cgal-discuss - Re: [cgal-discuss] question on Installation on unix
  • To:
  • Subject: Re: [cgal-discuss] question on Installation on unix
  • Date: Mon, 09 Feb 2009 17:11:55 +0100
Hi,
And the output for g++ with -H option is attached as a file "res.out".
> ...... /tmp/CGAL-3.4/include/CGAL/gmpxx.h
> ....... /usr/include/gmpxx.h
> ........ /usr/local/include/gmp.h
The last file is the culprit. There is a GMP installation in /usr/local which does not match the GMPXX installation in /usr. You should either move the GMP installation in /usr/local/include away (including libs in /usr/local/lib), or you need a consistent GMP+GMPXX+MPFR installation in /usr/local.
Joachim
