cgal-discuss - Re: [cgal-discuss] question on Installation on unix
  • To:
  • Subject: Re: [cgal-discuss] question on Installation on unix
  • Date: Mon, 9 Feb 2009 11:42:23 -0600 (CST)
Thank you so much for the help; it seems to be working now.
But I have a quick question that how I can make sure that my compiler will look in /usr/include and /usr/lib instead of /usr/local/include and /usr/local/lib.
Thanks,
Hanjun
On Mon, 9 Feb 2009, Joachim Reichel wrote:
Hi,
And the output for g++ with -H option is attached as a file "res.out".
...... /tmp/CGAL-3.4/include/CGAL/gmpxx.h
....... /usr/include/gmpxx.h
........ /usr/local/include/gmp.h
The last file is the culprit. There is a GMP installation in /usr/local which does not match the GMPXX installation in /usr. You should either move the GMP installation in /usr/local/include away (including libs in /usr/local/lib), or you need a consistent GMP+GMPXX+MPFR installation in /usr/local.
Joachim
