- To:
- Subject: Re: [cgal-discuss] question on Installation on unix
- Date: Sun, 8 Feb 2009 18:24:09 -0600 (CST)
We've reinstalled the gmp; we typed exactly what you suggested. But still
have the same error.
Could you tell me anything that I can check if something is wrong?
Thanks,
Hanjun
On Sun, 8 Feb 2009, Joachim Reichel wrote:
Hi,
We have installed the demo and dev packages you said.
This is the result for "dpkg -l | grep cgal"
ii libcgal-demo 3.4-1~etch1 C++ library for
computational geometry (demos)
ii libcgal-dev 3.4-1~etch1 C++ library for
computational geometry (development files)
ii libcgal3 3.4-1~etch1 C++ library for
ok, looks good.
And I typed in the command that you said,
"g++ -I/tmp/CGAL-3.4/include -frounding-math -L/tmp/CGAL-3.4/lib -lCGAL
abc.cpp -o abc.out"
But then the -I and -L directives should not be necessary.
And the error message now I get is
/usr/include/gmpxx.h: In destructor
'__gmp_alloc_cstring::~__gmp_alloc_cstring()':
/usr/include/gmpxx.h:1389: error: 'mp_get_memory_functions' was not
declared in this scope
Something is wrong with the GMP installation on your machine. gmpxx.h should
include gmp.h which defines 'mp_get_memory_functions'. Maybe your admins can
fix
that with "apt-get install --reinstall libgmp3-dev libgmp3c2 libgmpxx4".
Joachim
- Re: [cgal-discuss] cgal c2t3 face status, (continued)
- Re: [cgal-discuss] cgal c2t3 face status, Joachim Reichel, 02/07/2009
- Re: [cgal-discuss] cgal c2t3 face status, Laurent Rineau (GeometryFactory), 02/07/2009
- Re: [cgal-discuss] question on Installation on unix, Hanjun Kim, 02/07/2009
- Re: [cgal-discuss] question on Installation on unix, Joachim Reichel, 02/07/2009
- Re: [cgal-discuss] question on Installation on unix, Hanjun Kim, 02/08/2009
- Re: [cgal-discuss] question on Installation on unix, Joachim Reichel, 02/08/2009
- Re: [cgal-discuss] question on Installation on unix, Hanjun Kim, 02/09/2009
- Re: [cgal-discuss] question on Installation on unix, Joachim Reichel, 02/09/2009
- Re: [cgal-discuss] question on Installation on unix, Hanjun Kim, 02/10/2009
