- To:
- Subject: Re: [cgal-discuss] cgal c2t3 face status
- Date: Sat, 7 Feb 2009 14:25:01 +0100
On Saturday 07 February 2009 12:46:22 Hanjoerg Seybold wrote: > Hi! > I tried to check the face status of a edge using > > c2t3.face_status ( Cell_handle c, int i, int j) > Returns the status of edge (c,i,j) in the 2D complex. > > as described in the manual. but I always get an error except if > i use a face or a edge. > > In the header I could not find the function implemented. c2t3.face_status ( Cell_handle c, int i, int j) is not implemented. It will be fixed in next release of CGAL. As a workaround, you can use: c2t3.face_status ( Edge(c, i, j) ) that does exactly the same thing. Laurent Rineau, PhD Engineer at GeometryFactory http://www.geometryfactory.com/ |
- [cgal-discuss] question on Installation on unix, hkim, 02/06/2009
- Re: [cgal-discuss] question on Installation on unix, Andreas Fabri, 02/06/2009
- RE: [cgal-discuss] question on Installation on unix, avanindra, 02/07/2009
- Re: RE: [cgal-discuss] question on Installation on unix, hkim, 02/07/2009
- Re: [cgal-discuss] question on Installation on unix, Joachim Reichel, 02/07/2009
- [cgal-discuss] cgal c2t3 face status, Hanjoerg Seybold, 02/07/2009
- Re: [cgal-discuss] cgal c2t3 face status, Joachim Reichel, 02/07/2009
- Re: [cgal-discuss] cgal c2t3 face status, Laurent Rineau (GeometryFactory), 02/07/2009
- Re: [cgal-discuss] question on Installation on unix, Hanjun Kim, 02/07/2009
- Re: [cgal-discuss] question on Installation on unix, Hanjun Kim, 02/08/2009
- Re: [cgal-discuss] question on Installation on unix, Joachim Reichel, 02/08/2009
- Re: [cgal-discuss] question on Installation on unix, Hanjun Kim, 02/09/2009
- Re: [cgal-discuss] question on Installation on unix, Joachim Reichel, 02/09/2009
