- To:
- Subject: Re: [cgal-discuss] A mistake in linear_least_squares_fitting_3?
- Date: Mon, 16 Feb 2009 06:17:05 -0700
- Organization: INRIA
dear 杨成林,
that's a good point, I am glad to get feedback from a user (normal
estimation for surface reconstruction?)
what would be a convenient API for you? if you propose a precise
interface we could refine it together for the next release. I think one
constraint is to avoid computing twice the eigenvectors, hence a
separate function to get all eigenvectors seems not appropriate.
杨成林 a écrit :
> Hello Alliez,
> Thanks for your immediate response.
> In the PCA component,users can only get the eigenvector corresponding
> to the largest eigenvalue in line-fitting or the eigenvector
> corresponding to the smallest eigenvalue in plane-fitting.The other
> eigenvectors seem to be inaccessible,though they are also very useful.
> 2009/2/13 Pierre Alliez
>> Hello wildabc (I was unable to recover your first name from your email,
>> hence I take your gmail adress),
>> Many thanks for sending feedback on this bug - I will double check this and
>> correct it as soon as possible. Should you have any other suggestions I
>> would be pleased to improve the PCA component as well.
>> best regards,
>> Pierre Alliez
>> INRIA Sophia Antipolis - Mediterranee Project-team GEOMETRICA
>> http://www-sop.inria.fr/members/Pierre.Alliez/
>> Tel: +33 4 92 38 76 77
>> Fax: +33 4 97 15 53 95
>> 杨成林 a écrit :
>>> Hello
>>> I am new to CGAL.I use linear_least_squares_fitting_3 to estimate
>>> normals from point-cloud.But it can't give correct results
>>> sometimes.After examining the source code,I think line 709-710 in
>>> PCA_util.h(CGAL 3.4) may be incorrect.
>>> eigen_values[2] is the smallest eigenvalue,so "eigen_values[2] ==
>>> eigen_values[1]" means Degeneracy."eigen_values[0] == eigen_values[1]"
>>> just means the points distribute isotropically in the plane,but the
>>> fitting plane exists uniquely.
>>> I change this two lines to "if(eigen_values[2] != eigen_values[1])".It
>>> works well.
>> You are currently subscribed to cgal-discuss.
>> To unsubscribe or access the archives, go to
>> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] A mistake in linear_least_squares_fitting_3?, 杨成林, 02/13/2009
- Re: [cgal-discuss] A mistake in linear_least_squares_fitting_3?, Pierre Alliez, 02/13/2009
- Re: [cgal-discuss] A mistake in linear_least_squares_fitting_3?, 杨成林, 02/16/2009
- Re: [cgal-discuss] A mistake in linear_least_squares_fitting_3?, Pierre Alliez, 02/16/2009
- Re: [cgal-discuss] A mistake in linear_least_squares_fitting_3?, 杨成林, 02/17/2009
- Re: [cgal-discuss] A mistake in linear_least_squares_fitting_3?, Pierre Alliez, 02/23/2009
- Re:Re: [cgal-discuss] A mistake in linear_least_squares_fitting_3?, null, 02/18/2009
- Re:[cgal-discuss] A mistake in linear_least_squares_fitting_3?, null, 02/14/2009
