cgal-discuss - Re: [cgal-discuss] question on Installation on unix
  • To:
  • Subject: Re: [cgal-discuss] question on Installation on unix
  • Date: Sat, 7 Feb 2009 06:37:50 -0600 (CST)
I first tried Debian packages and but it didn't work well. So, I downloaded the CGAL-3.3.tar.gz. (not 3.4 accidentally) and built in the interactive mode.
In the CGAL-3.3/lib folder, I have
README i686_Linux-2.6_g++-4.1.2, where the second one is a directory.
Does this help?
Thanks,
Hanjun
On Sat, 7 Feb 2009, Joachim Reichel wrote:
Hi
(please setup you mailer to display a proper name)
It is a Debian linux (etch)
do you use the Debian packages? Or did you download the tar.gz and installed
it
yourself?
If you build CGAL yourself: Please show us the contents of the "lib"
directory.
In either case: please show us the command you used to build the example
including the complete output.
Regards,
Joachim
