.228 15.5756
-336.475 180.831 19.4936
-331.795 175.413 48.1656
-329.843 173.689 51.902
-323.687 164.464 -16.0396
-327.732 168.13 57.7097
-329.604 169.519 -9.41995
-331.854 172.162 -5.42613
-334.948 176.376 3.22336
-336.051 177.502 7.02289
-337.968 177.247 10.891
-339.222 178.222 22.5343
-339.33 178.014 25.4281
-337.306 178.857 32.3364
-337.933 177.14 35.5975
-335.795 177.053 40.3505
-335.295 174.394 45.0048
-319.469 158.866 65.8154
-319.967 157.945 -19.9041
-320.647 161.565 -18.5075
-328.06 166.19 -12.6454
-339.492 177.602 18.5807
-333.795 172.348 49.1606
-332.188 169.922 52.8882
-325.972 164.525 60.7774
-322.537 161.427 63.7932
-335.498 172.638 -0.779376
-336.893 174.189 3.2349
-338.052 175.223 6.93509
-339.553 176.494 14.1226
-339.509 177.097 29.8385
-337.596 174.276 41.5031
-332.857 169.159 -6.79766
-314.283 152.753 68.5489
-324.422 158.189 -17.9179
-332.449 166.1 55.283
-314.824 153.387 -22.3206
-327.141 160.989 -15.5205
-332.221 166.294 -9.30383
-336.494 168.256 -3.63888
-339.252 170.91 3.00395
-338.269 170.052 0.468508
-340.593 171.727 6.70951
-340.837 173.54 10.7109
-341.569 173.872 14.1023
-342.501 173.792 18.8676
-342.827 173.618 22.615
-342.56 173.709 26.8676
-341.336 174.084 32.3189
-340.258 173.439 37.1208
-338.528 170.445 44.7185
-336.227 169.521 48.9221
-339.822 171.433 41.2336
-330.14 164.443 57.9954
-317.821 154.856 67.2782
-334.748 165.322 -7.55971
-344.242 170.452 29.8471
-334.357 166.839 52.9451
-326.231 159.398 62.578
-331.358 162.585 -12.0032
-342.87 170.577 10.9135
-343.321 171.244 14.1521
-344.433 170.605 18.2001
-343.202 170.441 34.348
-342.012 169.917 38.5901
-330.056 160.612 59.7608
-318.15 153.561 -21.3708
-340.79 165.955 0.578652
-342.129 167.025 4.01404
-343.36 167.694 7.66782
-345.553 169.093 22.6765
-345.079 169.688 26.0558
-342.294 166.885 41.7538
-341.054 166.771 44.2687
-339.176 165.695 48.0697
-336.568 164.443 52.1595
-332.713 161.32 57.4013
-324.6 157.2 64.0287
-321.747 156.11 65.5924
-345.073 168.514 15.045
-322.22 153.306 -19.9397
-334.409 161.404 -9.84515
-338.788 164.289 -3.5679
-336.651 162.239 -7.22747
-344.478 167.674 10.9262
-345.295 166.613 34.1038
-344.051 166.595 38.0092
-335.802 160.824 54.8295
-313.478 149.699 -22.9919
-330.135 158.173 -14.4744
-332.902 159.184 -12.0479
-346.86 164.782 15.0208
-346.611 166.541 19.1556
-347.066 165.676 26.2404
-346.562 165.938 29.7146
-328.049 156.437 -16.2945
-344.112 163.386 4.66264
-345.077 164.005 7.65066
-345.922 164.376 10.5894
-338.933 161.62 50.8862
-328.803 156.257 61.9188
-321.401 151.647 66.4985
-339.919 161.858 -3.53752
-342.382 162.335 0.538937
-347.593 164.67 22.9006
-345.301 163.831 37.9715
-344.086 163.177 41.5318
-342.795 162.903 44.2997
-341.046 162.064 47.776
-326.288 153.945 -17.8462
-336.832 156.685 -9.31918
-337.523 159.782 -7.41472
-348.433 162.158 19.8865
-347.119 163.103 32.8147
-333.52 156.311 58.477
-324.967 153.614 64.5895
-332.158 154.982 -13.8567
-335.055 155.574 -11.2807
-340.109 157.195 -5.41467
-342.635 159.046 -1.00844
-345 160.326 4.13595
-347.063 159.616 8.77005
-347.907 159.917 12.0575
-348.464 160.738 16.0523
-348.859 161.161 22.9837
-348.639 161.245 27.4256
-346.477 160.703 37.8939
-344.937 160.21 42.0704
-343.468 158.541 45.8635
-341.142 158.495 49.5026
-338.736 157.283 53.0272
-336.519 156.531 55.6278
-318.214 150.866 67.6568
-321.449 149.57 -20.6478
-348.474 158.785 33.069
-329.769 152.945 -15.895
-328.101 152.03 63.0812
-343.35 154.734 -1.66668
-345.023 156.828 2.20657
-346.659 155.925 5.26155
-349.222 158.048 16.2149
-349.62 157.958 19.7949
-349.77 157.848 22.8994
-349.466 158.319 27.2727
-347.334 157.552 37.9803
-345.844 156.866 42.1158
-331.578 152.123 60.7879
-342.155 154.285 49.6141
-326.733 149.956 -18.1061
-340.615 152.935 -5.9574
-338 151.789 -9.20496
-348.131 154.527 8.51543
-348.951 155.321 11.9338
-349.538 155.429 14.8452
-350.087 155.389 27.4086
-349.586 155.453 30.8518
-344.598 153.583 45.8687
-338.875 152.385 54.1469
-335.909 151.755 57.2728
-345.661 153.618 2.21601
-350.357 153.977 18.8708
-350.312 155.16 23.0672
-349.19 153.766 34.1854
-348.209 153.861 37.5944
-346.558 153.326 42.0784
-344.432 151.545 -0.580888
-347.241 152.095 5.23315
-349.614 151.29 12.2476
-350.117 151.454 14.86
-350.82 151.7 23.7623
-350.64 151.068 27.7352
-350.145 151.203 31.1911
-341.186 150.918 51.5336
-342.851 149.815 -3.36406
-348.688 150.152 8.68258
-350.55 150.334 17.2922
-350.855 150.055 20.3228
-349.206 149.847 35.6907
-343.706 149.462 48.0986
3 0 1 2
3 2 3 0
3 4 5 6
3 7 5 4
3 8 9 10
3 11 10 9
3 12 13 14
3 15 14 13
3 16 17 15
3 18 19 20
3 21 3 2
3 22 3 21
3 23 24 22
3 24 23 25
3 6 25 26
3 6 26 4
3 27 28 7
3 29 30 28
3 27 29 28
3 31 32 30
3 30 29 31
3 33 32 31
3 33 34 32
3 35 36 34
3 33 35 34
3 37 38 36
3 36 35 37
3 39 38 37
3 39 9 8
3 40 41 42
3 42 41 43
3 43 44 42
3 12 44 43
3 45 17 16
3 46 47 48
3 1 49 2
3 23 50 25
3 50 26 25
3 4 51 7
3 7 51 27
3 40 11 52
3 53 12 43
3 12 53 13
3 29 54 31
3 33 31 54
3 55 37 35
3 35 56 55
3 37 55 57
3 57 39 37
3 58 9 39
3 57 58 39
3 11 9 59
3 58 59 9
3 11 59 52
3 40 52 60
3 60 41 40
3 41 60 43
3 13 61 15
3 61 16 15
3 62 20 63
3 21 64 22
3 23 22 64
3 65 27 51
3 51 66 65
3 29 27 65
3 54 67 33
3 56 35 33
3 33 67 56
3 68 69 46
3 62 18 20
3 18 70 71
3 72 23 64
3 23 72 50
3 26 50 73
3 26 73 74
3 4 26 74
3 74 66 4
3 66 51 4
3 65 75 29
3 54 29 75
3 43 76 53
3 45 77 78
3 78 77 69
3 70 79 71
3 80 71 79
3 49 81 82
3 49 82 2
3 21 2 82
3 76 43 60
3 83 53 76
3 13 53 84
3 53 83 84
3 61 13 84
3 85 16 61
3 45 16 85
3 85 77 45
3 72 86 50
3 86 73 50
3 66 87 65
3 88 75 65
3 87 88 65
3 89 54 75
3 75 88 89
3 67 54 89
3 90 59 58
3 58 91 90
3 92 52 59
3 59 90 92
3 60 52 92
3 79 93 80
3 49 80 93
3 93 81 49
3 94 21 82
3 64 21 95
3 72 64 95
3 74 73 86
3 89 96 67
3 97 56 67
3 67 96 97
3 55 56 98
3 56 97 98
3 99 57 55
3 55 98 99
3 91 58 57
3 57 99 91
3 60 100 76
3 70 18 62
3 21 94 95
3 100 101 76
3 84 102 61
3 102 103 61
3 81 104 82
3 95 105 72
3 105 106 72
3 106 86 72
3 107 66 74
3 74 108 107
3 87 66 109
3 66 107 109
3 110 88 87
3 109 110 87
3 111 89 88
3 88 110 111
3 112 96 89
3 111 112 89
3 112 97 96
3 99 113 91
3 114 91 113
3 114 90 91
3 90 114 115
3 90 115 92
3 92 116 60
3 100 60 116
3 76 101 83
3 117 83 101
3 102 84 83
3 83 117 102
3 77 118 69
3 104 94 82
3 108 74 86
3 85 61 103
3 119 97 112
3 98 97 120
3 97 119 120
3 99 98 121
3 98 120 121
3 113 99 121
3 116 92 115
3 85 122 77
3 122 118 77
3 104 123 94
3 123 95 94
3 86 106 108
3 100 124 101
3 63 125 126
3 62 63 126
3 127 81 93
3 81 127 104
3 128 110 109
3 111 110 129
3 110 128 129
3 112 111 130
3 111 129 130
3 112 130 119
3 131 113 121
3 114 113 131
3 132 116 115
3 100 116 133
3 124 134 101
3 117 101 134
3 135 102 117
3 136 103 102
3 137 85 103
3 136 137 103
3 138 70 62
3 79 70 138
3 95 123 139
3 95 139 105
3 108 106 140
3 140 141 108
3 108 141 142
3 107 108 142
3 142 143 107
3 107 143 144
3 109 107 144
3 144 128 109
3 120 119 145
3 120 146 121
3 131 121 146
3 147 114 131
3 115 114 147
3 147 132 115
3 132 133 116
3 124 100 133
3 135 117 134
3 135 136 102
3 46 69 148
3 106 105 149
3 140 106 149
3 145 119 130
3 85 137 122
3 138 150 79
3 93 79 150
3 151 123 104
3 139 152 105
3 152 149 105
3 146 153 131
3 131 153 147
3 132 154 133
3 154 155 133
3 155 124 133
3 126 156 62
3 157 93 150
3 127 93 157
3 139 123 151
3 158 141 140
3 142 141 158
3 159 128 144
3 129 128 159
3 130 129 159
3 146 120 145
3 160 147 153
3 161 132 147
3 160 161 147
3 132 161 154
3 124 155 134
3 140 149 162
3 144 163 159
3 155 164 134
3 135 134 164
3 135 165 166
3 166 136 135
3 46 167 47
3 149 152 162
3 158 140 162
3 142 168 143
3 168 169 143
3 144 143 169
3 144 169 163
3 170 130 159
3 171 170 159
3 170 172 130
3 130 172 145
3 173 146 145
3 145 174 173
3 146 173 153
3 175 160 153
3 125 176 126
3 177 127 157
3 104 127 178
3 177 178 127
3 104 178 151
3 178 179 151
3 139 151 180
3 180 152 139
3 158 181 142
3 168 142 181
3 163 171 159
3 145 172 174
3 182 153 173
3 153 182 175
3 160 183 161
3 183 184 161
3 161 184 154
3 164 165 135
3 185 122 137
3 137 186 185
3 137 136 186
3 166 186 136
3 62 156 138
3 150 187 157
3 157 187 177
3 151 179 188
3 188 180 151
3 152 180 189
3 190 152 189
3 162 152 190
3 191 158 162
3 162 190 191
3 192 181 158
3 191 192 158
3 193 168 181
3 192 193 181
3 194 169 168
3 168 193 194
3 163 169 194
3 195 163 194
3 171 163 195
3 196 172 170
3 171 196 170
3 172 196 174
3 197 173 174
3 174 198 197
3 173 197 182
3 183 160 175
3 184 199 154
3 154 199 200
3 155 154 200
3 200 201 155
3 201 164 155
3 189 180 188
3 198 174 196
3 165 164 201
3 202 118 122
3 185 202 122
3 69 118 148
3 203 182 197
3 203 204 182
3 175 182 204
3 205 183 175
3 204 205 175
3 206 184 183
3 183 205 206
3 199 184 206
3 165 207 166
3 208 185 186
3 202 148 118
3 138 209 150
3 210 194 193
3 211 195 194
3 194 210 211
3 212 171 195
3 211 212 195
3 213 196 171
3 171 212 213
3 196 213 198
3 166 214 186
3 208 186 214
3 156 215 138
3 138 215 209
3 178 216 179
3 217 188 179
3 179 216 217
3 188 217 189
3 218 190 189
3 191 190 218
3 191 219 192
3 220 193 192
3 192 219 220
3 193 220 210
3 221 198 213
3 197 198 221
3 203 197 221
3 222 200 199
3 199 223 222
3 222 201 200
3 187 150 209
3 224 189 217
3 189 224 218
3 165 225 207
3 166 207 214
3 187 226 177
3 227 178 177
3 216 178 227
3 218 228 191
3 191 228 229
3 219 191 229
3 230 219 229
3 230 220 219
3 220 230 231
3 210 220 231
3 210 232 211
3 233 212 211
3 211 232 233
3 234 213 212
3 212 233 234
3 213 234 221
3 235 203 221
3 236 204 203
3 203 235 236
3 237 205 204
3 236 237 204
3 205 237 206
3 223 199 206
3 201 222 225
3 225 165 201
3 223 206 237
3 207 238 214
3 148 239 46
3 176 125 240
3 227 177 226
3 241 216 227
3 242 217 216
3 216 241 242
3 224 217 242
3 243 230 229
3 210 231 232
3 234 244 221
3 235 221 244
3 223 245 222
3 246 222 245
3 246 225 222
3 239 167 46
3 233 247 234
3 237 248 223
3 248 245 223
3 225 238 207
3 231 230 243
3 231 249 232
3 233 232 250
3 249 250 232
3 233 250 247
3 185 251 202
3 252 187 209
3 226 253 227
3 227 253 241
3 242 254 224
3 255 224 254
3 218 224 255
3 255 256 218
3 256 228 218
3 229 228 256
3 257 231 243
3 231 257 249
3 247 258 234
3 259 244 234
3 234 258 259
3 260 235 244
3 244 259 260
3 236 235 261
3 235 260 261
3 262 237 236
3 236 261 262
3 237 262 248
3 185 208 251
3 208 263 251
3 264 239 148
3 226 187 252
3 229 256 265
3 243 229 265
3 243 265 266
3 243 266 257
3 267 245 248
3 246 245 267
3 268 225 246
3 225 268 269
3 225 269 238
3 238 270 214
3 263 208 214
3 270 263 214
3 202 251 264
3 148 202 264
3 257 271 249
3 271 250 249
3 209 215 272
3 272 252 209
3 273 241 253
3 242 241 274
3 241 273 274
3 254 242 274
3 250 271 275
3 247 250 275
3 276 247 275
3 258 247 276
3 259 277 260
3 260 277 278
3 278 261 260
3 278 279 261
3 279 262 261
3 280 248 262
3 262 279 280
3 248 280 267
3 215 281 272
3 282 257 266
3 257 282 271
3 283 267 280
3 246 267 283
3 283 284 246
3 284 268 246
3 156 126 285
3 156 281 215
3 252 286 226
3 254 287 255
3 288 256 255
3 256 288 289
3 265 256 289
3 290 258 276
3 259 258 290
3 290 291 259
3 259 291 277
3 292 277 291
3 292 278 277
3 269 268 284
3 253 226 286
3 253 293 273
3 294 273 293
3 294 274 273
3 294 295 274
3 254 274 295
3 287 254 295
3 296 266 265
3 289 296 265
3 296 282 266
3 282 296 297
3 282 297 271
3 297 298 271
3 271 298 275
3 299 275 298
3 300 276 275
3 275 299 300
3 276 300 290
3 278 292 301
3 301 279 278
3 302 279 301
3 302 280 279
3 280 302 303
3 303 283 280
3 304 270 238
3 305 270 304
3 305 263 270
3 305 306 263
3 263 306 251
3 255 287 307
3 307 288 255
3 308 269 284
3 238 269 304
3 295 309 287
3 288 307 310
3 289 288 310
3 300 311 290
3 291 290 311
3 304 269 308
3 306 312 251
3 251 312 264
3 286 313 253
3 293 253 313
3 287 309 307
3 314 283 303
3 283 314 284
3 176 285 126
3 286 252 272
3 315 307 309
3 316 296 289
3 297 296 317
3 296 316 317
3 318 298 297
3 297 317 318
3 299 298 319
3 298 318 319
3 300 299 320
3 319 320 299
3 311 300 320
3 311 321 291
3 322 292 291
3 291 321 322
3 323 301 292
3 292 322 323
3 302 301 323
3 302 323 324
3 302 324 303
3 325 293 313
3 294 293 325
3 326 295 294
3 326 309 295
3 327 310 307
3 315 327 307
3 289 310 328
3 310 327 328
3 289 328 316
3 324 329 303
3 314 303 329
3 314 330 284
3 284 330 308
3 308 331 304
3 305 304 331
3 332 294 325
3 333 316 328
3 334 317 316
3 316 333 334
3 318 317 334
3 335 318 334
3 335 319 318
3 336 320 319
3 335 336 319
3 337 311 320
3 336 337 320
3 338 321 311
3 337 338 311
3 339 322 321
3 321 338 339
3 340 323 322
3 322 339 340
3 323 340 341
3 323 341 324
3 330 342 308
3 281 156 285
3 343 286 272
3 344 313 286
3 325 313 344
3 326 294 332
3 326 345 309
3 345 315 309
3 308 342 331
3 346 306 305
3 343 344 286
3 315 345 347
3 327 315 348
3 315 347 348
3 328 327 349
3 327 348 349
3 350 333 328
3 328 349 350
3 333 350 351
3 333 351 334
3 334 352 335
3 338 353 339
3 354 340 339
3 339 353 354
3 341 340 354
3 341 355 324
3 356 329 324
3 355 356 324
3 357 314 329
3 356 357 329
3 314 357 330
3 357 358 330
3 359 342 330
3 330 358 359
3 312 306 346
3 239 360 167
3 272 281 361
3 343 272 361
3 334 351 352
3 359 362 342
3 362 331 342
3 363 305 331
3 362 363 331
3 305 363 346
3 364 312 346
3 365 264 312
3 312 364 365
3 366 239 264
3 367 281 285
3 368 332 325
3 335 369 336
3 370 336 369
3 370 337 336
3 337 370 371
3 371 338 337
3 338 371 353
3 354 372 341
3 355 341 372
3 367 361 281
3 343 373 344
3 344 374 325
3 332 368 375
3 326 332 375
3 326 375 345
3 376 345 375
3 345 376 347
3 376 377 347
3 377 348 347
3 378 349 348
3 348 377 378
3 379 350 349
3 349 378 379
3 351 350 380
3 350 379 380
3 381 352 351
3 351 380 381
3 335 352 382
3 381 382 352
3 382 369 335
3 383 353 371
3 354 353 383
3 384 358 357
3 358 384 359
3 47 167 385
3 366 360 239
3 386 343 361
3 373 374 344
3 325 374 387
3 368 325 387
3 379 388 380
3 389 370 369
3 369 382 389
3 390 371 370
3 370 389 390
3 371 390 383
3 383 391 354
3 354 391 392
3 354 392 372
3 393 355 372
3 372 392 393
3 394 356 355
3 355 393 394
3 356 394 357
3 395 357 394
3 357 395 384
3 264 365 366
3 396 375 368
3 377 397 378
3 388 379 378
3 397 388 378
3 388 398 380
3 398 381 380
3 346 399 364
3 376 400 377
3 401 393 392
3 392 402 401
3 393 401 394
3 401 403 394
3 394 403 395
3 360 385 167
3 343 386 373
3 387 404 368
3 396 368 404
3 396 405 375
3 405 376 375
3 397 377 406
3 407 381 398
3 407 382 381
3 407 408 382
3 382 408 389
3 408 409 389
3 410 390 389
3 409 410 389
3 390 410 411
3 383 390 411
3 411 412 383
3 413 391 383
3 383 412 413
3 392 391 413
3 392 413 402
3 414 395 403
3 414 384 395
3 414 415 384
3 359 384 415
3 416 362 359
3 415 416 359
3 417 363 362
3 362 416 417
3 346 363 418
3 363 417 418
3 399 365 364
3 419 285 176
3 285 419 367
3 376 405 400
3 377 400 406
3 373 420 374
3 387 374 420
3 400 421 406
3 422 397 406
3 422 388 397
3 423 407 398
3 408 407 423
3 410 424 411
3 399 346 418
3 425 366 365
3 426 419 176
3 386 361 427
3 428 405 396
3 421 400 405
3 405 428 421
3 422 429 388
3 398 388 429
3 430 398 429
3 398 430 423
3 427 361 367
3 431 386 427
3 373 386 431
3 373 431 420
3 432 408 423
3 423 433 432
3 424 410 409
3 424 434 411
3 412 411 435
3 411 434 435
3 436 413 412
3 435 436 412
3 402 413 436
3 436 437 402
3 401 402 437
3 401 437 438
3 438 403 401
3 439 415 414
3 440 416 415
3 439 440 415
3 416 440 417
3 440 441 417
3 417 441 418
3 399 425 365
3 404 387 442
3 396 404 443
3 442 443 404
3 406 421 444
3 422 406 445
3 406 444 445
3 429 446 430
3 446 433 430
3 433 423 430
3 408 432 447
3 447 409 408
3 424 409 447
3 448 414 403
3 403 438 448
3 448 439 414
3 420 442 387
3 396 443 428
3 449 434 424
3 434 449 435
3 450 437 436
3 437 450 438
3 451 421 428
3 444 421 451
3 429 422 452
3 422 453 452
3 452 446 429
3 433 454 432
3 455 447 432
3 432 454 455
3 456 424 447
3 447 455 456
3 424 456 449
3 449 457 435
3 457 436 435
3 457 458 436
3 436 458 450
3 419 459 367
3 428 443 460
3 451 428 460
3 422 445 453
3 440 461 441
3 418 462 399
3 426 176 240
3 463 451 460
3 463 444 451
3 444 463 464
3 445 444 465
3 444 464 465
3 453 445 465
3 466 433 446
3 433 466 454
3 438 450 467
3 461 440 439
3 367 459 427
3 468 442 420
3 465 469 453
3 452 453 469
3 470 446 452
3 466 446 470
3 438 467 448
3 461 471 441
3 418 441 462
3 399 462 472
3 399 472 425
3 425 473 366
3 473 360 366
3 474 420 431
3 442 475 443
3 475 476 443
3 443 476 460
3 477 454 466
3 478 455 454
3 454 477 478
3 479 456 455
3 455 478 479
3 449 456 479
3 480 449 479
3 480 457 449
3 481 457 480
3 481 458 457
3 450 458 482
3 458 481 482
3 467 450 482
3 483 448 467
3 484 439 448
3 483 484 448
3 484 485 439
3 439 485 461
3 471 462 441
3 475 442 468
3 486 460 476
3 463 460 486
3 487 452 469
3 487 470 452
3 488 466 470
3 470 487 488
3 466 488 477
3 431 427 489
3 468 420 474
3 478 490 479
3 490 491 479
3 482 492 467
3 492 493 467
3 467 493 483
3 462 494 472
3 419 495 459
3 489 427 459
3 486 496 463
3 463 496 497
3 463 497 464
3 464 497 498
3 465 464 498
3 499 469 465
3 498 499 465
3 487 469 499
3 488 500 477
3 478 477 500
3 501 478 500
3 478 501 490
3 479 491 480
3 461 502 471
3 494 462 471
3 474 503 468
3 503 475 468
3 504 476 475
3 486 476 504
3 480 505 481
3 505 506 481
3 482 481 506
3 506 492 482
3 507 485 484
3 502 461 485
3 474 431 489
3 475 508 504
3 486 509 496
3 510 488 487
3 487 511 510
3 488 510 500
3 507 484 483
3 508 475 503
3 509 512 496
3 513 497 496
3 512 513 496
3 514 498 497
3 497 513 514
3 499 498 514
3 511 487 499
3 515 500 510
3 501 500 515
3 480 491 516
3 491 517 516
3 505 480 516
3 506 518 492
3 519 483 493
3 483 519 507
3 502 485 507
3 502 520 471
3 494 471 520
3 521 474 489
3 509 486 504
3 522 510 511
3 515 523 501
3 490 501 523
3 523 524 490
3 491 490 524
3 524 517 491
3 493 492 518
3 525 493 518
3 493 525 519
3 526 489 459
3 527 499 514
3 499 527 511
3 528 511 527
3 511 528 522
3 515 510 522
3 495 419 426
3 474 521 529
3 529 503 474
3 504 508 530
3 530 509 504
3 531 517 524
3 531 516 517
3 516 531 532
3 516 532 505
3 533 506 505
3 532 533 505
3 534 502 507
3 425 472 535
3 508 503 529
3 508 536 530
3 537 513 512
3 513 537 538
3 514 513 538
3 506 533 539
3 539 518 506
3 525 518 539
3 525 540 519
3 507 519 540
3 502 534 520
3 489 526 541
3 489 541 521
3 542 509 530
3 512 509 542
3 512 542 537
3 543 514 538
3 527 514 543
3 527 544 528
3 522 528 545
3 528 544 545
3 545 546 522
3 522 546 515
3 515 546 547
3 547 523 515
3 524 523 547
3 540 548 507
3 507 548 534
3 494 549 472
3 549 550 472
3 472 550 535
3 473 425 535
3 551 521 541
3 551 529 521
3 536 508 529
3 524 552 531
3 552 553 531
3 531 553 532
3 520 554 494
3 554 549 494
3 555 360 473
3 385 360 555
3 495 556 459
3 556 526 459
3 557 527 543
3 557 544 527
3 546 558 547
3 559 547 558
3 559 524 547
3 524 559 552
3 560 532 553
3 561 533 532
3 532 560 561
3 539 533 561
3 539 562 525
3 563 540 525
3 564 534 548
3 548 565 564
3 564 566 534
3 520 534 566
3 567 542 530
3 542 567 537
3 567 568 537
3 568 538 537
3 568 543 538
3 525 562 563
3 535 569 473
3 555 473 569
3 536 570 530
3 544 557 571
3 545 544 572
3 544 571 572
3 573 546 545
3 545 572 573
3 552 574 553
3 560 553 574
3 565 548 540
3 526 575 541
3 529 551 576
3 529 576 536
3 530 577 567
3 543 568 578
3 543 578 557
3 571 557 578
3 546 573 579
3 579 558 546
3 580 559 558
3 558 579 580
3 552 559 581
3 559 580 581
3 552 581 574
3 582 560 574
3 560 582 561
3 583 561 582
3 583 539 561
3 583 584 539
3 585 562 539
3 539 584 585
3 562 585 563
3 540 563 565
3 566 586 520
3 586 554 520
3 576 587 536
3 587 570 536
3 570 577 530
3 577 588 567
3 588 589 567
3 568 567 589
3 572 590 573
3 590 579 573
3 583 591 584
3 585 584 591
3 592 563 585
3 565 563 592
3 565 593 564
3 564 593 566
3 551 541 594
3 568 595 578
3 595 596 578
3 571 578 596
3 580 597 581
3 574 581 597
3 575 594 541
3 587 598 570
3 577 570 598
3 568 589 599
3 572 571 600
3 600 601 572
3 572 601 590
3 579 590 602
3 580 579 602
3 582 603 583
3 604 585 591
3 585 604 592
3 549 605 550
3 526 556 575
3 551 594 606
3 576 551 606
3 588 577 598
3 568 599 595
3 571 596 600
3 602 607 580
3 597 580 607
3 608 574 597
3 609 582 574
3 574 608 609
3 582 609 603
3 593 610 566
3 586 566 610
3 599 589 588
3 601 611 590
3 590 611 602
3 603 612 583
3 612 591 583
3 613 592 604
3 614 565 592
3 592 613 614
3 565 614 593
3 615 586 610
3 616 550 605
3 606 617 576
3 617 587 576
3 618 595 599
3 618 596 595
3 591 612 604
3 554 586 615
3 605 554 615
3 549 554 605
3 535 550 616
3 569 535 616
3 619 588 598
3 588 620 599
3 599 620 618
3 596 618 621
3 622 600 596
3 596 621 622
3 611 601 600
3 600 622 611
3 611 623 602
3 624 607 602
3 602 623 624
3 597 607 624
3 624 625 597
3 597 625 608
3 626 608 625
3 609 608 627
3 608 626 627
3 628 603 609
3 627 628 609
3 629 612 603
3 603 628 629
3 630 604 612
3 629 630 612
3 604 630 613
3 617 631 587
3 587 631 598
3 632 593 614
3 610 593 632
3 575 633 594
3 634 619 598
3 588 619 620
3 622 635 636
3 636 611 622
3 611 636 637
3 638 623 611
3 611 637 638
3 624 623 638
3 639 613 630
3 640 614 613
3 613 639 640
3 614 640 632
3 610 641 615
3 615 641 605
3 569 642 555
3 495 426 643
3 633 606 594
3 631 634 598
3 644 620 619
3 645 618 620
3 620 644 645
3 618 645 621
3 556 646 575
3 645 647 621
3 635 622 621
3 621 647 635
3 648 624 638
3 649 625 624
3 624 648 649
3 650 626 625
3 625 649 650
3 626 650 651
3 651 627 626
3 651 628 627
3 651 652 628
3 628 652 629
3 642 569 616
3 643 556 495
3 629 652 653
3 653 630 629
3 654 630 653
3 630 654 639
3 640 655 632
3 656 610 632
3 610 656 641
3 617 657 631
3 644 658 645
3 647 659 635
3 660 636 635
3 659 660 635
3 661 637 636
3 636 660 661
3 661 638 637
3 662 638 661
3 662 648 638
3 648 662 663
3 648 663 649
3 664 649 663
3 649 664 650
3 665 650 664
3 665 651 650
3 654 666 639
3 639 666 640
3 656 632 655
3 667 605 641
3 605 667 616
3 619 634 668
3 644 619 668
3 651 665 669
3 651 669 670
3 670 652 651
3 640 671 655
3 643 646 556
3 646 672 575
3 633 575 672
3 606 633 673
3 617 606 673
3 617 673 657
3 674 634 631
3 645 658 675
3 647 645 675
3 676 647 675
3 676 659 647
3 661 677 662
3 664 663 678
3 679 653 652
3 652 670 679
3 654 653 679
3 666 671 640
3 426 240 680
3 663 662 681
3 662 677 681
3 663 681 678
3 671 682 655
3 656 655 682
3 631 657 683
3 674 631 683
3 668 634 674
3 684 644 668
3 644 684 685
3 685 658 644
3 675 658 685
3 678 686 664
3 665 664 686
3 686 687 665
3 669 665 687
3 688 670 669
3 633 689 673
3 690 657 673
3 690 683 657
3 691 675 685
3 676 675 691
3 692 676 691
3 659 676 692
3 693 660 659
3 692 693 659
3 661 660 694
3 693 694 660
3 677 661 694
3 687 695 669
3 688 669 695
3 696 666 654
3 696 671 666
3 656 697 641
3 667 698 616
3 698 642 616
3 699 385 555
3 700 668 674
3 674 701 700
3 684 668 700
3 685 702 691
3 703 677 694
3 677 703 704
3 677 704 681
3 705 686 678
3 687 686 705
3 670 688 706
3 679 670 706
3 707 654 679
3 708 707 679
3 654 707 696
3 709 667 641
3 642 710 555
3 672 711 633
3 711 689 633
3 673 689 712
3 712 690 673
3 701 674 683
3 713 681 704
3 678 681 713
3 705 678 713
3 708 679 706
3 696 714 671
3 682 671 714
3 682 715 656
3 697 709 641
3 684 700 716
3 702 685 684
3 684 716 702
3 702 717 691
3 692 691 717
3 703 694 693
3 705 718 687
3 718 719 687
3 695 687 719
3 720 688 695
3 719 720 695
3 721 706 688
3 688 720 721
3 708 706 721
3 722 707 708
3 722 696 707
3 696 722 714
3 697 656 715
3 667 709 723
3 426 724 643
3 725 683 690
3 701 683 725
3 701 726 700
3 716 700 726
3 727 692 717
3 692 727 728
3 693 692 728
3 729 703 693
3 693 728 729
3 704 703 730
3 729 730 703
3 713 704 730
3 730 731 713
3 732 705 713
3 713 731 732
3 705 732 718
3 733 714 722
3 734 682 714
3 714 733 734
3 715 682 734
3 667 723 698
3 721 735 708
3 712 689 711
3 736 690 712
3 737 716 726
3 738 702 716
3 737 738 716
3 738 739 702
3 739 717 702
3 717 739 740
3 717 740 727
3 732 741 718
3 718 741 719
3 708 735 742
3 742 722 708
3 734 743 715
3 697 715 743
3 642 698 744
3 744 710 642
3 555 710 699
3 725 690 736
3 745 701 725
3 726 701 745
3 745 737 726
3 746 719 741
3 746 720 719
3 720 746 747
3 747 721 720
3 735 721 747
3 722 742 748
3 722 748 733
3 426 680 724
3 709 697 749
3 709 750 723
3 751 711 672
3 752 712 711
3 712 752 753
3 712 753 736
3 754 740 739
3 739 755 754
3 727 740 754
3 728 727 756
3 727 754 756
3 729 728 757
3 728 756 757
3 758 730 729
3 729 757 758
3 758 731 730
3 731 758 759
3 732 731 759
3 760 741 732
3 732 759 760
3 741 760 746
3 747 761 735
3 761 762 735
3 762 742 735
3 748 742 762
3 763 733 748
3 733 763 734
3 763 764 734
3 764 743 734
3 743 749 697
3 751 752 711
3 745 725 765
3 766 746 760
3 746 766 747
3 767 723 750
3 698 723 767
3 643 768 646
3 672 646 769
3 751 672 769
3 753 770 736
3 765 725 736
3 770 765 736
3 771 737 745
3 737 771 772
3 737 772 738
3 738 773 739
3 739 773 755
3 749 743 764
3 769 646 768
3 745 774 771
3 773 738 772
3 775 755 773
3 775 754 755
3 754 775 776
3 756 754 776
3 777 756 776
3 757 756 777
3 778 757 777
3 778 758 757
3 758 778 779
3 758 779 759
3 759 780 760
3 766 760 780
3 766 781 747
3 761 747 781
3 782 748 762
3 763 748 782
3 749 783 709
3 750 709 783
3 752 784 753
3 765 774 745
3 785 761 781
3 761 785 762
3 785 786 762
3 762 786 782
3 784 752 751
3 787 773 772
3 773 787 788
3 773 788 775
3 789 759 779
3 759 789 780
3 790 766 780
3 766 790 781
3 767 791 698
3 744 698 791
3 771 774 792
3 787 772 771
3 771 792 787
3 793 775 788
3 794 776 775
3 775 793 794
3 795 777 776
3 776 794 795
3 796 778 777
3 777 795 796
3 797 779 778
3 778 796 797
3 797 789 779
3 798 780 789
3 790 780 798
3 799 781 790
3 799 785 781
3 800 782 786
3 763 782 800
3 800 801 763
3 764 763 802
3 763 801 802
3 783 803 750
3 767 750 803
3 769 804 751
3 710 805 699
3 385 699 806
3 47 385 806
3 643 724 768
3 751 804 807
3 807 784 751
3 753 784 808
3 770 753 808
3 765 770 809
3 774 765 810
3 792 774 810
3 787 811 788
3 797 812 789
3 789 812 813
3 789 813 798
3 814 798 813
3 814 790 798
3 814 815 790
3 790 815 799
3 799 816 785
3 786 785 816
3 817 749 764
3 764 802 817
3 817 783 749
3 805 710 744
3 765 809 810
3 768 818 769
3 809 770 808
3 810 819 792
3 792 820 787
3 811 787 820
3 821 788 811
3 793 788 821
3 793 821 822
3 823 794 793
3 793 822 823
3 824 795 794
3 823 824 794
3 796 795 825
3 795 824 825
3 796 825 826
3 796 826 797
3 812 797 826
3 812 827 813
3 814 813 827
3 799 815 828
3 828 816 799
3 829 786 816
3 786 829 800
3 830 800 829
3 800 830 801
3 831 809 808
3 809 831 810
3 832 812 826
3 833 815 814
3 828 815 833
3 834 784 807
3 784 834 808
3 792 819 820
3 820 835 811
3 811 835 821
3 836 823 822
3 823 837 824
3 825 824 838
3 824 837 838
3 839 826 825
3 838 839 825
3 826 839 832
3 827 812 832
3 827 840 814
3 833 814 840
3 829 816 828
3 830 841 801
3 842 802 801
3 841 842 801
3 802 842 817
3 843 803 783
3 767 803 843
3 744 791 844
3 744 844 805
3 845 768 724
3 819 810 846
3 847 821 835
3 836 822 821
3 821 847 836
3 828 848 829
3 848 849 829
3 830 829 849
3 850 817 842
3 817 850 851
3 783 817 851
3 767 852 791
3 852 844 791
3 834 853 808
3 808 853 831
3 831 846 810
3 854 835 820
3 820 855 854
3 835 854 847
3 856 823 836
3 856 837 823
3 857 832 839
3 858 827 832
3 832 857 858
3 840 827 858
3 851 843 783
3 852 767 843
3 805 806 699
3 768 845 818
3 859 769 818
3 859 804 769
3 860 807 804
3 846 861 819
3 855 820 819
3 819 861 855
3 862 838 837
3 862 839 838
3 857 839 862
3 863 833 840
3 833 863 864
3 828 833 864
3 865 828 864
3 828 865 848
3 830 866 841
3 842 867 850
3 804 859 860
3 847 868 836
3 836 868 869
3 856 836 869
3 857 870 858
3 863 840 858
3 858 870 863
3 834 871 853
3 872 853 871
3 831 853 872
3 873 855 861
3 854 855 873
3 854 874 847
3 847 874 868
3 862 837 856
3 862 875 857
3 857 875 876
3 876 870 857
3 863 877 864
3 865 864 877
3 865 878 848
3 849 848 879
3 848 878 879
3 866 830 849
3 849 879 866
3 880 841 866
3 880 842 841
3 867 842 880
3 807 860 881
3 834 807 881
3 882 846 831
3 883 861 846
3 846 882 883
3 883 873 861
3 856 884 862
3 867 885 850
3 851 850 885
3 871 834 881
3 872 882 831
3 873 886 854
3 887 874 854
3 854 886 887
3 888 868 874
3 874 887 888
3 889 869 868
3 868 888 889
3 856 869 884
3 869 889 884
3 884 890 862
3 890 875 862
3 891 875 890
3 891 876 875
3 876 892 870
3 863 870 892
3 893 879 878
3 893 866 879
3 866 893 894
3 866 894 880
3 859 895 860
3 892 896 863
3 863 896 877
3 897 851 885
3 843 851 897
3 843 898 852
3 844 899 805
3 881 900 871
3 901 882 872
3 882 901 883
3 902 873 883
3 873 902 903
3 903 886 873
3 904 892 876
3 905 877 896
3 905 865 877
3 906 878 865
3 865 905 906
3 878 906 893
3 907 845 724
3 895 908 860
3 881 860 908
3 871 900 909
3 909 872 871
3 872 909 901
3 902 883 901
3 910 889 888
3 888 911 910
3 884 889 910
3 910 912 884
3 913 890 884
3 884 912 913
3 891 890 913
3 904 876 891
3 914 892 904
3 914 896 892
3 905 896 914
3 867 915 885
3 885 916 897
3 843 897 898
3 898 917 852
3 680 907 724
3 886 903 918
3 887 886 918
3 918 919 887
3 888 887 919
3 919 911 888
3 905 920 906
3 867 880 915
3 844 852 917
3 881 921 900
3 891 913 922
3 904 891 922
3 920 923 906
3 893 906 923
3 924 893 923
3 894 893 924
3 880 894 925
3 894 924 925
3 880 925 915
3 915 916 885
3 818 845 926
3 859 818 927
3 895 859 927
3 928 902 901
3 901 929 928
3 902 928 930
3 903 902 931
3 902 930 931
3 918 903 931
3 932 914 904
3 904 933 932
3 905 914 934
3 914 932 934
3 897 935 898
3 921 936 900
3 909 900 936
3 929 901 909
3 937 911 919
3 910 911 937
3 938 912 910
3 910 937 938
3 913 912 939
3 912 938 939
3 940 913 939
3 913 940 922
3 922 941 904
3 941 933 904
3 905 934 942
3 920 905 942
3 915 943 916
3 944 917 898
3 908 921 881
3 945 909 936
3 945 929 909
3 946 897 916
3 897 946 935
3 927 818 926
3 947 940 939
3 922 940 948
3 940 947 948
3 941 922 948
3 949 933 941
3 949 932 933
3 950 934 932
3 932 949 950
3 934 950 942
3 942 951 920
3 923 920 951
3 923 952 924
3 924 952 925
3 925 943 915
3 935 944 898
3 917 953 844
3 845 907 926
3 930 954 931
3 954 955 931
3 918 931 955
3 918 955 956
3 919 918 956
3 957 919 956
3 957 937 919
3 937 957 958
3 959 938 937
3 937 958 959
3 939 938 960
3 938 959 960
3 947 939 960
3 943 961 916
3 916 961 946
3 895 927 962
3 908 895 962
3 929 963 928
3 949 964 950
3 950 965 942
3 965 951 942
3 966 923 951
3 966 952 923
3 952 967 925
3 844 953 899
3 930 928 968
3 928 963 968
3 968 954 930
3 969 948 947
3 970 969 947
3 969 941 948
3 969 971 941
3 972 949 941
3 941 971 972
3 949 972 964
3 925 967 973
3 973 943 925
3 974 961 943
3 974 975 961
3 975 946 961
3 805 899 976
3 977 936 921
3 945 936 977
3 978 955 954
3 956 955 978
3 957 979 958
3 979 980 958
3 980 959 958
3 981 960 959
3 959 980 981
3 947 960 981
3 981 970 947
3 966 951 965
3 974 943 973
3 935 946 975
3 917 944 982
3 982 953 917
3 962 983 908
3 921 908 983
3 984 929 945
3 929 984 963
3 985 963 984
3 968 963 985
3 986 957 956
3 957 986 987
3 957 987 979
3 964 988 950
3 950 988 965
3 978 954 968
3 986 956 978
3 971 989 972
3 964 972 989
3 966 990 991
3 952 966 991
3 991 992 952
3 992 967 952
3 992 973 967
3 975 993 935
3 944 994 982
3 926 995 927
3 962 927 995
3 977 996 945
3 996 997 945
3 997 984 945
3 980 998 981
3 965 999 966
3 999 990 966
3 994 944 935
3 983 1000 921
3 1000 977 921
3 1001 986 978
3 1002 970 981
3 1002 969 970
3 1002 1003 969
3 969 1003 971
3 989 971 1003
3 988 964 989
3 988 1004 965
3 974 973 992
3 993 994 935
3 806 805 976
3 1005 968 985
3 978 968 1006
3 968 1005 1006
3 978 1006 1001
3 986 1001 1007
3 987 986 1008
3 1007 1008 986
3 979 987 1009
3 1008 1009 987
3 980 979 1009
3 998 980 1009
3 998 1010 981
3 981 1010 1002
3 965 1004 999
3 953 1011 899
3 977 1000 996
3 985 984 997
3 1003 1012 989
3 1012 1013 989
3 1013 988 989
3 1004 988 1013
3 1014 991 990
3 990 1015 1014
3 992 991 1014
3 992 1016 974
3 974 1017 975
3 1017 1018 975
3 975 1018 993
3 953 982 1011
3 1011 976 899
3 962 1019 983
3 1019 1000 983
3 985 1020 1005
3 1021 998 1009
3 1010 998 1021
3 1015 990 999
3 1000 1022 996
3 997 996 1022
3 997 1023 985
3 1023 1020 985
3 1005 1024 1025
3 1025 1006 1005
3 1006 1025 1001
3 1026 1001 1025
3 1007 1001 1026
3 1027 1009 1008
3 1009 1027 1021
3 1021 1028 1010
3 1028 1029 1010
3 1002 1010 1029
3 1002 1029 1030
3 1031 1003 1002
3 1030 1031 1002
3 1012 1003 1031
3 1013 1032 1004
3 1004 1032 1033
3 999 1004 1033
3 999 1033 1015
3 1014 1034 992
3 992 1034 1016
3 1017 974 1016
3 993 1035 994
3 1036 1007 1026
3 1036 1008 1007
3 1008 1036 1027
3 1018 1035 993
3 1024 1005 1020
3 1013 1037 1032
3 1032 1038 1033
3 1033 1038 1039
3 1039 1015 1033
3 982 994 1040
3 962 995 1041
3 962 1041 1019
3 1042 997 1022
3 997 1042 1023
3 1036 1043 1027
3 1021 1027 1043
3 1044 1031 1030
3 1044 1012 1031
3 1037 1013 1012
3 1012 1044 1037
3 1015 1039 1014
3 1045 1034 1014
3 1016 1034 1045
3 1046 1017 1016
3 982 1047 1011
3 1046 1048 1017
3 1035 1018 1049
3 1035 1040 994
3 1050 907 680
3 1000 1019 1051
3 1051 1022 1000
3 1042 1052 1023
3 1020 1023 1052
3 1053 1036 1026
3 1036 1053 1043
3 1043 1054 1021
3 1055 1028 1021
3 1021 1054 1055
3 1056 1029 1028
3 1055 1056 1028
3 1030 1029 1057
3 1029 1056 1057
3 1030 1057 1044
3 1037 1058 1032
3 1038 1032 1059
3 1032 1058 1059
3 1039 1038 1059
3 1039 1060 1014
3 1045 1014 1060
3 1046 1016 1045
3 1017 1048 1018
3 1049 1018 1048
3 1040 1061 982
3 1062 995 926
3 1062 1041 995
3 1063 1024 1020
3 1025 1024 1064
3 1024 1063 1064
3 1026 1025 1065
3 1025 1064 1065
3 1065 1053 1026
3 1037 1044 1066
3 1037 1066 1058
3 1042 1067 1052
3 1020 1052 1063
3 1068 1058 1066
3 1059 1058 1068
3 1060 1069 1045
3 982 1061 1047
3 1067 1042 1022
3 1022 1051 1067
3 1070 1043 1053
3 1071 1070 1053
3 1072 1054 1043
3 1043 1070 1072
3 1073 1055 1054
3 1054 1072 1073
3 1056 1055 1073
3 1074 1056 1073
3 1074 1057 1056
3 1075 1039 1059
3 1039 1075 1060
3 1045 1076 1046
3 1077 806 976
3 907 1050 1078
3 926 907 1078
3 1019 1041 1079
3 1052 1080 1063
3 1074 1081 1057
3 1044 1057 1081
3 1082 1066 1044
3 1044 1081 1082
3 1066 1082 1068
3 1069 1060 1075
3 1069 1076 1045
3 1046 1083 1048
3 1049 1048 1083
3 1062 926 1078
3 1084 1051 1019
3 1068 1085 1059
3 1059 1085 1075
3 1076 1086 1046
3 1086 1083 1046
3 1049 1087 1035
3 1087 1040 1035
3 1061 1040 1087
3 1079 1041 1062
3 1084 1019 1079
3 1051 1084 1088
3 1067 1051 1088
3 1089 1052 1067
3 1052 1089 1080
3 1063 1080 1090
3 1064 1063 1090
3 1091 1053 1065
3 1091 1071 1053
3 1092 1070 1071
3 1072 1070 1092
3 1092 1093 1072
3 1093 1073 1072
3 1074 1073 1093
3 1094 1075 1085
3 1094 1069 1075
3 1090 1095 1064
3 1065 1064 1096
3 1095 1096 1064
3 1065 1096 1091
3 1074 1097 1081
3 1082 1081 1097
3 1098 1085 1068
3 1098 1094 1085
3 1099 1080 1089
3 1080 1099 1090
3 1077 976 1011
3 680 240 1100
3 1067 1101 1089
3 1089 1102 1099
3 1099 1103 1090
3 1095 1090 1103
3 1096 1104 1091
3 1071 1091 1105
3 1091 1104 1105
3 1105 1106 1071
3 1106 1092 1071
3 1107 1093 1092
3 1106 1107 1092
3 1108 1074 1093
3 1093 1107 1108
3 1074 1108 1097
3 1097 1109 1082
3 1109 1110 1082
3 1068 1082 1110
3 1110 1111 1068
3 1111 1098 1068
3 1069 1094 1112
3 1113 1076 1069
3 1112 1113 1069
3 1086 1076 1113
3 1049 1083 1114
3 1011 1115 1077
3 1086 1116 1083
3 1083 1116 1114
3 1011 1047 1115
3 1062 1117 1079
3 1079 1118 1084
3 1088 1119 1067
3 1067 1119 1101
3 1102 1089 1101
3 1103 1120 1095
3 1096 1095 1120
3 1121 1097 1108
3 1109 1097 1121
3 1094 1098 1122
3 1094 1122 1112
3 1114 1123 1049
3 1087 1124 1061
3 1123 1125 1049
3 1087 1049 1125
3 1125 1124 1087
3 1047 1126 1115
3 1120 1103 1127
3 1120 1128 1096
3 1129 1104 1096
3 1096 1128 1129
3 1105 1104 1129
3 1130 1107 1106
3 1107 1130 1131
3 1131 1108 1107
3 1108 1131 1132
3 1108 1132 1121
3 1133 1111 1110
3 1110 1134 1133
3 1111 1133 1135
3 1098 1111 1135
3 1098 1135 1122
3 1136 1112 1122
3 1136 1113 1112
3 1136 1137 1113
3 1086 1113 1137
3 1116 1086 1137
3 806 1077 1138
3 1118 1139 1084
3 1140 1088 1084
3 1084 1139 1140
3 1140 1119 1088
3 1102 1141 1099
3 1127 1103 1099
3 1099 1141 1127
3 1129 1142 1105
3 1106 1105 1143
3 1105 1142 1143
3 1106 1143 1130
3 1144 1121 1132
3 1145 1109 1121
3 1121 1144 1145
3 1134 1110 1109
3 1109 1145 1134
3 1146 1122 1135
3 1122 1146 1136
3 1061 1124 1126
3 1126 1047 1061
3 1138 47 806
3 1102 1101 1147
3 1114 1116 1148
3 1123 1114 1148
3 1117 1062 1078
3 1127 1149 1120
3 1150 1128 1120
3 1120 1149 1150
3 1129 1128 1150
3 1151 1132 1131
3 1134 1152 1133
3 1152 1153 1133
3 1153 1135 1133
3 1153 1154 1135
3 1146 1135 1154
3 1148 1116 1137
3 1125 1155 1124
3 1101 1119 1147
3 1119 1140 1147
3 1147 1156 1102
3 1157 1141 1102
3 1156 1157 1102
3 1127 1141 1157
3 1129 1150 1158
3 1158 1142 1129
3 1159 1142 1158
3 1159 1143 1142
3 1143 1159 1160
3 1130 1143 1160
3 1161 1130 1160
3 1161 1131 1130
3 1151 1131 1161
3 1162 1144 1132
3 1132 1151 1162
3 1163 1145 1144
3 1144 1162 1163
3 1134 1145 1164
3 1145 1163 1164
3 1152 1134 1164
3 1124 1155 1126
3 1079 1117 1165
3 1118 1079 1165
3 1157 1166 1127
3 1167 1149 1127
3 1127 1166 1167
3 1149 1167 1150
3 1160 1168 1161
3 1151 1161 1168
3 1169 1152 1164
3 1153 1152 1169
3 1170 1153 1169
3 1154 1153 1170
3 1171 1146 1154
3 1154 1170 1171
3 1146 1171 1172
3 1146 1172 1136
3 1172 1173 1136
3 1137 1136 1173
3 1137 1174 1148
3 1175 1126 1155
3 1050 680 1100
3 1176 1139 1118
3 1173 1174 1137
3 1177 1123 1148
3 1123 1177 1125
3 1126 1175 1115
3 1150 1167 1178
3 1158 1150 1178
3 1168 1179 1151
3 1179 1180 1151
3 1162 1151 1181
3 1151 1180 1181
3 1163 1162 1182
3 1162 1181 1182
3 1164 1163 1182
3 1125 1183 1155
3 1078 1050 1184
3 1117 1185 1165
3 1140 1139 1186
3 1139 1176 1186
3 1140 1186 1187
3 1140 1187 1147
3 1156 1188 1157
3 1166 1157 1188
3 1166 1189 1167
3 1178 1167 1189
3 1190 1158 1178
3 1159 1158 1190
3 1159 1190 1191
3 1160 1159 1192
3 1159 1191 1192
3 1192 1168 1160
3 1179 1168 1192
3 1181 1193 1182
3 1194 1164 1182
3 1194 1169 1164
3 1195 1169 1194
3 1195 1170 1169
3 1196 1171 1170
3 1195 1196 1170
3 1172 1171 1196
3 1174 1173 1197
3 1148 1174 1197
3 1183 1125 1177
3 1175 1198 1115
3 1115 1198 1077
3 1078 1184 1117
3 1148 1199 1200
3 1200 1177 1148
3 1176 1118 1165
3 1187 1201 1147
3 1156 1147 1201
3 1202 1156 1201
3 1202 1188 1156
3 1178 1203 1204
3 1178 1204 1190
3 1192 1205 1179
3 1206 1179 1205
3 1206 1180 1179
3 1207 1181 1180
3 1180 1206 1207
3 1181 1207 1193
3 1208 1182 1193
3 1208 1194 1182
3 1196 1209 1172
3 1199 1148 1197
3 1185 1117 1184
3 1188 1202 1210
3 1166 1188 1210
3 1211 1189 1166
3 1166 1210 1211
3 1203 1178 1189
3 1189 1211 1203
3 1212 1190 1204
3 1190 1212 1191
3 1191 1213 1192
3 1192 1213 1205
3 1172 1209 1214
3 1173 1172 1214
3 1173 1214 1215
3 1173 1215 1197
3 1177 1200 1183
3 1202 1201 1216
3 1194 1217 1195
3 1217 1218 1195
3 1219 1196 1195
3 1195 1218 1219
3 1196 1219 1209
3 1220 1199 1197
3 1185 1221 1165
3 1165 1221 1176
3 1216 1201 1187
3 1203 1222 1204
3 1222 1212 1204
3 1213 1191 1212
3 1205 1223 1206
3 1224 1207 1206
3 1206 1223 1224
3 1193 1207 1224
3 1193 1224 1225
3 1225 1208 1193
3 1194 1208 1217
3 1208 1225 1217
3 1219 1226 1209
3 1226 1214 1209
3 1215 1220 1197
3 1155 1183 1227
3 1175 1155 1227
3 1198 1228 1077
3 1228 1138 1077
3 1176 1229 1230
3 1186 1176 1230
3 1231 1186 1230
3 1231 1187 1186
3 1187 1231 1216
3 1202 1232 1210
3 1050 1100 1233
3 1050 1233 1184
3 1221 1229 1176
3 1234 1202 1216
3 1234 1232 1202
3 1210 1232 1235
3 1211 1210 1236
3 1210 1235 1236
3 1203 1211 1237
3 1211 1236 1237
3 1222 1203 1237
3 1212 1222 1238
3 1212 1238 1213
3 1239 1205 1213
3 1205 1239 1223
3 1240 1223 1239
3 1241 1224 1223
3 1223 1240 1241
3 1225 1224 1241
3 1225 1242 1217
3 1243 1218 1217
3 1217 1242 1243
3 1219 1218 1243
3 1215 1214 1226
3 1244 1199 1220
3 1200 1199 1244
3 1245 1200 1244
3 1246 1183 1200
3 1200 1245 1246
3 1183 1246 1227
3 1247 1213 1238
3 1213 1247 1239
3 1248 1185 1184
3 1216 1231 1249
3 1234 1216 1249
3 1237 1250 1222
3 1251 1238 1222
3 1225 1252 1242
3 1253 1219 1243
3 1253 1226 1219
3 1226 1254 1215
3 1254 1255 1215
3 1255 1220 1215
3 1256 1230 1229
3 1256 1231 1230
3 1234 1257 1232
3 1257 1235 1232
3 1222 1250 1251
3 1258 1247 1238
3 1238 1251 1258
3 1259 1239 1247
3 1258 1259 1247
3 1240 1239 1260
3 1239 1259 1260
3 1261 1241 1240
3 1240 1260 1261
3 1262 1225 1241
3 1241 1261 1262
3 1225 1262 1252
3 1242 1263 1243
3 1233 1248 1184
3 1256 1264 1231
3 1231 1264 1249
3 1237 1236 1265
3 1252 1266 1242
3 1242 1266 1263
3 1243 1263 1253
3 1253 1267 1226
3 1254 1226 1267
3 1220 1255 1268
3 1220 1268 1244
3 1268 1245 1244
3 1245 1269 1246
3 1227 1246 1269
3 1175 1227 1270
3 1249 1264 1271
3 1272 1234 1249
3 1271 1272 1249
3 1234 1272 1257
3 1236 1235 1265
3 1235 1257 1265
3 1265 1273 1237
3 1250 1237 1273
3 1273 1274 1250
3 1251 1250 1274
3 1275 1260 1259
3 1259 1276 1275
3 1277 1261 1260
3 1275 1277 1260
3 1262 1261 1277
3 1269 1270 1227
3 1221 1278 1229
3 1278 1279 1229
3 1229 1279 1256
3 1251 1274 1280
3 1258 1251 1280
3 1281 1266 1252
3 1266 1281 1263
3 1282 1253 1263
3 1267 1253 1282
3 1267 1283 1254
3 1283 1255 1254
3 1185 1248 1284
3 1284 1221 1185
3 1285 1257 1272
3 1257 1285 1265
3 1273 1286 1274
3 1286 1280 1274
3 1280 1287 1258
3 1276 1259 1258
3 1258 1287 1276
3 1277 1288 1262
3 1252 1262 1289
3 1262 1288 1289
3 1281 1252 1289
3 1281 1290 1263
3 1290 1282 1263
3 1255 1283 1268
3 1245 1291 1269
3 1292 1175 1270
3 1292 1198 1175
3 1278 1221 1284
3 1256 1293 1264
3 1271 1264 1293
3 1282 1294 1267
3 1291 1245 1268
3 1295 1285 1272
3 1285 1296 1265
3 1297 1273 1265
3 1296 1297 1265
3 1286 1273 1297
3 1298 1276 1287
3 1275 1276 1299
3 1276 1298 1299
3 1300 1277 1275
3 1275 1299 1300
3 1277 1300 1288
3 1294 1282 1290
3 1301 1279 1278
3 1256 1279 1301
3 1302 1271 1293
3 1295 1272 1271
3 1267 1294 1303
3 1283 1267 1303
3 1303 1304 1283
3 1283 1304 1268
3 1269 1305 1270
3 1295 1306 1285
3 1285 1306 1296
3 1307 1286 1297
3 1286 1307 1308
3 1286 1308 1280
3 1308 1309 1280
3 1287 1280 1309
3 1298 1287 1310
3 1309 1310 1287
3 1310 1311 1298
3 1312 1299 1298
3 1298 1311 1312
3 1299 1312 1300
3 1313 1288 1300
3 1314 1289 1288
3 1288 1313 1314
3 1281 1289 1314
3 1314 1315 1281
3 1281 1315 1290
3 1316 1290 1315
3 1290 1316 1294
3 1304 1317 1268
3 1318 1292 1270
3 1198 1292 1319
3 1319 1228 1198
3 1248 1320 1284
3 1320 1278 1284
3 1301 1321 1256
3 1321 1293 1256
3 1321 1302 1293
3 1295 1271 1322
3 1302 1322 1271
3 1323 1300 1312
3 1300 1323 1313
3 1268 1317 1291
3 1269 1324 1305
3 1306 1325 1296
3 1326 1297 1296
3 1296 1325 1326
3 1307 1297 1326
3 1269 1291 1324
3 1291 1327 1324
3 1305 1318 1270
3 1328 1301 1278
3 1295 1322 1329
3 1306 1295 1329
3 1311 1330 1312
3 1331 1323 1312
3 1330 1331 1312
3 1323 1332 1313
3 1332 1333 1313
3 1333 1314 1313
3 1334 1315 1314
3 1314 1333 1334
3 1335 1316 1315
3 1334 1335 1315
3 1294 1316 1335
3 1335 1336 1294
3 1294 1336 1303
3 1303 1337 1304
3 1337 1338 1304
3 1304 1338 1317
3 1339 1291 1317
3 1339 1327 1291
3 1292 1318 1319
3 1308 1307 1340
3 1307 1341 1340
3 1309 1308 1340
3 1336 1342 1303
3 1303 1342 1337
3 1339 1317 1338
3 1278 1320 1328
3 1322 1343 1329
3 1344 1306 1329
3 1325 1306 1344
3 1344 1345 1325
3 1325 1345 1326
3 1345 1341 1326
3 1341 1307 1326
3 1346 1309 1340
3 1310 1309 1346
3 1347 1311 1310
3 1310 1346 1347
3 1311 1347 1330
3 1323 1331 1332
3 1348 1302 1321
3 1302 1348 1322
3 1343 1322 1348
3 1329 1343 1349
3 1349 1344 1329
3 1350 1341 1345
3 1351 1340 1341
3 1341 1350 1351
3 1351 1346 1340
3 1352 1330 1347
3 1331 1330 1352
3 1353 1331 1352
3 1353 1332 1331
3 1354 1333 1332
3 1334 1355 1335
3 1355 1356 1335
3 1336 1335 1356
3 1337 1357 1338
3 1357 1358 1338
3 1358 1339 1338
3 1233 1359 1248
3 1248 1360 1320
3 1328 1361 1301
3 1362 1321 1301
3 1361 1362 1301
3 1321 1362 1348
3 1349 1363 1344
3 1344 1363 1345
3 1364 1346 1351
3 1346 1364 1365
3 1365 1347 1346
3 1347 1365 1352
3 1353 1366 1332
3 1332 1366 1354
3 1333 1354 1367
3 1334 1333 1367
3 1368 1337 1342
3 1357 1337 1368
3 125 1100 240
3 1369 1343 1348
3 1343 1369 1349
3 1355 1334 1367
3 1370 1336 1356
3 1336 1370 1342
3 1368 1342 1370
3 1358 1371 1339
3 1327 1339 1372
3 1339 1371 1372
3 1373 1324 1327
3 1372 1373 1327
3 1305 1324 1373
3 1328 1320 1374
3 1348 1375 1369
3 1345 1363 1376
3 1350 1345 1376
3 1376 1377 1350
3 1377 1351 1350
3 1378 1352 1365
3 1352 1378 1379
3 1379 1353 1352
3 1380 1354 1366
3 1367 1354 1380
3 1373 1381 1305
3 1318 1305 1381
3 1362 1375 1348
3 1382 1349 1369
3 1349 1382 1363
3 1377 1383 1351
3 1351 1383 1364
3 1384 1364 1383
3 1365 1364 1384
3 1378 1365 1384
3 1385 1366 1353
3 1353 1379 1385
3 1380 1366 1385
3 1367 1386 1355
3 1386 1356 1355
3 1370 1387 1368
3 1357 1368 1387
3 1357 1388 1358
3 1370 1356 1386
3 1320 1360 1374
3 1375 1389 1369
3 1369 1390 1382
3 1391 1363 1382
3 1376 1363 1391
3 1376 1392 1377
3 1384 1393 1378
3 1367 1394 1386
3 1370 1395 1387
3 1388 1357 1387
3 1358 1388 1396
3 1396 1371 1358
3 1248 1359 1360
3 1374 1397 1328
3 1361 1328 1397
3 1389 1390 1369
3 1390 1398 1382
3 1391 1382 1398
3 1392 1399 1377
3 1383 1377 1399
3 1383 1393 1384
3 1400 1378 1393
3 1378 1400 1401
3 1379 1378 1401
3 1402 1379 1401
3 1379 1402 1385
3 1403 1385 1402
3 1380 1385 1404
3 1385 1403 1404
3 1367 1380 1394
3 1380 1404 1394
3 1405 1386 1394
3 1386 1405 1406
3 1406 1370 1386
3 1370 1406 1395
3 1372 1371 1396
3 1387 1407 1388
3 1362 1408 1375
3 1389 1375 1408
3 1409 1376 1391
3 1392 1376 1409
3 1410 1383 1399
3 1410 1393 1383
3 1396 1411 1372
3 1411 1373 1372
3 1412 1413 1318
3 1319 1318 1413
3 1228 1319 1414
3 1415 1374 1360
3 1374 1415 1397
3 1362 1361 1416
3 1362 1416 1408
3 1410 1417 1393
3 1400 1393 1417
3 1400 1418 1401
3 1419 1402 1401
3 1418 1419 1401
3 1402 1419 1420
3 1402 1420 1403
3 1404 1403 1421
3 1420 1421 1403
3 1422 1406 1405
3 1423 1395 1406
3 1406 1422 1423
3 1387 1395 1423
3 1412 1318 1381
3 1381 1424 1412
3 1138 1228 1414
3 1389 1425 1390
3 1425 1398 1390
3 1398 1426 1391
3 1426 1409 1391
3 1427 1392 1409
3 1428 1399 1392
3 1392 1427 1428
3 1399 1428 1410
3 1394 1404 1429
3 1421 1429 1404
3 1405 1394 1429
3 1407 1387 1423
3 1388 1407 1430
3 1396 1388 1430
3 1411 1424 1373
3 1373 1424 1381
3 1416 1361 1397
3 1419 1431 1420
3 1432 1405 1429
3 1405 1432 1422
3 1360 1433 1415
3 1434 1409 1426
3 1409 1434 1427
3 1400 1417 1435
3 1435 1418 1400
3 1436 1422 1432
3 1407 1437 1430
3 1438 1396 1430
3 1396 1438 1411
3 1359 1233 1439
3 1440 1389 1408
3 1389 1441 1425
3 1442 1426 1398
3 1398 1425 1442
3 1443 1427 1434
3 1444 1428 1427
3 1427 1443 1444
3 1410 1428 1444
3 1418 1435 1445
3 1445 1419 1418
3 1431 1419 1445
3 1446 1420 1431
3 1446 1421 1420
3 1447 1429 1421
3 1446 1447 1421
3 1429 1447 1432
3 1436 1432 1447
3 1319 1413 1414
3 1389 1440 1441
3 1426 1442 1434
3 1448 1410 1444
3 1417 1410 1448
3 1449 1417 1448
3 1417 1449 1435
3 1422 1436 1450
3 1423 1422 1451
3 1450 1451 1422
3 1451 1407 1423
3 1437 1407 1451
3 1359 1433 1360
3 1440 1408 1416
3 1416 1452 1440
3 1437 1453 1430
3 1438 1430 1453
3 1452 1416 1397
3 1454 1441 1440
3 1425 1441 1455
3 1454 1455 1441
3 1425 1455 1442
3 1442 1456 1434
3 1434 1456 1457
3 1457 1443 1434
3 1443 1457 1458
3 1458 1444 1443
3 1448 1444 1458
3 1449 1459 1435
3 1459 1460 1435
3 1435 1460 1445
3 1445 1461 1431
3 1462 1446 1431
3 1461 1462 1431
3 1463 1447 1446
3 1462 1463 1446
3 1447 1463 1436
3 1436 1464 1450
3 1412 1424 1465
3 1233 1100 1439
3 1433 1466 1415
3 1466 1467 1415
3 1397 1415 1467
3 1397 1467 1452
3 1440 1468 1454
3 1448 1469 1449
3 1459 1449 1469
3 1464 1436 1463
3 1468 1440 1452
3 1470 1451 1450
3 1451 1470 1471
3 1437 1451 1471
3 1453 1472 1438
3 1411 1438 1472
3 1473 1411 1472
3 1473 1424 1411
3 1473 1465 1424
3 1474 1442 1455
3 1475 1456 1442
3 1442 1474 1475
3 1476 1457 1456
3 1456 1475 1476
3 1458 1457 1476
3 1458 1477 1448
3 1469 1448 1477
3 1460 1478 1445
3 1461 1445 1478
3 1462 1461 1478
3 1479 1464 1463
3 1470 1450 1464
3 1480 1455 1454
3 1479 1463 1462
3 1413 1481 1414
3 1482 1452 1467
3 1471 1483 1437
3 1453 1437 1483
3 1414 48 1138
3 1484 1433 1359
3 1467 1466 1482
3 1452 1485 1468
3 1468 1486 1454
3 1454 1486 1480
3 1455 1480 1487
3 1487 1474 1455
3 1488 1475 1474
3 1474 1489 1488
3 1490 1476 1475
3 1475 1488 1490
3 1491 1458 1476
3 1476 1490 1491
3 1492 1477 1458
3 1458 1491 1492
3 1493 1469 1477
3 1477 1492 1493
3 1459 1469 1494
3 1469 1493 1494
3 1460 1459 1494
3 1495 1460 1494
3 1495 1478 1460
3 1478 1495 1496
3 1478 1496 1462
3 1496 1497 1462
3 1462 1497 1479
3 1464 1479 1498
3 1499 1470 1464
3 1464 1498 1499
3 1470 1499 1471
3 1487 1489 1474
3 1500 1479 1497
3 1479 1500 1498
3 1483 1501 1453
3 1472 1453 1501
3 1413 1412 1502
3 1481 1413 1502
3 1482 1485 1452
3 1486 1503 1480
3 1487 1480 1503
3 1495 1504 1496
3 1499 1505 1471
3 1471 1505 1483
3 1506 1473 1472
3 1502 1412 1465
3 1468 1485 1507
3 1468 1507 1486
3 1490 1508 1491
3 1509 1492 1491
3 1508 1509 1491
3 1493 1492 1510
3 1492 1509 1510
3 1504 1511 1496
3 1511 1497 1496
3 1511 1512 1497
3 1497 1512 1500
3 1513 1472 1501
3 47 1138 48
3 1433 1484 1514
3 1472 1513 1506
3 1466 1433 1514
3 1503 1486 1507
3 1487 1515 1489
3 1488 1489 1516
3 1515 1516 1489
3 1490 1488 1516
3 1490 1516 1517
3 1490 1517 1508
3 1494 1493 1518
3 1493 1510 1518
3 1495 1494 1519
3 1494 1518 1519
3 1504 1495 1519
3 1512 1520 1500
3 1498 1500 1521
3 1520 1521 1500
3 1499 1498 1522
3 1521 1522 1498
3 1499 1522 1523
3 1523 1505 1499
3 1483 1505 1523
3 1483 1524 1501
3 1524 1513 1501
3 1473 1506 1525
3 1526 1465 1473
3 1525 1526 1473
3 1465 1526 1502
3 1527 1509 1508
3 1510 1509 1527
3 1482 1466 1528
3 1507 1529 1503
3 1487 1503 1530
3 1503 1531 1530
3 1487 1530 1515
3 1517 1532 1508
3 1508 1532 1527
3 1533 1511 1504
3 1511 1533 1534
3 1534 1512 1511
3 1520 1512 1534
3 1523 1535 1483
3 1535 1524 1483
3 1481 68 1414
3 1359 1439 1536
3 1484 1359 1536
3 1528 1466 1514
3 1485 1537 1507
3 1507 1538 1529
3 1539 1527 1532
3 1510 1527 1540
3 1518 1510 1540
3 1518 1541 1519
3 1542 1504 1519
3 1541 1542 1519
3 1504 1542 1533
3 1485 1482 1543
3 1543 1537 1485
3 1538 1507 1537
3 1531 1503 1529
3 1544 1516 1515
3 1517 1516 1545
3 1516 1544 1545
3 1546 1532 1517
3 1517 1545 1546
3 1532 1546 1539
3 1539 1540 1527
3 1547 1523 1522
3 1513 1548 1506
3 1549 1502 1526
3 68 48 1414
3 125 1439 1100
3 1550 1530 1531
3 1515 1530 1551
3 1530 1550 1551
3 1552 1518 1540
3 1541 1518 1552
3 1553 1534 1533
3 1554 1520 1534
3 1534 1553 1554
3 1521 1520 1555
3 1520 1554 1555
3 1522 1521 1556
3 1555 1556 1521
3 1522 1556 1547
3 1506 1548 1525
3 1536 19 1484
3 1514 1484 19
3 1482 1557 1543
3 1538 1558 1529
3 1559 1531 1529
3 1558 1559 1529
3 1531 1559 1550
3 1544 1515 1551
3 1560 1540 1539
3 1540 1560 1552
3 1561 1533 1542
3 1533 1561 1553
3 1535 1523 1547
3 1535 1562 1524
3 1513 1524 1562
3 1563 1526 1525
3 1549 1526 1563
3 1563 1525 1548
3 1564 1537 1543
3 1564 1538 1537
3 1564 1565 1538
3 1538 1565 1558
3 1566 1550 1559
3 1567 1550 1566
3 1567 1551 1550
3 1551 1567 1568
3 1568 1544 1551
3 1545 1544 1569
3 1544 1568 1569
3 1546 1545 1569
3 1569 1570 1546
3 1539 1546 1570
3 1571 1539 1570
3 1539 1571 1560
3 1560 1572 1552
3 1573 1541 1552
3 1572 1573 1552
3 1542 1541 1573
3 1561 1542 1573
3 1574 1553 1561
3 1575 1554 1553
3 1553 1574 1575
3 1555 1554 1575
3 1576 1556 1555
3 1555 1575 1576
3 1577 1556 1576
3 1547 1556 1577
3 1578 1535 1547
3 1577 1578 1547
3 1578 1579 1535
3 1535 1579 1562
3 1548 1513 1562
3 1549 1580 1502
3 1502 1580 1481
3 68 1481 1580
3 1439 63 1536
3 19 1581 1514
3 1581 1528 1514
3 1528 1557 1482
3 1566 1559 1558
3 1582 1561 1573
3 1561 1582 1574
3 1557 1583 1543
3 1583 1564 1543
3 1548 1584 1563
3 1566 1585 1567
3 1567 1585 1586
3 1567 1586 1568
3 1587 1568 1586
3 1568 1587 1569
3 1570 1588 1571
3 1560 1571 1589
3 1571 1588 1589
3 1590 1572 1560
3 1589 1590 1560
3 1591 1573 1572
3 1572 1590 1591
3 1573 1591 1582
3 1582 1592 1574
3 1593 1575 1574
3 1574 1592 1593
3 1575 1593 1576
3 1562 1594 1548
3 1594 1584 1548
3 1595 1577 1576
3 1578 1577 1595
3 1596 1557 1528
3 1557 1596 1583
3 1597 1566 1558
3 1598 1597 1558
3 1585 1566 1597
3 1587 1599 1569
3 1600 1570 1569
3 1569 1599 1600
3 1601 1588 1570
3 1570 1600 1601
3 1602 1591 1590
3 1603 1582 1591
3 1591 1602 1603
3 1604 1576 1593
3 1576 1604 1595
3 1578 1605 1579
3 1606 1579 1605
3 1562 1579 1606
3 1584 17 1563
3 1549 1563 17
3 1528 1581 1596
3 0 1564 1583
3 1564 0 1565
3 0 1598 1565
3 1558 1565 1598
3 1607 1586 1585
3 1587 1586 1607
3 1588 1601 1608
3 1608 1589 1588
3 1609 1590 1589
3 1589 1608 1609
3 1590 1609 1602
3 1582 1603 1610
3 1611 1592 1582
3 1582 1610 1611
3 1612 1593 1592
3 1592 1611 1612
3 1593 1612 1604
3 1605 1578 1595
3 1562 1606 1594
3 68 1580 78
3 1596 1 1583
3 1 0 1583
3 1585 1613 1607
3 1614 1587 1607
3 1599 1587 1614
3 1599 1615 1600
3 1601 1600 1616
3 1615 1616 1600
3 1608 1601 1616
3 1608 1617 1609
3 1617 1602 1609
3 1617 1618 1602
3 1619 1603 1602
3 1602 1618 1619
3 1619 1610 1603
3 1595 1620 1605
3 78 1580 1549
3 45 78 1549
3 1439 125 63
3 1621 1585 1597
3 1621 1613 1585
3 6 1607 1613
3 1607 6 1614
3 1594 15 1584
3 17 1584 15
3 45 1549 17
3 19 1536 20
3 22 1598 0
3 24 1597 1598
3 24 1621 1597
3 6 5 1614
3 1622 1599 1614
3 5 1622 1614
3 1615 1599 1622
3 1616 1623 1608
3 1623 1624 1608
3 1608 1624 1617
3 1619 1625 1610
3 1611 1610 1625
3 1611 1625 8
3 1611 8 1612
3 10 1612 8
3 1604 1612 10
3 1604 10 1626
3 1595 1604 1626
3 1620 1595 1626
3 14 1594 1606
3 1606 12 14
3 1594 14 15
3 19 18 1581
3 80 1596 1581
3 1581 71 80
3 22 24 1598
3 1621 25 1613
3 6 1613 25
3 42 1620 1626
3 1605 1620 42
3 42 44 1605
3 44 1606 1605
3 1606 44 12
3 63 20 1536
3 1 1596 49
3 0 3 22
3 5 7 1622
3 28 1615 1622
3 7 28 1622
3 30 1616 1615
3 28 30 1615
3 1623 1616 30
3 32 1624 1623
3 30 32 1623
3 1617 1624 34
3 32 34 1624
3 36 1618 1617
3 34 36 1617
3 38 1619 1618
3 1618 36 38
3 1625 1619 38
3 1625 38 39
3 8 1625 39
3 1626 40 42
3 68 46 48
3 1581 18 71
3 80 49 1596
3 25 1621 24
3 40 1626 10
3 10 11 40
3 78 69 68
