- To:
- Subject: Re: [cgal-discuss] A mistake in linear_least_squares_fitting_3?
- Date: Mon, 16 Feb 2009 12:39:34 +0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type:content-transfer-encoding; b=NlpFilu3zU3j/1olq4reGTM1jFkJr+VF1uS7iKxSPcaeiBrcoxljczP9zjvfgVOvtU f5ppJEJ+D9cs2witnLyeZbsASS4FBPtKhbMcWgaA4bEBjM0RxYZYKZY1O/5nGrWfKqjN WUm5mHgeUq3jQFBLY9vdIME9mMCXlGFYkT2lk=
Hello Alliez,
Thanks for your immediate response.
In the PCA component,users can only get the eigenvector corresponding
to the largest eigenvalue in line-fitting or the eigenvector
corresponding to the smallest eigenvalue in plane-fitting.The other
eigenvectors seem to be inaccessible,though they are also very useful.
2009/2/13 Pierre Alliez
> Hello wildabc (I was unable to recover your first name from your email,
> hence I take your gmail adress),
> Many thanks for sending feedback on this bug - I will double check this and
> correct it as soon as possible. Should you have any other suggestions I
> would be pleased to improve the PCA component as well.
> best regards,
> Pierre Alliez
> INRIA Sophia Antipolis - Mediterranee Project-team GEOMETRICA
> http://www-sop.inria.fr/members/Pierre.Alliez/
> Tel: +33 4 92 38 76 77
> Fax: +33 4 97 15 53 95
> 杨成林 a écrit :
>> Hello
>> I am new to CGAL.I use linear_least_squares_fitting_3 to estimate
>> normals from point-cloud.But it can't give correct results
>> sometimes.After examining the source code,I think line 709-710 in
>> PCA_util.h(CGAL 3.4) may be incorrect.
>> eigen_values[2] is the smallest eigenvalue,so "eigen_values[2] ==
>> eigen_values[1]" means Degeneracy."eigen_values[0] == eigen_values[1]"
>> just means the points distribute isotropically in the plane,but the
>> fitting plane exists uniquely.
>> I change this two lines to "if(eigen_values[2] != eigen_values[1])".It
>> works well.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] A mistake in linear_least_squares_fitting_3?, 杨成林, 02/13/2009
- Re: [cgal-discuss] A mistake in linear_least_squares_fitting_3?, Pierre Alliez, 02/13/2009
- Re: [cgal-discuss] A mistake in linear_least_squares_fitting_3?, 杨成林, 02/16/2009
- Re: [cgal-discuss] A mistake in linear_least_squares_fitting_3?, Pierre Alliez, 02/16/2009
- Re: [cgal-discuss] A mistake in linear_least_squares_fitting_3?, 杨成林, 02/17/2009
- Re: [cgal-discuss] A mistake in linear_least_squares_fitting_3?, Pierre Alliez, 02/23/2009
- Re:Re: [cgal-discuss] A mistake in linear_least_squares_fitting_3?, null, 02/18/2009
- Re:[cgal-discuss] A mistake in linear_least_squares_fitting_3?, null, 02/14/2009
