cgal-discuss - Re: [cgal-discuss] question on Installation on unix
  • To:
  • Subject: Re: [cgal-discuss] question on Installation on unix
  • Date: Sun, 8 Feb 2009 16:19:21 -0600 (CST)
Hi,
We have installed the demo and dev packages you said.
This is the result for "dpkg -l | grep cgal"
ii libcgal-demo 3.4-1~etch1 C++ library for computational geometry (demos)
ii libcgal-dev 3.4-1~etch1 C++ library for computational geometry (development files)
ii libcgal3 3.4-1~etch1 C++ library for computational geometry
And I typed in the command that you said,
"g++ -I/tmp/CGAL-3.4/include -frounding-math -L/tmp/CGAL-3.4/lib -lCGAL abc.cpp -o abc.out"
And the error message now I get is
/usr/include/gmpxx.h: In destructor '__gmp_alloc_cstring::~__gmp_alloc_cstring()':
/usr/include/gmpxx.h:1389: error: 'mp_get_memory_functions' was not declared in this scope
Thanks,
Hanjun
On Sun, 8 Feb 2009, Joachim Reichel wrote:
Hi,
Actually, it was installed by computer staff in my department. So, now
we have 3.4 installed, but it still doesn't work. We installed using
This file is in /tmp/CGAL-3.4/include/CGAL now.
If the file is not in /usr/include/CGAL, then your admins did NOT install the
Debian packages (at least not in a proper way). Did you install CGAL yourself
to
/tmp/GGAL-3.4?
In case of further problems, please post the output of "dpkg -l | grep cgal".
If
you installed CGAL yourself, please post all the steps you performed in order
to
install CGAL. Without you providing the necessary information, I do not see
any
chance to help you.
Anyway you should now be able to build your example with
$g++ -I/tmp/CGAL-3.4/include -frounding-math -L/tmp/CGAL-3.4/lib -lCGAL
abc.cpp
-o abc.out
Note that usually the contents of /tmp get deleted on reboot ...
Joachim
