- To: 杨成林 <>
- Cc: cgal-discuss <>
- Subject: Re:[cgal-discuss] A mistake in linear_least_squares_fitting_3?
- Date: Sat, 14 Feb 2009 15:18:31 +0800 (CST)
Heihei
在2009-02-13,"杨成林" <> 写道:
Hello I am new to CGAL.I use linear_least_squares_fitting_3 to estimate normals from point-cloud.But it can't give correct results sometimes.After examining the source code,I think line 709-710 in PCA_util.h(CGAL 3.4) may be incorrect. eigen_values[2] is the smallest eigenvalue,so "eigen_values[2] == eigen_values[1]" means Degeneracy."eigen_values[0] == eigen_values[1]" just means the points distribute isotropically in the plane,but the fitting plane exists uniquely. I change this two lines to "if(eigen_values[2] != eigen_values[1])".It works well. -- You are currently subscribed to cgal-discuss. To unsubscribe or access the archives, go to https://lists-sop.inria.fr/wws/info/cgal-discuss
网易邮箱,中国第一大电子邮件服务商
- [cgal-discuss] A mistake in linear_least_squares_fitting_3?, 杨成林, 02/13/2009
- Re: [cgal-discuss] A mistake in linear_least_squares_fitting_3?, Pierre Alliez, 02/13/2009
- Re: [cgal-discuss] A mistake in linear_least_squares_fitting_3?, 杨成林, 02/16/2009
- Re: [cgal-discuss] A mistake in linear_least_squares_fitting_3?, Pierre Alliez, 02/16/2009
- Re: [cgal-discuss] A mistake in linear_least_squares_fitting_3?, 杨成林, 02/17/2009
- Re:Re: [cgal-discuss] A mistake in linear_least_squares_fitting_3?, null, 02/18/2009
- Re:[cgal-discuss] A mistake in linear_least_squares_fitting_3?, null, 02/14/2009
