- To:
- Subject: Re: [cgal-discuss] question on Installation on unix
- Date: Sat, 07 Feb 2009 14:14:29 +0100
Hi Hanjun,
> I first tried Debian packages and but it didn't work well.
Unfortunately, you don't say why it doesn't work. There are no known problems
building the examples/demos in the (3.3) Debian package, so it should just
work.
> So, I
> downloaded the CGAL-3.3.tar.gz. (not 3.4 accidentally) and built in the
> interactive mode.
> In the CGAL-3.3/lib folder, I have
> README i686_Linux-2.6_g++-4.1.2, where the second one is a directory.
You never mentioned so far that you use CGAL 3.3, which is more than 18 months
old now. Since you said "accidentally", you seem to have no particular reason
to
use 3.3, right? I strongly recommend to use 3.4 then, and not to waste time on
problems with an old version.
Again, there are Debian packages for 3.4 as well and I'm not aware of any
problems building the examples/demos (read
/usr/share/doc/libcgal-demo/README.Debian).
Joachim
- [cgal-discuss] question on Installation on unix, hkim, 02/06/2009
- Re: [cgal-discuss] question on Installation on unix, Andreas Fabri, 02/06/2009
- RE: [cgal-discuss] question on Installation on unix, avanindra, 02/07/2009
- Re: RE: [cgal-discuss] question on Installation on unix, hkim, 02/07/2009
- Re: [cgal-discuss] question on Installation on unix, Joachim Reichel, 02/07/2009
- [cgal-discuss] cgal c2t3 face status, Hanjoerg Seybold, 02/07/2009
- Re: [cgal-discuss] cgal c2t3 face status, Joachim Reichel, 02/07/2009
- Re: [cgal-discuss] cgal c2t3 face status, Laurent Rineau (GeometryFactory), 02/07/2009
- Re: [cgal-discuss] question on Installation on unix, Hanjun Kim, 02/07/2009
- Re: [cgal-discuss] question on Installation on unix, Hanjun Kim, 02/08/2009
- Re: [cgal-discuss] question on Installation on unix, Joachim Reichel, 02/08/2009
- Re: [cgal-discuss] question on Installation on unix, Hanjun Kim, 02/09/2009
- Re: [cgal-discuss] question on Installation on unix, Joachim Reichel, 02/09/2009
