- To: 杨成林 <>
- Cc: cgal-discuss <>
- Subject: Re:Re: [cgal-discuss] A mistake in linear_least_squares_fitting_3?
- Date: Wed, 18 Feb 2009 12:18:25 +0800 (CST)
heihei
在2009-02-17,"杨成林" <> 写道:
Hello Alliez, I think the interface could be like this: void PCA_d( InputIterator first, InputIterator beyond, OutputIterator it, typename K::Point_d& centroid, K k, Tag tag); Here d can be 2 or 3. It just replace the Line_d or Plane_d with an output iterator. Besides, In Polyhedra component if you want to add your own items to the polyhedron,you have to rewrite the item class.It is a formidable task for a newbie. But it is very easy to add items in OpenMesh. -- You are currently subscribed to cgal-discuss. To unsubscribe or access the archives, go to https://lists-sop.inria.fr/wws/info/cgal-discuss
网易邮箱,中国第一大电子邮件服务商
- [cgal-discuss] A mistake in linear_least_squares_fitting_3?, 杨成林, 02/13/2009
- Re: [cgal-discuss] A mistake in linear_least_squares_fitting_3?, Pierre Alliez, 02/13/2009
- Re: [cgal-discuss] A mistake in linear_least_squares_fitting_3?, 杨成林, 02/16/2009
- Re: [cgal-discuss] A mistake in linear_least_squares_fitting_3?, Pierre Alliez, 02/16/2009
- Re: [cgal-discuss] A mistake in linear_least_squares_fitting_3?, 杨成林, 02/17/2009
- Re: [cgal-discuss] A mistake in linear_least_squares_fitting_3?, Pierre Alliez, 02/23/2009
- Re:Re: [cgal-discuss] A mistake in linear_least_squares_fitting_3?, null, 02/18/2009
- Re:[cgal-discuss] A mistake in linear_least_squares_fitting_3?, null, 02/14/2009
