- To:
- Subject: Re: [cgal-discuss] A mistake in linear_least_squares_fitting_3?
- Date: Fri, 13 Feb 2009 15:49:10 +0100
- Organization: INRIA
Hello wildabc (I was unable to recover your first name from your email, hence I take your gmail adress),
Many thanks for sending feedback on this bug - I will double check this and correct it as soon as possible. Should you have any other suggestions I would be pleased to improve the PCA component as well.
best regards,
Pierre Alliez
INRIA Sophia Antipolis - Mediterranee Project-team GEOMETRICA http://www-sop.inria.fr/members/Pierre.Alliez/
Tel: +33 4 92 38 76 77
Fax: +33 4 97 15 53 95
杨成林 a écrit :
Hello
I am new to CGAL.I use linear_least_squares_fitting_3 to estimate
normals from point-cloud.But it can't give correct results
sometimes.After examining the source code,I think line 709-710 in
PCA_util.h(CGAL 3.4) may be incorrect.
eigen_values[2] is the smallest eigenvalue,so "eigen_values[2] ==
eigen_values[1]" means Degeneracy."eigen_values[0] == eigen_values[1]"
just means the points distribute isotropically in the plane,but the
fitting plane exists uniquely.
I change this two lines to "if(eigen_values[2] != eigen_values[1])".It
works well.
- [cgal-discuss] A mistake in linear_least_squares_fitting_3?, 杨成林, 02/13/2009
- Re: [cgal-discuss] A mistake in linear_least_squares_fitting_3?, Pierre Alliez, 02/13/2009
- Re: [cgal-discuss] A mistake in linear_least_squares_fitting_3?, 杨成林, 02/16/2009
- Re: [cgal-discuss] A mistake in linear_least_squares_fitting_3?, Pierre Alliez, 02/16/2009
- Re: [cgal-discuss] A mistake in linear_least_squares_fitting_3?, 杨成林, 02/17/2009
- Re: [cgal-discuss] A mistake in linear_least_squares_fitting_3?, Pierre Alliez, 02/23/2009
- Re:Re: [cgal-discuss] A mistake in linear_least_squares_fitting_3?, null, 02/18/2009
- Re:[cgal-discuss] A mistake in linear_least_squares_fitting_3?, null, 02/14/2009
