- To:
- Subject: Re: [cgal-discuss] compile an example code on win32 to produce
- Date: Tue, 3 Feb 2009 13:01:34 +0100 (CET)
Hi!
I'm not sure whether your problem is the same with mine, view this topic I
post
on the mailing list last week if you like.
https://lists-sop.inria.fr/sympa/arc/cgal-discuss/2009-01/msg00308.html
I'm also curious on the question that if an application using CGAL could use
static link in Windows.
I've tried building CGAL using static link and then used the compiled static
library,however,errors occur when I compiled my application using static link.
Anyone could help us?
- [cgal-discuss] compile an example code on win32 to produce stand-alone binary, Qianqian Fang, 02/02/2009
- Re: [cgal-discuss] compile an example code on win32 to produce, wangk0705, 02/03/2009
- Re: [cgal-discuss] compile an example code on win32 to produce, Qianqian Fang, 02/03/2009
- Re: [cgal-discuss] compile an example code on win32 to produce, Laurent Rineau (GeometryFactory), 02/03/2009
- Re: [cgal-discuss] compile an example code on win32 to produce, Kye Wong, 02/04/2009
- Re: [cgal-discuss] compile an example code on win32 to produce, Andreas Fabri, 02/04/2009
- Re: [cgal-discuss] compile an example code on win32 to produce, Laurent Rineau (GeometryFactory), 02/04/2009
