cgal-discuss - Re: [cgal-discuss] question on Installation on unix
  • To:
  • Subject: Re: [cgal-discuss] question on Installation on unix
  • Date: Mon, 9 Feb 2009 09:24:02 -0600 (CST)
The output for the "dpkg -l | grep gmp" is
ii libgmp3-dev 4.2.1+dfsg-4 Multiprecision arithmetic library developers tools
ii libgmp3c2 4.2.1+dfsg-4 Multiprecision arithmetic library
ii libgmpxx4 4.2.1+dfsg-4 Multiprecision arithmetic library (C++ bindings)
ii libmath-bigint-gmp-perl 1.18-2 GMP library for Math::BigInt routines
ii libmath-gmp-perl 2.04-2 high speed arbitrary size integer math for perl
ii libpari2-gmp 2.3.1-2 PARI/GP Computer Algebra System shared library
And the output for g++ with -H option is attached as a file "res.out".
Thanks,
Hanjun
On Mon, 9 Feb 2009, Joachim Reichel wrote:
Hi,
We've reinstalled the gmp; we typed exactly what you suggested. But still
have the same error.
Could you tell me anything that I can check if something is wrong?
What gmp packages are installed ("dpkg -l | grep gmp")? What's the output of
"g++ -I/tmp/CGAL-3.4/include -frounding-math -c abc.cpp -H" (as attachment)?
Joachim
Script started on Mon Feb 9 09:11:21 2009
vv417:~/research/C++> g++ -I/tmp/CGAL-3.4/include
. /tmp/CGAL-3.4/include/CGAL/Exact_predicates_inexact_constructions_kernel.h
.. /tmp/CGAL-3.4/include/CGAL/Simple_cartesian.h
... /tmp/CGAL-3.4/include/CGAL/Cartesian/Cartesian_base.h
.... /tmp/CGAL-3.4/include/CGAL/basic.h
..... /tmp/CGAL-3.4/include/CGAL/config.h
...... /usr/include/boost/config.hpp
....... /usr/include/boost/config/user.hpp
....... /usr/include/boost/config/select_compiler_config.hpp
....... /usr/include/boost/config/compiler/gcc.hpp
....... /usr/include/boost/config/select_stdlib_config.hpp
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/utility
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/i486-linux-gnu/bits/c++config.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/i486-linux-gnu/bits/os_defines.h
........... /usr/include/features.h
............ /usr/include/sys/cdefs.h
............ /usr/include/gnu/stubs.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/i486-linux-gnu/bits/cpu_defines.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/stl_relops.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/stl_pair.h
....... /usr/include/boost/config/stdlib/libstdcpp3.hpp
....... /usr/include/boost/config/select_platform_config.hpp
....... /usr/include/boost/config/platform/linux.hpp
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/cstdlib
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/cstddef
.......... /usr/lib/gcc/i486-linux-gnu/4.1.2/include/stddef.h
......... /usr/include/stdlib.h
.......... /usr/include/bits/waitflags.h
.......... /usr/include/bits/waitstatus.h
........... /usr/include/endian.h
............ /usr/include/bits/endian.h
.......... /usr/include/xlocale.h
.......... /usr/include/sys/types.h
........... /usr/include/bits/types.h
............ /usr/include/bits/wordsize.h
............ /usr/lib/gcc/i486-linux-gnu/4.1.2/include/stddef.h
............ /usr/include/bits/typesizes.h
........... /usr/include/time.h
........... /usr/include/sys/select.h
............ /usr/include/bits/select.h
............ /usr/include/bits/sigset.h
............ /usr/include/time.h
............ /usr/include/bits/time.h
........... /usr/include/sys/sysmacros.h
........... /usr/include/bits/pthreadtypes.h
............ /usr/include/bits/sched.h
.......... /usr/include/alloca.h
........ /usr/include/boost/config/posix_features.hpp
......... /usr/include/unistd.h
.......... /usr/include/bits/posix_opt.h
.......... /usr/include/bits/environments.h
.......... /usr/include/bits/confname.h
.......... /usr/include/getopt.h
....... /usr/include/boost/config/suffix.hpp
........ /usr/lib/gcc/i486-linux-gnu/4.1.2/include/limits.h
......... /usr/lib/gcc/i486-linux-gnu/4.1.2/include/syslimits.h
.......... /usr/lib/gcc/i486-linux-gnu/4.1.2/include/limits.h
........... /usr/include/limits.h
............ /usr/include/bits/posix1_lim.h
............. /usr/include/bits/local_lim.h
.............. /usr/include/linux/limits.h
............ /usr/include/bits/posix2_lim.h
............ /usr/include/bits/xopen_lim.h
............. /usr/include/bits/stdio_lim.h
...... /tmp/CGAL-3.4/include/CGAL/version.h
...... /tmp/CGAL-3.4/include/CGAL/compiler_config.h
...... /tmp/CGAL-3.4/include/CGAL/auto_link/CGAL.h
....... /tmp/CGAL-3.4/include/CGAL/auto_link/auto_link.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/algorithm
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/stl_algobase.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/cstring
......... /usr/include/string.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/climits
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/iosfwd
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/i486-linux-gnu/bits/c++locale.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/cstdio
........... /usr/include/stdio.h
............ /usr/include/libio.h
............. /usr/include/_G_config.h
.............. /usr/lib/gcc/i486-linux-gnu/4.1.2/include/stddef.h
.............. /usr/include/wchar.h
............... /usr/lib/gcc/i486-linux-gnu/4.1.2/include/stddef.h
............... /usr/include/bits/wchar.h
.............. /usr/include/gconv.h
............... /usr/include/wchar.h
................ /usr/lib/gcc/i486-linux-gnu/4.1.2/include/stddef.h
............. /usr/lib/gcc/i486-linux-gnu/4.1.2/include/stdarg.h
............ /usr/include/bits/sys_errlist.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/clocale
........... /usr/include/locale.h
............ /usr/include/bits/locale.h
.......... /usr/include/langinfo.h
........... /usr/include/nl_types.h
.......... /usr/include/iconv.h
.......... /usr/include/libintl.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/i486-linux-gnu/bits/c++io.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/i486-linux-gnu/bits/gthr.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/i486-linux-gnu/bits/gthr-default.h
............ /usr/include/pthread.h
............. /usr/include/sched.h
.............. /usr/include/time.h
.............. /usr/include/bits/sched.h
.............. /usr/include/bits/time.h
............. /usr/include/signal.h
.............. /usr/include/bits/sigset.h
............. /usr/include/bits/pthreadtypes.h
............. /usr/include/bits/initspin.h
............. /usr/include/bits/sigthread.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/cctype
.......... /usr/include/ctype.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/stringfwd.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/postypes.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/cwchar
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/ctime
.......... /usr/include/stdint.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/functexcept.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/exception_defines.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/cpp_type_traits.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/stl_iterator_base_types.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/stl_iterator_base_funcs.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/concept_check.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/stl_iterator.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/debug/debug.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/stl_construct.h
........ /usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/new
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/stl_uninitialized.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/stl_algo.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/stl_heap.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/stl_tempbuf.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/memory
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/allocator.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/i486-linux-gnu/bits/c++allocator.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/ext/new_allocator.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/stl_raw_storage_iter.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/limits
..... /usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/iostream
...... /usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/ostream
....... /usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/ios
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/char_traits.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/localefwd.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/ios_base.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/atomicity.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/i486-linux-gnu/bits/atomic_word.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/locale_classes.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/string
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/stl_function.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/basic_string.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/basic_string.tcc
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/streambuf
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/streambuf.tcc
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/basic_ios.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/streambuf_iterator.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/locale_facets.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/cwctype
........... /usr/include/wctype.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/i486-linux-gnu/bits/ctype_base.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/i486-linux-gnu/bits/ctype_inline.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/codecvt.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/i486-linux-gnu/bits/time_members.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/i486-linux-gnu/bits/messages_members.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/basic_ios.tcc
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/ostream.tcc
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/locale
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/locale_facets.tcc
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/typeinfo
...... /usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/istream
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/istream.tcc
..... /tmp/CGAL-3.4/include/CGAL/assertions.h
...... /tmp/CGAL-3.4/include/CGAL/Uncertain.h
....... /tmp/CGAL-3.4/include/CGAL/assertions.h
....... /tmp/CGAL-3.4/include/CGAL/enum.h
........ /tmp/CGAL-3.4/include/CGAL/Kernel/Same_uncertainty.h
....... /tmp/CGAL-3.4/include/CGAL/Profile_counter.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/iomanip
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/functional
........ /usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/map
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/stl_tree.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/stl_map.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/stl_multimap.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/stdexcept
..... /tmp/CGAL-3.4/include/CGAL/tags.h
...... /tmp/CGAL-3.4/include/CGAL/IO/io_tags.h
..... /tmp/CGAL-3.4/include/CGAL/number_type_basic.h
...... /tmp/CGAL-3.4/include/CGAL/basic.h
...... /usr/include/boost/type_traits/is_same.hpp
....... /usr/include/boost/type_traits/config.hpp
....... /usr/include/boost/type_traits/detail/bool_trait_def.hpp
........ /usr/include/boost/type_traits/detail/template_arity_spec.hpp
......... /usr/include/boost/mpl/int.hpp
.......... /usr/include/boost/mpl/int_fwd.hpp
........... /usr/include/boost/mpl/aux_/adl_barrier.hpp
............ /usr/include/boost/mpl/aux_/config/adl.hpp
............. /usr/include/boost/mpl/aux_/config/msvc.hpp
............. /usr/include/boost/mpl/aux_/config/intel.hpp
............. /usr/include/boost/mpl/aux_/config/gcc.hpp
............. /usr/include/boost/mpl/aux_/config/workaround.hpp
.............. /usr/include/boost/detail/workaround.hpp
........... /usr/include/boost/mpl/aux_/nttp_decl.hpp
............ /usr/include/boost/mpl/aux_/config/nttp.hpp
.......... /usr/include/boost/mpl/aux_/integral_wrapper.hpp
........... /usr/include/boost/mpl/integral_c_tag.hpp
............ /usr/include/boost/mpl/aux_/config/static_constant.hpp
........... /usr/include/boost/mpl/aux_/static_cast.hpp
........... /usr/include/boost/preprocessor/cat.hpp
............ /usr/include/boost/preprocessor/config/config.hpp
......... /usr/include/boost/mpl/aux_/template_arity_fwd.hpp
......... /usr/include/boost/mpl/aux_/preprocessor/params.hpp
.......... /usr/include/boost/mpl/aux_/config/preprocessor.hpp
.......... /usr/include/boost/preprocessor/comma_if.hpp
........... /usr/include/boost/preprocessor/punctuation/comma_if.hpp
............ /usr/include/boost/preprocessor/control/if.hpp
............. /usr/include/boost/preprocessor/control/iif.hpp
............. /usr/include/boost/preprocessor/logical/bool.hpp
............ /usr/include/boost/preprocessor/facilities/empty.hpp
............ /usr/include/boost/preprocessor/punctuation/comma.hpp
.......... /usr/include/boost/preprocessor/repeat.hpp
........... /usr/include/boost/preprocessor/repetition/repeat.hpp
............ /usr/include/boost/preprocessor/debug/error.hpp
............ /usr/include/boost/preprocessor/detail/auto_rec.hpp
............ /usr/include/boost/preprocessor/tuple/eat.hpp
.......... /usr/include/boost/preprocessor/inc.hpp
........... /usr/include/boost/preprocessor/arithmetic/inc.hpp
......... /usr/include/boost/mpl/aux_/config/lambda.hpp
.......... /usr/include/boost/mpl/aux_/config/ttp.hpp
.......... /usr/include/boost/mpl/aux_/config/ctps.hpp
......... /usr/include/boost/mpl/aux_/config/overload_resolution.hpp
........ /usr/include/boost/type_traits/integral_constant.hpp
......... /usr/include/boost/mpl/bool.hpp
.......... /usr/include/boost/mpl/bool_fwd.hpp
......... /usr/include/boost/mpl/integral_c.hpp
.......... /usr/include/boost/mpl/integral_c_fwd.hpp
........ /usr/include/boost/mpl/aux_/lambda_support.hpp
....... /usr/include/boost/type_traits/detail/bool_trait_undef.hpp
...... /tmp/CGAL-3.4/include/CGAL/Kernel/mpl.h
...... /tmp/CGAL-3.4/include/CGAL/known_bit_size_integers.h
....... /tmp/CGAL-3.4/include/CGAL/number_type_basic.h
....... /usr/include/boost/mpl/if.hpp
........ /usr/include/boost/mpl/aux_/value_wknd.hpp
......... /usr/include/boost/mpl/aux_/config/integral.hpp
......... /usr/include/boost/mpl/aux_/config/eti.hpp
........ /usr/include/boost/mpl/aux_/na_spec.hpp
......... /usr/include/boost/mpl/lambda_fwd.hpp
.......... /usr/include/boost/mpl/void_fwd.hpp
.......... /usr/include/boost/mpl/aux_/na.hpp
........... /usr/include/boost/mpl/aux_/na_fwd.hpp
.......... /usr/include/boost/mpl/aux_/lambda_arity_param.hpp
......... /usr/include/boost/mpl/aux_/arity.hpp
.......... /usr/include/boost/mpl/aux_/config/dtp.hpp
......... /usr/include/boost/mpl/aux_/preprocessor/enum.hpp
......... /usr/include/boost/mpl/aux_/preprocessor/def_params_tail.hpp
.......... /usr/include/boost/mpl/limits/arity.hpp
.......... /usr/include/boost/preprocessor/logical/and.hpp
........... /usr/include/boost/preprocessor/logical/bitand.hpp
.......... /usr/include/boost/preprocessor/identity.hpp
........... /usr/include/boost/preprocessor/facilities/identity.hpp
.......... /usr/include/boost/preprocessor/empty.hpp
.......... /usr/include/boost/preprocessor/arithmetic/add.hpp
........... /usr/include/boost/preprocessor/arithmetic/dec.hpp
........... /usr/include/boost/preprocessor/control/while.hpp
............ /usr/include/boost/preprocessor/list/fold_left.hpp
............. /usr/include/boost/preprocessor/control/while.hpp
............. /usr/include/boost/preprocessor/detail/auto_rec.hpp
............. /usr/include/boost/preprocessor/list/detail/fold_left.hpp
.............. /usr/include/boost/preprocessor/control/expr_iif.hpp
.............. /usr/include/boost/preprocessor/list/adt.hpp
............... /usr/include/boost/preprocessor/detail/is_binary.hpp
................ /usr/include/boost/preprocessor/detail/check.hpp
............... /usr/include/boost/preprocessor/logical/compl.hpp
............ /usr/include/boost/preprocessor/list/fold_right.hpp
............. /usr/include/boost/preprocessor/list/detail/fold_right.hpp
.............. /usr/include/boost/preprocessor/list/reverse.hpp
............ /usr/include/boost/preprocessor/control/detail/while.hpp
........... /usr/include/boost/preprocessor/tuple/elem.hpp
.......... /usr/include/boost/preprocessor/arithmetic/sub.hpp
...... /tmp/CGAL-3.4/include/CGAL/Coercion_traits.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/iterator
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/stream_iterator.h
....... /usr/include/boost/iterator/transform_iterator.hpp
........ /usr/include/boost/function.hpp
......... /usr/include/boost/preprocessor/iterate.hpp
.......... /usr/include/boost/preprocessor/iteration/iterate.hpp
........... /usr/include/boost/preprocessor/array/elem.hpp
............ /usr/include/boost/preprocessor/array/data.hpp
............ /usr/include/boost/preprocessor/array/size.hpp
........... /usr/include/boost/preprocessor/slot/slot.hpp
............ /usr/include/boost/preprocessor/slot/detail/def.hpp
......... /usr/include/boost/function/detail/prologue.hpp
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/cassert
........... /usr/include/assert.h
.......... /usr/include/boost/throw_exception.hpp
.......... /usr/include/boost/function/function_base.hpp
........... /usr/include/boost/assert.hpp
............ /usr/include/assert.h
........... /usr/include/boost/type_traits/is_integral.hpp
............ /usr/include/boost/type_traits/detail/bool_trait_def.hpp
............. /usr/include/boost/type_traits/detail/template_arity_spec.hpp
............ /usr/include/boost/type_traits/detail/bool_trait_undef.hpp
........... /usr/include/boost/type_traits/composite_traits.hpp
............ /usr/include/boost/type_traits/is_array.hpp
............. /usr/include/boost/type_traits/detail/bool_trait_def.hpp
.............. /usr/include/boost/type_traits/detail/template_arity_spec.hpp
............. /usr/include/boost/type_traits/detail/bool_trait_undef.hpp
............ /usr/include/boost/type_traits/is_enum.hpp
............. /usr/include/boost/type_traits/add_reference.hpp
.............. /usr/include/boost/type_traits/is_reference.hpp
............... /usr/include/boost/type_traits/detail/bool_trait_def.hpp
................ /usr/include/boost/type_traits/detail/template_arity_spec.hpp
............... /usr/include/boost/type_traits/detail/bool_trait_undef.hpp
.............. /usr/include/boost/type_traits/detail/type_trait_def.hpp
.............. /usr/include/boost/type_traits/detail/type_trait_undef.hpp
............. /usr/include/boost/type_traits/is_arithmetic.hpp
.............. /usr/include/boost/type_traits/is_float.hpp
.............. /usr/include/boost/type_traits/detail/ice_or.hpp
............. /usr/include/boost/type_traits/is_convertible.hpp
.............. /usr/include/boost/type_traits/detail/yes_no_type.hpp
.............. /usr/include/boost/type_traits/ice.hpp
............... /usr/include/boost/type_traits/detail/ice_and.hpp
............... /usr/include/boost/type_traits/detail/ice_not.hpp
............... /usr/include/boost/type_traits/detail/ice_eq.hpp
.............. /usr/include/boost/type_traits/is_abstract.hpp
............... /usr/include/boost/static_assert.hpp
............... /usr/include/boost/type_traits/detail/yes_no_type.hpp
............... /usr/include/boost/type_traits/is_class.hpp
................ /usr/include/boost/type_traits/is_union.hpp
................. /usr/include/boost/type_traits/remove_cv.hpp
.................. /usr/include/boost/type_traits/broken_compiler_spec.hpp
.................. /usr/include/boost/type_traits/detail/cv_traits_impl.hpp
.................. /usr/include/boost/type_traits/detail/type_trait_def.hpp
.................. /usr/include/boost/type_traits/detail/type_trait_undef.hpp
................. /usr/include/boost/type_traits/intrinsics.hpp
................. /usr/include/boost/type_traits/detail/bool_trait_def.hpp
................. /usr/include/boost/type_traits/detail/bool_trait_undef.hpp
............. /usr/include/boost/type_traits/is_function.hpp
.............. /usr/include/boost/type_traits/detail/false_result.hpp
/usr/include/boost/type_traits/detail/is_function_ptr_helper.hpp
............... /usr/include/boost/type_traits/config.hpp
............ /usr/include/boost/type_traits/is_member_pointer.hpp
............. /usr/include/boost/type_traits/is_member_function_pointer.hpp
/usr/include/boost/type_traits/detail/is_mem_fun_pointer_impl.hpp
............ /usr/include/boost/type_traits/is_pointer.hpp
........... /usr/include/boost/type_traits/is_stateless.hpp
............ /usr/include/boost/type_traits/has_trivial_constructor.hpp
............. /usr/include/boost/type_traits/is_pod.hpp
.............. /usr/include/boost/type_traits/is_void.hpp
.............. /usr/include/boost/type_traits/is_scalar.hpp
............ /usr/include/boost/type_traits/has_trivial_copy.hpp
............. /usr/include/boost/type_traits/is_volatile.hpp
............ /usr/include/boost/type_traits/has_trivial_destructor.hpp
............ /usr/include/boost/type_traits/is_empty.hpp
........... /usr/include/boost/ref.hpp
............ /usr/include/boost/utility/addressof.hpp
........... /usr/include/boost/pending/ct_if.hpp
........... /usr/include/boost/utility/enable_if.hpp
........... /usr/include/boost/function_equal.hpp
.......... /usr/include/boost/mem_fn.hpp
........... /usr/include/boost/get_pointer.hpp
........... /usr/include/boost/bind/mem_fn_template.hpp
........... /usr/include/boost/bind/mem_fn_cc.hpp
.......... /usr/include/boost/preprocessor/enum.hpp
........... /usr/include/boost/preprocessor/repetition/enum.hpp
............ /usr/include/boost/preprocessor/tuple/rem.hpp
.......... /usr/include/boost/preprocessor/enum_params.hpp
........... /usr/include/boost/preprocessor/repetition/enum_params.hpp
......... /usr/include/boost/preprocessor/iteration/detail/iter/forward1.hpp
.......... /usr/include/boost/preprocessor/iteration/detail/bounds/lower1.hpp
........... /usr/include/boost/preprocessor/slot/detail/shared.hpp
.......... /usr/include/boost/preprocessor/iteration/detail/bounds/upper1.hpp
.......... /usr/include/boost/function/detail/function_iterate.hpp
........... /usr/include/boost/function/detail/maybe_include.hpp
............ /usr/include/boost/function/function_template.hpp
........ /usr/include/boost/iterator.hpp
........ /usr/include/boost/iterator/detail/enable_if.hpp
......... /usr/include/boost/mpl/identity.hpp
......... /usr/include/boost/iterator/detail/config_def.hpp
......... /usr/include/boost/iterator/detail/config_undef.hpp
........ /usr/include/boost/iterator/iterator_adaptor.hpp
......... /usr/include/boost/detail/iterator.hpp
......... /usr/include/boost/iterator/iterator_categories.hpp
.......... /usr/include/boost/iterator/detail/config_def.hpp
.......... /usr/include/boost/mpl/eval_if.hpp
.......... /usr/include/boost/mpl/placeholders.hpp
........... /usr/include/boost/mpl/arg.hpp
............ /usr/include/boost/mpl/arg_fwd.hpp
............ /usr/include/boost/mpl/aux_/na_assert.hpp
............. /usr/include/boost/mpl/assert.hpp
.............. /usr/include/boost/mpl/not.hpp
............... /usr/include/boost/mpl/aux_/nested_type_wknd.hpp
.............. /usr/include/boost/mpl/aux_/yes_no.hpp
............... /usr/include/boost/mpl/aux_/config/arrays.hpp
............ /usr/include/boost/mpl/aux_/arity_spec.hpp
............ /usr/include/boost/mpl/aux_/arg_typedef.hpp
............ /usr/include/boost/mpl/aux_/config/use_preprocessed.hpp
............ /usr/include/boost/mpl/aux_/include_preprocessed.hpp
............. /usr/include/boost/mpl/aux_/config/compiler.hpp
............. /usr/include/boost/preprocessor/stringize.hpp
............. /usr/include/boost/mpl/aux_/preprocessed/gcc/arg.hpp
............ /usr/include/boost/mpl/aux_/preprocessed/gcc/placeholders.hpp
.......... /usr/include/boost/iterator/detail/config_undef.hpp
......... /usr/include/boost/iterator/iterator_facade.hpp
.......... /usr/include/boost/iterator/interoperable.hpp
........... /usr/include/boost/mpl/or.hpp
............. /usr/include/boost/mpl/aux_/preprocessed/gcc/or.hpp
........... /usr/include/boost/iterator/detail/config_def.hpp
........... /usr/include/boost/iterator/detail/config_undef.hpp
.......... /usr/include/boost/iterator/iterator_traits.hpp
.......... /usr/include/boost/iterator/detail/facade_iterator_category.hpp
........... /usr/include/boost/mpl/and.hpp
............. /usr/include/boost/mpl/aux_/preprocessed/gcc/and.hpp
........... /usr/include/boost/type_traits/is_const.hpp
........... /usr/include/boost/detail/indirect_traits.hpp
............ /usr/include/boost/type_traits/remove_reference.hpp
............ /usr/include/boost/type_traits/remove_pointer.hpp
.......... /usr/include/boost/implicit_cast.hpp
.......... /usr/include/boost/type_traits/add_const.hpp
.......... /usr/include/boost/type_traits/add_pointer.hpp
.......... /usr/include/boost/type_traits/remove_const.hpp
.......... /usr/include/boost/mpl/always.hpp
.......... /usr/include/boost/mpl/apply.hpp
........... /usr/include/boost/mpl/apply_fwd.hpp
............. /usr/include/boost/mpl/aux_/preprocessed/gcc/apply_fwd.hpp
........... /usr/include/boost/mpl/apply_wrap.hpp
............ /usr/include/boost/mpl/aux_/has_apply.hpp
............. /usr/include/boost/mpl/has_xxx.hpp
.............. /usr/include/boost/mpl/aux_/type_wrapper.hpp
.............. /usr/include/boost/mpl/aux_/config/has_xxx.hpp
.............. /usr/include/boost/mpl/aux_/config/msvc_typename.hpp
............. /usr/include/boost/mpl/aux_/config/has_apply.hpp
............ /usr/include/boost/mpl/aux_/msvc_never_true.hpp
............. /usr/include/boost/mpl/aux_/preprocessed/gcc/apply_wrap.hpp
........... /usr/include/boost/mpl/placeholders.hpp
........... /usr/include/boost/mpl/lambda.hpp
............ /usr/include/boost/mpl/bind.hpp
............. /usr/include/boost/mpl/bind_fwd.hpp
.............. /usr/include/boost/mpl/aux_/config/bind.hpp
.............. /usr/include/boost/mpl/aux_/include_preprocessed.hpp
............... /usr/include/boost/mpl/aux_/preprocessed/gcc/bind_fwd.hpp
............. /usr/include/boost/mpl/placeholders.hpp
............. /usr/include/boost/mpl/next.hpp
.............. /usr/include/boost/mpl/next_prior.hpp
............... /usr/include/boost/mpl/aux_/common_name_wknd.hpp
............. /usr/include/boost/mpl/protect.hpp
............. /usr/include/boost/mpl/apply_wrap.hpp
.............. /usr/include/boost/mpl/aux_/preprocessed/gcc/bind.hpp
............ /usr/include/boost/mpl/aux_/full_lambda.hpp
............. /usr/include/boost/mpl/quote.hpp
.............. /usr/include/boost/mpl/void.hpp
.............. /usr/include/boost/mpl/aux_/has_type.hpp
............... /usr/include/boost/mpl/aux_/preprocessed/gcc/quote.hpp
............. /usr/include/boost/mpl/arg.hpp
............. /usr/include/boost/mpl/aux_/template_arity.hpp
/usr/include/boost/mpl/aux_/preprocessed/gcc/template_arity.hpp
.............. /usr/include/boost/mpl/aux_/preprocessed/gcc/full_lambda.hpp
............ /usr/include/boost/mpl/aux_/preprocessed/gcc/apply.hpp
........ /usr/include/boost/type_traits/function_traits.hpp
...... /tmp/CGAL-3.4/include/CGAL/Algebraic_structure_traits.h
....... /tmp/CGAL-3.4/include/CGAL/type_traits.h
........ /usr/include/boost/type_traits/is_base_and_derived.hpp
...... /tmp/CGAL-3.4/include/CGAL/Real_embeddable_traits.h
...... /tmp/CGAL-3.4/include/CGAL/Fraction_traits.h
...... /tmp/CGAL-3.4/include/CGAL/Rational_traits.h
...... /tmp/CGAL-3.4/include/CGAL/Scalar_factor_traits.h
...... /tmp/CGAL-3.4/include/CGAL/Algebraic_extension_traits.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/numeric
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/stl_numeric.h
...... /tmp/CGAL-3.4/include/CGAL/Needs_parens_as_product.h
....... /tmp/CGAL-3.4/include/CGAL/IO/io.h
........ /tmp/CGAL-3.4/include/CGAL/IO/Color.h
...... /tmp/CGAL-3.4/include/CGAL/utils_classes.h
...... /tmp/CGAL-3.4/include/CGAL/utils.h
...... /tmp/CGAL-3.4/include/CGAL/number_utils.h
...... /tmp/CGAL-3.4/include/CGAL/number_utils_classes.h
...... /tmp/CGAL-3.4/include/CGAL/FPU.h
....... /usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/cmath
........ /usr/include/math.h
......... /usr/include/bits/huge_val.h
......... /usr/include/bits/huge_valf.h
......... /usr/include/bits/huge_vall.h
......... /usr/include/bits/inf.h
......... /usr/include/bits/nan.h
......... /usr/include/bits/mathdef.h
......... /usr/include/bits/mathcalls.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/cmath.tcc
...... /tmp/CGAL-3.4/include/CGAL/float.h
...... /tmp/CGAL-3.4/include/CGAL/double.h
...... /tmp/CGAL-3.4/include/CGAL/long_double.h
....... /tmp/CGAL-3.4/include/CGAL/Interval_nt.h
...... /tmp/CGAL-3.4/include/CGAL/int.h
....... /tmp/CGAL-3.4/include/CGAL/Modular_traits.h
........ /tmp/CGAL-3.4/include/CGAL/Residue.h
......... /tmp/CGAL-3.4/include/CGAL/Modular_arithmetic/Residue_type.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/cfloat
........... /usr/lib/gcc/i486-linux-gnu/4.1.2/include/float.h
.......... /usr/include/boost/operators.hpp
.......... /usr/include/boost/thread/tss.hpp
........... /usr/include/boost/thread/detail/config.hpp
............ /usr/include/boost/config/requires_threads.hpp
............ /usr/include/boost/config/auto_link.hpp
........... /usr/include/boost/utility.hpp
............ /usr/include/boost/utility/base_from_member.hpp
/usr/include/boost/preprocessor/repetition/enum_binary_params.hpp
............. /usr/include/boost/preprocessor/repetition/repeat_from_to.hpp
.............. /usr/include/boost/preprocessor/detail/auto_rec.hpp
............ /usr/include/boost/utility/enable_if.hpp
............ /usr/include/boost/checked_delete.hpp
............ /usr/include/boost/next_prior.hpp
............ /usr/include/boost/noncopyable.hpp
........... /usr/include/boost/function.hpp
.............. /usr/include/boost/preprocessor/slot/detail/shared.hpp
............. /usr/include/boost/function/detail/function_iterate.hpp
.............. /usr/include/boost/function/detail/maybe_include.hpp
........... /usr/include/boost/thread/exceptions.hpp
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/vector
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/stl_vector.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/stl_bvector.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/vector.tcc
...... /tmp/CGAL-3.4/include/CGAL/long_long.h
...... /tmp/CGAL-3.4/include/CGAL/Root_of_traits.h
....... /tmp/CGAL-3.4/include/CGAL/Root_of_2.h
........ /tmp/CGAL-3.4/include/CGAL/Root_of_traits.h
........ /tmp/CGAL-3.4/include/CGAL/NT_converter.h
/tmp/CGAL-3.4/include/CGAL/Number_types/internal_functions_comparison_root_of_2.h
......... /tmp/CGAL-3.4/include/CGAL/kernel_assertions.h
........ /tmp/CGAL-3.4/include/CGAL/Interval_arithmetic.h
........ /tmp/CGAL-3.4/include/CGAL/assertions.h
....... /tmp/CGAL-3.4/include/CGAL/Quotient.h
...... /tmp/CGAL-3.4/include/CGAL/gmpxx.h
....... /usr/include/gmpxx.h
........ /usr/local/include/gmp.h
....... /tmp/CGAL-3.4/include/CGAL/mpz_class.h
........ /tmp/CGAL-3.4/include/CGAL/gmpxx_coercion_traits.h
......... /usr/include/gmpxx.h
......... /usr/include/mpfr.h
....... /tmp/CGAL-3.4/include/CGAL/mpq_class.h
..... /tmp/CGAL-3.4/include/CGAL/kernel_basic.h
...... /tmp/CGAL-3.4/include/CGAL/aff_transformation_tags.h
...... /tmp/CGAL-3.4/include/CGAL/Object.h
....... /tmp/CGAL-3.4/include/CGAL/Handle_for_virtual.h
...... /tmp/CGAL-3.4/include/CGAL/Qualified_result_of.h
....... /usr/include/boost/type_traits.hpp
........ /usr/include/boost/type_traits/add_cv.hpp
........ /usr/include/boost/type_traits/add_volatile.hpp
........ /usr/include/boost/type_traits/alignment_of.hpp
......... /usr/include/boost/type_traits/detail/size_t_trait_def.hpp
.......... /usr/include/boost/mpl/size_t.hpp
........... /usr/include/boost/mpl/size_t_fwd.hpp
........... /usr/include/boost/mpl/aux_/integral_wrapper.hpp
......... /usr/include/boost/type_traits/detail/size_t_trait_undef.hpp
........ /usr/include/boost/type_traits/has_nothrow_assign.hpp
......... /usr/include/boost/type_traits/has_trivial_assign.hpp
........ /usr/include/boost/type_traits/has_nothrow_constructor.hpp
........ /usr/include/boost/type_traits/has_nothrow_copy.hpp
........ /usr/include/boost/type_traits/has_nothrow_destructor.hpp
........ /usr/include/boost/type_traits/has_virtual_destructor.hpp
........ /usr/include/boost/type_traits/is_signed.hpp
........ /usr/include/boost/type_traits/is_unsigned.hpp
........ /usr/include/boost/type_traits/is_base_of.hpp
........ /usr/include/boost/type_traits/is_compound.hpp
......... /usr/include/boost/type_traits/is_fundamental.hpp
........ /usr/include/boost/type_traits/is_floating_point.hpp
........ /usr/include/boost/type_traits/is_member_object_pointer.hpp
........ /usr/include/boost/type_traits/is_object.hpp
........ /usr/include/boost/type_traits/is_polymorphic.hpp
........ /usr/include/boost/type_traits/rank.hpp
........ /usr/include/boost/type_traits/extent.hpp
........ /usr/include/boost/type_traits/remove_bounds.hpp
........ /usr/include/boost/type_traits/remove_extent.hpp
........ /usr/include/boost/type_traits/remove_all_extents.hpp
........ /usr/include/boost/type_traits/remove_volatile.hpp
........ /usr/include/boost/type_traits/type_with_alignment.hpp
......... /usr/include/boost/preprocessor/list/for_each_i.hpp
.......... /usr/include/boost/preprocessor/repetition/for.hpp
........... /usr/include/boost/preprocessor/repetition/detail/for.hpp
......... /usr/include/boost/preprocessor/tuple/to_list.hpp
......... /usr/include/boost/preprocessor/list/transform.hpp
......... /usr/include/boost/preprocessor/list/append.hpp
......... /usr/include/boost/type_traits/alignment_of.hpp
........ /usr/include/boost/type_traits/aligned_storage.hpp
......... /usr/include/boost/aligned_storage.hpp
...... /tmp/CGAL-3.4/include/CGAL/Kernel_traits.h
.... /tmp/CGAL-3.4/include/CGAL/basic_classes.h
..... /tmp/CGAL-3.4/include/CGAL/Origin.h
..... /tmp/CGAL-3.4/include/CGAL/Bbox_2.h
...... /tmp/CGAL-3.4/include/CGAL/Dimension.h
...... /tmp/CGAL-3.4/include/CGAL/array.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/tr1/array
..... /tmp/CGAL-3.4/include/CGAL/Bbox_3.h
..... /tmp/CGAL-3.4/include/CGAL/representation_tags.h
.... /tmp/CGAL-3.4/include/CGAL/Kernel/global_functions.h
..... /tmp/CGAL-3.4/include/CGAL/Kernel/global_functions_2.h
...... /tmp/CGAL-3.4/include/CGAL/user_classes.h
....... /tmp/CGAL-3.4/include/CGAL/Point_2.h
........ /tmp/CGAL-3.4/include/CGAL/Kernel/Return_base_tag.h
....... /tmp/CGAL-3.4/include/CGAL/Vector_2.h
....... /tmp/CGAL-3.4/include/CGAL/Direction_2.h
....... /tmp/CGAL-3.4/include/CGAL/Line_2.h
....... /tmp/CGAL-3.4/include/CGAL/Ray_2.h
....... /tmp/CGAL-3.4/include/CGAL/Segment_2.h
....... /tmp/CGAL-3.4/include/CGAL/Triangle_2.h
....... /tmp/CGAL-3.4/include/CGAL/Iso_rectangle_2.h
....... /tmp/CGAL-3.4/include/CGAL/Circle_2.h
....... /tmp/CGAL-3.4/include/CGAL/Conic_2.h
........ /tmp/CGAL-3.4/include/CGAL/Conic_misc.h
....... /tmp/CGAL-3.4/include/CGAL/Aff_transformation_2.h
....... /tmp/CGAL-3.4/include/CGAL/Point_3.h
....... /tmp/CGAL-3.4/include/CGAL/Plane_3.h
....... /tmp/CGAL-3.4/include/CGAL/Vector_3.h
....... /tmp/CGAL-3.4/include/CGAL/Direction_3.h
....... /tmp/CGAL-3.4/include/CGAL/Line_3.h
....... /tmp/CGAL-3.4/include/CGAL/Ray_3.h
....... /tmp/CGAL-3.4/include/CGAL/Segment_3.h
....... /tmp/CGAL-3.4/include/CGAL/Triangle_3.h
....... /tmp/CGAL-3.4/include/CGAL/Tetrahedron_3.h
....... /tmp/CGAL-3.4/include/CGAL/Iso_cuboid_3.h
....... /tmp/CGAL-3.4/include/CGAL/Sphere_3.h
....... /tmp/CGAL-3.4/include/CGAL/Circle_3.h
....... /tmp/CGAL-3.4/include/CGAL/Aff_transformation_3.h
...... /tmp/CGAL-3.4/include/CGAL/Kernel/global_functions_internal_2.h
..... /tmp/CGAL-3.4/include/CGAL/Kernel/global_functions_3.h
...... /tmp/CGAL-3.4/include/CGAL/Kernel/global_functions_internal_3.h
.... /tmp/CGAL-3.4/include/CGAL/Cartesian/Point_2.h
.... /tmp/CGAL-3.4/include/CGAL/Cartesian/Vector_2.h
..... /tmp/CGAL-3.4/include/CGAL/constant.h
..... /tmp/CGAL-3.4/include/CGAL/Handle_for.h
...... /tmp/CGAL-3.4/include/CGAL/memory.h
.... /tmp/CGAL-3.4/include/CGAL/Cartesian/Direction_2.h
.... /tmp/CGAL-3.4/include/CGAL/Cartesian/Line_2.h
..... /tmp/CGAL-3.4/include/CGAL/predicates/kernel_ftC2.h
...... /tmp/CGAL-3.4/include/CGAL/algorithm.h
...... /tmp/CGAL-3.4/include/CGAL/predicates/sign_of_determinant.h
....... /tmp/CGAL-3.4/include/CGAL/determinant.h
...... /tmp/CGAL-3.4/include/CGAL/constructions/kernel_ftC2.h
.... /tmp/CGAL-3.4/include/CGAL/Cartesian/Ray_2.h
.... /tmp/CGAL-3.4/include/CGAL/Cartesian/Segment_2.h
..... /tmp/CGAL-3.4/include/CGAL/Cartesian/predicates_on_points_2.h
.... /tmp/CGAL-3.4/include/CGAL/Cartesian/Triangle_2.h
.... /tmp/CGAL-3.4/include/CGAL/Cartesian/Circle_2.h
..... /usr/include/boost/tuple/tuple.hpp
...... /usr/include/boost/tuple/detail/tuple_basic.hpp
....... /usr/include/boost/concept_check.hpp
........ /usr/include/boost/type_traits/conversion_traits.hpp
....... /usr/include/boost/type_traits/cv_traits.hpp
.... /tmp/CGAL-3.4/include/CGAL/Cartesian/Iso_rectangle_2.h
.... /tmp/CGAL-3.4/include/CGAL/Cartesian/Aff_transformation_2.h
..... /tmp/CGAL-3.4/include/CGAL/Cartesian/Aff_transformation_rep_2.h
..... /tmp/CGAL-3.4/include/CGAL/Cartesian/Translation_rep_2.h
..... /tmp/CGAL-3.4/include/CGAL/Cartesian/Rotation_rep_2.h
...... /tmp/CGAL-3.4/include/CGAL/rational_rotation.h
..... /tmp/CGAL-3.4/include/CGAL/Cartesian/Scaling_rep_2.h
.... /tmp/CGAL-3.4/include/CGAL/Cartesian/Data_accessor_2.h
.... /tmp/CGAL-3.4/include/CGAL/ConicCPA2.h
.... /tmp/CGAL-3.4/include/CGAL/Cartesian/predicates_on_directions_2.h
.... /tmp/CGAL-3.4/include/CGAL/Cartesian/basic_constructions_2.h
..... /tmp/CGAL-3.4/include/CGAL/Cartesian/point_constructions_2.h
..... /tmp/CGAL-3.4/include/CGAL/Cartesian/line_constructions_2.h
..... /tmp/CGAL-3.4/include/CGAL/Cartesian/ft_constructions_2.h
.... /tmp/CGAL-3.4/include/CGAL/Cartesian/Point_3.h
.... /tmp/CGAL-3.4/include/CGAL/Cartesian/Vector_3.h
.... /tmp/CGAL-3.4/include/CGAL/Cartesian/Direction_3.h
.... /tmp/CGAL-3.4/include/CGAL/Cartesian/Line_3.h
.... /tmp/CGAL-3.4/include/CGAL/Cartesian/Plane_3.h
.... /tmp/CGAL-3.4/include/CGAL/Cartesian/Ray_3.h
.... /tmp/CGAL-3.4/include/CGAL/Cartesian/Segment_3.h
.... /tmp/CGAL-3.4/include/CGAL/Cartesian/Triangle_3.h
.... /tmp/CGAL-3.4/include/CGAL/Cartesian/Tetrahedron_3.h
.... /tmp/CGAL-3.4/include/CGAL/Cartesian/Iso_cuboid_3.h
..... /tmp/CGAL-3.4/include/CGAL/Cartesian/predicates_on_points_3.h
...... /tmp/CGAL-3.4/include/CGAL/predicates/kernel_ftC3.h
....... /tmp/CGAL-3.4/include/CGAL/constructions/kernel_ftC3.h
.... /tmp/CGAL-3.4/include/CGAL/Cartesian/Sphere_3.h
.... /tmp/CGAL-3.4/include/CGAL/Cartesian/Circle_3.h
.... /tmp/CGAL-3.4/include/CGAL/Cartesian/Aff_transformation_3.h
..... /tmp/CGAL-3.4/include/CGAL/Cartesian/Aff_transformation_rep_3.h
..... /tmp/CGAL-3.4/include/CGAL/Cartesian/Translation_rep_3.h
..... /tmp/CGAL-3.4/include/CGAL/Cartesian/Scaling_rep_3.h
.... /tmp/CGAL-3.4/include/CGAL/Cartesian/predicates_on_planes_3.h
.... /tmp/CGAL-3.4/include/CGAL/Cartesian/basic_constructions_3.h
..... /tmp/CGAL-3.4/include/CGAL/Cartesian/point_constructions_3.h
..... /tmp/CGAL-3.4/include/CGAL/Cartesian/plane_constructions_3.h
..... /tmp/CGAL-3.4/include/CGAL/Cartesian/ft_constructions_3.h
.... /tmp/CGAL-3.4/include/CGAL/Cartesian/function_objects.h
..... /tmp/CGAL-3.4/include/CGAL/Kernel/function_objects.h
...... /tmp/CGAL-3.4/include/CGAL/squared_distance_2.h
....... /tmp/CGAL-3.4/include/CGAL/squared_distance_2_1.h
........ /tmp/CGAL-3.4/include/CGAL/wmult.h
......... /tmp/CGAL-3.4/include/CGAL/Kernel/Wutils.h
........ /tmp/CGAL-3.4/include/CGAL/squared_distance_utils.h
....... /tmp/CGAL-3.4/include/CGAL/squared_distance_2_2.h
...... /tmp/CGAL-3.4/include/CGAL/squared_distance_3.h
....... /tmp/CGAL-3.4/include/CGAL/squared_distance_3_0.h
....... /tmp/CGAL-3.4/include/CGAL/squared_distance_3_1.h
....... /tmp/CGAL-3.4/include/CGAL/squared_distance_3_2.h
...... /tmp/CGAL-3.4/include/CGAL/intersection_2.h
....... /tmp/CGAL-3.4/include/CGAL/intersection_2_1.h
........ /tmp/CGAL-3.4/include/CGAL/Line_2_Line_2_intersection.h
........ /tmp/CGAL-3.4/include/CGAL/Segment_2_Line_2_intersection.h
........ /tmp/CGAL-3.4/include/CGAL/Segment_2_Segment_2_intersection.h
......... /tmp/CGAL-3.4/include/CGAL/predicates_on_points_2.h
........ /tmp/CGAL-3.4/include/CGAL/Ray_2_Line_2_intersection.h
........ /tmp/CGAL-3.4/include/CGAL/Ray_2_Segment_2_intersection.h
........ /tmp/CGAL-3.4/include/CGAL/Ray_2_Ray_2_intersection.h
........ /tmp/CGAL-3.4/include/CGAL/Point_2_Line_2_intersection.h
........ /tmp/CGAL-3.4/include/CGAL/Point_2_Ray_2_intersection.h
........ /tmp/CGAL-3.4/include/CGAL/Point_2_Segment_2_intersection.h
........ /tmp/CGAL-3.4/include/CGAL/Point_2_Point_2_intersection.h
........ /tmp/CGAL-3.4/include/CGAL/Point_2_Triangle_2_intersection.h
......... /tmp/CGAL-3.4/include/CGAL/Straight_2.h
....... /tmp/CGAL-3.4/include/CGAL/intersection_2_2.h
........ /tmp/CGAL-3.4/include/CGAL/Triangle_2_Triangle_2_intersection.h
......... /tmp/CGAL-3.4/include/CGAL/Triangle_2_Triangle_2_do_intersect.h
/tmp/CGAL-3.4/include/CGAL/Intersections_2/Triangle_2_Triangle_2_intersection_impl.h
........ /tmp/CGAL-3.4/include/CGAL/Triangle_2_Line_2_intersection.h
......... /tmp/CGAL-3.4/include/CGAL/Line_2_Triangle_2_intersection.h
........ /tmp/CGAL-3.4/include/CGAL/Triangle_2_Ray_2_intersection.h
......... /tmp/CGAL-3.4/include/CGAL/Ray_2_Triangle_2_intersection.h
........ /tmp/CGAL-3.4/include/CGAL/Triangle_2_Segment_2_intersection.h
......... /tmp/CGAL-3.4/include/CGAL/Segment_2_Triangle_2_intersection.h
........ /tmp/CGAL-3.4/include/CGAL/Line_2_Iso_rectangle_2_intersection.h
........ /tmp/CGAL-3.4/include/CGAL/Ray_2_Iso_rectangle_2_intersection.h
........ /tmp/CGAL-3.4/include/CGAL/Segment_2_Iso_rectangle_2_intersection.h
........ /tmp/CGAL-3.4/include/CGAL/Point_2_Iso_rectangle_2_intersection.h
/tmp/CGAL-3.4/include/CGAL/Iso_rectangle_2_Iso_rectangle_2_intersection.h
....... /tmp/CGAL-3.4/include/CGAL/intersection_2_3.h
........ /tmp/CGAL-3.4/include/CGAL/Circle_2_Circle_2_intersection.h
........ /tmp/CGAL-3.4/include/CGAL/Circle_2_Line_2_intersection.h
...... /tmp/CGAL-3.4/include/CGAL/intersection_3.h
....... /tmp/CGAL-3.4/include/CGAL/intersection_3_1.h
........ /tmp/CGAL-3.4/include/CGAL/bbox_intersection_3.h
........ /tmp/CGAL-3.4/include/CGAL/Intersections_3/intersection_3_1_impl.h
....... /tmp/CGAL-3.4/include/CGAL/Triangle_3_Line_3_do_intersect.h
....... /tmp/CGAL-3.4/include/CGAL/Triangle_3_Plane_3_do_intersect.h
....... /tmp/CGAL-3.4/include/CGAL/Triangle_3_Point_3_do_intersect.h
....... /tmp/CGAL-3.4/include/CGAL/Triangle_3_Ray_3_do_intersect.h
....... /tmp/CGAL-3.4/include/CGAL/Triangle_3_Segment_3_do_intersect.h
....... /tmp/CGAL-3.4/include/CGAL/Triangle_3_Tetrahedron_3_do_intersect.h
........ /tmp/CGAL-3.4/include/CGAL/Triangle_3_Triangle_3_do_intersect.h
..... /tmp/CGAL-3.4/include/CGAL/Cartesian/solve_3.h
...... /tmp/CGAL-3.4/include/CGAL/Kernel/solve.h
... /tmp/CGAL-3.4/include/CGAL/Kernel/Type_equality_wrapper.h
.... /tmp/CGAL-3.4/include/CGAL/Kernel/interface_macros.h
.. /tmp/CGAL-3.4/include/CGAL/Filtered_kernel.h
... /tmp/CGAL-3.4/include/CGAL/Filtered_predicate.h
... /tmp/CGAL-3.4/include/CGAL/Cartesian_converter.h
.... /tmp/CGAL-3.4/include/CGAL/Enum_converter.h
... /tmp/CGAL-3.4/include/CGAL/MP_Float.h
... /tmp/CGAL-3.4/include/CGAL/Exact_type_selecter.h
.... /tmp/CGAL-3.4/include/CGAL/Lazy_exact_nt.h
..... /tmp/CGAL-3.4/include/CGAL/Handle.h
..... /tmp/CGAL-3.4/include/CGAL/Lazy.h
...... /tmp/CGAL-3.4/include/CGAL/Kernel/Type_mapper.h
....... /tmp/CGAL-3.4/include/CGAL/Kernel/interface_macros.h
...... /tmp/CGAL-3.4/include/CGAL/min_max_n.h
...... /tmp/CGAL-3.4/include/CGAL/Default_argument.h
.... /tmp/CGAL-3.4/include/CGAL/Gmpz.h
..... /tmp/CGAL-3.4/include/CGAL/Gmp_coercion_traits.h
...... /tmp/CGAL-3.4/include/CGAL/GMP/Gmpz_type.h
....... /tmp/CGAL-3.4/include/CGAL/auto_link/GMP.h
........ /tmp/CGAL-3.4/include/CGAL/auto_link/auto_link.h
....... /tmp/CGAL-3.4/include/CGAL/auto_link/MPFR.h
...... /tmp/CGAL-3.4/include/CGAL/GMP/Gmpzf_type.h
...... /tmp/CGAL-3.4/include/CGAL/GMP/Gmpq_type.h
..... /tmp/CGAL-3.4/include/CGAL/Gmpz.h
..... /tmp/CGAL-3.4/include/CGAL/Gmpq.h
...... /tmp/CGAL-3.4/include/CGAL/Gmpq.h
...... /tmp/CGAL-3.4/include/CGAL/Gmpzf.h
....... /tmp/CGAL-3.4/include/CGAL/Gmpzf.h
... /tmp/CGAL-3.4/include/CGAL/Static_filters.h
.... /tmp/CGAL-3.4/include/CGAL/Static_filters/tools.h
.... /tmp/CGAL-3.4/include/CGAL/Static_filters/Orientation_2.h
..... /tmp/CGAL-3.4/include/CGAL/Static_filter_error.h
.... /tmp/CGAL-3.4/include/CGAL/Static_filters/Orientation_3.h
.... /tmp/CGAL-3.4/include/CGAL/Static_filters/Compare_y_at_x_2.h
.... /tmp/CGAL-3.4/include/CGAL/Static_filters/Side_of_oriented_circle_2.h
.... /tmp/CGAL-3.4/include/CGAL/Static_filters/Side_of_oriented_sphere_3.h
. /tmp/CGAL-3.4/include/CGAL/Polygon_2.h
.. /usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/list
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/stl_list.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/list.tcc
.. /tmp/CGAL-3.4/include/CGAL/circulator.h
... /tmp/CGAL-3.4/include/CGAL/circulator_bases.h
.. /tmp/CGAL-3.4/include/CGAL/Polygon_2_algorithms.h
... /tmp/CGAL-3.4/include/CGAL/Polygon_2/polygon_assertions.h
... /tmp/CGAL-3.4/include/CGAL/Polygon_2/Polygon_2_algorithms_impl.h
.... /tmp/CGAL-3.4/include/CGAL/Polygon_2/Polygon_2_simplicity.h
..... /tmp/CGAL-3.4/include/CGAL/Polygon_2/polygon_assertions.h
..... /usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/set
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/stl_set.h
/usr/lib/gcc/i486-linux-gnu/4.1.2/../../../../include/c++/4.1.2/bits/stl_multiset.h
.. /tmp/CGAL-3.4/include/CGAL/Polygon_2/Polygon_2_vertex_circulator.h
.. /tmp/CGAL-3.4/include/CGAL/Polygon_2/Polygon_2_edge_iterator.h
.. /tmp/CGAL-3.4/include/CGAL/Polygon_2/Polygon_2_edge_circulator.h
.. /tmp/CGAL-3.4/include/CGAL/Polygon_2/Polygon_2_impl.h
/usr/include/gmpxx.h: In destructor
'__gmp_alloc_cstring::~__gmp_alloc_cstring()':
/usr/include/gmpxx.h:1389: error: 'mp_get_memory_functions' was not declared
in this scope
vv417:~/research/C++> exit
Script done on Mon Feb 9 09:11:33 2009
